Hi,
As the title say: xfce won’t start
It worked before the last 3 updates.
There are no errors in the Xorg.0.log.
I’ve been investigating this for some time now and I don’t know where to look for the problem.
I can log into the terminal but when I startx
, I get a blank screen and then the prompt returns.
The output on the terminal states:
`waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
my .xinitrc
#!/bin/sh
# ~/.xinitrc
# Executed by startx (run your window manager from here)
export GTK2_RC_FILES="$HOME/.gtkrc-2.0"
DEFAULT_SESSION=xfce4-session
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
sysresources=/etc/X11/xinit/.Xresources
sysmodmap=/etc/X11/xinit/.Xmodmap
# merge in defaults and keymaps
if [ -f $sysresources ]; then
xrdb -merge $sysresources
fi
if [ -f $sysmodmap ]; then
xmodmap $sysmodmap
fi
if [ -f "$userresources" ]; then
xrdb -merge "$userresources"
fi
if [ -f "$usermodmap" ]; then
xmodmap "$usermodmap"
fi
# start some nice programs
if [ -d /etc/X11/xinit/xinitrc.d ] ; then
for f in /etc/X11/xinit/xinitrc.d/?*.sh ; do
[ -x "$f" ] && . "$f"
done
unset f
fi
get_session(){
local dbus_args=(--sh-syntax --exit-with-session)
case "$1" in
xfce) dbus_args+=(xfce4-session) ;;
openbox) dbus_args+=(openbox-session) ;;
*) dbus_args+=("$1") ;;
esac
echo "dbus-launch ${dbus_args[*]}"
exec $(get_session "$1")
#case $1 in
# xfce) exec dbus-launch xfce4-session ;;
# openbox) exec dbus-launch openbox-session ;;
# *) exec dbus-launch $DEFAULT_SESSION ;;
#esac
some inxi info
System: Kernel: 5.4.200-1-MANJARO arch: x86_64 bits: 64 Console: tty 1 Distro: Manjaro Linux Machine: Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC v: 0691120000204610000620100 serial: Mobo: Hewlett-Packard model: 166F v: 09.4C serial: BIOS: Insyde v: F.66 date: 01/24/2013 CPU: Info: dual core model: Intel Core i5-2430M bits: 64 type: MT MCP cache: L2: 512 KiB Speed (MHz): avg: 798 min/max: 800/3000 cores: 1: 798 2: 798 3: 798 4: 798 Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics driver: i915 v: kernel Device-2: Chicony HP Integrated Webcam type: USB driver: uvcvideo Display: server: X.org v: 1.21.1.3 driver: X: loaded: intel gpu: i915 tty: 170x48 resolution: 1366x768 Message: Unable to show GL data. Required tool glxinfo missing. Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel Sound Server-1: ALSA v: k5.4.200-1-MANJARO running: yes Network: Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter driver: bcma-pci-bridge Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 IF: eno1 state: up speed: 100 Mbps duplex: full mac: IF-ID-1: wlp1s0b1 state: up mac: Info: Processes: 112 Uptime: 54m Memory: 3.79 GiB used: 353.5 MiB (9.1%) Init: systemd Shell: Bash inxi: 3.3.19
Can anyone help?
Thank you.
