As far as I can tell, this part is meant to extract the information from the data returned by:
But that’s all I can see. This:
…doesn’t interpret the extracted information at all. That might be done here:
…if this was successful:
so the only way this:
could override this:
…is if this was successful:
And that needs:
So, I honestly don’t think your problem, whatever it is, has to do with either xdg-open
, nor the shell.
I also know you’ve been on the forum long enough to know this, but:
Tip
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
Edit:
Just had an epiphany on the toilet, thanks toiletfaeries!
This:
Extracts the info from this:
I think
So if this:
isn’t successful, then this
won’t happen, causing this:
not to be overrode.
So it affirms my previous diagnoses, that whatever your problem is, I don’t think it has to do with either xdg-open
, nor the shell.
