Hi everyone!, I changed from PulseAudio to Pipewire (I’m on XFCE) then I realized I don’t have any working sound applet , is there any way to have a working sound applet with Pipewire in XFCE?
Thanks for the help!
How did you switch? (Is pipewire-pulse installed?) The pulseaudio one should be working with pipewire as well.
Installing Manjaro-Pipewire, I’ll check for the package you said.
pipewire-pulse is installed.
Should I change the audio mixer reference in the pulseaudio applet to something else?..
or maybe restart the PC? , I just relogged after the installation…
Is pavucontrol still installed? If not you might to reinstall it I guess. Aeh ya. And restart
yeah restart. And maybe also check for pacnew files. AFAIR 2 pacnew files related to pipewire also dropped in with the update.
Oh God!!! I just needed to restart
, this is so awkward
, thanks for the help,
