I have an external display plugged in to my laptop, and until today the desktop environment would appear normal and properly scaled on the external monitor. However, it suddenly stopped displaying properly. I don’t believe recent updates caused this issue. The hidden parts of the desktop environment are still “there” and I can move my mouse cursor into those hidden areas. I can see these hidden areas if I take a screenshot. All four sides of the external monitor portion of the desktop environment are cut off.
I have tried different cables and different HDMI ports, and I have confirmed the issue is not with any settings on the external display itself.
I made sure the screen is zoomed out all the way by fiddling with ALT + mouse wheel.
Here is the output for
inxi --admin --verbosity=7 --filter --width
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4bdadf24-7f64-49a0-a361-f705c03481b0 rw quiet
cryptdevice=UUID=d85a4a7b-55d6-47e3-b75a-ef16a86157cb:luks-d85a4a7b-55d6-47e3-b75a-ef16a86157cb
root=/dev/mapper/luks-d85a4a7b-55d6-47e3-b75a-ef16a86157cb apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20ASX50200 v: ThinkPad L440
Mobo: LENOVO model: 20ASX50200 v: SDK0E50510 WIN
serial: <superuser required> UEFI: LENOVO v: J4ET93WW(1.93) date: 05/30/2018
ID-1: BAT0 charge: 40.6 Wh (100.0%) condition: 40.6/56.2 Wh (72.3%)
volts: 12.2 min: 10.8 model: SMP 45N1149 type: Li-ion serial: <filter>
status: not charging
System RAM: total: 12 GiB available: 11.58 GiB used: 2.26 GiB (19.5%)
Info: model: Intel Core i3-4000M bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/2400 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 19161
Flags: abm acpi aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Display: x11 server: X[dot]Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1848 s-dpi: 96 s-size: 508x489mm (20.00x19.25")
s-diag: 705mm (27.76")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top model: Samsung serial: <filter>
built: 2011 res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2
size: 160x90mm (6.3x3.54") diag: 1285mm (50.6") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,bottom model: LG Display 0x045e built: 2014
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 310x174mm (12.2x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo 8
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Ethernet I217-V vendor: Lenovo driver: e1000e v: kernel
port: 5080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:088f
class-ID: 0280
Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-11:2
chip-ID: 8087:07da class-ID: e001
Device-1: luks-d85a4a7b-55d6-47e3-b75a-ef16a86157cb maj-min: 254:0
type: LUKS dm: dm-0 size: 465.46 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 465.46 GiB
Local Storage: total: 465.76 GiB used: 222.79 GiB (47.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM021-1KJ152
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: LIM1 scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD-RW DU8A6SH rev: DU61
dev-links: cdrom
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 222.79 GiB (48.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-d85a4a7b-55d6-47e3-b75a-ef16a86157cb label: N/A
uuid: 4bdadf24-7f64-49a0-a361-f705c03481b0
used: 472 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 51C0-138F
Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Hub-3: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-6:4 info: Razer USA Naga Chroma type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0053 class-ID: 0300
Device-2: 3-11:2 info: Intel Centrino Bluetooth Wireless Transceiver
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 8087:07da
class-ID: e001
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Processes: 210 Uptime: 44m wakeups: 1 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1557 libs: 444 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.30
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
