XFCE screen does not recover from "suspend"
Hi,
Using an i7-3770 desktop, machine with no swap ( no swap partition or swap file ) .
But required the machine to be fully ON even if left it for a couple of hours without intervention…
For my dismay I am unable to recover the machine to working condition , the screen simply does not activate .
If I press the “power off” button the screen I recovers with the shutdown usual messages though .
I get this unexpected behaviour even If followed the “Forum disable hibernate tutorial” :
All I need is to keep the system visually working even if leave it for a few hours .
( I do power off the monitor though when leaving the machine )
Any Ideas where should I try to analyse / solve this ?
Check the journal to see what is blocking the process of suspending.
journalctl --boot -1 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Hi..
(thanks for the fast reply )
after executing the journalctl cmd I did not see anything special besides the DHCP lease request every hour and a full shutdown sequence…
Here is the journalctl result ( a litle bit edited, though ) since the previous system boot startup .
Dec 27 01:13:40 manjaro kernel: Linux version 6.19.0-rc1-1-MANJARO (linux619@manjaro) (gcc (GCC) 15.2.1 20251112, GNU ld (GNU Binutils) 2.45.1) #1 SMP PREEMPT_DYNAMIC Mon, 15
Dec 2025 00:06:18 +0000
Dec 27 01:13:40 manjaro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64 root=UUID=f4bc51ae-9d55-400c-b716-e17bcf600731 rw nowatchdog noacpi……
Dec 27 01:44:01 mrkmanjaro NetworkManager[1194]:   [1766799841.1284] dhcp4 (eno1): state changed new lease, address=10.212.212.2
Dec 27 01:44:01 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.4’ (uid=0 pid=1194 comm=“/usr/bin/NetworkManager --no-daemon”)
Dec 27 01:44:01 mrkmanjaro systemd[1]: Starting Network Manager Script Dispatcher Service…
Dec 27 01:44:01 mrkmanjaro dbus-daemon[1044]: [system] Successfully activated service ‘org.freedesktop.nm_dispatcher’
Dec 27 01:44:01 mrkmanjaro systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 27 01:44:11 mrkmanjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 27 02:01:00 mrkmanjaro CROND[6958]: (root) CMD (run-parts /etc/cron.hourly)
Dec 27 02:01:01 mrkmanjaro anacron[6965]: Anacron started on 2025-12-27
Dec 27 02:01:01 mrkmanjaro CROND[6957]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 27 02:01:01 mrkmanjaro anacron[6965]: Normal exit (0 jobs run)
Dec 27 02:14:01 mrkmanjaro NetworkManager[1194]:   [1766801641.1403] dhcp4 (eno1): state changed new lease, address=10.212.212.2
Dec 27 02:14:01 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.4’ (uid=0 pid=1194 comm=“/usr/bin/NetworkManager --no-daemon”)
Dec 27 02:14:01 mrkmanjaro systemd[1]: Starting Network Manager Script Dispatcher Service…
Dec 27 02:14:01 mrkmanjaro dbus-daemon[1044]: [system] Successfully activated service ‘org.freedesktop.nm_dispatcher’
Dec 27 02:14:01 mrkmanjaro systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 27 02:14:11 mrkmanjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 27 02:14:33 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.manjaro.pamac.daemon’ unit=‘pamac-daemon.service’ requested by ‘:1.53’ (uid=1000 pid=7134 comm=“pamac-checkupdates”)
Dec 27 02:14:33 mrkmanjaro systemd[1]: Starting Pamac Daemon…
Dec 27 02:14:33 mrkmanjaro dbus-daemon[1044]: [system] Successfully activated service ‘org.manjaro.pamac.daemon’
Dec 27 02:14:33 mrkmanjaro systemd[1]: Started Pamac Daemon.
Dec 27 02:14:33 mrkmanjaro systemd[1]: pamac-daemon.service: Deactivated successfully.…
Dec 27 03:14:01 mrkmanjaro NetworkManager[1194]:   [1766805241.1529] dhcp4 (eno1): state changed new lease, address=10.212.212.2
Dec 27 03:14:01 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.4’ (uid=0 pid=1194 comm=“/usr/bin/NetworkManager --no-daemon”)
Dec 27 03:14:01 mrkmanjaro systemd[1]: Starting Network Manager Script Dispatcher Service…
Dec 27 03:14:01 mrkmanjaro dbus-daemon[1044]: [system] Successfully activated service ‘org.freedesktop.nm_dispatcher’
Dec 27 03:14:01 mrkmanjaro systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 27 03:14:11 mrkmanjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 27 03:14:34 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.manjaro.pamac.daemon’ unit=‘pamac-daemon.service’ requested by ‘:1.57’ (uid=1000 pid=7963 comm=“pamac-checkupdates”)
Dec 27 03:14:34 mrkmanjaro systemd[1]: Starting Pamac Daemon…
Dec 27 03:14:34 mrkmanjaro dbus-daemon[1044]: [system] Successfully activated service ‘org.manjaro.pamac.daemon’
Dec 27 03:14:34 mrkmanjaro systemd[1]: Started Pamac Daemon.
Dec 27 03:14:34 mrkmanjaro systemd[1]: pamac-daemon.service: Deactivated successfully.…
Dec 27 03:44:01 mrkmanjaro NetworkManager[1194]:   [1766807041.1340] dhcp4 (eno1): state changed new lease, address=10.212.212.2
Dec 27 03:44:01 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.4’ (uid=0 pid=1194 comm=“/usr/bin/NetworkManager --no-daemon”)
Dec 27 03:44:01 mrkmanjaro systemd[1]: Starting Network Manager Script Dispatcher Service…
Dec 27 03:44:01 mrkmanjaro dbus-daemon[1044]: [system] Successfully activated service ‘org.freedesktop.nm_dispatcher’
Dec 27 03:44:01 mrkmanjaro systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 27 03:44:11 mrkmanjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 27 03:47:00 mrkmanjaro anacron[7805]: Job cron.daily' started
Dec 27 03:47:00 mrkmanjaro anacron[7805]: Job cron.daily’ terminated
Dec 27 03:47:00 mrkmanjaro anacron[7805]: Normal exit (1 job run)
Dec 27 03:48:43 mrkmanjaro systemd[1]: Reached target Network is Online.
Dec 27 03:48:43 mrkmanjaro systemd[1]: Starting Generate mirrorlist…
Dec 27 03:48:46 mrkmanjaro pacman-mirrors[8499]: ::INFO Downloading mirrors from Manjaro
Dec 27 03:48:46 mrkmanjaro pacman-mirrors[8499]: ::INFO => Mirror pool: https://repo.manjaro.org/mirrors.json
Dec 27 03:48:46 mrkmanjaro pacman-mirrors[8499]: ::INFO => Mirror status: https://repo.manjaro.org/status.json
Dec 27 03:48:46 mrkmanjaro pacman-mirrors[8499]: ::INFO Using custom mirror file
Dec 27 03:48:46 mrkmanjaro pacman-mirrors[8499]: ::INFO Querying mirrors - This may take some time
Dec 27 03:48:46 mrkmanjaro pacman-mirrors[8499]: [71B blob data]
Dec 27 03:48:47 mrkmanjaro pacman-mirrors[8499]: [65B blob data]
Dec 27 03:48:47 mrkmanjaro pacman-mirrors[8499]: [59B blob data]
Dec 27 03:48:47 mrkmanjaro pacman-mirrors[8499]: ::INFO Writing mirror list
Dec 27 03:48:47 mrkmanjaro pacman-mirrors[8499]: ::Germany         : https://manjaro.kurdy.org/stable/$repo/$arch
Dec 27 03:48:47 mrkmanjaro pacman-mirrors[8499]: ::Germany         : https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Dec 27 03:48:47 mrkmanjaro pacman-mirrors[8499]: ::Germany         : https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Dec 27 03:48:47 mrkmanjaro pacman-mirrors[8499]: ::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
Dec 27 03:48:48 mrkmanjaro pacman-mirrors[8504]: Local mirror status for stable branch
Dec 27 03:48:48 mrkmanjaro pacman-mirrors[8504]: Mirror #1   OK  00:18   Germany  https://manjaro.kurdy.org/
Dec 27 03:48:48 mrkmanjaro pacman-mirrors[8504]: Mirror #2   OK  00:18   Germany
Dec 27 03:48:48 mrkmanjaro pacman-mirrors[8504]: Mirror #3   OK  00:08   Germany
Dec 27 03:48:48 mrkmanjaro systemd[1]: pamac-mirrorlist.service: Deactivated successfully.
Dec 27 03:48:48 mrkmanjaro systemd[1]: Finished Generate mirrorlist.
Dec 27 03:48:48 mrkmanjaro systemd[1]: pamac-mirrorlist.service: Consumed 1.087s CPU time, 32.3M memory peak.
Dec 27 04:01:00 mrkmanjaro CROND[8638]: (root) CMD (run-parts /etc/cron.hourly)
Dec 27 04:01:00 mrkmanjaro CROND[8637]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 27 04:14:01 mrkmanjaro NetworkManager[1194]:   [1766808841.1338] dhcp4 (eno1): state changed new lease, address=10.212.212.2
Dec 27 04:14:01 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.4’ (uid=0 pid=1194 comm=“/usr/bin/NetworkManager --no-daemon”)
Dec 27 04:14:01 mrkmanjaro systemd[1]: Starting Network Manager Script Dispatcher Service…
Dec 27 04:14:01 mrkmanjaro dbus-daemon[1044]: [system] Successfully activated service ‘org.freedesktop.nm_dispatcher’
Dec 27 04:14:01 mrkmanjaro systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 27 04:14:11 mrkmanjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 27 07:44:01 mrkmanjaro NetworkManager[1194]:   [1766821441.1339] dhcp4 (eno1): state changed new lease, address=10.212.212.2
Dec 27 07:44:01 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.4’ (uid=0 pid=1194 comm=“/usr/bin/NetworkManager --no-daemon”)
Dec 27 07:44:01 mrkmanjaro systemd[1]: Starting Network Manager Script Dispatcher Service…
Dec 27 07:44:01 mrkmanjaro dbus-daemon[1044]: [system] Successfully activated service ‘org.freedesktop.nm_dispatcher’
Dec 27 07:44:01 mrkmanjaro systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 27 07:44:11 mrkmanjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd-logind[1058]: Power key pressed short.
Dec 27 07:46:43 mrkmanjaro systemd-logind[1058]: Powering off…
Dec 27 07:46:43 mrkmanjaro systemd-logind[1058]: System is powering down.
Dec 27 07:46:43 mrkmanjaro sddm-helper[3806]: Signal received: SIGTERM
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping Session 4 of User markmarques…
Dec 27 07:46:43 mrkmanjaro systemd[1]: Removed slice Slice /system/getty.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Removed slice Slice /system/modprobe.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped target Graphical Interface.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped target Network is Online.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped target Sound Card.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped target Timer Units.
Dec 27 07:46:43 mrkmanjaro systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Dec 27 07:46:43 mrkmanjaro systemd[1]: logrotate.timer: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Daily rotation of log files.
Dec 27 07:46:43 mrkmanjaro systemd[1]: man-db.timer: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Daily man-db regeneration.
Dec 27 07:46:43 mrkmanjaro systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Monthly clean packages cache.
Dec 27 07:46:43 mrkmanjaro systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Generate mirrorlist weekly.
Dec 27 07:46:43 mrkmanjaro systemd[1]: plocate-updatedb.timer: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro polkitd[1050]: Unregistered Authentication Agent for unix-session:4 (system bus name :1.43, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected from bus)
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Update the plocate database daily.
Dec 27 07:46:43 mrkmanjaro systemd[1]: shadow.timer: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Daily verification of password and group files.
Dec 27 07:46:43 mrkmanjaro systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Dec 27 07:46:43 mrkmanjaro sddm[3647]: Authentication error: SDDM::Auth::ERROR_INTERNAL “Process crashed”
Dec 27 07:46:43 mrkmanjaro sddm[3647]: Auth: sddm-helper (–socket /tmp/sddm-auth-548107c2-8dfa-4b7f-8a52-e6d5b33af5d0 --id 1 --start startxfce4 --user markmarques) crashed (exit code 1)
Dec 27 07:46:43 mrkmanjaro sddm[3647]: Auth: sddm-helper exited with 1
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped target System Time Set.
Dec 27 07:46:43 mrkmanjaro systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Closed LVM2 poll daemon socket.
Dec 27 07:46:43 mrkmanjaro systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping Accounts Service…
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping Save/Restore Sound Card State…
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Terminating
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping Bluetooth service…
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/ldac
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSink/aptx_hd
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/aptx_hd
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSink/aac
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/aac
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSink/opus_g
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/opus_g
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSink/sbc
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/sbc
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/faststream
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/faststream_duplex
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSink/opus_05
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/opus_05
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Endpoint unregistered: sender=:1.37 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Dec 27 07:46:43 mrkmanjaro dbus-daemon[1044]: [system] Rejected send message, 0 matched rules; type=“error”, sender=“:1.37” (uid=1000 pid=3882 comm=“/usr/bin/wireplumber”) interface=“(unset)” member=“(unset)” error name=“org.bluez.MediaEndpoint1.Error.NotImplemented” requested_reply=“0” destination=“:1.21” (uid=0 pid=3645 comm=“/usr/lib/bluetooth/bluetoothd”)
Dec 27 07:46:43 mrkmanjaro at-spi2-registryd[3999]: X connection to :0 broken (explicit kill or server shutdown).
Dec 27 07:46:43 mrkmanjaro systemd[1]: Starting Generate shutdown-ramfs…
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping RealtimeKit Scheduling Policy Service…
Dec 27 07:46:43 mrkmanjaro sddm[3647]: Signal received: SIGTERM
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping Simple Desktop Display Manager…
Dec 27 07:46:43 mrkmanjaro systemd[3837]: dbus-:1.17-org.a11y.atspi.Registry@0.service: Main process exited, code=exited, status=1/FAILURE
Dec 27 07:46:43 mrkmanjaro systemd[3837]: dbus-:1.17-org.a11y.atspi.Registry@0.service: Failed with result ‘exit-code’.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping Load/Save OS Random Seed…
Dec 27 07:46:43 mrkmanjaro systemd[1]: systemd-udev-load-credentials.service: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Load udev Rules from Credentials.
Dec 27 07:46:43 mrkmanjaro sddm[3647]: Socket server stopping…
Dec 27 07:46:43 mrkmanjaro sddm[3647]: Socket server stopped.
Dec 27 07:46:43 mrkmanjaro sddm[3647]: Display server stopping…
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping TLP system startup/shutdown…
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopping Disk Manager…
Dec 27 07:46:43 mrkmanjaro systemd[1]: Starting Zpool Export All pools…
Dec 27 07:46:43 mrkmanjaro systemd[1]: rtkit-daemon.service: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Dec 27 07:46:43 mrkmanjaro systemd[1]: accounts-daemon.service: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Accounts Service.
Dec 27 07:46:43 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.freedesktop.Accounts’ unit=‘accounts-daemon.service’ requested by ‘:1.76’ (uid=1000 pid=4039 comm=“xfdesktop”)
Dec 27 07:46:43 mrkmanjaro dbus-daemon[1044]: [system] Rejected send message, 0 matched rules; type=“error”, sender=“:1.37” (uid=1000 pid=3882 comm=“/usr/bin/wireplumber”) interface=“(unset)” member=“(unset)” error name=“org.bluez.Profile1.Error.NotImplemented” requested_reply=“0” destination=“:1.21” (uid=0 pid=3645 comm=“/usr/lib/bluetooth/bluetoothd”)
Dec 27 07:46:43 mrkmanjaro dbus-daemon[1044]: [system] Rejected send message, 1 matched rules; type=“method_call”, sender=“:1.21” (uid=0 pid=3645 comm=“/usr/lib/bluetooth/bluetoothd”) interface=“org.bluez.GattProfile1” member=“Release” error name=“(unset)” requested_reply=“0” destination=“:1.38” (uid=1000 pid=3882 comm=“/usr/bin/wireplumber”)
Dec 27 07:46:43 mrkmanjaro systemd-logind[1058]: Session 4 logged out. Waiting for processes to exit.
Dec 27 07:46:43 mrkmanjaro systemd[1]: udisks2.service: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Disk Manager.
Dec 27 07:46:43 mrkmanjaro systemd[1]: udisks2.service: Consumed 14.550s CPU time, 9.2M memory peak.
Dec 27 07:46:43 mrkmanjaro systemd[1]: alsa-restore.service: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Save/Restore Sound Card State.
Dec 27 07:46:43 mrkmanjaro systemd[1]: systemd-random-seed.service: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Battery Provider Manager destroyed
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Load/Save OS Random Seed.
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Stopping SDP server
Dec 27 07:46:43 mrkmanjaro bluetoothd[3645]: Exit
Dec 27 07:46:43 mrkmanjaro sudo[11916]:     root : PWD=/ ; USER=root ; COMMAND=/usr/bin/zpool export -a
Dec 27 07:46:43 mrkmanjaro systemd[1]: bluetooth.service: Deactivated successfully.
Dec 27 07:46:43 mrkmanjaro systemd[1]: Stopped Bluetooth service.
Dec 27 07:46:43 mrkmanjaro systemd[1]: bluetooth.service: Consumed 1.246s CPU time, 2.1M memory peak.
Dec 27 07:46:43 mrkmanjaro dbus-daemon[1044]: [system] Activation via systemd failed for unit ‘accounts-daemon.service’: Refusing activation, D-Bus is shutting down.
Dec 27 07:46:44 mrkmanjaro sudo[11916]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Dec 27 07:46:44 mrkmanjaro systemd[1]: session-4.scope: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped Session 4 of User markmarques.
Dec 27 07:46:44 mrkmanjaro systemd[1]: session-4.scope: Consumed 4min 9.489s CPU time, 540.8M memory peak.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopping User Manager for UID 1000…
Dec 27 07:46:44 mrkmanjaro systemd-logind[1058]: Removed session 4.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Activating special unit Exit the Session…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Removed slice Slice /app/dbus-:1.17-org.a11y.atspi.Registry.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped target Main User Target.
Dec 27 07:46:44 mrkmanjaro dbus-broker[3992]: Dispatched 332 messages @ 5(±7)μs / message.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping Accessibility services bus…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping User preferences database…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping GNOME Keyring daemon…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping Virtual filesystem service - Apple File Conduit monitor…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping Virtual filesystem service…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping Virtual filesystem service - digital camera monitor…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping Virtual filesystem metadata service…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping Virtual filesystem service - Media Transfer Protocol monitor…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping Virtual filesystem service - disk device monitor…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping PipeWire PulseAudio…
Dec 27 07:46:44 mrkmanjaro systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Unmounted /run/user/1000/gvfs.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping XFCE notifications service…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped GNOME Keyring daemon.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped PipeWire PulseAudio.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped User preferences database.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: dconf.service: Consumed 2.200s CPU time, 5.9M memory peak.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped Virtual filesystem metadata service.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: gvfs-metadata.service: Consumed 2.939s CPU time, 2.9M memory peak.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped XFCE notifications service.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped Virtual filesystem service - digital camera monitor.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped Virtual filesystem service - disk device monitor.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped Virtual filesystem service.
Dec 27 07:46:44 mrkmanjaro sudo[11933]: The ZFS modules cannot be auto-loaded.
Dec 27 07:46:44 mrkmanjaro sudo[11933]: Try running ‘modprobe zfs’ as root to manually load them.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping Multimedia Service Session Manager…
Dec 27 07:46:44 mrkmanjaro sudo[11916]: pam_unix(sudo:session): session closed for user root
Dec 27 07:46:44 mrkmanjaro systemd[1]: zpool_all.service: Main process exited, code=exited, status=1/FAILURE
Dec 27 07:46:44 mrkmanjaro systemd[1]: zpool_all.service: Failed with result ‘exit-code’.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Failed to start Zpool Export All pools.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Requested transaction contradicts existing jobs: Transaction for sound.target/start is destructive (exit.target has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[3837]: sys-devices-pci0000:00-0000:00:01.0-0000:01:00.0-0000:02:00.0-0000:03:00.1-sound-card1-controlC1.device: Failed to enqueue SYSTEMD_USER_WANTS job, ignoring: Transaction for sound.target/start is destructive (exit.target has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[1]: Requested transaction contradicts existing jobs: Transaction for sound.target/start is destructive (poweroff.target has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[1]: sys-devices-pci0000:00-0000:00:01.0-0000:01:00.0-0000:02:00.0-0000:03:00.1-sound-card1-controlC1.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for sound.target/start is destructive (poweroff.target has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-rfkill.socket/start is destructive (shutdown.target has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for systemd-rfkill.socket/start is destructive (shutdown.target has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[1]: Requested transaction contradicts existing jobs: Transaction for sound.target/start is destructive (systemd-poweroff.service has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[1]: sys-devices-pci0000:00-0000:00:1b.0-sound-card0-controlC0.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for sound.target/start is destructive (systemd-poweroff.service has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Requested transaction contradicts existing jobs: Transaction for sound.target/start is destructive (systemd-exit.service has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[3837]: sys-devices-pci0000:00-0000:00:1b.0-sound-card0-controlC0.device: Failed to enqueue SYSTEMD_USER_WANTS job, ignoring: Transaction for sound.target/start is destructive (systemd-exit.service has ‘start’ job queued, but ‘stop’ is included in transaction).
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped Multimedia Service Session Manager.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping D-Bus User Message Bus…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopping PipeWire Multimedia Service…
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped D-Bus User Message Bus.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: dbus.service: Consumed 1.223s CPU time, 3.3M memory peak.
Dec 27 07:46:44 mrkmanjaro systemd[3837]: Stopped PipeWire Multimedia Service.
Dec 27 07:46:44 mrkmanjaro systemd[1]: tlp.service: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped TLP system startup/shutdown.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped target Multi-User System.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped target Login Prompts.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped target ZFS startup target.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped target ZFS pool import target.
Dec 27 07:46:44 mrkmanjaro ModemManager[1189]:  caught signal, shutting down…
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopping Modem Manager…
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopping Command Scheduler…
Dec 27 07:46:44 mrkmanjaro NetworkManager[1194]:   [1766821604.0789] modem-manager: ModemManager no longer available
Dec 27 07:46:44 mrkmanjaro ModemManager[1189]:  ModemManager is shut down
Dec 27 07:46:44 mrkmanjaro mkinitcpio[11913]: ==> Starting build: ‘none’
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopping Initialize hardware monitoring sensors…
Dec 27 07:46:44 mrkmanjaro ntpd[1411]: ntpd exiting on signal 15 (Terminated)
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopping Network Time Service…
Dec 27 07:46:44 mrkmanjaro crond[1409]: (CRON) INFO (Shutting down)
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopping “Sophos Anti-Virus daemon”…
Dec 27 07:46:44 mrkmanjaro systemd[1]: cronie.service: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped Command Scheduler.
Dec 27 07:46:44 mrkmanjaro systemd[1]: ntpd.service: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped Network Time Service.
Dec 27 07:46:44 mrkmanjaro mkinitcpio[11913]:   → Running build hook: [sd-shutdown]
Dec 27 07:46:44 mrkmanjaro (udev-worker)[11979]: sr0: Process ‘/usr/sbin/pktsetup -i -d 11:0’ failed with exit code 1.
Dec 27 07:46:44 mrkmanjaro systemd[1]: ModemManager.service: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped Modem Manager.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopping Authorization Manager…
Dec 27 07:46:44 mrkmanjaro systemd[1]: polkit.service: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped Authorization Manager.
Dec 27 07:46:44 mrkmanjaro (modprobe)[12055]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Dec 27 07:46:44 mrkmanjaro mkinitcpio[11913]: ==> Build complete.
Dec 27 07:46:44 mrkmanjaro systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Finished Generate shutdown-ramfs.
Dec 27 07:46:44 mrkmanjaro systemd[1]: lm_sensors.service: Deactivated successfully.
Dec 27 07:46:44 mrkmanjaro systemd[1]: Stopped Initialize hardware monitoring sensors.
Dec 27 07:46:46 mrkmanjaro savd[2433]: savd.daemon: On-access scanning disabled.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Stopped Accessibility services bus.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Removed slice User Core Session Slice.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: session.slice: Consumed 5.900s CPU time, 36.9M memory peak.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Stopped target Basic System.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Stopped target Paths.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Stopped target Sockets.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Stopped target Timers.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed D-Bus User Message Bus Socket.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed GnuPG network certificate management daemon.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed GCR ssh-agent wrapper.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed GNOME Keyring daemon.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed GnuPG cryptographic agent and passphrase cache.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed GnuPG public key management service.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed p11-kit server.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed PipeWire PulseAudio.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed PipeWire Multimedia System Sockets.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed Speech Dispatcher Socket.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Closed Query the User Interactively for a Password.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Removed slice User Application Slice.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: app.slice: Consumed 2.850s CPU time, 46.7M memory peak.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Reached target Shutdown.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Finished Exit the Session.
Dec 27 07:46:46 mrkmanjaro systemd[3837]: Reached target Exit the Session.
Dec 27 07:46:46 mrkmanjaro (sd-pam)[3864]: pam_unix(systemd-user:session): session closed for user markmarques
Dec 27 07:46:46 mrkmanjaro systemd-logind[1058]: Removed session 5.
Dec 27 07:46:46 mrkmanjaro (sd-pam)[3864]: pam_systemd(systemd-user:session): Failed to issue ReleaseSession() varlink call: io.systemd.Login.NoSuchSession
Dec 27 07:46:46 mrkmanjaro (sd-pam)[3864]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal= user=[markmarques] ruser= rhost=
Dec 27 07:46:46 mrkmanjaro systemd[1]: user@1000.service: Deactivated successfully.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped User Manager for UID 1000.
Dec 27 07:46:46 mrkmanjaro systemd[1]: user@1000.service: Consumed 9.463s CPU time, 89.7M memory peak.
Dec 27 07:46:46 mrkmanjaro sddm[3647]: Display server stopped.
Dec 27 07:46:46 mrkmanjaro sddm[3647]: Running display stop script  QList(“/usr/share/sddm/scripts/Xstop”)
Dec 27 07:46:46 mrkmanjaro systemd[1]: sddm.service: Deactivated successfully.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped Simple Desktop Display Manager.
Dec 27 07:46:46 mrkmanjaro systemd[1]: sddm.service: Consumed 8min 22.017s CPU time, 134.4M memory peak.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopping Permit User Sessions…
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopping User Runtime Directory /run/user/1000…
Dec 27 07:46:46 mrkmanjaro systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped Permit User Sessions.
Dec 27 07:46:46 mrkmanjaro systemd[1]: run-user-1000.mount: Deactivated successfully.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Unmounted /run/user/1000.
Dec 27 07:46:46 mrkmanjaro systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped User Runtime Directory /run/user/1000.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Removed slice User Slice of UID 1000.
Dec 27 07:46:46 mrkmanjaro systemd[1]: user-1000.slice: Consumed 4min 18.974s CPU time, 608M memory peak.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped target Network.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped target Remote File Systems.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopping Network Manager…
Dec 27 07:46:46 mrkmanjaro NetworkManager[1194]:   [1766821606.6466] caught SIGTERM, shutting down normally.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopping User Login Management…
Dec 27 07:46:46 mrkmanjaro NetworkManager[1194]:   [1766821606.6470] dhcp4 (eno1): canceled DHCP transaction
Dec 27 07:46:46 mrkmanjaro NetworkManager[1194]:   [1766821606.6471] dhcp4 (eno1): activation: beginning transaction (timeout in 45 seconds)
Dec 27 07:46:46 mrkmanjaro NetworkManager[1194]:   [1766821606.6471] dhcp4 (eno1): state changed no lease
Dec 27 07:46:46 mrkmanjaro NetworkManager[1194]:   [1766821606.6473] manager: NetworkManager state is now CONNECTED_SITE
Dec 27 07:46:46 mrkmanjaro dbus-daemon[1044]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.4’ (uid=0 pid=1194 comm=“/usr/bin/NetworkManager --no-daemon”)
Dec 27 07:46:46 mrkmanjaro dbus-daemon[1044]: [system] Activation via systemd failed for unit ‘dbus-org.freedesktop.nm-dispatcher.service’: Refusing activation, D-Bus is shutting down.
Dec 27 07:46:46 mrkmanjaro systemd[1]: systemd-logind.service: Deactivated successfully.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped User Login Management.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped target User and Group Name Lookups.
Dec 27 07:46:46 mrkmanjaro NetworkManager[1194]:   [1766821606.6868] exiting (success)
Dec 27 07:46:46 mrkmanjaro systemd[1]: NetworkManager.service: Deactivated successfully.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped Network Manager.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopping D-Bus System Message Bus…
Dec 27 07:46:46 mrkmanjaro systemd[1]: dbus.service: Deactivated successfully.
Dec 27 07:46:46 mrkmanjaro systemd[1]: Stopped D-Bus System Message Bus.
Dec 27 07:46:46 mrkmanjaro systemd[1]: dbus.service: Consumed 2.710s CPU time, 6.3M memory peak.
Dec 27 07:46:46 mrkmanjaro savd[2433]: savd.daemon: Sophos Anti-Virus daemon stopped.
Dec 27 07:46:47 mrkmanjaro systemd[1]: sav-protect.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped “Sophos Anti-Virus daemon”.
Dec 27 07:46:47 mrkmanjaro systemd[1]: sav-protect.service: Consumed 46.662s CPU time, 908.5M memory peak.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Basic System.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Path Units.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Slice Units.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Removed slice User and Session Slice.
Dec 27 07:46:47 mrkmanjaro systemd[1]: user.slice: Consumed 4min 21.621s CPU time, 653M memory peak.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Socket Units.
Dec 27 07:46:47 mrkmanjaro systemd[1]: dbus.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed D-Bus System Message Bus Socket.
Dec 27 07:46:47 mrkmanjaro systemd[1]: dirmngr@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Removed slice Slice /system/dirmngr.
Dec 27 07:46:47 mrkmanjaro systemd[1]: gpg-agent-browser@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Removed slice Slice /system/gpg-agent-browser.
Dec 27 07:46:47 mrkmanjaro systemd[1]: gpg-agent-extra@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Removed slice Slice /system/gpg-agent-extra.
Dec 27 07:46:47 mrkmanjaro systemd[1]: gpg-agent-ssh@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Removed slice Slice /system/gpg-agent-ssh.
Dec 27 07:46:47 mrkmanjaro systemd[1]: gpg-agent@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Removed slice Slice /system/gpg-agent.
Dec 27 07:46:47 mrkmanjaro systemd[1]: keyboxd@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed GnuPG public key management service for /etc/pacman.d/gnupg.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Removed slice Slice /system/keyboxd.
Dec 27 07:46:47 mrkmanjaro systemd[1]: sshd-unix-local.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-hostnamed.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed Hostname Service Socket.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-importd.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed Disk Image Download Service Socket.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-logind-varlink.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed User Login Management Varlink Socket.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-machined.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed Virtual Machine and Container Registration Service Socket.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target System Initialization.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Local Encrypted Volumes.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Image Downloads.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Local Integrity Protected Volumes.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Local Verity Protected Volumes.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopping Set Up Additional Binary Formats…
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-sysctl.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Apply Kernel Variables.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-coredump.socket: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Closed Process Core Dump Socket.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-modules-load.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Load Kernel Modules.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-update-done.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Update is Completed.
Dec 27 07:46:47 mrkmanjaro systemd[1]: ldconfig.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-hwdb-update.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Rebuild Hardware Database.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-journal-catalog-update.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Rebuild Journal Catalog.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopping Record System Boot/Shutdown in UTMP…
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-binfmt.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Set Up Additional Binary Formats.
Dec 27 07:46:47 mrkmanjaro systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Dec 27 07:46:47 mrkmanjaro systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Create System Files and Directories.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Local File Systems.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Unmounting /tmp…
Dec 27 07:46:47 mrkmanjaro systemd[1]: tmp.mount: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Unmounted /tmp.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Preparation for Local File Systems.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped target Swaps.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Reached target Unmount All Filesystems.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Create Static Device Nodes in /dev.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-sysusers.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Create System Users.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Remount Root and Kernel File Systems.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-fsck-root.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped File System Check on Root Device.
Dec 27 07:46:47 mrkmanjaro systemd[1]: systemd-tmpfiles-setup-dev-early.service: Deactivated successfully.
Dec 27 07:46:47 mrkmanjaro systemd[1]: Stopped Create Static Device Nodes in /dev gracefully.
Dec 27 07:46:49 mrkmanjaro systemd[1]: lvm2-monitor.service: Deactivated successfully.
Dec 27 07:46:49 mrkmanjaro systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Dec 27 07:46:49 mrkmanjaro systemd[1]: Reached target System Shutdown.
Dec 27 07:46:49 mrkmanjaro systemd[1]: Reached target Late Shutdown Services.
Dec 27 07:46:49 mrkmanjaro systemd[1]: systemd-poweroff.service: Deactivated successfully.
Dec 27 07:46:49 mrkmanjaro systemd[1]: Finished System Power Off.
Dec 27 07:46:49 mrkmanjaro systemd[1]: Reached target System Power Off.
Dec 27 07:46:49 mrkmanjaro systemd[1]: Shutting down.
Dec 27 07:46:49 mrkmanjaro systemd-shutdown[1]: Syncing filesystems and block devices.
Dec 27 07:46:49 mrkmanjaro systemd-shutdown[1]: Sending SIGTERM to remaining processes…
Dec 27 07:46:49 mrkmanjaro systemd-journald[347]: Received SIGTERM from PID 1 (systemd-shutdow).
Dec 27 07:46:49 mrkmanjaro systemd-udevd[380]: Failed to remove file descriptor “config-serialization” from the store, ignoring: Connection refused
Dec 27 07:46:49 mrkmanjaro systemd-udevd[380]: Failed to push serialization fd to service manager: Connection refused
Dec 27 07:46:49 mrkmanjaro systemd-journald[347]: Journal stopped
Edited 1:
A few more details that I forgot …
Using the latest 6.19 Kernel, an AMD graphic card and have disabled the Watchdog timers …
@markmarques
Please edit your post and place the command output in a scrollable pre-formatted text enclosure according to forum guidelines.
[MiniHowTo] Present code or command output
What is a Quark?
Well, then no suspend occurred during the last boot. See:
journalctl --list-boots
You can also trigger a suspend process on the terminal:
systemctl suspend
Please correct your post as instructed by @soundofthunder. Thanks.
One more detail …
Most of the time the machine is kept in tty only; no graphical.target active and it does not suspend | hibernate the screen…
Calling journal --list-boots, get more than 256 entries ( I think is the limit … ) spanning more than 6 months ago … This system were installed in 2015 … :wink:
(Nonetheless noticed that in Nov the entries changed from WEST time zone to WET ? )
-50 0f4a6fe6b7ee4f978b5cd75f6ab2c150 Sun 2025-10-05 12:19:31 WEST Sun 2025-10-05 12:22:56 WEST
 -49 5677b20d09d24661a848e073f03cd727 Mon 2025-10-06 21:00:50 WEST Mon 2025-10-06 20:17:29 WEST
 -48 0b8722f81232400ea10f0e1f6b0c33b8 Mon 2025-11-03 19:54:36 WET  Mon 2025-11-03 20:10:05 WET
 -47 6e06a47e35f74dcbb0827e278b1f7610 Tue 2025-11-04 17:03:26 WET  Tue 2025-11-04 17:16:09 WET
 -46 cdec37b791874f6ca119996387e5b3a5 Fri 2025-11-07 21:14:24 WET  Fri 2025-11-07 21:21:38 WET
Calling the systemctl suspend I get :
Call to Suspend failed: Access denied
Another odd detail that found checking the journals was the GRUB noacpi flag ….
Do I need it to disable the suspend | hibernate details ?
No idea about the suspend, but the time is normal:
West european summer time vs. west european time (winter/astronomical).
This may be helpful in understanding the differences:
Yeah, and knowing this is totally helpful. :wink: You know that you called boot -1 before, right?
sudo systemctl suspend
If that works, then you have a permission problem.
Hi,
After several trials and adjustments , finally was able to keep the computer ON without suspend nor hibernate.
The detail was the noacpi flag in GRUB , once I removed it and remade the grub configuration, Manjaro behaved as expected .
Although it takes about one minute and half to activate the display .
Final conclusion: having the noacpi GRUB flag makes all the difference …
Edit 1: Validated that the HDMI sound is still active , as in the past once recovered the display the sound were amiss …
Thank you all for the support.
Slight correction: that’s not a grub flag, that’s a kernel parameter. :wink:
Which is why an inxi is worth a thousand words. Maybe someone would have spotted it if you have posted it - the kernel boot line is also there.
