XFCE Screen Blanking
XFCE
screen blanking
So the screen started tuning itself off despite all power management disabled including screensaver.
I uninstalled the screensaver and it was fine for awhile.
I have added and enabled ‘presentation mode’ which too worked for awhile.
It’s even disabling presentation mode it seems. Re-enabling is not helping.
On/off just seems to be ignored.
So I’m now thinking of going back to 4.18.
Your post has been moved to a dedicated topic.
Your bolded text seems meaningless.
Version 4.18 of what?
You can’t. Manjaro only has one version of whateveryouuse, and partial updates are not supported. Rather try and figure out why this is happening. To that end, please provide the output of:
journalctl --priority=warning..crit --no-pager --boot=0
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • --no-pager formats the output nicely for use here, on the forum;
  • the --boot=0 argument limits the messages to be from the current boot.
More:
Note that the above text is partially pre-prepared as general information for new users. Please take the time to follow the given links and learn more.
I have not used xfce in a while. Does it respond to xset commands?
As in: xset dpms force on
This forces the display on. (and off too)
Don’t recall how to post that without someone complaining
IT does. xset q showed “DPMS is Disabled”
tried xset dpms force on
BUT after 10mins its off.
Checking status again and it says
DPMS (Display Power Management Signaling):
Standby: 600 Suspend: 600 Off: 600
DPMS is Enabled
Monitor is On
Yet it turned off !
On the chance that you actually want someone to help you, please provide the requested logs. Additionally, please provide system information as described (below).
Like this;
Paste your command output between two rows of three backtick characters.
Which results in:
Please see:
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Thankyou to deroberts1 showing me xset.
And tgpt showed me how to apply settings
xset dpms 0 0 0 && xset s noblank && xset s off
Monitor has remained on for over 45 minutes.
And here’s my configs
inxi -zv8
  Kernel: 6.13.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.13-x86_64
    root=UUID=bdcedd2d-8e83-45fe-ae9c-683ee6633a62 rw rootflags=subvol=@
    ipv6.disable=1 apparmor=1 security=apparmor udev.log_priority=3
    pcie_aspm.policy=performance
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: HP product: HP EliteDesk 800 G5 Desktop Mini v: SBKPF
    serial: <superuser required> Chassis: type: 6 serial: <superuser required>
  Mobo: HP model: 8594 v: KBC Version 08.09.21 serial: <superuser required>
    part-nu: 7PF42ET#ABU uuid: <superuser required> UEFI: HP
    v: R21 Ver. 02.21.01 date: 08/30/2024
  System RAM: total: 32 GiB available: 30.57 GiB used: 3.39 GiB (11.1%)
  Device-1: Channel-B DIMM1 type: DDR4 detail: synchronous size: 16 GiB
    speed: spec: 3200 MT/s actual: 2667 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Crucial part-no: CT16G4SFRA32A.C16FP
    serial: <filter>
  Device-2: Channel-A DIMM3 type: DDR4 detail: synchronous size: 16 GiB
    serial: <filter>
  Info: model: Intel Core i5-9500 bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 4319 min/max: 800/4400 scaling: driver: intel_pstate
    governor: performance cores: 1: 4319 2: 4319 3: 4319 4: 4319 5: 4319 6: 4319
    bogomips: 36000
    sgx sgx_lc smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: gather_data_sampling mitigation: Microcode (locked)
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Hewlett-Packard
    ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3e92 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
    s-diag: 584mm (22.99") monitors: <missing: xrandr>
  Monitor-1: DP-3 model: Idek Iiyama PLE2407HDS serial: <filter> built: 2009
    res: 1920x1080 dpi: 94 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.282 y: 0.608 blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 521x293mm (20.51x11.54") diag: 600mm (23.6") ratio: 16:9
    modes: 1920x1080, 1920x1080i, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e92 memory: 14.93 GiB unified: yes
    x11: xdpyinfo,xprop
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  API: ALSA v: k6.13.5-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
  Local Storage: total: 1.82 TiB used: 1.61 TiB (88.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 20.9 C
    scheme: MBR
  ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 22.6 GiB (22.6%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: bdcedd2d-8e83-45fe-ae9c-683ee6633a62
  ID-2: /boot/efi raw-size: 550 MiB size: 548.9 MiB (99.80%)
    used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 361B-8F2D
  ID-3: /home raw-size: 1.71 TiB size: 1.71 TiB (100.00%)
    used: 1.59 TiB (93.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 1a508a91-aedf-446d-b445-77ef4f0be846
  ID-4: /var/cache raw-size: 10 GiB size: 10 GiB (100.00%)
    used: 160.8 MiB (1.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: ad3a681d-8df7-490c-8257-2bfce615ffcc
  ID-5: /var/log raw-size: 2 GiB size: 2 GiB (100.00%) used: 32.8 MiB (1.6%)
    fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: ba1de450-ba78-4f42-b598-35a9e19da9d4
  ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 1 KiB fs: <superuser required>
    label: N/A uuid: N/A
  Device-1: 1-4:4 info: Megawin Defender Gaming Keyboard type: keyboard
    chip-ID: 0e6a:02c0 class-ID: 0301
  Device-2: 1-5:5 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1bcf:08a0 class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  System Temperatures: cpu: 33.0 C pch: 30.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1419 libs: 390 tools: pamac,yay
    1: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 292
  1: cpu: 0.8% command: brave pid: 445401 mem: 233.1 MiB (0.7%)
  2: cpu: 0.3% command: Xorg pid: 813 mem: 188.3 MiB (0.6%)
  3: cpu: 0.3% command: brave pid: 347444 mem: 287.2 MiB (0.9%)
  4: cpu: 0.2% command: brave pid: 5516 mem: 518.4 MiB (1.6%)
  5: cpu: 0.2% command: brave pid: 5558 mem: 318.3 MiB (1.0%)
  Memory top: 5 of 292
  1: mem: 518.4 MiB (1.6%) command: brave pid: 5516 cpu: 0.2%
  2: mem: 365.8 MiB (1.1%) command: brave pid: 125039 cpu: 0.0%
  3: mem: 318.3 MiB (1.0%) command: brave pid: 5558 cpu: 0.2%
  4: mem: 304.8 MiB (0.9%) command: brave pid: 329849 cpu: 0.0%
  5: mem: 287.2 MiB (0.9%) command: brave pid: 347444 cpu: 0.3%
  Processes: 292 Power: uptime: 3d 1h 58m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 17 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.22 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 257
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.37
Hi @jaroMAN ,
I wonder whether you could try to set put to sleep never in the display power management picture you have posted. You could find this in System SettingsPower ManagerDisplay Tab
I am on XFCE and I only have one monitor but it never does not go blank.
Hope it help,
Regards
Me too only one monitor.
Always was ‘NEVER’ for both options. it’s just the switch from 4.18 → 4.20 finally caught up with me despite always having screensaver & locker disabled.
But I placed the xset commands into a bash script and have added to ‘Application Autostart’ under ‘session and startup’.
now I need to test if I still need 'presentation mode/ enabled.
