xdg-desktop-portal is used extensively by flatpak, but also by a number of non-flatpak applications such as Gnome-Network-Displays.
org.freedesktop.portal.ScreenCast is used by Gnome-Network-Displays for doing Miracast, for example to an Android TV. Gnome-Network-Displays does not work for this reason. I have tried both the flatpak version as well as the two AUR versions, the same error is present.
This portal is missing from Manjaro’s build of xdg-desktop-portal. This shows up with the following error on Gnome-Network-Displays:
(gnome-network-displays:6217): Gnd-WARNING **: 20:41:36.603: Failed to create screencast session: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface “org.freedesktop.portal.ScreenCast”
Looking deeper, I investigated using Door Knocker and this portal is indeed missing from xdg-desktop-portal.
This could be due to the way xdg-desktop-portal is built.
I’m providing some diagnostic info below.
$ pamac list | grep xdg-desktop-portal
xdg-desktop-portal 1.18.4-2 extra 2,3 MB
xdg-desktop-portal-gnome 47.1-3 extra 820,8 kB
xdg-desktop-portal-gtk 1.15.1-2 extra 443,7 kB
xdg-desktop-portal-xapp 1.1.0-1 extra 159,1 kB
$ uname -a
Linux xxxxx 6.12.4-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon, 09 Dec 2024 11:58:37 +0000 x86_64 GNU/Linux
systemctl status --user xdg-desktop-portal.service
● xdg-desktop-portal.service - Portal service
Loaded: loaded (/usr/lib/systemd/user/xdg-desktop-portal.service; static)
Active: active (running) since Thu 2024-12-26 20:37:48 CET; 54min ago
Invocation: 777a2bb53d0a4966822a5a1b9ee4fff2
Main PID: 1384 (xdg-desktop-por)
Tasks: 7 (limit: 18503)
Memory: 203.7M (peak: 872.5M)
CPU: 8.232s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/xdg-desktop-portal.service
└─1384 /usr/lib/xdg-desktop-portal
Dez 26 20:37:48 zzzzzz systemd[1065]: Starting Portal service...
Dez 26 20:37:48 zzzzzz xdg-desktop-por[1384]: Error loading /usr/share/xdg-desktop-portal/portals/gnome.portal: Not a portal backend interface: org.freedesktop.portal.ScreenCast
Dez 26 20:37:48 zzzzzz xdg-desktop-por[1384]: Choosing xapp.portal for org.freedesktop.impl.portal.Background via the deprecated UseIn key
Dez 26 20:37:48 zzzzzz xdg-desktop-por[1384]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Dez 26 20:37:48 zzzzzz xdg-desktop-por[1384]: Choosing xapp-gnome-keyring.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Dez 26 20:37:48 zzzzzz systemd[1065]: Started Portal service.
Dez 26 20:38:25 zzzzzz xdg-desktop-por[1384]: Failed to get application states: GDBus.Error:org.freedesktop.portal.Error.Failed: GetAppState currently only supported in Cinnamon
It seems to be running fine.
My suspicion is that xdg-desktop-portal.service does not support ScreenCast unless built with certain flags.
I also checked and ScreenCast definitely is available on current stable branch. Something is broken on your side – I don’t use gnome portal – maybe this is issue:
Please note that it’s easy to miss information given in forum posts. Instead of claiming “you didn’t read it” (and similar), perhaps think about how you might have presented the information better:
