Hi, I have compiled mesa drivers to have AVC/HEVC/VC-1 hardware acceleration. Unfortunately, after restarting the computer, the x11 session does not start. The login window appears, enter the password, enter. A black window appears for a moment and then flashes back to the login window.
yay -S mesa-git
Anything posted in your .xsession-errors? login in a tty and
cat .xsession-errors
After using the command
message appears: there is no file or folder with the given name
banjo
20 March 2023 22:51
4
Please read, we have unofficial repo for manjaro https://nonfree.eu/
GitHub - mesa-freeworld/mesa-nonfree
### install ###
# locally trust the ci key
sudo pacman-key --recv-keys B728DB23B92CB01B && \
sudo pacman-key --lsign-key B728DB23B92CB01B
## add the repo configuration:
sudo sh -c "curl -s https://nonfree.eu/$(pacman-mirrors -G)/ > /etc/pacman.d/mesa-nonfree.pre.repo.conf"
## include the repo configuration:
sudo sed -i '/^\[core\]/i \Include = /etc/pacman.d/mesa-nonfree.pre.repo.conf\n' /etc/pacman.conf
Could you tell me how to install it?
banjo
21 March 2023 06:31
6
I already told you. You see the commands in my post ? Three commands copy/paste in the terminal. This is the source , so you can verify .
Yes, I pasted it but nothing happened.
ο ξ° ο ~ ξ° LC_ALL=C sudo pacman-key --recv-keys B728DB23B92CB01B ξ² 1 β
[sudo] password for maciek:
gpg: key B728DB23B92CB01B: "Mesa Freeworld <info@manjaro.download>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
ο ξ° ο ~ ξ° LC_ALL=C sudo pacman-key --lsign-key B728DB23B92CB01B ξ² β ξ² 3s ο
-> Locally signed 1 keys.
==> Updating trust database...
gpg: next trustdb check due at 2023-07-07
ο ξ° ο ~ ξ° LC_ALL=C sudo sh -c "curl -s https://nonfree.eu/$(pacman-mirrors -G)/ > /etc/pacman.d/mesa-nonfree.pre.repo.conf"
ο ξ° ο ~ ξ° LC_ALL=C sudo sed -i '/^\[core\]/i \Include = /etc/pacman.d/mesa-nonfree.pre.repo.conf\n' /etc/pacman.conf
ο ξ° ο ~ ξ° ξ² β
banjo
21 March 2023 16:06
9
What do you expect to happen ? If this is done, refresh your mirrors/database with
sudo pacman-mirrors -f5 && sudo pacman -Syyu
Now, when you open pamac-manager (install/delete software) and clic Repositories , you should see mesa-nonfree on top of the list.
β¦from now on the βmesa-nonfree repoβ will be preferred, no compiling needed, these are pre-compiled packages.
Thank you for help. I am a newbie in linux. But with every problem I encounter, I learn something new.
If you would be so kind and tell me the simplest way to check if hardware acceleration is working
banjo
21 March 2023 19:24
12
Verify the settings for VA-API by running vainfo , which is provided by libva-utils
Useful for browser settings
Something must have gone wrong with the driver installation
ο ξ° ο ~ ξ° vainfo ξ² 127 β ξ² 26s ο
Trying display: wayland
Trying display: x11
vaInitialize failed with error code -1 (unknown libva error),exit
ο ξ° ο ~ ξ° LC_ALL=C inxi -v7azy ξ² β ξ² 4s ο
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=8ce5fb83-4fc9-4ac1-95e9-27e0b9f16360 rw quiet splash apparmor=1
security=apparmor resume=UUID=c37b4737-4448-4b91-b00a-0f818485b606
udev.log_priority=3
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: LENOVO product: 20238 v: Lenovo G510
serial: <superuser required> Chassis: type: 10 v: Lenovo G510
Mobo: LENOVO model: INVALID v: 31900058Std serial: <superuser required>
UEFI: LENOVO v: 79CN46WW(V3.05) date: 12/23/2013
RAM: total: 7.67 GiB used: 2.55 GiB (33.3%)
Info: model: Intel Core i5-4200M bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 800 4: 800
bogomips: 19963
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: HDMI-A-1 off: eDP-1 empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0416
class-ID: 0300
Device-2: AMD Jet PRO [Radeon R5 M230 / R7 M260DX Radeon 520/610 Mobile]
vendor: Lenovo driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6665 class-ID: 0380
temp: 45.0 C
Device-3: Syntek Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 3-4:2
chip-ID: 174f:148d class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: modesetting,radeon
alternate: fbdev,vesa dri: crocus,radeonsi gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Samsung built: 2011
res: 1366x768 hz: 60 dpi: 217 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 801mm (31.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
Monitor-2: eDP-1 note: disabled model: Samsung 0x4752 built: 2012
res: 1366x768 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct-render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Lenovo driver: wl v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 14e4:4365
class-ID: 0280
IF: wlp8s0 state: dormant mac: <filter>
Device-2: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo driver: alx
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 09:00.0
chip-ID: 1969:10a0 class-ID: 0200
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Foxconn BCM43142A0 Bluetooth module type: USB driver: btusb v: 0.8
bus-ID: 3-7:4 chip-ID: 105b:e065 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 24.58 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSDPR-CX400-256
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 10.86 GiB (11.1%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 8ce5fb83-4fc9-4ac1-95e9-27e0b9f16360
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: CBC7-F791
ID-3: /home raw-size: 121.97 GiB size: 119.49 GiB (97.97%)
used: 13.72 GiB (11.5%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 55f3191a-5393-4e39-8b92-60b843f868aa
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: c37b4737-4448-4b91-b00a-0f818485b606
ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ext4 label: home
uuid: a5bba619-ab0e-4260-a0ec-330974d42ce2
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-4:2 info: Syntek Lenovo EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:148d
Device-2: 3-6:3 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
Device-3: 3-7:4 info: Foxconn BCM43142A0 Bluetooth module type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 105b:e065
Device-4: 3-8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 58.0 C mobo: N/A gpu: radeon temp: 45.0 C
Processes: 218 Uptime: 7m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1315 libs: 338 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.25
banjo
21 March 2023 21:37
14
Ah, system info (should always be first, my fault).
Now we know you have intel cpu and amd graphics .
I am at work and only using mobile phone,
but maybe it is a libva problem .
See here:
rebuilt libva as per instructions, and video acceleration is back again. other than what is already mentioned you can follow the bug@;
