What did you install? how ? where did you get it ? version ? link ?
Thats not a regular manjaro installation.
Did you install over a previous system while preserving home ?
yes, I had Manjaro Gnome, so I erased the partition with the gnome version and I preserved /home )with my personal files)
why did I decide to change enviroment_?
because my laptop runs better with xfce.
you said u preserved /home partition. that might be a problem because previous gnome installation left some ‘.(dot)hiddenfiles’ in home direcotry, those are configurations which interferes with the new installation
To view those files press Ctrl+H in /home (Note : XFCE also generates these configs)
i would recommend you to delete those ‘.(dot)hiddenfiles’ in home directory and reinstall Manjaro XFCE
I am going to guess you dont want the user ‘tester’ so maybe create one with whatever name you prefer.
(maybe you already did )
But of course you probably also want to move/backup your files and photos and whatnot.
Then make sure your new user is in all the right groups.
Check current groups: groups
and check new user groups (example username tester): groups tester
Mainly you want to make sure it is in its own user group and wheel at least.
You can add the user to new groups using (replace ex ‘group1’ with ‘wheel’ etc):
sudo usermod -aG group1,group2,group3 username
Then if you are sure you have everything you need safe you can log into your new account and delete the old user and its home (again using any desktop utility or) using terminal command:
userdel -r original-username-to-be-killed
(it does remove home when the -r flag is specified)
I think I prefer to reinstall again for a clean install, but first I need to do a back up in a portable HD for my /home,
then during the reinstallation I will erase /home and format that partition.
and I will let u know.
