Hello, I’d like to use one of the toolbar actions in thunar to open my default termial. Manjaro stable version offers this but does not open my selected custom emulator, instead, I get the XFCE terminal.
I opened an issue some time ago in the thunar gitlab and they indicate this could potentially be a distribution-specific issue. Their suggestion was to take a look at the custom actions that have been declared. I do not know how to do this.
Can someoe show me what they might be referring to?
I
If you want to go down the custom action path (with a menu entry when you right click on a folder) you can look here and here but changing default application is a more universal solution.
My default terminal is set to terminator. This is what I want to bring up. In in spite of having it set, the default action that is available for the toolbar opens xfce ignoring my selection.
Maybe the default action should be to use the default terminal.
The accepted solution works fantastically, I just expected this option to work out of the box with the system configuration.
