Xfce Application Autostart
Hi folks!
I’d like to have Firefox startup automatically when I turn my laptop on and login.
I’ve opened up Session and Startup, tab Application Autostart, + Add, Name: Firefox, Description: Web Browser…
Now I’m stuck… Command: ???
What do I put here? I’ve tried Firefox, firefox… I’ve made a file using mousepad and tried ~/Desktop/autostartup… none of these worked…
Thanks in advance for your help! Cheers!
/usr/bin/firefox
There is also a little symbol next to the text input field.
It opens a file browser - navigate to where the program is,
it should be:
and select it that way.
which firefox
in a terminal will also tell you the location, the PATH to it
Many thanks folks!
