Hi there! Unfortunately after the last 2 updates xbacklight is not working anymore on my manjaro openbox installation. The hotkeys are not working anymore, also. Is there anyone who can point me to the right direction in solving this issue? Thank you very much and keep the great work up!
Hello, @elia
I use Openbox but I’am not help here. For obtein a help, add a link to openbox after Laptop (below the title of your help demand) with the result of this:
Inxi --full --verbosity=7 --filter
Here is my configuration:
~ >>> inxi --full --verbosity=7 --filter
Kernel: 5.4.148-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce info: polybar, tint2 wm: Openbox 3.6.1 vt: 7
Type: Laptop System: SAMSUNG product: 350V5C/351V5C/3540VC/3440VC
v: P09ABE.012.CP serial: <filter> Chassis: type: 9 v: 0.1 serial: <filter>
Mobo: SAMSUNG model: NP350V5C-S09IT v: BOARD REVISION 00 serial: <filter>
UEFI: American Megatrends v: P09ABE date: 07/04/2013
ID-1: BAT1 charge: 9.0 Wh (100.0%) condition: 9.0/47.5 Wh (19.0%)
volts: 12.5 min: 10.8 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: Full cycles: 35
RAM: total: 15.53 GiB used: 2.07 GiB (13.3%)
Info: Quad Core model: Intel Core i7-3630QM bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L2: 6 MiB bogomips: 38333
Speed: 1197 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1197 4: 1197 5: 1197 6: 1197 7: 1197 8: 1197
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Thames [Radeon HD 7500M/7600M Series] vendor: Samsung Co
driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:6840 class-ID: 0300
Device-3: Silicon Motion WebCam SC-13HDL11939N type: USB driver: uvcvideo
bus-ID: 1-1.4:5 chip-ID: 2232:1029 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver:
loaded: ati,modesetting,radeon alternate: fbdev,vesa
resolution: 1640x922~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.2.2 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Samsung Co driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.4.148-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.37 running: no
vendor: Samsung Co driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: Samsung Co driver: ath9k v: kernel port: 2000 bus-ID: 03:00.0
chip-ID: 168c:0032 class-ID: 0280
Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-1.2:6 chip-ID: 0cf3:3004 class-ID: e001 serial: <filter>
Local Storage: total: 447.13 GiB used: 169.78 GiB (38.0%)
ID-1: /dev/sda vendor: Intenso model: SSD Sata III size: 447.13 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 8A0 scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SN-208DN rev: SC00
dev-links: cdrom
ID-1: / size: 213.35 GiB used: 169.78 GiB (79.6%) fs: ext4 dev: /dev/sda6
label: N/A uuid: 010f61ff-2d96-43f5-8289-aa0953bf6ec5
ID-2: /boot/efi size: 360.3 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/sda7 label: N/A uuid: B090-5B39
ID-1: swap-1 type: partition size: 18.07 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 label: N/A
uuid: f1116a1e-fbc5-4f97-8e50-085b39f39e24
ID-1: /dev/sda1 size: 300 MiB fs: ntfs label: Ripristino
uuid: 5692720E9271F2BB
ID-2: /dev/sda2 size: 100 MiB fs: vfat label: N/A uuid: 4A72-DAA9
ID-3: /dev/sda3 size: 128 MiB fs: <superuser required> label: N/A uuid: N/A
ID-4: /dev/sda4 size: 210.42 GiB fs: ntfs label: N/A uuid: EAE4865DE4862BBF
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-1.2:6 info: Qualcomm Atheros AR3012 Bluetooth 4.0
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0cf3:3004 class-ID: e001 serial: <filter>
Device-3: 1-1.4:5 info: Silicon Motion WebCam SC-13HDL11939N type: Video
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 2-3:2 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 60.0 C mobo: N/A gpu: radeon temp: 47.5 C
Processes: 263 Uptime: 1h 48m wakeups: 1 Init: systemd v: 249 Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1779 Shell: Zsh v: 5.8
running-in: termite inxi: 3.3.06
Thank you @Guytoo !!
Glad to see that you understand my english !
Look here: Backlight - ArchWiki and here : [SOLVED]How to enable brightness in Xfce, Openbox and i3 - ArcoLinux -D -B Forum
Maybe to help you
The backlight are controlled by XF86MonBrightnessUp and XF86MonBrightnessDown
When you press those keys a program called xbacklight is called with arguments to raise and lower the backlight. You can check the functionality by running the command in terminal.
xbacklight +10
and
xbacklight -10
If you do not have it you can install a power manager like xfce4-power-manager which provides handlers for setting the backlight.
I haven’t been using my laptop for a while so I haven’t noticed - but I will check.
Hi. It seems that xbacklight from xorg-xbacklight package might not work with your graphics drivers
Quote from Archwiki:
Note:
You can try xbacklight implementation from acpilight package. It is backward compatible and has some extra features. Maybe that will work.
Thank you all for the kind help!
xfce4-power-manager works well on my system tray, thanks!
I installed acpilight but it look like i should sudo it in order to work. I used to have a command configured in kde-connect to dim my display from my mobile phone. Is there a way to run xbacklight from “acplight” without sudo privileges?
Thank you all for your help!
Tested with Intel GPU (630) using modesetting driver and acpilight package
Steps to enable backlight keys using acpilight and XF86MonBrightness{Up|Down} on Openbox based systems.
Install the package acpilight.
Add yourself to the group video
sudo gpasswd -a $USER video
Restart your system - otherwise acpilight may not function as expected.
The following should not be necessary - provided as an alternative
Ensure your user is member of wheel group (the install user on Manjaro is member of the group)
Add the following rule to /etc/sudoers.d to allow xbacklight to be run without password
echo "%wheel ALL=(ALL) NOPASSWD:/usr/bin/xbacklight" | sudo tee -i /etc/sudoers.d/10-xbacklight
Then create an alias in .zshrc (openbox has used zsh for years) so unless you changed it this should do
echo 'alias xbacklight="sudo xbacklight"' >> ~/.zshrc
Log off and login to make sure it work and the alias is loaded. Now you can set backlight using the designated keys as defined in ~/.config/openbox/rc.xml.
Another way to use acpilight without sudo is to add the user to video group. The package has an udev rule so that members of video group can set brightness without sudo.
~ >>> cat /usr/lib/udev/rules.d/90-backlight.rules
# Allow video group to control backlight and leds
SUBSYSTEM=="backlight", ACTION=="add", \
RUN+="/bin/chgrp video /sys/class/backlight/%k/brightness", \
RUN+="/bin/chmod g+w /sys/class/backlight/%k/brightness"
SUBSYSTEM=="leds", ACTION=="add", KERNEL=="*::kbd_backlight", \
RUN+="/bin/chgrp video /sys/class/leds/%k/brightness", \
RUN+="/bin/chmod g+w /sys/class/leds/%k/brightness"
See also
thank you for that tip - I will check tomorrow.
Thank you! I followed your indications. I then used obkey and added “sudo” in front of the xbacklight Actions. Now it’s working, again many thanks!
