Hi, got a problem with mesa 21.2.4-1. My X-Server crashed immeidatly at startup with a segfault. Downgraded mesa (and libva-mesa-driver, lib32-mesa, lib32-libva-mesa-driver) to 21.2.3-1
and it worked again.
I’m on a Vmware VM with an i5-7500 CPU. Disabling/Enabling 3D-Acceleration for the VM didn’t change anything.
can you check on 21.2.3 via hwinfo --gfx which mesa driver is used. From a first glance on the release notes I don’t see any changes in that regard, but can be wrong …
Yeah, no problem
➜ hwinfo --gfx
26: PCI 0f.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: _+Pw.jBKePf3JQB5
SysFS ID: /devices/pci0000:00/0000:00:0f.0
SysFS BusID: 0000:00:0f.0
Hardware Class: graphics card
Model: "VMware VMWARE0405"
Vendor: pci 0x15ad "VMware, Inc."
Device: pci 0x0405 "VMWARE0405"
SubVendor: pci 0x15ad "VMware, Inc."
SubDevice: pci 0x0405
Driver: "vmwgfx"
Driver Modules: "vmwgfx"
I/O Ports: 0x2040-0x204f (rw)
Memory Range: 0xf0000000-0xf7ffffff (ro,non-prefetchable)
Memory Range: 0xfb800000-0xfbffffff (rw,non-prefetchable)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 16 (311075 events)
Module Alias: "pci:v000015ADd00000405sv000015ADsd00000405bc03sc00i00"
Driver Info #0:
XFree86 v4 Server Module: vmware
Config Status: cfg=new, avail=yes, need=no, active=unknown
Primary display adapter: #26
