I thought a clean install with the latest iso xfce-23.1.3-240113 would help but no.
manjaro-downgrade
DOWNGRADE_FROM_ALA=1 sudo downgrade mesa
Down grade to mesa 1:23.1.9-1
Now I am on …9-1 everything is working fine. Is there a better workaround than this?
What time period do you think before this bug is fixed.
inxi -Fazy
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7de2947a-a4ff-40b0-baf2-cbbbcb88cc0c rw quiet splash apparmor=1
security=apparmor resume=UUID=2262e34b-9c31-4649-b2c1-2ca2ae1abadf
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: ASUSTeK product: K73TA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: K73TA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 214 date: 04/06/2012
ID-1: BAT1 charge: 20.8 Wh (100.0%) condition: 20.8/48.8 Wh (42.6%)
volts: 12.4 min: 11.1 model: ASUS PA3533U type: Li-ion serial: <filter>
status: full
Info: model: AMD A6-3400M APU with Radeon HD Graphics bits: 64 type: MCP
arch: K12 Fusion level: v1 built: 2011 process: GF 32nm family: 0x12 (18)
model-id: 1 stepping: 0 microcode: 0x3000027
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 512 KiB
desc: d-4x64 KiB; i-4x64 KiB L2: 4 MiB desc: 4x1024 KiB
Speed (MHz): avg: 849 high: 1000 min/max: 800/1400 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 800 2: 799 3: 800 4: 1000
bogomips: 11185
Flags: ht lm nx pae sse sse2 sse3 sse4a svm
Type: spec_store_bypass status: Not affected
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Sumo [Radeon HD 6520G] vendor: ASUSTeK driver: radeon v: kernel
alternate: amdgpu arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
built: 2009-15 ports: active: LVDS-1 empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0
chip-ID: 1002:9647 class-ID: 0300
Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
vendor: ASUSTeK driver: radeon v: kernel alternate: amdgpu arch: TeraScale-2
code: Evergreen process: TSMC 32-40nm built: 2009-15 pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 1002:6741 class-ID: 0300 temp: 50.5 C
Display: x11 server: X.org v: 1.21.1.10 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
gpu: radeon display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: LVDS-1 model: Chi Mei Opto 0x1721 built: 2009 res: 1600x900
dpi: 104 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 448mm (17.6")
ratio: 16:9 modes: max: 1600x900 min: 640x480
API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
drv: r600 device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600
x11: drv: r600 inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: AMD SUMO (DRM 2.50.0 / 6.6.10-1-MANJARO LLVM
16.0.6) device-ID: 1002:9647 memory: 500 MiB unified: no
Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:1714 class-ID: 0403
Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MediaTek Wireless_Device driver: mt7921u type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0e8d:7961
class-ID: 0000 serial: <filter>
IF: wlp0s16f0u2 state: up mac: <filter>
Local Storage: total: 2.93 TiB used: 212.43 GiB (7.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Netac model: SSD 120GB MX
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 17O4 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-3: /dev/sdd maj-min: 8:48 model: USB 3.0 Disk 3.0 size: 1.91 TiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
ID-1: / raw-size: 102.69 GiB size: 100.52 GiB (97.89%)
used: 25.85 GiB (25.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 185.18 GiB (20.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 6280.4 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: radeon temp: 51.0 C device: radeon temp: 51.0 C
Memory: total: 16 GiB note: est. available: 15.11 GiB used: 2.23 GiB (14.8%)
Processes: 228 Power: uptime: 3h 11m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 6.02 GiB
daemons: xfce4-power-manager,upowerd Init: systemd v: 255
Packages: 1096 pm: pacman pkgs: 1091 libs: 350 tools: pamac pm: flatpak
pkgs: 5 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.32
All thoughts welcome.
