Xbox controller only works with Proton 9 – not detected in newer versions
Hello!
I’m having a strange issue and I wanted to know if anyone else has experienced something similar. :pray:
I’m using kernel 6.12, a Microsoft Xbox wireless dongle, and an Xbox Series controller.
After installing xone-dkms and the dongle firmware from the AUR:
The controller is correctly detected, both wired and wirelessly through the dongle. Even in Steam Big Picture mode, I can navigate menus without any problems. However, no game detects the controller. The only thing that works is pressing the Xbox button to open Steam’s overlay.
After further testing, I discovered that the issue only happens when using Proton versions newer than 9 (e.g., Proton 10, Experimental, Hotfix). On Proton 9, everything works as expected.
Unfortunately, some of the games I play run significantly worse on Proton 9, so I’m trying to find a fix.
Additionally:
  • This issue also happens with xpad (when connecting the Xbox Series controller via USB), so it’s not exclusive to xone.
  • I tested a Switch Pro Controller via Bluetooth and a wired Xbox 360 controller, and both have the same issue.
  • I tried different kernels (6.6 and 6.15), but the behavior remains unchanged.
I opened a report on the Proton GitHub, but I’d love to hear if anyone else on Manjaro has found a workaround or solution.
Thanks in advance! :bowing_man:
Well, I never have (and never will) use an Xbox, which means I can’t offer anything overly constructive concerning this issue.
However, the following may be helpful to you and also to those who might wish to help; please provide system information as described (below).
I’m sure someone will help when they are able.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
Hi soundofthunder, thanks for the reply!
This issue happens with all the controllers I’ve tested, both when connected wirelessly using xone, and via USB (with both xone and xpad). The problem only occurs when launching games through Steam. For example, I tried Super Tux Kart outside of Steam, and the controller works perfectly.
So if you’re using a controller in Steam and it works for you, any details you can share would be really helpful — like your Proton version, kernel, how you connect the controller, or any other relevant configuration.
Thanks again!
 Kernel: 6.12.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
   root=UUID=2d07b322-8441-4d4e-8687-ea32809be0b3 rw rootflags=subvol=@
   quiet
   cryptdevice=UUID=15a7de2e-894f-4e4b-b008-6ff4e3679b87:luks-15a7de2e-894f-4e4b-b008-6ff4e3679b87
   root=/dev/mapper/luks-15a7de2e-894f-4e4b-b008-6ff4e3679b87 splash
   udev.log_priority=3
 Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
 Type: Desktop Mobo: Micro-Star model: MAG B550M MORTAR WIFI (MS-7C94) v: 1.0
   serial: <superuser required> uuid: <superuser required>
   UEFI: American Megatrends v: 1.52 date: 11/13/2020
 System RAM: total: 32 GiB available: 31.27 GiB used: 2.33 GiB (7.5%)
   (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
   min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
   part-no: KHX3200C16D4/8GX serial: <filter>
 Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
 Info: model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
   model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
   desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
 Speed (MHz): avg: 2218 min/max: 550/3411 boost: enabled scaling:
   driver: amd-pstate-epp governor: performance cores: 1: 2218 2: 2218 3: 2218
   4: 2218 5: 2218 6: 2218 7: 2218 8: 2218 9: 2218 10: 2218 11: 2218 12: 2218
   13: 2218 14: 2218 15: 2218 16: 2218 bogomips: 96034
   stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
   v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
   wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
   affected
 Device-1: NVIDIA GB203 [GeForce RTX 5070 Ti] vendor: ASUSTeK driver: nvidia
   v: 575.64.03 alternate: nouveau,nvidia_drm non-free: N/A
   status: unknown device ID pcie: gen: 4 speed: 16 GT/s lanes: 16 link-max:
   gen: 5 speed: 32 GT/s ports: active: none off: DP-1,HDMI-A-1
   empty: DP-2,DP-3,HDMI-A-2 bus-ID: 2b:00.0 chip-ID: 10de:2c05
   class-ID: 0300
 Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
   compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
   display-ID: :0 screens: 1
 Screen-1: 0 s-res: 2560x1440 s-dpi: 107 s-size: 608x342mm (23.94x13.46")
   s-diag: 698mm (27.46")
 Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary
   model: Gigabyte AORUS FI27Q-P serial: <filter> built: 2020 res: N/A dpi: 109
   gamma: 1.2 chroma: red: x: 0.682 y: 0.310 green: x: 0.278 y: 0.647 blue:
   x: 0.149 y: 0.067 white: x: 0.314 y: 0.329 size: 596x335mm (23.46x13.19")
   diag: 684mm (26.9") ratio: 16:9 modes: 2560x1440, 1920x1080, 1680x1050,
   1280x1024, 1440x900, 1280x960, 1152x864, 1280x720, 1024x768, 800x600,
   720x576, 720x480, 640x480
 EDID-Warnings: 1: parse_edid: unknown tag 112
 Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled
   model: LG (GoldStar) TV SSCR2 serial: <filter> built: 2022 res: N/A dpi: 61
   gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue:
   x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 1600x900mm (62.99x35.43")
   diag: 1836mm (72.3") ratio: 16:9 modes: 3840x2160, 4096x2160, 2560x1440,
   1920x1080, 1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
   720x480, 640x480
 EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
   unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
   unhandled CEA mode 117 5: parse_edid: unhandled CEA mode 102 6: parse_edid:
   unhandled CEA mode 101 7: parse_edid: unhandled CEA mode 91 8: parse_edid:
   unhandled CEA mode 90 9: parse_edid: unhandled CEA mode 93 10: parse_edid:
   unhandled CEA mode 94 11: parse_edid: unhandled CEA mode 95 12: parse_edid:
   unhandled CEA mode 98 13: parse_edid: unhandled CEA mode 99 14: parse_edid:
   unhandled CEA mode 100
 API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
   drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
   inactive: wayland,device-1
 API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.03
   glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 5070 Ti/PCIe/SSE2
   memory: 15.55 GiB
 API: Vulkan v: 1.4.321 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
   GeForce RTX 5070 Ti driver: nvidia v: 575.64.03 device-ID: 10de:2c05
   surfaces: N/A
 Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
   lanes: 16 link-max: gen: 5 speed: 32 GT/s bus-ID: 2b:00.1 chip-ID: 10de:22e9
   class-ID: 0403
 Device-2: Thesycon System & Consulting GmbH E2x2
   driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
   lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 152a:8752 class-ID: 0300
 Device-3: AudioQuest DragonFly Black v1.5
   driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
   lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 21b4:0083 class-ID: 0300
   serial: <filter>
 API: ALSA v: k6.12.39-1-MANJARO status: kernel-api with: aoss
 Server-1: JACK v: 1.9.22 status: off tools: jack_control,qjackctl
 Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
 Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
   speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2723 class-ID: 0280
 IF: wlo1 state: down mac: <filter>
 Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
   v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
 IF: enp42s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
 IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
 IP v4: <filter> scope: global
   speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 8087:0029
   class-ID: e001
 Device-1: luks-15a7de2e-894f-4e4b-b008-6ff4e3679b87 maj-min: 254:0
   type: LUKS dm: dm-0 size: 931.22 GiB
 Components:
 p-1: sdc2 maj-min: 8:34 size: 931.22 GiB
 Local Storage: total: 3.64 TiB used: 389.48 GiB (10.5%)
 ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 2TB
   size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
   tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
 ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
   tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
 ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB
   tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
 ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
   used: 389.48 GiB (41.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
   mapped: luks-15a7de2e-894f-4e4b-b008-6ff4e3679b87 label: N/A
   uuid: 2d07b322-8441-4d4e-8687-ea32809be0b3
   used: 776 KiB (0.3%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
   uuid: C41F-1E06
 ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
 ID-4: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
 ID-5: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
 ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
   label: N/A uuid: N/A
 ID-2: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: N/A
   uuid: CE82E80C82E7F73D
 ID-3: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
   uuid: C293-36CF
 ID-4: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
 ID-5: /dev/sdb3 maj-min: 8:19 size: 930.86 GiB fs: ntfs label: N/A
   uuid: E8C694AEC6947E8E
 ID-6: /dev/sdb4 maj-min: 8:20 size: 546 MiB fs: ntfs label: N/A
   uuid: 3A1CE3251CE2DAC1
 Device-1: 1-4:2 info: Logitech USB Receiver type: mouse,keyboard,HID
   lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c545 class-ID: 0300
 Device-2: 1-5:3 info: Logitech USB Receiver type: mouse,keyboard,HID
   lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
 Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
 Device-1: 1-7.1:6 info: NZXT USB Device type: HID
   lanes: 1 mode: 1.1 power: 100mA chip-ID: 1e71:2001 class-ID: 0300
   serial: <filter>
 Device-2: 1-7.4:8 info: NZXT Kraken X type: HID
   driver: nzxt-kraken2,usbhid interfaces: 1 rev: 2.0
   chip-ID: 1e71:170e class-ID: 0300 serial: <filter>
 Device-3: 1-8:5 info: Micro Star MYSTIC LIGHT type: HID
   lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c94 class-ID: 0300
   serial: <filter>
 Device-4: 1-9:7 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
   power: 100mA chip-ID: 8087:0029 class-ID: e001
 Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
 Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
 Device-1: 3-1:2 info: Thesycon System & Consulting GmbH E2x2
   type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
   rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
 Device-2: 3-4:3 info: AudioQuest DragonFly Black v1.5 type: audio,HID
   driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
   speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 40mA
   chip-ID: 21b4:0083 class-ID: 0300 serial: <filter>
 Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
 System Temperatures: cpu: 32.4 C mobo: N/A gpu: nvidia temp: 30 C
 Fan Speeds (rpm): fan-1: 0 gpu: nvidia fan: 0%
 Packages: 1464 pm: pacman pkgs: 1447 libs: 463 tools: pamac,yay pm: flatpak
   pkgs: 17
   1: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
   2: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
   3: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
 CPU top: 5 of 365
 1: cpu: 3.5% command: firefox pid: 1652 mem: 504.4 MiB (1.5%)
 2: cpu: 1.1% command: firefox pid: 1900 mem: 237.3 MiB (0.7%)
 3: cpu: 1.0% command: Xorg pid: 1016 mem: 85.9 MiB (0.2%)
 4: cpu: 1.0% command: kwin_x11 pid: 1157 mem: 174.4 MiB (0.5%)
 5: cpu: 0.9% command: firefox pid: 1897 mem: 233.2 MiB (0.7%)
 Memory top: 5 of 365
 1: mem: 504.4 MiB (1.5%) command: firefox pid: 1652 cpu: 3.5%
 2: mem: 387.8 MiB (1.2%) command: plasmashell pid: 1187 cpu: 0.4%
 3: mem: 249.6 MiB (0.7%) command: firefox pid: 1825 cpu: 0.7%
 4: mem: 237.3 MiB (0.7%) command: firefox pid: 1900 cpu: 1.1%
 5: mem: 233.2 MiB (0.7%) command: firefox pid: 1897 cpu: 0.9%
 Processes: 365 Power: uptime: 10m states: freeze,mem,disk suspend: deep
   suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
   tool: systemctl
 Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.38
Quick tip: Type @ and a modal will appear allowing you to select a user from a dropdown. This has the benefit of ensuring you don’t spell a user’s name incorrectly, and notifying them that they have been mentioned; without that, they may never know.
The only controller I use is a keyboard, unfortunately.
However, if any of those games (via Steam) are Windows based, then this recent note in Known Issues and Solutions may have some bearing on it; albeit not directly:
WINE with WoW64 is known to be not as performant as previous iterations using pure 32-bit. Perhaps it’s worth seeing what Valve might have to say about it.
Otherwise, I can only suggest searching forum topics in case anyone else has a similar issue, and wait for input from others (many gamers use Manjaro and might have encountered this already).
:wave:
Perhaps it could help. Please try to disable “Steam Input”. It can be done via Steam > Settings > Controller > Enable Steam Input for Xbox controllers toggle it to disable. After in the same window, scroll down to Non-Game Controller Layouts > Desktop Layout then Edit, and click in Disable Steam Input.
:vulcan_salute:
Hi @RuKsu! Thanks for the suggestion. Sadly, it didn’t work.
