And with lightdm and light-locker things are getting really weird.
Independent of what I set in terms of timings in the xfce4 display power options, my screens all turn off (even if they are “just” supposed to blank) and directly wake up again. Depending on if I set in power manager security settings “automatically lock session” when screensaver is deactivated or activated this sleep and wakeupcycle continues forever, or works right from the moment that light-locker seems to take over. So as soon as I have seen the light-locker unlock box once the screens can fall truly asleep (and turn off). I will see if I can live with the setting “when screensaver is activated” - and have a one time wakeup after screens are turning off.
In this small testing series, I couldn’t reproduce the double-login problem from teh previous author, but will soon contine with some tests on my laptop.
Here is the full log when Display power setting are set to never, never,1 min and security to “when screensaver is activated”, 10s delay
(With a 10s delay the re-wakeup is barely noticable).
Oct 15 11:46:14 ulno-desktop rtkit-daemon[1907]: Supervising 7 threads of 4 processes of 1 users.
Oct 15 11:46:14 ulno-desktop rtkit-daemon[1907]: Successfully made thread 2903639 of process 2900201 owned by '1000' RT at priority 5.
Oct 15 11:46:14 ulno-desktop rtkit-daemon[1907]: Supervising 8 threads of 4 processes of 1 users.
Oct 15 11:46:14 ulno-desktop pulseaudio[2900201]: E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
Oct 15 11:46:14 ulno-desktop pulseaudio[2900201]: E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="2" name="usb-Altec_Lansi_Altec_Lansing_XT2_--00" card_name="alsa_card.usb-Altec_Lansi_Altec_Lansing_XT2_--00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
Oct 15 11:46:14 ulno-desktop rtkit-daemon[1907]: Successfully made thread 2903664 of process 2900201 owned by '1000' RT at priority 5.
Oct 15 11:46:14 ulno-desktop pipewire[516210]: [E][000318347.220049][alsa-pcm.c:33 spa_alsa_open()] 'hdmi:0,5': playback open failed: Device or resource busy
Oct 15 11:46:14 ulno-desktop pipewire[516210]: [W][000318347.220072][adapter.c:175 find_format()] adapter 0x5558e50d0d60: can't get format: Device or resource busy
Oct 15 11:46:14 ulno-desktop pipewire[516210]: [E][000318347.220080][module-adapter.c:231 create_object()] can't create node: Device or resource busy
Oct 15 11:46:14 ulno-desktop pipewire[516212]: [E][000318347.220196][core.c:71 core_event_error()] core 0x557880634430: proxy 0x5578807c0570 id:56: seq:6236 res:-16 (Device or resource busy) msg:"can't create node: Device or resource busy"
Oct 15 11:46:14 ulno-desktop pipewire[516212]: [E][000318347.220211][media-session.c:1951 core_error()] error id:56 seq:6236 res:-16 (Device or resource busy): can't create node: Device or resource busy
Oct 15 11:46:15 ulno-desktop rtkit-daemon[1907]: Supervising 7 threads of 4 processes of 1 users.
Oct 15 11:46:15 ulno-desktop rtkit-daemon[1907]: Successfully made thread 2903665 of process 2900201 owned by '1000' RT at priority 5.
Oct 15 11:46:15 ulno-desktop rtkit-daemon[1907]: Supervising 8 threads of 4 processes of 1 users.
Oct 15 11:46:15 ulno-desktop audit[2903669]: CRED_ACQ pid=2903669 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:46:15 ulno-desktop lightdm[2903669]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=969) by (uid=0)
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1103 audit(1602773175.672:1095): pid=2903669 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:46:15 ulno-desktop systemd[1]: Created slice User Slice of UID 969.
Oct 15 11:46:15 ulno-desktop systemd[1]: Starting User Runtime Directory /run/user/969...
Oct 15 11:46:15 ulno-desktop systemd-logind[1375]: [🡕] New session c10 of user lightdm.
Oct 15 11:46:15 ulno-desktop systemd[1]: Finished User Runtime Directory /run/user/969.
Oct 15 11:46:15 ulno-desktop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 15 11:46:15 ulno-desktop systemd[1]: Starting User Manager for UID 969...
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1130 audit(1602773175.706:1096): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 15 11:46:15 ulno-desktop dbus-daemon[1369]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.17804' (uid=0 pid=2903673 comm="(systemd) " label="unconfined")
Oct 15 11:46:15 ulno-desktop dbus-daemon[1369]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 15 11:46:15 ulno-desktop pulseaudio[2900201]: E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
Oct 15 11:46:15 ulno-desktop audit[2903673]: USER_ACCT pid=2903673 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1101 audit(1602773175.716:1097): pid=2903673 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1103 audit(1602773175.716:1098): pid=2903673 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1006 audit(1602773175.716:1099): pid=2903673 uid=0 subj==unconfined old-auid=4294967295 auid=969 tty=(none) old-ses=4294967295 ses=22 res=1
Oct 15 11:46:15 ulno-desktop audit[2903673]: CRED_ACQ pid=2903673 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 15 11:46:15 ulno-desktop systemd[2903673]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 15 11:46:15 ulno-desktop pulseaudio[2900201]: E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="2" name="usb-Altec_Lansi_Altec_Lansing_XT2_--00" card_name="alsa_card.usb-Altec_Lansi_Altec_Lansing_XT2_--00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Oct 15 11:46:15 ulno-desktop systemd[2903673]: pam_unix(systemd-user:session): session opened for user lightdm(uid=969) by (uid=0)
Oct 15 11:46:15 ulno-desktop audit[2903673]: USER_START pid=2903673 uid=0 auid=969 ses=22 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1105 audit(1602773175.719:1100): pid=2903673 uid=0 auid=969 ses=22 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 15 11:46:15 ulno-desktop audit: BPF prog-id=194 op=LOAD
Oct 15 11:46:15 ulno-desktop audit: BPF prog-id=194 op=UNLOAD
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1334 audit(1602773175.729:1101): prog-id=194 op=LOAD
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1334 audit(1602773175.729:1102): prog-id=194 op=UNLOAD
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: /etc/xdg/autostart/org.kde.kgpg.desktop:8: Unknown key name 'MimeType' in section 'Desktop Entry', ignoring.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Configuration file /etc/xdg/autostart/org.kde.discover.notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Configuration file /etc/xdg/autostart/klipper.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Rfkill-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-xfce4\x2dclipman\x2dplugin\x2dautostart-autostart.service, it is hidden.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: kde-systemd-start-condition not found: No such file or directory
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dsecrets-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Sound-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Wwan-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.ScreensaverProxy-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-pulseaudio-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-xapp\x2dsn\x2dwatcher-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Color-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.MediaKeys-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Housekeeping-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-xscreensaver-autostart.service, could not find TryExec= binary xscreensaver: No such file or directory
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.A11ySettings-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dssh-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.XSettings-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-gnome\x2dkeyring\x2dpkcs11-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-at\x2dspi\x2ddbus\x2dbus-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Power-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.PrintNotifications-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Wacom-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-powerdevil-autostart.service, only Type=Application is supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Keyboard-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Datetime-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-xfce4\x2dnotes\x2dautostart-autostart.service, it is hidden.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Smartcard-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.UsbProtection-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-org.gnome.SettingsDaemon.Sharing-autostart.service, startup phases are not supported.
Oct 15 11:46:15 ulno-desktop systemd[2903681]: Not generating service for XDG autostart app-kaccess-autostart.service, only Type=Application is supported.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Queued start job for default target Main User Target.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Reached target Paths.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Reached target Timers.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Starting D-Bus User Message Bus Socket.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on GnuPG network certificate management daemon.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on GnuPG cryptographic agent and passphrase cache.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on p11-kit server.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on Multimedia System.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on Sound System.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Listening on D-Bus User Message Bus Socket.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Reached target Sockets.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Reached target Basic System.
Oct 15 11:46:15 ulno-desktop systemd[1]: Started User Manager for UID 969.
Oct 15 11:46:15 ulno-desktop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Starting Update XDG user dir configuration...
Oct 15 11:46:15 ulno-desktop systemd[1]: Started Session c10 of user lightdm.
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1130 audit(1602773175.962:1103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 15 11:46:15 ulno-desktop systemd[2903673]: xdg-user-dirs-update.service: Succeeded.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Finished Update XDG user dir configuration.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Reached target Main User Target.
Oct 15 11:46:15 ulno-desktop systemd[2903673]: Startup finished in 237ms.
Oct 15 11:46:15 ulno-desktop audit[2903669]: USER_START pid=2903669 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:46:15 ulno-desktop kernel: audit: type=1105 audit(1602773175.969:1104): pid=2903669 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:46:16 ulno-desktop systemd[2903673]: Started D-Bus User Message Bus.
Oct 15 11:46:16 ulno-desktop dbus-daemon[2903712]: [session uid=969 pid=2903712] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=969 pid=2903686 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Oct 15 11:46:16 ulno-desktop systemd[2903673]: Starting Accessibility services bus...
Oct 15 11:46:16 ulno-desktop dbus-daemon[2903712]: [session uid=969 pid=2903712] Successfully activated service 'org.a11y.Bus'
Oct 15 11:46:16 ulno-desktop systemd[2903673]: Started Accessibility services bus.
Oct 15 11:46:16 ulno-desktop dbus-daemon[2903712]: [session uid=969 pid=2903712] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=969 pid=2903686 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Oct 15 11:46:16 ulno-desktop systemd[2903673]: Starting Virtual filesystem service...
Oct 15 11:46:16 ulno-desktop dbus-daemon[2903712]: [session uid=969 pid=2903712] Successfully activated service 'org.gtk.vfs.Daemon'
Oct 15 11:46:16 ulno-desktop systemd[2903673]: Started Virtual filesystem service.
Oct 15 11:46:16 ulno-desktop pipewire[516210]: [E][000318348.660594][alsa-pcm.c:33 spa_alsa_open()] 'hdmi:0,1': playback open failed: Device or resource busy
Oct 15 11:46:16 ulno-desktop pipewire[516210]: [W][000318348.660620][adapter.c:175 find_format()] adapter 0x5558e50c4530: can't get format: Device or resource busy
Oct 15 11:46:16 ulno-desktop pipewire[516210]: [E][000318348.660629][module-adapter.c:231 create_object()] can't create node: Device or resource busy
Oct 15 11:46:16 ulno-desktop pipewire[516212]: [E][000318348.660776][core.c:71 core_event_error()] core 0x557880634430: proxy 0x5578807c0570 id:57: seq:6329 res:-16 (Device or resource busy) msg:"can't create node: Device or resource busy"
Oct 15 11:46:16 ulno-desktop pipewire[516212]: [E][000318348.660790][media-session.c:1951 core_error()] error id:57 seq:6329 res:-16 (Device or resource busy): can't create node: Device or resource busy
Oct 15 11:46:16 ulno-desktop polkitd[1623]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Oct 15 11:46:16 ulno-desktop polkitd[1623]: <no filename>:4: subject=[Subject pid=2903686 user='lightdm' groups=lightdm seat='seat0' session='c10' local=true active=true]
Oct 15 11:46:16 ulno-desktop at-spi-bus-launcher[2903719]: dbus-daemon[2903719]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=969 pid=2903686 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Oct 15 11:46:16 ulno-desktop at-spi-bus-launcher[2903719]: dbus-daemon[2903719]: Successfully activated service 'org.a11y.atspi.Registry'
Oct 15 11:46:16 ulno-desktop at-spi-bus-launcher[2903742]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Oct 15 11:47:13 ulno-desktop rtkit-daemon[1907]: Supervising 7 threads of 4 processes of 1 users.
Oct 15 11:47:13 ulno-desktop rtkit-daemon[1907]: Successfully made thread 2903806 of process 2900201 owned by '1000' RT at priority 5.
Oct 15 11:47:13 ulno-desktop rtkit-daemon[1907]: Supervising 8 threads of 4 processes of 1 users.
Oct 15 11:47:23 ulno-desktop lightdm[2903740]: gkr-pam: unable to locate daemon control file
Oct 15 11:47:23 ulno-desktop audit[2903740]: USER_AUTH pid=2903740 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ulno" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop lightdm[2903740]: gkr-pam: stashed password to try later in open session
Oct 15 11:47:23 ulno-desktop dbus-daemon[1369]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.17809' (uid=0 pid=2903740 comm="lightdm --session-child 13 22 " label="unconfined")
Oct 15 11:47:23 ulno-desktop dbus-daemon[1369]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 15 11:47:23 ulno-desktop lightdm[2903740]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 15 11:47:23 ulno-desktop audit[2903740]: USER_ACCT pid=2903740 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="ulno" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop kernel: audit: type=1100 audit(1602773243.163:1105): pid=2903740 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ulno" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop kernel: audit: type=1101 audit(1602773243.166:1106): pid=2903740 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="ulno" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop audit[2903740]: CRED_REFR pid=2903740 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ulno" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop kernel: audit: type=1110 audit(1602773243.273:1107): pid=2903740 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="ulno" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop systemd[1]: Stopping Session c10 of user lightdm.
Oct 15 11:47:23 ulno-desktop pulseaudio[2900201]: E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
Oct 15 11:47:23 ulno-desktop pulseaudio[2900201]: E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="2" name="usb-Altec_Lansi_Altec_Lansing_XT2_--00" card_name="alsa_card.usb-Altec_Lansi_Altec_Lansing_XT2_--00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
Oct 15 11:47:23 ulno-desktop lightdm[2903669]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Oct 15 11:47:23 ulno-desktop audit[2903669]: USER_END pid=2903669 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop audit[2903669]: CRED_DISP pid=2903669 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop systemd[1]: session-c10.scope: Succeeded.
Oct 15 11:47:23 ulno-desktop kernel: audit: type=1106 audit(1602773243.726:1108): pid=2903669 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop kernel: audit: type=1104 audit(1602773243.726:1109): pid=2903669 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Oct 15 11:47:23 ulno-desktop systemd[1]: Stopped Session c10 of user lightdm.
Oct 15 11:47:23 ulno-desktop systemd-logind[1375]: [🡕] Removed session c10.
Oct 15 11:47:23 ulno-desktop pipewire[516210]: [E][000318416.056742][alsa-pcm.c:33 spa_alsa_open()] 'hdmi:0,5': playback open failed: Device or resource busy
Oct 15 11:47:23 ulno-desktop pipewire[516212]: [E][000318416.056889][core.c:71 core_event_error()] core 0x557880634430: proxy 0x5578807c0570 id:57: seq:6565 res:-16 (Device or resource busy) msg:"enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed"
Oct 15 11:47:23 ulno-desktop pipewire[516212]: [E][000318416.056904][media-session.c:1951 core_error()] error id:57 seq:6565 res:-16 (Device or resource busy): enum params id:3 (Spa:Enum:ParamId:EnumFormat) failed
Oct 15 11:47:23 ulno-desktop rtkit-daemon[1907]: Supervising 7 threads of 4 processes of 1 users.
Oct 15 11:47:23 ulno-desktop rtkit-daemon[1907]: Successfully made thread 2903819 of process 2900201 owned by '1000' RT at priority 5.
Oct 15 11:47:23 ulno-desktop rtkit-daemon[1907]: Supervising 8 threads of 4 processes of 1 users.
Oct 15 11:47:23 ulno-desktop rtkit-daemon[1907]: Successfully made thread 2903821 of process 2900201 owned by '1000' RT at priority 5.
And a closing word on running xfce with lightdm, without light-locker and with xfce4-screensaver:
My displays turn off quickly but then turn on and show the screen saver and never turn off again. Things seem to lock correctly and I can unlock well. But no correct display turning off. Just light-locker seems to be able to correctly turn off displays.
Will open a new thread for that.
