Using the Xfce Screensaver, after login/boot I need to open the screensaver settings and change any setting and revert it back in order to get the screensaver to be active.
The Xfce Screensaver program is listed in the ‘Session and Autostart’ settings to run on login.
After login I can see Xfce Screensaver listed as a running process.
However the screensaver itself will never activate until I enter its settings and change something and revert it back.
This used to work correctly but it’s been a while since it became broken and I can no longer remember exactly when it became broken.
Below is the contents of ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-screensaver.xml
<?xml version="1.0" encoding="UTF-8"?>
<channel name="xfce4-screensaver" version="1.0">
<property name="saver" type="empty">
<property name="mode" type="int" value="0"/>
<property name="enabled" type="bool" value="true"/>
<property name="idle-activation" type="empty">
<property name="delay" type="int" value="5"/>
</property>
</property>
<property name="lock" type="empty">
<property name="saver-activation" type="empty">
<property name="delay" type="int" value="2"/>
</property>
<property name="user-switching" type="empty">
<property name="enabled" type="bool" value="false"/>
</property>
</property>
</channel>
The file contents are the same before and after I modify and revert some setting, but the file does get saved at that point.
Below is a partial output from hardinfo
Computer
Summary
-Computer-
Processor : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Memory : 16329MB (1633MB used)
Machine Type : Desktop
Operating System : Manjaro Linux
-Display-
Resolution : 3840x1080 pixels
OpenGL Renderer : (Unknown)
Session Display Server : The X.Org Foundation 21.1.10
-Audio Devices-
Audio Adapter : HDA-Intel - HDA Intel PCH
Audio Adapter : HDA-Intel - HDA NVidia
-Input Devices-
Power Button
Power Button
MOSART Semi. 2.4G Keyboard Mouse
MOSART Semi. 2.4G Keyboard Mouse Consumer Control
MOSART Semi. 2.4G Keyboard Mouse System Control
USBest Technology SiS HID Touch Controller
Video Bus
Eee PC WMI hotkeys
PC Speaker
ENE eHome Infrared Remote Receiver
HDA NVidia HDMI/DP,pcm:3
HDA NVidia HDMI/DP,pcm:7
HDA NVidia HDMI/DP,pcm:8
HDA NVidia HDMI/DP,pcm:9
HDA Intel PCH Mic
HDA Intel PCH Headphone
-Printers (CUPS)-
Brother-DCP-197C : <i>Default</i>
-SCSI Disks-
ATA Crucial_CT480M50
Slimtype DVD A DL8A4SH
USB Flash Disk
Operating System
-Version-
Kernel : Linux 6.6.8-2-MANJARO (x86_64)
Version : #1 SMP PREEMPT_DYNAMIC Thu Dec 21 16:21:45 UTC 2023
C Library : GNU C Library / (GNU libc) 2.38
Distribution : Manjaro Linux
-Security-
Available entropy in /dev/random : 256 bits (medium)
ASLR : Fully enabled (mmap base+stack+VDSO base+heap)
-Misc-
Uptime : 7 minutes
Load Average : 0.08, 0.20, 0.12
Kernel Modules
-Loaded Modules-
rfcomm : Bluetooth RFCOMM ver 1.11
uvcvideo : USB Video Class driver
videobuf2_vmalloc : vmalloc memory handling routines for videobuf2
uvc
videobuf2_memops : common memory handling routines for videobuf2
videobuf2_v4l2 : Driver helper framework for Video for Linux 2
videodev : Video4Linux2 core driver
videobuf2_common : Media buffer core framework
mc : Device node registration for media drivers
cmac : CMAC keyed hash algorithm
algif_hash
algif_skcipher
af_alg
bnep : Bluetooth BNEP ver 1.3
ath3k : Atheros AR30xx firmware driver
btusb : Generic Bluetooth USB driver ver 0.8
btrtl : Bluetooth support for Realtek devices ver 0.1
btintel : Bluetooth support for Intel devices ver 0.1
btbcm : Bluetooth support for Broadcom devices ver 0.1
btmtk : Bluetooth support for MediaTek devices ver 0.1
bluetooth : Bluetooth Core ver 2.22
ecdh_generic : ECDH generic algorithm
joydev : Joystick device interfaces
mousedev : Mouse (ExplorerPS/2) device interfaces
qrtr : Qualcomm IPC-router driver
nvidia_uvm
intel_rapl_msr : Driver for Intel RAPL (Running Average Power Limit) control via MSR interface
intel_rapl_common : Intel Runtime Average Power Limit (RAPL) common code
x86_pkg_temp_thermal : X86 PKG TEMP Thermal Driver
intel_powerclamp : Package Level C-state Idle Injection for Intel CPUs
coretemp : Intel Core temperature monitor
kvm_intel
kvm
irqbypass : IRQ bypass manager utility module
ath9k : Support for Atheros 802.11n wireless LAN cards.
crct10dif_pclmul : T10 DIF CRC calculation accelerated with PCLMULQDQ.
snd_hda_codec_realtek : Realtek HD-audio codec
crc32_pclmul
polyval_clmulni : POLYVAL hash function accelerated by PCLMULQDQ-NI
ath9k_common : Shared library for Atheros wireless 802.11n LAN cards.
snd_hda_codec_generic : Generic HD-audio codec parser
polyval_generic : POLYVAL hash function
snd_hda_codec_hdmi : HDMI HD-audio codec
gf128mul : Functions for multiplying elements of GF(2^128)
ath9k_hw : Support for Atheros 802.11n wireless LAN cards.
ghash_clmulni_intel : GHASH hash function, accelerated by PCLMULQDQ-NI
sha512_ssse3 : SHA512 Secure Hash Algorithm, Supplemental SSE3 accelerated
snd_hda_intel : Intel HDA driver
ath : Shared library for Atheros wireless LAN cards.
nvidia_drm
sha256_ssse3 : SHA256 Secure Hash Algorithm, Supplemental SSE3 accelerated
snd_intel_dspcfg : Intel DSP config driver
snd_intel_sdw_acpi : Intel Soundwire ACPI helpers
sha1_ssse3 : SHA1 Secure Hash Algorithm, Supplemental SSE3 accelerated
mac80211 : IEEE 802.11 subsystem
nvidia_modeset
aesni_intel : Rijndael (AES) Cipher Algorithm, Intel AES-NI instructions optimized
snd_hda_codec : HDA codec core
ir_rc6_decoder : RC6 IR protocol decoder
crypto_simd
snd_hda_core : HD-audio bus
cryptd : Software async crypto daemon
iTCO_wdt : Intel TCO WatchDog Timer Driver
rapl
snd_hwdep : Hardware dependent layer
intel_pmc_bxt : Intel Broxton PMC driver
at24 : Driver for most I2C EEPROMs
mei_hdcp : MEI HDCP
mei_pxp : MEI PXP
iTCO_vendor_support : Intel TCO Vendor Specific WatchDog Timer Driver Support
r8169 : RealTek RTL-8169 Gigabit Ethernet driver
snd_pcm : Midlevel PCM code for ALSA.
intel_cstate
rc_rc6_mce
libarc4
nvidia
realtek : Realtek PHY driver
ene_ir : Infrared input driver for KB3926B/C/D/E/F (aka ENE0100/ENE0200/ENE0201/ENE0202) CIR port
mdio_devres
snd_timer : ALSA timer interface
intel_uncore
cfg80211 : wireless configuration support
i2c_i801 : I801 SMBus driver
snd : Advanced Linux Sound Architecture driver for soundcards.
pcspkr : PC Speaker beeper driver
mei_me : Intel(R) Management Engine Interface
libphy : PHY library
i2c_smbus : SMBus protocol extensions support
soundcore : Core sound module
eeepc_wmi : Eee PC WMI Hotkey Driver
mei : Intel(R) Management Engine Interface
lpc_ich : LPC interface for Intel ICH
asus_wmi : Asus Generic WMI Driver
ledtrig_audio : LED trigger for audio mute control
sparse_keymap : Generic support for sparse keymaps
platform_profile
i8042 : i8042 keyboard and mouse controller driver
serio : Serio abstraction core
rfkill : RF switch support
mac_hid
wmi_bmof : WMI embedded Binary MOF driver
mxm_wmi : MXM WMI Driver
ipmi_devintf : Linux device interface for the IPMI message handler.
ipmi_msghandler : Incoming and outgoing message routing for an IPMI interface.
video : ACPI Video Driver
wmi : ACPI-WMI Mapping Driver
vboxnetflt : Oracle VM VirtualBox Network Filter Driver
vboxnetadp : Oracle VM VirtualBox Network Adapter Driver
vboxdrv : Oracle VM VirtualBox Support Driver
crypto_user : Crypto userspace configuration API
dm_mod : device-mapper driver
fuse : Filesystem in Userspace
loop
bpf_preload
ip_tables : IPv4 packet filter
x_tables : {ip,ip6,arp,eb}_tables backend module
ext4 : Fourth Extended Filesystem
crc32c_generic : CRC32c (Castagnoli) calculations wrapper for lib/crc32c
crc16 : CRC16 calculations
mbcache : Meta block cache (for extended attributes)
jbd2
hid_multitouch : HID multitouch panels
crc32c_intel : CRC32c (Castagnoli) optimization using Intel Hardware.
uas
sr_mod : SCSI cdrom (sr) driver
xhci_pci : xHCI PCI Host Controller Driver
usb_storage : USB Mass Storage driver for Linux
usbhid : USB HID core driver
cdrom
xhci_pci_renesas
Filesystems
-Mounted File Systems-
dev /dev 0.00 % (7.8 GiB of 7.8 GiB)
run /run 0.02 % (7.8 GiB of 7.8 GiB)
efivarfs /sys/firmware/efi/efivars 46.52 % (68.5 KiB of 128.0 KiB)
/dev/sda3 / 33.50 % (26.0 GiB of 39.1 GiB)
tmpfs /dev/shm 0.00 % (7.8 GiB of 7.8 GiB)
tmpfs /tmp 0.00 % (7.8 GiB of 7.8 GiB)
/dev/sda5 /home 13.46 % (339.7 GiB of 392.5 GiB)
tmpfs /run/user/1000 0.01 % (1.6 GiB of 1.6 GiB)
Display
-Session-
Type : x11
-Wayland-
Current Display Name : (Not Available)
-X Server-
Current Display Name : :0.0
Vendor : The X.Org Foundation
Version : 21.1.10
Release Number : 12101010
-Screens-
Screen 0 : 3840x1080 pixels
-Outputs (XRandR)-
HDMI-0 : Connected; 1920x1080 pixels, offset (1920, 0)
HDMI-1 : Connected; 1920x1080 pixels, offset (0, 0)
-OpenGL (GLX)-
Vendor : (Unknown)
Direct Rendering : No
Version (Compatibility) : (Unknown)
Shading Language Version (Compatibility) : (Unknown)
Version (Core) : (Unknown)
Shading Language Version (Core) : (Unknown)
Version (ES) : (Unknown)
Shading Language Version (ES) : (Unknown)
GLX Version : (Unknown)
Devices
Processor
-Processors-
Package Information
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 0 0:0 3900.00 MHz
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 1 0:1 3900.00 MHz
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 2 0:2 3900.00 MHz
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3 0:3 3900.00 MHz
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 4 0:0 3900.00 MHz
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 5 0:1 3900.00 MHz
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 6 0:2 3900.00 MHz
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 7 0:3 3900.00 MHz
Memory
-Memory-
MemTotal Total Memory 16329968 KiB
MemFree Free Memory 13889064 KiB
MemAvailable 14539588 KiB
Buffers 82728 KiB
Cached 827392 KiB
SwapCached Cached Swap 0 KiB
Active 1817900 KiB
Inactive 303912 KiB
Active(anon) 1249812 KiB
Inactive(anon) 0 KiB
Active(file) 568088 KiB
Inactive(file) 303912 KiB
Unevictable 9204 KiB
Mlocked 1104 KiB
SwapTotal Virtual Memory 4194300 KiB
SwapFree Free Virtual Memory 4194300 KiB
Zswap 0 KiB
Zswapped 0 KiB
Dirty 388 KiB
Writeback 0 KiB
AnonPages 1135400 KiB
Mapped 428024 KiB
Shmem 38120 KiB
KReclaimable 59468 KiB
Slab 137180 KiB
SReclaimable 59468 KiB
SUnreclaim 77712 KiB
KernelStack 12160 KiB
PageTables 17752 KiB
SecPageTables 0 KiB
NFS_Unstable 0 KiB
Bounce 0 KiB
WritebackTmp 0 KiB
CommitLimit 12359284 KiB
Committed_AS 6814152 KiB
VmallocTotal -1 KiB
VmallocUsed 78696 KiB
VmallocChunk 0 KiB
Percpu 4256 KiB
HardwareCorrupted 0 KiB
AnonHugePages 342016 KiB
ShmemHugePages 0 KiB
ShmemPmdMapped 0 KiB
FileHugePages 22528 KiB
FilePmdMapped 18432 KiB
CmaTotal 0 KiB
CmaFree 0 KiB
Unaccepted 0 KiB
HugePages_Total 0
HugePages_Free 0
HugePages_Rsvd 0
HugePages_Surp 0
Hugepagesize 2048 KiB
Hugetlb 0 KiB
DirectMap4k 259140 KiB
DirectMap2M 16467968 KiB
Graphics Processors
-GPUs-
drm-card1 : NVIDIA Corporation GK107M [GeForce GT 730M]
PCI Devices
-PCI Devices-
0000:00:00.0 : Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller
0000:00:01.0 : Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port
0000:00:14.0 : Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller
0000:00:16.0 : Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1
0000:00:1a.0 : Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2
0000:00:1b.0 : Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller
0000:00:1c.0 : Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1
0000:00:1c.2 : Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3
0000:00:1c.3 : Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 4
0000:00:1d.0 : Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1
0000:00:1e.0 : Intel Corporation 82801 PCI Bridge
0000:00:1f.0 : Intel Corporation B75 Express Chipset LPC Controller
0000:00:1f.2 : Intel Corporation 7 Series/C210 Series Chipset Family 6-port SATA Controller [AHCI mode]
0000:00:1f.3 : Intel Corporation 7 Series/C216 Chipset Family SMBus Controller
0000:01:00.0 : NVIDIA Corporation GK107M [GeForce GT 730M]
0000:01:00.1 : NVIDIA Corporation GK107 HDMI Audio Controller
0000:03:00.0 : Qualcomm Atheros AR9462 Wireless Network Adapter
0000:04:00.0 : Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
USB Devices
-USB Devices-
001:001 : Linux Foundation 2.0 root hub
001:002 : Intel Corp. Integrated Rate Matching Hub
001:003 : Genesys Logic, Inc. microSD Reader/Writer
001:004 : MosArt Semiconductor Corp. Wireless Keyboard/Mouse
001:005 : Genesys Logic, Inc. Hub
001:006 : Silicon Integrated Systems Corp. SiS-184-ASUS-4352.17 touch panel
001:007 : Chicony Electronics Co., Ltd UVC 1.00 device HD UVC WebCam
001:008 : ASUSTek Computer, Inc. ASUS Tablet P1801-T
002:001 : Linux Foundation 2.0 root hub
002:002 : Intel Corp. Integrated Rate Matching Hub
002:003 : Afatech Rtl2832UDVB
002:004 : IMC Networks (Unknown)
003:001 : Linux Foundation 2.0 root hub
004:001 : Linux Foundation 3.0 root hub
Input Devices
-Input Devices-
Power Button
Power Button
Video Bus
Eee PC WMI hotkeys
PC Speaker
HDA Intel PCH Mic
