Hello
i got the KDE minimal iso so maybe i’m missing codecs or packages.
i also had to choose VDPAU output in VLC for it not to crash upon opening a file when i first installed Manjaro.
edit:
seems to be solved by changing the Video output in VLC to “X11 video output (XCB)”
inxi -Fazy
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=2c155c12-a203-4f76-83f3-c5a47e892804 rw quiet splash
resume=UUID=906e149c-5c8b-4b11-91fd-041805a54c5a udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING Z790-PLUS WIFI D4 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0809
date: 01/06/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x119
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 801
24: 800 bogomips: 164088
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti GDDR6X] vendor: ASUSTeK
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:24c9 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-2 res: 2560x1440 dpi: 65024 size: 1x1mm (0.04x0.04")
diag: 1mm (0.06") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 535.113.01 device-ID: 10de:24c9
surfaces: xcb,xlib
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:125c
class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 931.51 GiB used: 181.95 GiB (19.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QJXD7 temp: 42.9 C
scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 181.95 GiB (20.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 393 Uptime: 5h 25m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.09 GiB used: 4.43 GiB (14.3%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1174 libs: 366 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
