Hi,
Yes im using a 4K wallpaper for sure. I’ve tried scaling with xrandr with different values and none really help at all.
xrandr --verbose
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
eDP1 connected 3840x2160+0+0 (0x4a) normal (normal left inverted right x axis y axis) 350mm x 190mm
Identifier: 0x43
Timestamp: 18565407
Subpixel: unknown
Gamma: 0.96:0.96:0.92
Brightness: 0.98
Clones:
CRTC: 0
CRTCs: 0 1 2
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff004d10761400000000
311a0104a52313780e5059a85435ba25
0c4d5500000001010101010101010101
0101010101014dd000a0f0703e803020
35005ac2100000180000000000000000
00000000000000000000000000fe0059
32584e44804c51313536443100000000
0002410328001200000b010a202000dc
BACKLIGHT: 1500
range: (0, 1500)
Backlight: 1500
range: (0, 1500)
scaling mode: Full aspect
supported: Full, Center, Full aspect
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
link-status: Good
supported: Good, Bad
non-desktop: 0
range: (0, 1)
3840x2160 (0x4a) 533.250MHz -HSync -VSync *current +preferred
h: width 3840 start 3888 end 3920 total 4000 skew 0 clock 133.31KHz
v: height 2160 start 2163 end 2168 total 2222 clock 60.00Hz
3840x2160 (0x1b8) 533.000MHz +HSync -VSync
h: width 3840 start 3888 end 3920 total 4000 skew 0 clock 133.25KHz
v: height 2160 start 2163 end 2168 total 2222 clock 59.97Hz
3200x1800 (0x1b9) 492.000MHz -HSync +VSync
h: width 3200 start 3456 end 3800 total 4400 skew 0 clock 111.82KHz
v: height 1800 start 1803 end 1808 total 1865 clock 59.96Hz
3200x1800 (0x1ba) 491.567MHz -HSync +VSync
h: width 3200 start 3448 end 3800 total 4400 skew 0 clock 111.72KHz
v: height 1800 start 1801 end 1804 total 1862 clock 60.00Hz
3200x1800 (0x1bb) 373.000MHz +HSync -VSync
h: width 3200 start 3248 end 3280 total 3360 skew 0 clock 111.01KHz
v: height 1800 start 1803 end 1808 total 1852 clock 59.94Hz
2880x1620 (0x1bc) 397.413MHz -HSync +VSync
h: width 2880 start 3096 end 3416 total 3952 skew 0 clock 100.56KHz
v: height 1620 start 1621 end 1624 total 1676 clock 60.00Hz
2880x1620 (0x1bd) 396.250MHz -HSync +VSync
h: width 2880 start 3096 end 3408 total 3936 skew 0 clock 100.67KHz
v: height 1620 start 1623 end 1628 total 1679 clock 59.96Hz
2880x1620 (0x1be) 303.750MHz +HSync -VSync
h: width 2880 start 2928 end 2960 total 3040 skew 0 clock 99.92KHz
v: height 1620 start 1623 end 1628 total 1666 clock 59.97Hz
2560x1600 (0x1bf) 348.500MHz -HSync +VSync
h: width 2560 start 2760 end 3032 total 3504 skew 0 clock 99.46KHz
v: height 1600 start 1603 end 1609 total 1658 clock 59.99Hz
2560x1600 (0x1c0) 268.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 98.71KHz
v: height 1600 start 1603 end 1609 total 1646 clock 59.97Hz
2560x1440 (0x1c1) 312.250MHz -HSync +VSync
h: width 2560 start 2752 end 3024 total 3488 skew 0 clock 89.52KHz
v: height 1440 start 1443 end 1448 total 1493 clock 59.96Hz
2560x1440 (0x1c2) 311.827MHz -HSync +VSync
h: width 2560 start 2744 end 3024 total 3488 skew 0 clock 89.40KHz
v: height 1440 start 1441 end 1444 total 1490 clock 60.00Hz
2560x1440 (0x1c3) 241.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
2048x1536 (0x1c4) 266.950MHz -HSync +VSync
h: width 2048 start 2200 end 2424 total 2800 skew 0 clock 95.34KHz
v: height 1536 start 1537 end 1540 total 1589 clock 60.00Hz
1920x1440 (0x1c5) 234.000MHz -HSync +VSync
h: width 1920 start 2048 end 2256 total 2600 skew 0 clock 90.00KHz
v: height 1440 start 1441 end 1444 total 1500 clock 60.00Hz
1856x1392 (0x1c6) 218.300MHz -HSync +VSync
h: width 1856 start 1952 end 2176 total 2528 skew 0 clock 86.35KHz
v: height 1392 start 1393 end 1396 total 1439 clock 60.01Hz
1792x1344 (0x1c7) 204.800MHz -HSync +VSync
h: width 1792 start 1920 end 2120 total 2448 skew 0 clock 83.66KHz
v: height 1344 start 1345 end 1348 total 1394 clock 60.01Hz
2048x1152 (0x1c8) 197.967MHz -HSync +VSync
h: width 2048 start 2184 end 2408 total 2768 skew 0 clock 71.52KHz
v: height 1152 start 1153 end 1156 total 1192 clock 60.00Hz
2048x1152 (0x1c9) 197.000MHz -HSync +VSync
h: width 2048 start 2184 end 2400 total 2752 skew 0 clock 71.58KHz
v: height 1152 start 1155 end 1160 total 1195 clock 59.90Hz
2048x1152 (0x1ca) 156.750MHz +HSync -VSync
h: width 2048 start 2096 end 2128 total 2208 skew 0 clock 70.99KHz
v: height 1152 start 1155 end 1160 total 1185 clock 59.91Hz
1920x1200 (0x1cb) 193.250MHz -HSync +VSync
h: width 1920 start 2056 end 2256 total 2592 skew 0 clock 74.56KHz
v: height 1200 start 1203 end 1209 total 1245 clock 59.88Hz
1920x1200 (0x1cc) 154.000MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 74.04KHz
v: height 1200 start 1203 end 1209 total 1235 clock 59.95Hz
1920x1080 (0x1cd) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1920x1080 (0x1ce) 172.798MHz -HSync +VSync
h: width 1920 start 2040 end 2248 total 2576 skew 0 clock 67.08KHz
v: height 1080 start 1081 end 1084 total 1118 clock 60.00Hz
1920x1080 (0x1cf) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1600x1200 (0x1d0) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1680x1050 (0x1d1) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1680x1050 (0x1d2) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1400x1050 (0x1d3) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1600x900 (0x1d4) 118.997MHz -HSync +VSync
h: width 1600 start 1696 end 1864 total 2128 skew 0 clock 55.92KHz
v: height 900 start 901 end 904 total 932 clock 60.00Hz
1600x900 (0x1d5) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x1d6) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1280x1024 (0x1d7) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1400x900 (0x1d8) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x1d9) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1280x960 (0x1da) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1368x768 (0x1db) 85.860MHz -HSync +VSync
h: width 1368 start 1440 end 1584 total 1800 skew 0 clock 47.70KHz
v: height 768 start 769 end 772 total 795 clock 60.00Hz
1368x768 (0x1dc) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x1dd) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1280x800 (0x1de) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x800 (0x1df) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1280x720 (0x1e0) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x1e1) 74.480MHz -HSync +VSync
h: width 1280 start 1336 end 1472 total 1664 skew 0 clock 44.76KHz
v: height 720 start 721 end 724 total 746 clock 60.00Hz
1280x720 (0x1e2) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1024x768 (0x1e3) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1024x576 (0x1e4) 46.995MHz -HSync +VSync
h: width 1024 start 1064 end 1168 total 1312 skew 0 clock 35.82KHz
v: height 576 start 577 end 580 total 597 clock 60.00Hz
1024x576 (0x1e5) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0x1e6) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x540 (0x1e7) 40.784MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.54KHz
v: height 540 start 541 end 544 total 559 clock 60.00Hz
960x540 (0x1e8) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
960x540 (0x1e9) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
800x600 (0x1ea) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x1eb) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
864x486 (0x1ec) 32.901MHz -HSync +VSync
h: width 864 start 888 end 976 total 1088 skew 0 clock 30.24KHz
v: height 486 start 487 end 490 total 504 clock 60.00Hz
864x486 (0x1ed) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0x1ee) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
640x480 (0x1ef) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x405 (0x1f0) 22.500MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 422 clock 59.51Hz
720x405 (0x1f1) 22.176MHz -HSync +VSync
h: width 720 start 728 end 800 total 880 skew 0 clock 25.20KHz
v: height 405 start 406 end 409 total 420 clock 60.00Hz
720x405 (0x1f2) 21.750MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 24.72KHz
v: height 405 start 408 end 413 total 419 clock 58.99Hz
640x360 (0x1f3) 18.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 22.50KHz
v: height 360 start 363 end 368 total 376 clock 59.84Hz
640x360 (0x1f4) 17.750MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.19KHz
v: height 360 start 363 end 368 total 374 clock 59.32Hz
640x360 (0x1f5) 17.187MHz -HSync +VSync
h: width 640 start 640 end 704 total 768 skew 0 clock 22.38KHz
v: height 360 start 361 end 364 total 373 clock 60.00Hz
3840x2160_60.00 (0x1f6) 712.750MHz -HSync +VSync
h: width 3840 start 4160 end 4576 total 5312 skew 0 clock 134.18KHz
v: height 2160 start 2163 end 2168 total 2237 clock 59.98Hz
2560x1440_60.00 (0x1f7) 312.250MHz -HSync +VSync
1920x1080_60.00 (0x1f8) 173.000MHz -HSync +VSync
1600x900_60.00 (0x1f9) 118.250MHz -HSync +VSync
1368x768_60.00 (0x1fa) 85.250MHz -HSync +VSync
1280x720_60.00 (0x1fb) 74.500MHz -HSync +VSync
1152x648_60.00 (0x1fc) 59.250MHz -HSync +VSync
h: width 1152 start 1200 end 1312 total 1472 skew 0 clock 40.25KHz
v: height 648 start 651 end 656 total 674 clock 59.72Hz
1024x576_60.00 (0x1fd) 46.500MHz -HSync +VSync
DP1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x44
Timestamp: 18565407
Subpixel: unknown
Clones: HDMI1
CRTCs: 0 1 2
filter:
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
max bpc: 12
range: (6, 12)
audio: auto
supported: force-dvi, off, auto, on
link-status: Good
non-desktop: 0
range: (0, 1)
DP2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x45
Timestamp: 18565407
Subpixel: unknown
Clones: HDMI2
CRTCs: 0 1 2
filter:
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
HDMI1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x46
Timestamp: 18565407
Subpixel: unknown
Clones: DP1
CRTCs: 0 1 2
filter:
max bpc: 12
range: (8, 12)
content type: No Data
supported: No Data, Graphics, Photo, Cinema, Game
Colorspace: Default
supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
HDMI2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x47
Timestamp: 18565407
Subpixel: unknown
Clones: DP2
CRTCs: 0 1 2
filter:
max bpc: 12
range: (8, 12)
Colorspace: Default
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x48
Timestamp: 18565407
Subpixel: no subpixels
Clones:
CRTCs: 3
filter:
non-desktop: 0
supported: 0, 1
