X360 controller dpad functions incorrectly on 6.15/6.16 kernels
Hi, it’s my post here, apologies if this was already asked - I couldn’t find a similar recent topic here.
I use a genuine wireless Xbox 360 controller with an original dongle. It works as intended on 6.13.12-2-MANJARO kernel; however, when I tried newer kernels (6.15.7-1-MANJARO, 6.16.0rc6-1-MANJARO), the dpad no longer works correctly. When I press right, it’s registered as if I pressed down; down functions as left, etc. Basically, it’s as if the dpad was rotated 90 degrees. This seems to happen in all games (Steam, Wine), as well as tools like gamepadtester. Other than that, the controller seems to function correctly - the analog sticks are unaffected. Reverting to 6.13 kernel fixes the dpad operation.
I use up-to-date Manjaro with KDE 6.3.6, KDE Frameworks 6.16.0, Qt 6.9.1. My PC runs Ryzen 5700X3D and Radeon 6700XT. Probably not relevant, but I compiled the kernels myself (I need to apply a patch for my display to work correctly).
Any ideas what might be wrong and how to fix it? Thanks!
Indeed it is relevant as it changes the context of you Support request entirely. Your topic has been moved to appropriate categories.
I note that a customised kernel might be outside the scope of Manjaro users who might otherwise wish to help.
Did you have any success with kernel 6.12 (LTS)?
Please provide system information as described (below).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
See if this helps: [pkg-upd] 6.15.9-2 (e0af7be3) · Commits · Packages / core / linux615 · GitLab
I don’t recall having this issue before, it definitely worked correctly on 6.12 back when I used it.
Here’s my system info for the completeness’ sake, although do note that I’ve already upgraded kernel to 6.16.0-5-MANJARO and the issue is now fixed:
  Kernel: 6.16.0-5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
    root=UUID=9a08e60e-4549-4c84-9cc7-6f2a0df31bc4 rw
    amdgpu.ppfeaturemask=0xfff7ffff udev.log_priority=3 debug
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
  Type: Desktop Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: F20d date: 09/02/2024
  System RAM: total: 32 GiB available: 31.24 GiB used: 6.38 GiB (20.4%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 3600 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: G.Skill part-no: F4-3600C16-16GVKC
    serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
    serial: N/A
  Info: model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
    desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 2984 min/max: 575/3001 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2984 2: 2984 3: 2984
    4: 2984 5: 2984 6: 2984 7: 2984 8: 2984 9: 2984 10: 2984 11: 2984 12: 2984
    13: 2984 14: 2984 15: 2984 16: 2984 bogomips: 95820
    stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
    XT/6750 XT / 6800M/6850M XT] vendor: Gigabyte driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: HDMI-A-1,HDMI-A-2,Writeback-1 bus-ID: 08:00.0 chip-ID: 1002:73df
    class-ID: 0300
  Device-2: ANYKA V380 FHD Camera driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.4:10
    chip-ID: 0380:2006 class-ID: 0301 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 7680x2520 display-ID: 0
  Monitor-1: DP-1 pos: bottom-l model: Samsung LC49G95T serial: <filter>
    built: 2020 res: mode: 5120x1440 hz: 240 scale: 100% (1) dpi: 82 gamma: 1.2
    chroma: red: x: 0.694 y: 0.294 green: x: 0.275 y: 0.659 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 1193x336mm (46.97x13.23")
    diag: 1239mm (48.8") modes: 5120x1440, 3840x1080, 2560x1440, 2560x1080,
    1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
    640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 90 2: parse_edid:
    unhandled CEA mode 92 3: parse_edid: unknown tag 112
  Monitor-2: DP-2 pos: top-right model: LG (GoldStar) ULTRAWIDE
    serial: <filter> built: 2015 res: mode: 2560x1080 hz: 75 scale: 100% (1)
    dpi: 81 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green: x: 0.306 y: 0.631
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: 2560x1080,
    1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
    navi22 LLVM 20.1.8 DRM 3.64 6.16.0-5-MANJARO) device-ID: 1002:73df
    memory: 11.72 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 5 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 25.1.6-arch1.1
    device-ID: 1002:73df surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 08:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.3:9
    chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
  Device-4: ANYKA V380 FHD Camera driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.16.0-5-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  Device-3: Microsoft Xbox 360 Wireless Adapter driver: xpad type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1:11
    chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: N/A
  Local Storage: total: 1.86 TiB used: 1.4 TiB (75.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 42AZS6AC temp: 46.9 C
    scheme: GPT
  ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 36.6 GiB (18.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 9a08e60e-4549-4c84-9cc7-6f2a0df31bc4
    used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 4626-76E3
  ID-3: /home raw-size: 1.63 TiB size: 1.61 TiB (98.37%)
    used: 1.36 TiB (84.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: N/A uuid: 6433402f-1e1e-4ad4-a0a9-790b610f0438
  ID-1: swap-1 type: partition size: 34.38 GiB used: 310.1 MiB (0.9%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: bccd5122-00cd-4382-8a37-eafc6ddd2b1d
  Device-1: 1-3:2 info: China Resource Semico Keyboard type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1a2c:2124 class-ID: 0300
  Device-2: 1-7:3 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-3: 1-8:4 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-4: 3-1:2 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 3-1.1:11 info: Microsoft Xbox 360 Wireless Adapter type: WiFi
    driver: xpad interfaces: 8 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 260mA chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
  Device-2: 3-1.3:9 info: C-Media Blue Snowball type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-3: 3-1.4:10 info: ANYKA V380 FHD Camera type: video,audio,mouse
    driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.0
  Device-4: 3-3:3 info: Kingston HyperX Alloy FPS Mechanical Gaming Keyboard
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 0951:16b7 class-ID: 0301
  Device-5: 3-4:6 info: Kingston HyperX Pulsefire FPS Pro
    type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 0951:16d7 class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 41.5 C mobo: 41.0 C gpu: amdgpu temp: 54.0 C
    mem: 52.0 C
  Fan Speeds (rpm): cpu: 1051 fan-2: 0 fan-3: 0 gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.12 gpu: amdgpu watts: 28.00
  Packages: pm: pacman pkgs: 1841 libs: 534 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    3: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    6: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    7: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    8: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 412
  1: cpu: 61.1% command: baloo_file_extractor pid: 1634
    mem: 321.8 MiB (1.0%)
  2: cpu: 36.3% command: firefox pid: 1814 mem: 766.5 MiB (2.3%)
  3: cpu: 11.3% command: firefox pid: 2506 mem: 438.9 MiB (1.3%)
  4: cpu: 10.9% command: kwin_wayland pid: 892 mem: 368.9 MiB (1.1%)
  5: cpu: 10.7% command: firefox pid: 2774 mem: 516.5 MiB (1.6%)
  Memory top: 5 of 412
  1: mem: 766.5 MiB (2.3%) command: firefox pid: 1814 cpu: 36.3%
  2: mem: 582.8 MiB (1.8%) command: plasmashell pid: 1160 cpu: 3.2%
  3: mem: 527.0 MiB (1.6%) command: thunderbird pid: 1755 cpu: 1.7%
  4: mem: 516.5 MiB (1.6%) command: firefox pid: 2774 cpu: 10.7%
  5: mem: 491.2 MiB (1.5%) command: firefox pid: 2194 cpu: 3.7%
  Processes: 412 Power: uptime: 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.0 running-in: konsole inxi: 3.3.38
I’ve upgraded the kernel to 6.16.0-5-MANJARO version and everything seems to be working correctly now, thanks :+1:
One interesting thing I’ve noticed when troubleshooting, is that this issue only affected my Xbox 360 controller. I’ve dug out my Xbox Series wireless controller, as well as a wired Logitech Dual Action controller, and they worked correctly on every kernel. I suppose this problem is isolated to the X360 gamepads and that’s why it went unnoticed? Weird.
Then, irrespective of the new found joy with kernel 6.16, at least you have kernel 6.12 (LTS) as a safe option to fall back to.
Another advantage of 6.12 (LTS) is that it’s expected EOL is December 2026, whereas most others (including 6.16) will likely be short-lived in comparison.
Good to know the issue is no more.
