XDG_DATA_DIRS environment variable
flatpak install --reinstall
Note that the directories
'/var/lib/flatpak/exports/share'
'/home/user/.local/share/flatpak/exports/share'
are not in the search path set by the XDG_DATA_DIRS environment variable, so
applications installed by Flatpak may not appear on your desktop until the
session is restarted.
error: At least one REF must be specified
See 'flatpak install --help'
i restarted manjaro and the warning is still there even if nothing is installed
yes - and?
What is the perceived problem?
Isn’t it all there in the message?
it should go away with the restart
No it does not, why do you believe it?
… why would it?
It’s just an informational message - as far as I can see.
If it is more than that:
it’s why I asked
I don’t have flatpak (the command) installed
and, therefore, hopefully obviously, not any flatpak apps
so:
I can’t try and see what I get back when simply issuing:
perhaps I’d get the same response?
IDK
follow up:
the keword here seems to be:
also heed the next message:
you probably need to specify what you want to (re)install - is my guess
this is the exact same message I get to see when I issue that command
… with no flatpaks installed at all …
