Xfce Asus k73ta laptop will not recover from Hybrid Sleep
Xfce Asus k73ta laptop will not recover from Hybrid Sleep. However, it does recovery from Hibernate.
I read the following and other articles but I haven’t found the answer?
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate
Any thoughts appreciated.
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=66eedc1d-bc9a-4f78-8a0e-9ba04943f625 rw quiet apparmor=1
    security=apparmor resume=UUID=6395f3d6-8cb0-4153-8eff-4b3fee016210
    udev.log_priority=3
  Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: K73TA v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: K73TA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: 214 date: 04/06/2012
  ID-1: BAT1 charge: 28.9 Wh (87.6%) condition: 33.0/48.8 Wh (67.5%)
    volts: 11.8 min: 11.1 model: ASUS PA3533U type: Li-ion serial: <filter>
    status: discharging
  RAM: total: 15.11 GiB used: 1.6 GiB (10.6%)
  Info: model: AMD A6-3400M APU with Radeon HD Graphics bits: 64 type: MCP
    arch: K12 Fusion level: v1 built: 2011 process: GF 32nm family: 0x12 (18)
    model-id: 1 stepping: 0 microcode: 0x3000027
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 512 KiB
    desc: d-4x64 KiB; i-4x64 KiB L2: 4 MiB desc: 4x1024 KiB
  Speed (MHz): avg: 830 high: 918 min/max: 800/1400 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 801 2: 918 3: 803 4: 801
    bogomips: 11185
  Flags: 3dnow 3dnowext 3dnowprefetch abm aperfmperf apic arat clflush cmov
    cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de extapic
    extd_apicid fpu fxsr fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce
    misalignsse mmx mmxext monitor msr mtrr nonstop_tsc nopl npt nrip_save nx
    osvw pae pat pausefilter pdpe1gb pge pni popcnt pse pse36 rdtscp rep_good
    sep skinit sse sse2 sse4a svm svm_lock syscall tsc vme vmmcall wdt
  Type: spec_store_bypass status: Not affected
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: AMD Sumo [Radeon HD 6520G] vendor: ASUSTeK driver: radeon v: kernel
    arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm built: 2009-15 ports:
    active: LVDS-1 empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9647
    class-ID: 0300
  Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
    vendor: ASUSTeK driver: radeon v: kernel arch: TeraScale-2 code: Evergreen
    process: TSMC 32-40nm built: 2009-15 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 1002:6741
    class-ID: 0300 temp: 48.0 C
  Device-3: Chicony CNFA078 type: USB driver: uvcvideo bus-ID: 1-3:3
    chip-ID: 04f2:b23b class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
    loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
    gpu: radeon display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
    s-diag: 485mm (19.11")
  Monitor-1: LVDS-1 mapped: LVDS model: Chi Mei Opto 0x1721 built: 2009
    res: 1600x900 hz: 60 dpi: 106 gamma: 1.2 size: 382x215mm (15.04x8.46")
    diag: 448mm (17.6") ratio: 16:9 modes: max: 1600x900 min: 640x480
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series]
    vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:01.1
    chip-ID: 1002:1714 class-ID: 0403
  Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: yes
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: AzureWave
    AW-NE785 / AW-NE785H 802.11bgn driver: ath9k v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:002b class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Local Storage: total: 931.51 GiB used: 27.01 GiB (2.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
  Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DS8A5SH rev: XAA2
    dev-links: cdrom
  Features: speed: 8 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 914.59 GiB size: 899.16 GiB (98.31%) used: 27.01 GiB (3.0%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 66eedc1d-bc9a-4f78-8a0e-9ba04943f625
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: AF77-C435
  Kernel: swappiness: 30 (default 60) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 16.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 6395f3d6-8cb0-4153-8eff-4b3fee016210
  Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-3:3 info: Chicony CNFA078 type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b23b
  Device-2: 1-5:4 info: Realtek RTS5138 Card Reader Controller
    type: Mass Storage driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s
    power: 500mA chip-ID: 0bda:0138 class-ID: 0806 serial: <filter>
  Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
    chip-ID: 1d6b:0001 class-ID: 0900
  Device-1: 2-1:2 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 10c4:8108 class-ID: 0301
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 6280.4 C mobo: N/A
  GPU: device: radeon temp: 48.0 C device: radeon temp: 46.0 C
  Processes: 201 Uptime: 7m wakeups: 8 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1134
  pm: pacman pkgs: 1129 libs: 333 tools: pamac pm: flatpak pkgs: 5 Shell: Bash
  v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
