Hi,
I need Xerox DocuCentre-V 2060 driver for my network printer. How to install it? Thanks.
Hi,
Hello,
You will have to install this:
https://aur.archlinux.org/packages/xerox-docucentre-driver/
From terminal:
sudo pacman -Syu base-devel
pamac build xerox-docucentre-driver
Or maybe this one:
https://aur.archlinux.org/packages/xeroxprtdrv/
pamac build xeroxprtdrv
I just wondering is it possible install it without terminal? I did download fxlinuxprint-1.1.2-1.x86_64.rpm from your link.
And what you will do with it in an arch based system ? The PKGBUILD was made with that in mind.
If you don;t want terminal, then us Pamac UI and enable AUR support, search for the package and install it.
Oh I see, I’m new to Linux. I’m only know minor thing about Linux For Windows, I just download files and install it with device manager. I was thinking the same thing to do it with Linux
I’m try to learn easy way to do it. Thanks.
