Hi y’all,
Here’s a fun one: I get a frozen X server (can’t move mouse, sometimes can’t hit tty2) after logging in on gnome/gdm, but only when my hp 27 inch 1440p monitor is connected.
Setting the resolution of that monitor to 1080p means I can log in and there are no problems. Disconnecting that monitor, rebooting, logging in, and then connecting it works (at 1440p).
I’ve tried:
- Downgrading to
video-nvidia-470xx
(same issue)
[abrahamq@abraham-linux-woody ~]$ sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2024.05.03 false PCI
$ inxi -zv8
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
root=UUID=c32e8e2e-8ec8-4a4f-aa28-10670708e38b rw quiet splash apparmor=1 security=apparmor
resume=UUID=3528e895-dcd5-42d3-b7ad-2bcb7a3773a9 udev.log_priority=3
Console: pty pts/5 DM: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: TUF GAMING X870-PLUS WIFI v: Rev 1.xx serial: <filter> part-nu: SKU
uuid: 83a43c01-77dd-f812-224b-60cf847c99a9 UEFI: American Megatrends v: 0237 date: 07/22/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
System RAM: total: 96 GiB available: 91.95 GiB used: 2.11 GiB (2.3%)
Array-1: capacity: 192 GiB note: est. slots: 4 modules: 2 EC: None max-module-size: 48 GiB
note: est.
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered (unregistered)
size: 48 GiB speed: 4800 MT/s volts: curr: 1.1 min: 1.1 max: 1.1 width (bits): data: 64
total: 64 manufacturer: Corsair part-no: CMK96GX5M2B6000C30 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered (unregistered)
Slot: 0 type: PCIe gen: 5 status: in use length: long volts: 3.3 bus-ID: 00:01.1 children:
1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1 class-ID: 0403 type: audio
Slot: 1 type: PCIe gen: 4 status: available length: long volts: 3.3 bus-ID: 00:1f.7
Slot: N/A type: N/A status: in use info: M.2 length: long volts: 3.3 bus-ID: 00:01.2 children:
1: 02:00.0 class-ID: 0108 type: mass-storage
Slot: N/A type: N/A status: in use info: M.2 length: long volts: 3.3 bus-ID: 00:01.3 children:
1: 03:00.0 class-ID: 0108 type: mass-storage
Slot: N/A type: N/A status: available info: M.2 length: long volts: 3.3 bus-ID: 00:1f.7
Slot: N/A type: N/A status: in use info: M.2 length: short volts: 3.3 bus-ID: 05:07.0
Info: model: AMD Ryzen 9 9950X socket: AM5 bits: 64 type: MT MCP arch: N/A level: v4 note: check
family: 0x1A (26) model-id: 0x44 (68) stepping: 0 microcode: 0xB40401A
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2 smt: enabled cache:
L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB L3: 64 MiB
desc: 2x32 MiB
Speed (MHz): avg: 2981 min/max: 600/5752 boost: enabled base/boost: 4300/5750 scaling:
driver: amd-pstate-epp governor: powersave volts: 1.3 V ext-clock: 100 MHz cores: 1: 2981
2: 2981 3: 2981 4: 2981 5: 2981 6: 2981 7: 2981 8: 2981 9: 2981 10: 2981 11: 2981 12: 2981
13: 2981 14: 2981 15: 2981 16: 2981 17: 2981 18: 2981 19: 2981 20: 2981 21: 2981 22: 2981
23: 2981 24: 2981 25: 2981 26: 2981 27: 2981 28: 2981 29: 2981 30: 2981 31: 2981 32: 2981
bogomips: 274782
Flags: 3dnowprefetch abm adx aes amd_lbr_pmc_freeze amd_lbr_v2 aperfmperf apic arat avx avx2
avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vp2intersect avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb
cppc cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba mca
mce misalignsse mmx mmxext monitor movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional; STIBP: always-on;
$ cat /etc/X11/mhwd.d/nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 550.144.03
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
VendorName "NVIDIA Corporation"
ChipId 0x0
ChipRev 0x0
IRQ 0
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
dmesg when crash happens:
[ 0.000000] Linux version 6.12.11-1-MANJARO (linux612@manjaro) (gcc (GCC) 14.2.1 20240910, GNU ld (GNU Binutils) 2.43.1) #1 SMP PREEMPT_DYNAMIC Thu, 23 Jan 2025 20:29:02 +0000
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=c32e8e2e-8ec8-4a4f-aa28-10670708e38b rw quiet splash apparmor=1 security=apparmor resume=UUID=3528e895-dcd5-42d3-b7ad-2bcb7a3773a9 udev.log_priority=3
[ 0.000000] x86/split lock detection: #DB: warning on user-space bus_locks
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009afefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009aff000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a21ffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a220000-0x000000000affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b020fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000b021000-0x0000000068ef4fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000068ef5000-0x000000006f741fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006f742000-0x000000006f9bffff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000006f9c0000-0x00000000719bffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000719c0000-0x00000000783fefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000783ff000-0x0000000079ff6fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000079ff7000-0x0000000079ffbfff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079ffc000-0x0000000079ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007a000000-0x000000007bffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007d7f3000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f7000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000017fdd7ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000017fedc0000-0x00000018a01fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000fd00000000-0x000000ffffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] e820: update [mem 0x45bf0018-0x45c14657] usable ==> usable
[ 0.000000] e820: update [mem 0x45be1018-0x45bef057] usable ==> usable
[ 0.000000] e820: update [mem 0x45bd6018-0x45be0e57] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x0000000009afefff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000009aff000-0x0000000009ffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000a200000-0x000000000a21ffff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000000a220000-0x000000000affffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000b000000-0x000000000b020fff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000000b021000-0x0000000045bd6017] usable
[ 0.000000] reserve setup_data: [mem 0x0000000045bd6018-0x0000000045be0e57] usable
[ 0.000000] reserve setup_data: [mem 0x0000000045be0e58-0x0000000045be1017] usable
[ 0.000000] reserve setup_data: [mem 0x0000000045be1018-0x0000000045bef057] usable
[ 0.000000] reserve setup_data: [mem 0x0000000045bef058-0x0000000045bf0017] usable
[ 0.000000] reserve setup_data: [mem 0x0000000045bf0018-0x0000000045c14657] usable
[ 0.000000] reserve setup_data: [mem 0x0000000045c14658-0x0000000068ef4fff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000068ef5000-0x000000006f741fff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000006f742000-0x000000006f9bffff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x000000006f9c0000-0x00000000719bffff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000719c0000-0x00000000783fefff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000783ff000-0x0000000079ff6fff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000079ff7000-0x0000000079ffbfff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000079ffc000-0x0000000079ffffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000007a000000-0x000000007bffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000007d7f3000-0x000000007fffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000f7000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x00000017fdd7ffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000017fedc0000-0x00000018a01fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000fd00000000-0x000000ffffffffff] reserved
[ 0.000000] efi: EFI v2.9 by American Megatrends
[ 0.000000] efi: ACPI=0x6f9bf000 ACPI 2.0=0x6f9bf014 TPMFinalLog=0x71975000 SMBIOS=0x7788f000 SMBIOS 3.0=0x7788e000 MEMATTR=0x63869018 ESRT=0x6338a018 INITRD=0x51e4b898 RNG=0x6f9a4018 TPMEventLog=0x6f7b9018
[ 0.000000] random: crng init done
[ 0.000000] efi: Remove mem61: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
[ 0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
[ 0.000000] efi: Remove mem62: MMIO range=[0xf7000000-0xfedfffff] (126MB) from e820 map
[ 0.000000] e820: remove [mem 0xf7000000-0xfedfffff] reserved
[ 0.000000] efi: Not removing mem63: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem64: MMIO range=[0xfee01000-0xffffffff] (17MB) from e820 map
[ 0.000000] e820: remove [mem 0xfee01000-0xffffffff] reserved
[ 0.000000] efi: Remove mem66: MMIO range=[0x1880000000-0x18a01fffff] (514MB) from e820 map
[ 0.000000] e820: remove [mem 0x1880000000-0x18a01fffff] reserved
[ 0.000000] SMBIOS 3.6.0 present.
[ 0.000000] DMI: ASUS System Product Name/TUF GAMING X870-PLUS WIFI, BIOS 0237 07/22/2024
[ 0.000000] DMI: Memory slots populated: 2/4
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 4291.655 MHz processor
[ 0.000113] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000114] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000119] last_pfn = 0x17fdd80 max_arch_pfn = 0x400000000
[ 0.000124] MTRR map: 5 entries (3 fixed + 2 variable; max 20), built from 9 variable MTRRs
[ 0.000126] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000319] e820: update [mem 0x80000000-0xffffffff] usable ==> reserved
[ 0.000324] last_pfn = 0x7a000 max_arch_pfn = 0x400000000
[ 0.003034] esrt: Reserving ESRT space from 0x000000006338a018 to 0x000000006338a050.
[ 0.003039] e820: update [mem 0x6338a000-0x6338afff] usable ==> reserved
[ 0.003050] Using GB pages for direct mapping
[ 0.003247] Secure boot disabled
[ 0.003247] RAMDISK: [mem 0x46d1b000-0x4c9eefff]
[ 0.003264] ACPI: Early table checksum verification disabled
[ 0.003267] ACPI: RSDP 0x000000006F9BF014 000024 (v02 ALASKA)
[ 0.003269] ACPI: XSDT 0x000000006F9BE728 0000EC (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003274] ACPI: FACP 0x000000006F9B3000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.003277] ACPI: DSDT 0x000000006F98D000 0131DF (v120 ALASKA A M I 01072009 INTL 20230331)
[ 0.003279] ACPI: FACS 0x00000000719A5000 000040
[ 0.003280] ACPI: SSDT 0x000000006F9B5000 00816C (v02 AMD Splinter 00000002 MSFT 05000000)
[ 0.003281] ACPI: SSDT 0x000000006F9B4000 0003F1 (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.003282] ACPI: FIDT 0x000000006F9A5000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003284] ACPI: MCFG 0x000000006F9A3000 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.003285] ACPI: HPET 0x000000006F9A2000 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.003286] ACPI: FPDT 0x000000006F9A1000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003287] ACPI: VFCT 0x000000006F9A8000 00AE84 (v01 ALASKA A M I 00000001 AMD 33504F47)
[ 0.003288] ACPI: BGRT 0x000000006F9A7000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003289] ACPI: WPBT 0x000000006F7F4000 000040 (v01 ALASKA A M I 00000001 ASUS 00000001)
[ 0.003290] ACPI: SSDT 0x000000006F7EA000 009BAE (v02 AMD AMD CPU 00000001 AMD 00000001)
[ 0.003291] ACPI: SSDT 0x000000006F7DD000 00C682 (v02 AMD DISCUSB4 00000002 INTL 20230331)
[ 0.003292] ACPI: SSDT 0x000000006F7DB000 00169E (v02 AMD CPMDFIG2 00000001 INTL 20230331)
[ 0.003293] ACPI: SSDT 0x000000006F7D8000 002AA6 (v02 AMD CDFAAIG2 00000001 INTL 20230331)
[ 0.003294] ACPI: SSDT 0x000000006F7D7000 00078F (v02 AMD CPMDFDG1 00000001 INTL 20230331)
[ 0.003295] ACPI: SSDT 0x000000006F7CC000 00A62A (v02 AMD CPMCMN 00000001 INTL 20230331)
[ 0.003296] ACPI: SSDT 0x000000006F7C9000 002646 (v02 AMD AOD 00000001 INTL 20230331)
[ 0.003297] ACPI: TPM2 0x000000006F7C8000 00004C (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.003297] ACPI: WSMT 0x000000006F7C7000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003299] ACPI: APIC 0x000000006F7C6000 00015E (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.003299] ACPI: IVRS 0x000000006F7C5000 0000C8 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003300] ACPI: SSDT 0x000000006F7C4000 000500 (v02 AMD MEMTOOL0 00000002 INTL 20230331)
[ 0.003301] ACPI: SSDT 0x000000006F7C3000 0009E6 (v02 AMD CPMMSOSC 00000001 INTL 20230331)
[ 0.003302] ACPI: SSDT 0x000000006F7C2000 00047C (v02 AMD AMDWOV 00000001 INTL 20230331)
[ 0.003303] ACPI: SSDT 0x000000006F7C1000 00044E (v02 AMD AmdTable 00000001 INTL 20230331)
[ 0.003304] ACPI: Reserving FACP table memory at [mem 0x6f9b3000-0x6f9b3113]
[ 0.003305] ACPI: Reserving DSDT table memory at [mem 0x6f98d000-0x6f9a01de]
[ 0.003305] ACPI: Reserving FACS table memory at [mem 0x719a5000-0x719a503f]
[ 0.003305] ACPI: Reserving SSDT table memory at [mem 0x6f9b5000-0x6f9bd16b]
[ 0.003305] ACPI: Reserving SSDT table memory at [mem 0x6f9b4000-0x6f9b43f0]
[ 0.003306] ACPI: Reserving FIDT table memory at [mem 0x6f9a5000-0x6f9a509b]
[ 0.003306] ACPI: Reserving MCFG table memory at [mem 0x6f9a3000-0x6f9a303b]
[ 0.003306] ACPI: Reserving HPET table memory at [mem 0x6f9a2000-0x6f9a2037]
[ 0.003306] ACPI: Reserving FPDT table memory at [mem 0x6f9a1000-0x6f9a1043]
[ 0.003307] ACPI: Reserving VFCT table memory at [mem 0x6f9a8000-0x6f9b2e83]
[ 0.003307] ACPI: Reserving BGRT table memory at [mem 0x6f9a7000-0x6f9a7037]
[ 0.003307] ACPI: Reserving WPBT table memory at [mem 0x6f7f4000-0x6f7f403f]
[ 0.003307] ACPI: Reserving SSDT table memory at [mem 0x6f7ea000-0x6f7f3bad]
[ 0.003307] ACPI: Reserving SSDT table memory at [mem 0x6f7dd000-0x6f7e9681]
[ 0.003308] ACPI: Reserving SSDT table memory at [mem 0x6f7db000-0x6f7dc69d]
[ 0.003308] ACPI: Reserving SSDT table memory at [mem 0x6f7d8000-0x6f7daaa5]
[ 0.003308] ACPI: Reserving SSDT table memory at [mem 0x6f7d7000-0x6f7d778e]
[ 0.003308] ACPI: Reserving SSDT table memory at [mem 0x6f7cc000-0x6f7d6629]
[ 0.003309] ACPI: Reserving SSDT table memory at [mem 0x6f7c9000-0x6f7cb645]
[ 0.003309] ACPI: Reserving TPM2 table memory at [mem 0x6f7c8000-0x6f7c804b]
[ 0.003309] ACPI: Reserving WSMT table memory at [mem 0x6f7c7000-0x6f7c7027]
[ 0.003309] ACPI: Reserving APIC table memory at [mem 0x6f7c6000-0x6f7c615d]
[ 0.003309] ACPI: Reserving IVRS table memory at [mem 0x6f7c5000-0x6f7c50c7]
[ 0.003310] ACPI: Reserving SSDT table memory at [mem 0x6f7c4000-0x6f7c44ff]
[ 0.003310] ACPI: Reserving SSDT table memory at [mem 0x6f7c3000-0x6f7c39e5]
[ 0.003310] ACPI: Reserving SSDT table memory at [mem 0x6f7c2000-0x6f7c247b]
[ 0.003310] ACPI: Reserving SSDT table memory at [mem 0x6f7c1000-0x6f7c144d]
[ 0.003353] No NUMA configuration found
[ 0.003353] Faking a node at [mem 0x0000000000000000-0x00000017fdd7ffff]
[ 0.003357] NODE_DATA(0) allocated [mem 0x17fdd552c0-0x17fdd7ffff]
[ 0.003468] Zone ranges:
[ 0.003468] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.003469] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.003470] Normal [mem 0x0000000100000000-0x00000017fdd7ffff]
[ 0.003470] Device empty
[ 0.003470] Movable zone start for each node
[ 0.003471] Early memory node ranges
[ 0.003471] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.003472] node 0: [mem 0x0000000000100000-0x0000000009afefff]
[ 0.003472] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.003473] node 0: [mem 0x000000000a220000-0x000000000affffff]
[ 0.003473] node 0: [mem 0x000000000b021000-0x0000000068ef4fff]
[ 0.003473] node 0: [mem 0x00000000783ff000-0x0000000079ff6fff]
[ 0.003473] node 0: [mem 0x0000000079ffc000-0x0000000079ffffff]
[ 0.003473] node 0: [mem 0x0000000100000000-0x00000017fdd7ffff]
[ 0.003477] Initmem setup node 0 [mem 0x0000000000001000-0x00000017fdd7ffff]
[ 0.003482] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.003489] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.003538] On node 0, zone DMA32: 1281 pages in unavailable ranges
[ 0.003543] On node 0, zone DMA32: 32 pages in unavailable ranges
[ 0.004016] On node 0, zone DMA32: 33 pages in unavailable ranges
[ 0.004105] On node 0, zone DMA32: 29962 pages in unavailable ranges
[ 0.004105] On node 0, zone DMA32: 5 pages in unavailable ranges
[ 0.070097] On node 0, zone Normal: 24576 pages in unavailable ranges
[ 0.070125] On node 0, zone Normal: 8832 pages in unavailable ranges
[ 0.070937] ACPI: PM-Timer IO Port: 0x808
[ 0.070944] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.070955] IOAPIC[0]: apic_id 32, version 33, address 0xfec00000, GSI 0-23
[ 0.070958] IOAPIC[1]: apic_id 33, version 33, address 0xfec01000, GSI 24-55
[ 0.070959] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.070960] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.070963] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.070964] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.070971] e820: update [mem 0x61fb7000-0x62167fff] usable ==> reserved
[ 0.070983] CPU topo: Max. logical packages: 1
[ 0.070984] CPU topo: Max. logical dies: 2
[ 0.070984] CPU topo: Max. dies per package: 2
[ 0.070985] CPU topo: Max. threads per core: 2
[ 0.070986] CPU topo: Num. cores per package: 16
[ 0.070986] CPU topo: Num. threads per package: 32
[ 0.070987] CPU topo: Allowing 32 present CPUs plus 0 hotplug CPUs
[ 0.070998] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.070999] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.070999] PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
[ 0.071000] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a21ffff]
[ 0.071000] PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
[ 0.071001] PM: hibernation: Registered nosave memory: [mem 0x45bd6000-0x45bd6fff]
[ 0.071001] PM: hibernation: Registered nosave memory: [mem 0x45be0000-0x45be0fff]
[ 0.071002] PM: hibernation: Registered nosave memory: [mem 0x45be1000-0x45be1fff]
[ 0.071002] PM: hibernation: Registered nosave memory: [mem 0x45bef000-0x45beffff]
[ 0.071002] PM: hibernation: Registered nosave memory: [mem 0x45bf0000-0x45bf0fff]
[ 0.071003] PM: hibernation: Registered nosave memory: [mem 0x45c14000-0x45c14fff]
[ 0.071003] PM: hibernation: Registered nosave memory: [mem 0x61fb7000-0x62167fff]
[ 0.071004] PM: hibernation: Registered nosave memory: [mem 0x6338a000-0x6338afff]
[ 0.071004] PM: hibernation: Registered nosave memory: [mem 0x68ef5000-0x6f741fff]
[ 0.071004] PM: hibernation: Registered nosave memory: [mem 0x6f742000-0x6f9bffff]
[ 0.071005] PM: hibernation: Registered nosave memory: [mem 0x6f9c0000-0x719bffff]
[ 0.071005] PM: hibernation: Registered nosave memory: [mem 0x719c0000-0x783fefff]
[ 0.071005] PM: hibernation: Registered nosave memory: [mem 0x79ff7000-0x79ffbfff]
[ 0.071006] PM: hibernation: Registered nosave memory: [mem 0x7a000000-0x7bffffff]
[ 0.071006] PM: hibernation: Registered nosave memory: [mem 0x7c000000-0x7d7f2fff]
[ 0.071006] PM: hibernation: Registered nosave memory: [mem 0x7d7f3000-0x7fffffff]
[ 0.071006] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xfedfffff]
[ 0.071006] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.071007] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[ 0.071008] [mem 0x80000000-0xfedfffff] available for PCI devices
[ 0.071008] Booting paravirtualized kernel on bare hardware
[ 0.071010] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.073856] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:32 nr_cpu_ids:32 nr_node_ids:1
[ 0.074687] percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
[ 0.074692] pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1*2097152
[ 0.074694] pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07
[ 0.074695] pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15
[ 0.074697] pcpu-alloc: [0] 16 17 18 19 [0] 20 21 22 23
[ 0.074698] pcpu-alloc: [0] 24 25 26 27 [0] 28 29 30 31
[ 0.074706] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=c32e8e2e-8ec8-4a4f-aa28-10670708e38b rw quiet splash apparmor=1 security=apparmor resume=UUID=3528e895-dcd5-42d3-b7ad-2bcb7a3773a9 udev.log_priority=3
[ 0.074755] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64", will be passed to user space.
[ 0.074953] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.074954] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.074954] printk: log_buf_len min size: 131072 bytes
[ 0.075014] printk: log_buf_len: 262144 bytes
[ 0.075015] printk: early log buf free: 113776(86%)
[ 0.077454] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.078646] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.078755] Fallback order for Node 0: 0
[ 0.078760] Built 1 zonelists, mobility grouping on. Total pages: 24543950
[ 0.078760] Policy zone: Normal
[ 0.078854] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.078885] software IO TLB: area num 32.
[ 0.167650] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.167687] ftrace: allocating 51339 entries in 201 pages
[ 0.174835] ftrace: allocated 201 pages with 4 groups
[ 0.174898] Dynamic Preempt: full
[ 0.174957] rcu: Preemptible hierarchical RCU implementation.
[ 0.174958] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=32.
[ 0.174958] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.174959] Trampoline variant of Tasks RCU enabled.
[ 0.174959] Rude variant of Tasks RCU enabled.
[ 0.174960] Tracing variant of Tasks RCU enabled.
[ 0.174960] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.174961] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.174970] RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=32.
[ 0.174972] RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=32.
[ 0.174973] RCU Tasks Trace: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=32.
[ 0.176696] NR_IRQS: 524544, nr_irqs: 1224, preallocated irqs: 16
[ 0.176880] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.177027] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.177054] Console: colour dummy device 80x25
[ 0.177056] printk: legacy console [tty0] enabled
[ 0.177084] ACPI: Core revision 20240827
[ 0.177207] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.177219] APIC: Switch to symmetric I/O mode setup
[ 0.177600] AMD-Vi: Using global IVHD EFR:0x246577efa2254afa, EFR2:0x0
[ 0.178369] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.193891] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3ddc97eed09, max_idle_ns: 440795236367 ns
[ 0.193893] Calibrating delay loop (skipped), value calculated using timer frequency.. 8586.94 BogoMIPS (lpj=14305516)
[ 0.193906] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.193966] LVT offset 1 assigned for vector 0xf9
[ 0.194177] LVT offset 2 assigned for vector 0xf4
[ 0.194240] Last level iTLB entries: 4KB 64, 2MB 64, 4MB 32
[ 0.194241] Last level dTLB entries: 4KB 128, 2MB 128, 4MB 64, 1GB 0
[ 0.194242] process: using mwait in idle threads
[ 0.194244] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.194246] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[ 0.194246] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.194247] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.194248] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.194249] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.194254] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.194255] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.194255] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.194255] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[ 0.194256] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[ 0.194256] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[ 0.194257] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.194257] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[ 0.194258] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.194259] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[ 0.194259] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[ 0.194260] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[ 0.194260] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
[ 0.194261] x86/fpu: xstate_offset[11]: 2440, xstate_sizes[11]: 16
[ 0.194261] x86/fpu: Enabled xstate features 0xae7, context size is 2456 bytes, using 'compacted' format.
[ 0.209033] Freeing SMP alternatives memory: 40K
[ 0.209034] pid_max: default: 32768 minimum: 301
[ 0.209975] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
[ 0.210022] landlock: Up and running.
[ 0.210024] Yama: becoming mindful.
[ 0.210144] LSM support for eBPF active
[ 0.210174] AppArmor: AppArmor initialized
[ 0.210218] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.210260] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.318210] smpboot: CPU0: AMD Ryzen 9 9950X 16-Core Processor (family: 0x1a, model: 0x44, stepping: 0x0)
[ 0.318337] Performance Events: Fam17h+ 16-deep LBR, core perfctr, AMD PMU driver.
[ 0.318356] ... version: 2
[ 0.318357] ... bit width: 48
[ 0.318357] ... generic registers: 6
[ 0.318358] ... value mask: 0000ffffffffffff
[ 0.318358] ... max period: 00007fffffffffff
[ 0.318358] ... fixed-purpose events: 0
[ 0.318358] ... event mask: 000000000000003f
[ 0.318435] signal: max sigframe size: 3376
[ 0.318459] rcu: Hierarchical SRCU implementation.
[ 0.318460] rcu: Max phase no-delay instances is 1000.
[ 0.318491] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[ 0.318628] MCE: In-kernel MCE decoding enabled.
[ 0.318659] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.318812] smp: Bringing up secondary CPUs ...
[ 0.318873] smpboot: x86: Booting SMP configuration:
[ 0.318874] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16 #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31
[ 0.325275] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.325275] smp: Brought up 1 node, 32 CPUs
[ 0.325275] smpboot: Total of 32 processors activated (274775.32 BogoMIPS)
[ 0.327397] Memory: 96275704K/98175800K available (18432K kernel code, 2671K rwdata, 14316K rodata, 4268K init, 4024K bss, 1862120K reserved, 0K cma-reserved)
[ 0.327676] devtmpfs: initialized
[ 0.327676] x86/mm: Memory block size: 2048MB
[ 0.330731] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a21ffff] (131072 bytes)
[ 0.330731] ACPI: PM: Registering ACPI NVS region [mem 0x6f9c0000-0x719bffff] (33554432 bytes)
[ 0.330731] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.330731] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.330743] pinctrl core: initialized pinctrl subsystem
[ 0.330793] PM: RTC time: 18:19:32, date: 2025-02-10
[ 0.330990] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.331145] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.331259] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.331369] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.331373] audit: initializing netlink subsys (disabled)
[ 0.331376] audit: type=2000 audit(1739211572.000:1): state=initialized audit_enabled=0 res=1
[ 0.331376] thermal_sys: Registered thermal governor 'fair_share'
[ 0.331376] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.331376] thermal_sys: Registered thermal governor 'step_wise'
[ 0.331376] thermal_sys: Registered thermal governor 'user_space'
[ 0.331376] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.331376] cpuidle: using governor ladder
[ 0.331376] cpuidle: using governor menu
[ 0.331376] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.331376] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[ 0.331376] PCI: Using configuration type 1 for base access
[ 0.331376] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.331376] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.331376] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.331376] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.331376] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.331376] ACPI: Added _OSI(Module Device)
[ 0.331376] ACPI: Added _OSI(Processor Device)
[ 0.331376] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.331376] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.338371] ACPI: 14 ACPI AML tables successfully acquired and loaded
[ 0.359307] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.359309] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.359562] ACPI: EC: EC started
[ 0.359562] ACPI: EC: interrupt blocked
[ 0.359701] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.359703] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[ 0.359703] ACPI: Interpreter enabled
[ 0.359711] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.359712] ACPI: Using IOAPIC for interrupt routing
[ 0.392809] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.392810] PCI: Ignoring E820 reservations for host bridge windows
[ 0.392956] ACPI: Enabled 8 GPEs in block 00 to 1F
[ 0.394408] ACPI: \_SB_.PCI0.GPP0.M237: New power resource
[ 0.395562] ACPI: \_SB_.PCI0.GPP8.PWRS: New power resource
[ 0.400559] ACPI: \_SB_.PCI0.GPP8.U4UP.PWRS: New power resource
[ 0.401919] ACPI: \_SB_.PCI0.GPP8.U4UP.U4P0.PWRS: New power resource
[ 0.404395] ACPI: \_SB_.PCI0.GPP8.U4UP.U4P0.UP0D.PWRS: New power resource
[ 0.404672] ACPI: \_SB_.PCI0.GPP8.U4UP.U4P1.PWRS: New power resource
[ 0.407146] ACPI: \_SB_.PCI0.GPP8.U4UP.U4P1.UP1D.PWRS: New power resource
[ 0.407422] ACPI: \_SB_.PCI0.GPP8.U4UP.U4P2.PWRS: New power resource
[ 0.410559] ACPI: \_SB_.PCI0.GPP8.U4UP.U4P2.UXHC.PWRS: New power resource
[ 0.412615] ACPI: \_SB_.PCI0.GPP8.U4UP.U4P3.PWRS: New power resource
[ 0.415049] ACPI: \_SB_.PCI0.GPP8.U4UP.U4P3.UHI0.PWRS: New power resource
[ 0.420561] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.420561] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.420561] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.420561] PCI host bridge to bus 0000:00
[ 0.420561] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.420561] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.420561] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.420561] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.420561] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.420561] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.420561] pci_bus 0000:00: root bus resource [mem 0x1880000000-0xffffffffff window]
[ 0.420561] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.420561] pci 0000:00:00.0: [1022:14d8] type 00 class 0x060000 conventional PCI endpoint
[ 0.420561] pci 0000:00:00.2: [1022:14d9] type 00 class 0x080600 conventional PCI endpoint
[ 0.420561] pci 0000:00:01.0: [1022:14da] type 00 class 0x060000 conventional PCI endpoint
[ 0.420561] pci 0000:00:01.1: [1022:14db] type 01 class 0x060400 PCIe Root Port
[ 0.420561] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.420561] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 0.420561] pci 0000:00:01.1: bridge window [mem 0xdd000000-0xde0fffff]
[ 0.420561] pci 0000:00:01.1: bridge window [mem 0xf800000000-0xfc01ffffff 64bit pref]
[ 0.420561] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.420561] pci 0000:00:01.2: [1022:14db] type 01 class 0x060400 PCIe Root Port
[ 0.420561] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.420561] pci 0000:00:01.2: bridge window [mem 0xdf200000-0xdf2fffff]
[ 0.420561] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.420561] pci 0000:00:01.3: [1022:14db] type 01 class 0x060400 PCIe Root Port
[ 0.420561] pci 0000:00:01.3: PCI bridge to [bus 03]
[ 0.420561] pci 0000:00:01.3: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.420561] pci 0000:00:01.3: PME# supported from D0 D3hot D3cold
[ 0.420561] pci 0000:00:02.0: [1022:14da] type 00 class 0x060000 conventional PCI endpoint
[ 0.420561] pci 0000:00:02.1: [1022:14db] type 01 class 0x060400 PCIe Root Port
[ 0.420561] pci 0000:00:02.1: PCI bridge to [bus 04-0b]
[ 0.420561] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 0.420561] pci 0000:00:02.1: bridge window [mem 0xde200000-0xde8fffff]
[ 0.420561] pci 0000:00:02.1: enabling Extended Tags
[ 0.420561] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 0.420561] pci 0000:00:02.2: [1022:14db] type 01 class 0x060400 PCIe Root Port
[ 0.420561] pci 0000:00:02.2: PCI bridge to [bus 0c-73]
[ 0.420561] pci 0000:00:02.2: bridge window [io 0x7000-0xcfff]
[ 0.420561] pci 0000:00:02.2: bridge window [mem 0xac000000-0xdc7fffff]
[ 0.420561] pci 0000:00:02.2: bridge window [mem 0xb800000000-0xf7ffffffff 64bit pref]
[ 0.420561] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[ 0.420563] pci 0000:00:03.0: [1022:14da] type 00 class 0x060000 conventional PCI endpoint
[ 0.420603] pci 0000:00:04.0: [1022:14da] type 00 class 0x060000 conventional PCI endpoint
[ 0.420647] pci 0000:00:08.0: [1022:14da] type 00 class 0x060000 conventional PCI endpoint
[ 0.420684] pci 0000:00:08.1: [1022:14dd] type 01 class 0x060400 PCIe Root Port
[ 0.420694] pci 0000:00:08.1: PCI bridge to [bus 74]
[ 0.420696] pci 0000:00:08.1: bridge window [io 0xd000-0xdfff]
[ 0.420697] pci 0000:00:08.1: bridge window [mem 0xdea00000-0xdeffffff]
[ 0.420700] pci 0000:00:08.1: bridge window [mem 0xfc10000000-0xfc1fffffff 64bit pref]
[ 0.420704] pci 0000:00:08.1: enabling Extended Tags
[ 0.420726] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.420785] pci 0000:00:08.3: [1022:14dd] type 01 class 0x060400 PCIe Root Port
[ 0.420794] pci 0000:00:08.3: PCI bridge to [bus 75]
[ 0.420797] pci 0000:00:08.3: bridge window [mem 0xdf000000-0xdf0fffff]
[ 0.420803] pci 0000:00:08.3: enabling Extended Tags
[ 0.420826] pci 0000:00:08.3: PME# supported from D0 D3hot D3cold
[ 0.420889] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500 conventional PCI endpoint
[ 0.420955] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100 conventional PCI endpoint
[ 0.421033] pci 0000:00:18.0: [1022:14e0] type 00 class 0x060000 conventional PCI endpoint
[ 0.421050] pci 0000:00:18.1: [1022:14e1] type 00 class 0x060000 conventional PCI endpoint
[ 0.421066] pci 0000:00:18.2: [1022:14e2] type 00 class 0x060000 conventional PCI endpoint
[ 0.421084] pci 0000:00:18.3: [1022:14e3] type 00 class 0x060000 conventional PCI endpoint
[ 0.421100] pci 0000:00:18.4: [1022:14e4] type 00 class 0x060000 conventional PCI endpoint
[ 0.421116] pci 0000:00:18.5: [1022:14e5] type 00 class 0x060000 conventional PCI endpoint
[ 0.421132] pci 0000:00:18.6: [1022:14e6] type 00 class 0x060000 conventional PCI endpoint
[ 0.421148] pci 0000:00:18.7: [1022:14e7] type 00 class 0x060000 conventional PCI endpoint
[ 0.421209] pci 0000:01:00.0: [10de:2504] type 00 class 0x030000 PCIe Legacy Endpoint
[ 0.421216] pci 0000:01:00.0: BAR 0 [mem 0xdd000000-0xddffffff]
[ 0.421221] pci 0000:01:00.0: BAR 1 [mem 0xf800000000-0xfbffffffff 64bit pref]
[ 0.421227] pci 0000:01:00.0: BAR 3 [mem 0xfc00000000-0xfc01ffffff 64bit pref]
[ 0.421230] pci 0000:01:00.0: BAR 5 [io 0xf000-0xf07f]
[ 0.421234] pci 0000:01:00.0: ROM [mem 0xde000000-0xde07ffff pref]
[ 0.421270] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.421322] pci 0000:01:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:00:01.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.421387] pci 0000:01:00.1: [10de:228e] type 00 class 0x040300 PCIe Endpoint
[ 0.421393] pci 0000:01:00.1: BAR 0 [mem 0xde080000-0xde083fff]
[ 0.421487] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.421681] pci 0000:02:00.0: [144d:a80c] type 00 class 0x010802 PCIe Endpoint
[ 0.421693] pci 0000:02:00.0: BAR 0 [mem 0xdf200000-0xdf203fff 64bit]
[ 0.421879] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.422098] pci 0000:03:00.0: [144d:a80c] type 00 class 0x010802 PCIe Endpoint
[ 0.422109] pci 0000:03:00.0: BAR 0 [mem 0xdf100000-0xdf103fff 64bit]
[ 0.422285] pci 0000:00:01.3: PCI bridge to [bus 03]
[ 0.422336] pci 0000:04:00.0: [1022:43f4] type 01 class 0x060400 PCIe Switch Upstream Port
[ 0.422353] pci 0000:04:00.0: PCI bridge to [bus 05-0b]
[ 0.422357] pci 0000:04:00.0: bridge window [io 0xe000-0xefff]
[ 0.422358] pci 0000:04:00.0: bridge window [mem 0xde200000-0xde8fffff]
[ 0.422371] pci 0000:04:00.0: enabling Extended Tags
[ 0.422414] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 0.422542] pci 0000:00:02.1: PCI bridge to [bus 04-0b]
[ 0.422597] pci 0000:05:00.0: [1022:43f5] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.422615] pci 0000:05:00.0: PCI bridge to [bus 06]
[ 0.422633] pci 0000:05:00.0: enabling Extended Tags
[ 0.422678] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[ 0.422775] pci 0000:05:06.0: [1022:43f5] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.422792] pci 0000:05:06.0: PCI bridge to [bus 07]
[ 0.422796] pci 0000:05:06.0: bridge window [io 0xe000-0xefff]
[ 0.422797] pci 0000:05:06.0: bridge window [mem 0xde800000-0xde8fffff]
[ 0.422811] pci 0000:05:06.0: enabling Extended Tags
[ 0.422854] pci 0000:05:06.0: PME# supported from D0 D3hot D3cold
[ 0.422947] pci 0000:05:07.0: [1022:43f5] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.422965] pci 0000:05:07.0: PCI bridge to [bus 08]
[ 0.422969] pci 0000:05:07.0: bridge window [mem 0xde200000-0xde4fffff]
[ 0.422983] pci 0000:05:07.0: enabling Extended Tags
[ 0.423026] pci 0000:05:07.0: PME# supported from D0 D3hot D3cold
[ 0.423122] pci 0000:05:08.0: [1022:43f5] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.423139] pci 0000:05:08.0: PCI bridge to [bus 09]
[ 0.423157] pci 0000:05:08.0: enabling Extended Tags
[ 0.423202] pci 0000:05:08.0: PME# supported from D0 D3hot D3cold
[ 0.423298] pci 0000:05:0c.0: [1022:43f5] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.423315] pci 0000:05:0c.0: PCI bridge to [bus 0a]
[ 0.423319] pci 0000:05:0c.0: bridge window [mem 0xde700000-0xde7fffff]
[ 0.423332] pci 0000:05:0c.0: enabling Extended Tags
[ 0.423361] pci 0000:05:0c.0: PME# supported from D0 D3hot D3cold
[ 0.423426] pci 0000:05:0d.0: [1022:43f5] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.423443] pci 0000:05:0d.0: PCI bridge to [bus 0b]
[ 0.423447] pci 0000:05:0d.0: bridge window [mem 0xde600000-0xde6fffff]
[ 0.423460] pci 0000:05:0d.0: enabling Extended Tags
[ 0.423489] pci 0000:05:0d.0: PME# supported from D0 D3hot D3cold
[ 0.423547] pci 0000:04:00.0: PCI bridge to [bus 05-0b]
[ 0.423574] pci 0000:05:00.0: PCI bridge to [bus 06]
[ 0.423622] pci 0000:07:00.0: [10ec:8125] type 00 class 0x020000 PCIe Endpoint
[ 0.423639] pci 0000:07:00.0: BAR 0 [io 0xe000-0xe0ff]
[ 0.423664] pci 0000:07:00.0: BAR 2 [mem 0xde800000-0xde80ffff 64bit]
[ 0.423679] pci 0000:07:00.0: BAR 4 [mem 0xde810000-0xde813fff 64bit]
[ 0.423795] pci 0000:07:00.0: supports D1 D2
[ 0.423795] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.424018] pci 0000:05:06.0: PCI bridge to [bus 07]
[ 0.424064] pci 0000:08:00.0: [14c3:7925] type 00 class 0x028000 PCIe Endpoint
[ 0.424086] pci 0000:08:00.0: BAR 0 [mem 0xde200000-0xde3fffff 64bit]
[ 0.424099] pci 0000:08:00.0: BAR 2 [mem 0xde400000-0xde407fff 64bit]
[ 0.424129] pci 0000:08:00.0: enabling Extended Tags
[ 0.424208] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold
[ 0.424385] pci 0000:05:07.0: PCI bridge to [bus 08]
[ 0.424413] pci 0000:05:08.0: PCI bridge to [bus 09]
[ 0.424449] pci 0000:0a:00.0: [1022:43fc] type 00 class 0x0c0330 PCIe Legacy Endpoint
[ 0.424460] pci 0000:0a:00.0: BAR 0 [mem 0xde700000-0xde707fff 64bit]
[ 0.424485] pci 0000:0a:00.0: enabling Extended Tags
[ 0.424517] pci 0000:0a:00.0: PME# supported from D0 D3hot D3cold
[ 0.424595] pci 0000:05:0c.0: PCI bridge to [bus 0a]
[ 0.424630] pci 0000:0b:00.0: [1022:43f6] type 00 class 0x010601 PCIe Legacy Endpoint
[ 0.424660] pci 0000:0b:00.0: BAR 5 [mem 0xde680000-0xde6803ff]
[ 0.424664] pci 0000:0b:00.0: ROM [mem 0xde600000-0xde67ffff pref]
[ 0.424669] pci 0000:0b:00.0: enabling Extended Tags
[ 0.424694] pci 0000:0b:00.0: PME# supported from D0 D3hot D3cold
[ 0.424746] pci 0000:05:0d.0: PCI bridge to [bus 0b]
[ 0.424824] pci 0000:0c:00.0: [1b21:2421] type 01 class 0x060400 PCIe Switch Upstream Port
[ 0.424841] pci 0000:0c:00.0: PCI bridge to [bus 0d-73]
[ 0.424844] pci 0000:0c:00.0: bridge window [io 0x7000-0xcfff]
[ 0.424846] pci 0000:0c:00.0: bridge window [mem 0xac000000-0xdc7fffff]
[ 0.424852] pci 0000:0c:00.0: bridge window [mem 0xb800000000-0xf7ffffffff 64bit pref]
[ 0.424903] pci 0000:0c:00.0: PME# supported from D0 D3hot D3cold
[ 0.425027] pci 0000:00:02.2: PCI bridge to [bus 0c-73]
[ 0.425068] pci 0000:0d:00.0: [1b21:2423] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.425085] pci 0000:0d:00.0: PCI bridge to [bus 12-41]
[ 0.425089] pci 0000:0d:00.0: bridge window [io 0x7000-0x9fff]
[ 0.425090] pci 0000:0d:00.0: bridge window [mem 0xac000000-0xc3ffffff]
[ 0.425096] pci 0000:0d:00.0: bridge window [mem 0xb800000000-0xd7ffffffff 64bit pref]
[ 0.425187] pci 0000:0d:00.0: PME# supported from D0 D3hot D3cold
[ 0.425482] pci 0000:0d:01.0: [1b21:2423] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.425499] pci 0000:0d:01.0: PCI bridge to [bus 42-71]
[ 0.425502] pci 0000:0d:01.0: bridge window [io 0xa000-0xcfff]
[ 0.425505] pci 0000:0d:01.0: bridge window [mem 0xc4000000-0xdbffffff]
[ 0.425510] pci 0000:0d:01.0: bridge window [mem 0xd800000000-0xf7ffffffff 64bit pref]
[ 0.425595] pci 0000:0d:01.0: PME# supported from D0 D3hot D3cold
[ 0.425878] pci 0000:0d:02.0: [1b21:2423] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.425895] pci 0000:0d:02.0: PCI bridge to [bus 72]
[ 0.425899] pci 0000:0d:02.0: bridge window [mem 0xdc000000-0xdc3fffff]
[ 0.425947] pci 0000:0d:02.0: PME# supported from D0 D3hot D3cold
[ 0.426021] pci 0000:0d:03.0: [1b21:2423] type 01 class 0x060400 PCIe Switch Downstream Port
[ 0.426038] pci 0000:0d:03.0: PCI bridge to [bus 73]
[ 0.426042] pci 0000:0d:03.0: bridge window [mem 0xdc400000-0xdc7fffff]
[ 0.426090] pci 0000:0d:03.0: PME# supported from D0 D3hot D3cold
[ 0.426172] pci 0000:0c:00.0: PCI bridge to [bus 0d-73]
[ 0.426209] pci 0000:0d:00.0: PCI bridge to [bus 12-41]
[ 0.426246] pci 0000:0d:01.0: PCI bridge to [bus 42-71]
[ 0.426284] pci 0000:72:00.0: [1b21:2426] type 00 class 0x0c0330 PCIe Legacy Endpoint
[ 0.426295] pci 0000:72:00.0: BAR 0 [mem 0xdc000000-0xdc007fff 64bit]
[ 0.426353] pci 0000:72:00.0: PME# supported from D0 D3hot D3cold
[ 0.426425] pci 0000:0d:02.0: PCI bridge to [bus 72]
[ 0.426471] pci 0000:73:00.0: [1b21:2425] type 00 class 0x0c0340 PCIe Legacy Endpoint
[ 0.426480] pci 0000:73:00.0: BAR 0 [mem 0xdc400000-0xdc43ffff 64bit]
[ 0.426486] pci 0000:73:00.0: BAR 2 [mem 0xdc440000-0xdc44ffff 64bit]
[ 0.426532] pci 0000:73:00.0: PME# supported from D0 D3hot D3cold
[ 0.426682] pci 0000:0d:03.0: PCI bridge to [bus 73]
[ 0.426748] pci 0000:74:00.0: [1002:13c0] type 00 class 0x030000 PCIe Legacy Endpoint
[ 0.426755] pci 0000:74:00.0: BAR 0 [mem 0xfc10000000-0xfc1fffffff 64bit pref]
[ 0.426759] pci 0000:74:00.0: BAR 2 [mem 0xdea00000-0xdebfffff 64bit pref]
[ 0.426762] pci 0000:74:00.0: BAR 4 [io 0xd000-0xd0ff]
[ 0.426765] pci 0000:74:00.0: BAR 5 [mem 0xdef00000-0xdef7ffff]
[ 0.426770] pci 0000:74:00.0: enabling Extended Tags
[ 0.426802] pci 0000:74:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.426864] pci 0000:74:00.1: [1002:1640] type 00 class 0x040300 PCIe Legacy Endpoint
[ 0.426869] pci 0000:74:00.1: BAR 0 [mem 0xdef88000-0xdef8bfff]
[ 0.426882] pci 0000:74:00.1: enabling Extended Tags
[ 0.426902] pci 0000:74:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.426938] pci 0000:74:00.2: [1022:1649] type 00 class 0x108000 PCIe Endpoint
[ 0.426967] pci 0000:74:00.2: BAR 2 [mem 0xdee00000-0xdeefffff]
[ 0.426973] pci 0000:74:00.2: BAR 5 [mem 0xdef8c000-0xdef8dfff]
[ 0.426977] pci 0000:74:00.2: enabling Extended Tags
[ 0.427027] pci 0000:74:00.3: [1022:15b6] type 00 class 0x0c0330 PCIe Endpoint
[ 0.427034] pci 0000:74:00.3: BAR 0 [mem 0xded00000-0xdedfffff 64bit]
[ 0.427049] pci 0000:74:00.3: enabling Extended Tags
[ 0.427070] pci 0000:74:00.3: PME# supported from D0 D3hot D3cold
[ 0.427107] pci 0000:74:00.4: [1022:15b7] type 00 class 0x0c0330 PCIe Endpoint
[ 0.427113] pci 0000:74:00.4: BAR 0 [mem 0xdec00000-0xdecfffff 64bit]
[ 0.427128] pci 0000:74:00.4: enabling Extended Tags
[ 0.427149] pci 0000:74:00.4: PME# supported from D0 D3hot D3cold
[ 0.427186] pci 0000:74:00.6: [1022:15e3] type 00 class 0x040300 PCIe Endpoint
[ 0.427190] pci 0000:74:00.6: BAR 0 [mem 0xdef80000-0xdef87fff]
[ 0.427203] pci 0000:74:00.6: enabling Extended Tags
[ 0.427222] pci 0000:74:00.6: PME# supported from D0 D3hot D3cold
[ 0.427361] pci 0000:00:08.1: PCI bridge to [bus 74]
[ 0.427383] pci 0000:75:00.0: [1022:15b8] type 00 class 0x0c0330 PCIe Endpoint
[ 0.427394] pci 0000:75:00.0: BAR 0 [mem 0xdf000000-0xdf0fffff 64bit]
[ 0.427415] pci 0000:75:00.0: enabling Extended Tags
[ 0.427441] pci 0000:75:00.0: PME# supported from D0 D3hot D3cold
[ 0.427492] pci 0000:00:08.3: PCI bridge to [bus 75]
[ 0.443548] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.443567] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.443583] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.443602] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.443620] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.443634] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.443648] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.443662] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.444182] ACPI: EC: interrupt unblocked
[ 0.444183] ACPI: EC: event unblocked
[ 0.444187] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.444188] ACPI: EC: GPE=0x4
[ 0.444188] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 0.444189] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.444222] iommu: Default domain type: Translated
[ 0.444222] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.444222] SCSI subsystem initialized
[ 0.444222] libata version 3.00 loaded.
[ 0.444222] ACPI: bus type USB registered
[ 0.444222] usbcore: registered new interface driver usbfs
[ 0.444222] usbcore: registered new interface driver hub
[ 0.444222] usbcore: registered new device driver usb
[ 0.445858] EDAC MC: Ver: 3.0.0
[ 0.447244] efivars: Registered efivars operations
[ 0.447329] NetLabel: Initializing
[ 0.447330] NetLabel: domain hash size = 128
[ 0.447331] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.447337] NetLabel: unlabeled traffic allowed by default
[ 0.447338] mctp: management component transport protocol core
[ 0.447339] NET: Registered PF_MCTP protocol family
[ 0.447342] PCI: Using ACPI for IRQ routing
[ 0.452243] PCI: pci_cache_line_size set to 64 bytes
[ 0.452948] e820: reserve RAM buffer [mem 0x09aff000-0x0bffffff]
[ 0.452949] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.452950] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[ 0.452950] e820: reserve RAM buffer [mem 0x45bd6018-0x47ffffff]
[ 0.452950] e820: reserve RAM buffer [mem 0x45be1018-0x47ffffff]
[ 0.452951] e820: reserve RAM buffer [mem 0x45bf0018-0x47ffffff]
[ 0.452951] e820: reserve RAM buffer [mem 0x61fb7000-0x63ffffff]
[ 0.452951] e820: reserve RAM buffer [mem 0x6338a000-0x63ffffff]
[ 0.452952] e820: reserve RAM buffer [mem 0x68ef5000-0x6bffffff]
[ 0.452952] e820: reserve RAM buffer [mem 0x79ff7000-0x7bffffff]
[ 0.452952] e820: reserve RAM buffer [mem 0x7a000000-0x7bffffff]
[ 0.452952] e820: reserve RAM buffer [mem 0x17fdd80000-0x17ffffffff]
[ 0.453912] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.453912] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.453912] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.453912] pci 0000:74:00.0: vgaarb: bridge control possible
[ 0.453912] pci 0000:74:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.453912] vgaarb: loaded
[ 0.453914] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.453916] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.454942] clocksource: Switched to clocksource tsc-early
[ 0.454944] VFS: Disk quotas dquot_6.6.0
[ 0.454944] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.454944] AppArmor: AppArmor Filesystem Enabled
[ 0.454944] pnp: PnP ACPI init
[ 0.454944] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.454944] system 00:01: [mem 0x1800000000-0x187fffffff window] has been reserved
[ 0.454944] system 00:03: [io 0x0290-0x029f] has been reserved
[ 0.454944] system 00:03: [io 0x0200-0x023f] has been reserved
[ 0.454944] pnp 00:04: [dma 0 disabled]
[ 0.454944] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.454944] system 00:05: [io 0x040b] has been reserved
[ 0.454944] system 00:05: [io 0x04d6] has been reserved
[ 0.454944] system 00:05: [io 0x0c00-0x0c01] has been reserved
[ 0.454944] system 00:05: [io 0x0c14] has been reserved
[ 0.454944] system 00:05: [io 0x0c50-0x0c51] has been reserved
[ 0.454944] system 00:05: [io 0x0c52] has been reserved
[ 0.454944] system 00:05: [io 0x0c6c] has been reserved
[ 0.454944] system 00:05: [io 0x0c6f] has been reserved
[ 0.454944] system 00:05: [io 0x0cd8-0x0cdf] has been reserved
[ 0.454944] system 00:05: [io 0x0800-0x089f] has been reserved
[ 0.454944] system 00:05: [io 0x0b00-0x0b0f] has been reserved
[ 0.454944] system 00:05: [io 0x0b20-0x0b3f] has been reserved
[ 0.454944] system 00:05: [io 0x0900-0x090f] has been reserved
[ 0.454944] system 00:05: [io 0x0910-0x091f] has been reserved
[ 0.454944] system 00:05: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.454944] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.454944] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.454944] system 00:05: [mem 0xfeb00000-0xfeb00fff] has been reserved
[ 0.454944] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.455854] pnp: PnP ACPI: found 6 devices
[ 0.461182] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.461204] NET: Registered PF_INET protocol family
[ 0.461281] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.467254] tcp_listen_portaddr_hash hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.467288] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.467451] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.467650] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.467697] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.467799] MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
[ 0.467920] UDP hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.468072] UDP-Lite hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.468174] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.468178] NET: Registered PF_XDP protocol family
[ 0.468186] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.468189] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 0.468191] pci 0000:00:01.1: bridge window [mem 0xdd000000-0xde0fffff]
[ 0.468192] pci 0000:00:01.1: bridge window [mem 0xf800000000-0xfc01ffffff 64bit pref]
[ 0.468202] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.468204] pci 0000:00:01.2: bridge window [mem 0xdf200000-0xdf2fffff]
[ 0.468214] pci 0000:00:01.3: PCI bridge to [bus 03]
[ 0.468216] pci 0000:00:01.3: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.468226] pci 0000:05:00.0: PCI bridge to [bus 06]
[ 0.468236] pci 0000:05:06.0: PCI bridge to [bus 07]
[ 0.468237] pci 0000:05:06.0: bridge window [io 0xe000-0xefff]
[ 0.468240] pci 0000:05:06.0: bridge window [mem 0xde800000-0xde8fffff]
[ 0.468244] pci 0000:05:07.0: PCI bridge to [bus 08]
[ 0.468246] pci 0000:05:07.0: bridge window [mem 0xde200000-0xde4fffff]
[ 0.468250] pci 0000:05:08.0: PCI bridge to [bus 09]
[ 0.468256] pci 0000:05:0c.0: PCI bridge to [bus 0a]
[ 0.468258] pci 0000:05:0c.0: bridge window [mem 0xde700000-0xde7fffff]
[ 0.468262] pci 0000:05:0d.0: PCI bridge to [bus 0b]
[ 0.468264] pci 0000:05:0d.0: bridge window [mem 0xde600000-0xde6fffff]
[ 0.468269] pci 0000:04:00.0: PCI bridge to [bus 05-0b]
[ 0.468270] pci 0000:04:00.0: bridge window [io 0xe000-0xefff]
[ 0.468272] pci 0000:04:00.0: bridge window [mem 0xde200000-0xde8fffff]
[ 0.468276] pci 0000:00:02.1: PCI bridge to [bus 04-0b]
[ 0.468276] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 0.468278] pci 0000:00:02.1: bridge window [mem 0xde200000-0xde8fffff]
[ 0.468288] pci 0000:0d:00.0: PCI bridge to [bus 12-41]
[ 0.468289] pci 0000:0d:00.0: bridge window [io 0x7000-0x9fff]
[ 0.468292] pci 0000:0d:00.0: bridge window [mem 0xac000000-0xc3ffffff]
[ 0.468293] pci 0000:0d:00.0: bridge window [mem 0xb800000000-0xd7ffffffff 64bit pref]
[ 0.468296] pci 0000:0d:01.0: PCI bridge to [bus 42-71]
[ 0.468297] pci 0000:0d:01.0: bridge window [io 0xa000-0xcfff]
[ 0.468299] pci 0000:0d:01.0: bridge window [mem 0xc4000000-0xdbffffff]
[ 0.468301] pci 0000:0d:01.0: bridge window [mem 0xd800000000-0xf7ffffffff 64bit pref]
[ 0.468304] pci 0000:0d:02.0: PCI bridge to [bus 72]
[ 0.468306] pci 0000:0d:02.0: bridge window [mem 0xdc000000-0xdc3fffff]
[ 0.468311] pci 0000:0d:03.0: PCI bridge to [bus 73]
[ 0.468313] pci 0000:0d:03.0: bridge window [mem 0xdc400000-0xdc7fffff]
[ 0.468317] pci 0000:0c:00.0: PCI bridge to [bus 0d-73]
[ 0.468318] pci 0000:0c:00.0: bridge window [io 0x7000-0xcfff]
[ 0.468320] pci 0000:0c:00.0: bridge window [mem 0xac000000-0xdc7fffff]
[ 0.468322] pci 0000:0c:00.0: bridge window [mem 0xb800000000-0xf7ffffffff 64bit pref]
[ 0.468325] pci 0000:00:02.2: PCI bridge to [bus 0c-73]
[ 0.468326] pci 0000:00:02.2: bridge window [io 0x7000-0xcfff]
[ 0.468327] pci 0000:00:02.2: bridge window [mem 0xac000000-0xdc7fffff]
[ 0.468328] pci 0000:00:02.2: bridge window [mem 0xb800000000-0xf7ffffffff 64bit pref]
[ 0.468338] pci 0000:00:08.1: PCI bridge to [bus 74]
[ 0.468342] pci 0000:00:08.1: bridge window [io 0xd000-0xdfff]
[ 0.468344] pci 0000:00:08.1: bridge window [mem 0xdea00000-0xdeffffff]
[ 0.468345] pci 0000:00:08.1: bridge window [mem 0xfc10000000-0xfc1fffffff 64bit pref]
[ 0.468347] pci 0000:00:08.3: PCI bridge to [bus 75]
[ 0.468348] pci 0000:00:08.3: bridge window [mem 0xdf000000-0xdf0fffff]
[ 0.468351] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.468352] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.468352] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.468352] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.468353] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.468353] pci_bus 0000:00: resource 9 [mem 0x80000000-0xdfffffff window]
[ 0.468354] pci_bus 0000:00: resource 10 [mem 0x1880000000-0xffffffffff window]
[ 0.468354] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 0.468355] pci_bus 0000:01: resource 1 [mem 0xdd000000-0xde0fffff]
[ 0.468355] pci_bus 0000:01: resource 2 [mem 0xf800000000-0xfc01ffffff 64bit pref]
[ 0.468355] pci_bus 0000:02: resource 1 [mem 0xdf200000-0xdf2fffff]
[ 0.468356] pci_bus 0000:03: resource 1 [mem 0xdf100000-0xdf1fffff]
[ 0.468356] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 0.468357] pci_bus 0000:04: resource 1 [mem 0xde200000-0xde8fffff]
[ 0.468357] pci_bus 0000:05: resource 0 [io 0xe000-0xefff]
[ 0.468357] pci_bus 0000:05: resource 1 [mem 0xde200000-0xde8fffff]
[ 0.468358] pci_bus 0000:07: resource 0 [io 0xe000-0xefff]
[ 0.468358] pci_bus 0000:07: resource 1 [mem 0xde800000-0xde8fffff]
[ 0.468358] pci_bus 0000:08: resource 1 [mem 0xde200000-0xde4fffff]
[ 0.468359] pci_bus 0000:0a: resource 1 [mem 0xde700000-0xde7fffff]
[ 0.468359] pci_bus 0000:0b: resource 1 [mem 0xde600000-0xde6fffff]
[ 0.468359] pci_bus 0000:0c: resource 0 [io 0x7000-0xcfff]
[ 0.468360] pci_bus 0000:0c: resource 1 [mem 0xac000000-0xdc7fffff]
[ 0.468360] pci_bus 0000:0c: resource 2 [mem 0xb800000000-0xf7ffffffff 64bit pref]
[ 0.468361] pci_bus 0000:0d: resource 0 [io 0x7000-0xcfff]
[ 0.468361] pci_bus 0000:0d: resource 1 [mem 0xac000000-0xdc7fffff]
[ 0.468361] pci_bus 0000:0d: resource 2 [mem 0xb800000000-0xf7ffffffff 64bit pref]
[ 0.468362] pci_bus 0000:12: resource 0 [io 0x7000-0x9fff]
[ 0.468362] pci_bus 0000:12: resource 1 [mem 0xac000000-0xc3ffffff]
[ 0.468362] pci_bus 0000:12: resource 2 [mem 0xb800000000-0xd7ffffffff 64bit pref]
[ 0.468363] pci_bus 0000:42: resource 0 [io 0xa000-0xcfff]
[ 0.468363] pci_bus 0000:42: resource 1 [mem 0xc4000000-0xdbffffff]
[ 0.468363] pci_bus 0000:42: resource 2 [mem 0xd800000000-0xf7ffffffff 64bit pref]
[ 0.468364] pci_bus 0000:72: resource 1 [mem 0xdc000000-0xdc3fffff]
[ 0.468364] pci_bus 0000:73: resource 1 [mem 0xdc400000-0xdc7fffff]
[ 0.468365] pci_bus 0000:74: resource 0 [io 0xd000-0xdfff]
[ 0.468365] pci_bus 0000:74: resource 1 [mem 0xdea00000-0xdeffffff]
[ 0.468365] pci_bus 0000:74: resource 2 [mem 0xfc10000000-0xfc1fffffff 64bit pref]
[ 0.468366] pci_bus 0000:75: resource 1 [mem 0xdf000000-0xdf0fffff]
[ 0.468418] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 0.468430] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.468929] pci 0000:74:00.1: D0 power state depends on 0000:74:00.0
[ 0.469047] PCI: CLS 64 bytes, default 64
[ 0.469062] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.469089] pci 0000:00:01.0: Adding to iommu group 0
[ 0.469090] Trying to unpack rootfs image as initramfs...
[ 0.469095] pci 0000:00:01.1: Adding to iommu group 1
[ 0.469101] pci 0000:00:01.2: Adding to iommu group 2
[ 0.469107] pci 0000:00:01.3: Adding to iommu group 3
[ 0.469117] pci 0000:00:02.0: Adding to iommu group 4
[ 0.469123] pci 0000:00:02.1: Adding to iommu group 5
[ 0.469129] pci 0000:00:02.2: Adding to iommu group 6
[ 0.469137] pci 0000:00:03.0: Adding to iommu group 7
[ 0.469145] pci 0000:00:04.0: Adding to iommu group 8
[ 0.469155] pci 0000:00:08.0: Adding to iommu group 9
[ 0.469160] pci 0000:00:08.1: Adding to iommu group 10
[ 0.469166] pci 0000:00:08.3: Adding to iommu group 11
[ 0.469177] pci 0000:00:14.0: Adding to iommu group 12
[ 0.469183] pci 0000:00:14.3: Adding to iommu group 12
[ 0.469210] pci 0000:00:18.0: Adding to iommu group 13
[ 0.469216] pci 0000:00:18.1: Adding to iommu group 13
[ 0.469222] pci 0000:00:18.2: Adding to iommu group 13
[ 0.469228] pci 0000:00:18.3: Adding to iommu group 13
[ 0.469234] pci 0000:00:18.4: Adding to iommu group 13
[ 0.469240] pci 0000:00:18.5: Adding to iommu group 13
[ 0.469246] pci 0000:00:18.6: Adding to iommu group 13
[ 0.469252] pci 0000:00:18.7: Adding to iommu group 13
[ 0.469263] pci 0000:01:00.0: Adding to iommu group 14
[ 0.469270] pci 0000:01:00.1: Adding to iommu group 14
[ 0.469277] pci 0000:02:00.0: Adding to iommu group 15
[ 0.469283] pci 0000:03:00.0: Adding to iommu group 16
[ 0.469290] pci 0000:04:00.0: Adding to iommu group 17
[ 0.469298] pci 0000:05:00.0: Adding to iommu group 18
[ 0.469305] pci 0000:05:06.0: Adding to iommu group 19
[ 0.469311] pci 0000:05:07.0: Adding to iommu group 20
[ 0.469318] pci 0000:05:08.0: Adding to iommu group 21
[ 0.469325] pci 0000:05:0c.0: Adding to iommu group 22
[ 0.469331] pci 0000:05:0d.0: Adding to iommu group 23
[ 0.469334] pci 0000:07:00.0: Adding to iommu group 19
[ 0.469336] pci 0000:08:00.0: Adding to iommu group 20
[ 0.469338] pci 0000:0a:00.0: Adding to iommu group 22
[ 0.469341] pci 0000:0b:00.0: Adding to iommu group 23
[ 0.469348] pci 0000:0c:00.0: Adding to iommu group 24
[ 0.469355] pci 0000:0d:00.0: Adding to iommu group 25
[ 0.469361] pci 0000:0d:01.0: Adding to iommu group 26
[ 0.469367] pci 0000:0d:02.0: Adding to iommu group 27
[ 0.469374] pci 0000:0d:03.0: Adding to iommu group 28
[ 0.469377] pci 0000:72:00.0: Adding to iommu group 27
[ 0.469381] pci 0000:73:00.0: Adding to iommu group 28
[ 0.469401] pci 0000:74:00.0: Adding to iommu group 29
[ 0.469407] pci 0000:74:00.1: Adding to iommu group 30
[ 0.469414] pci 0000:74:00.2: Adding to iommu group 31
[ 0.469421] pci 0000:74:00.3: Adding to iommu group 32
[ 0.469427] pci 0000:74:00.4: Adding to iommu group 33
[ 0.469433] pci 0000:74:00.6: Adding to iommu group 34
[ 0.469438] pci 0000:75:00.0: Adding to iommu group 35
[ 0.472012] AMD-Vi: Extended features (0x246577efa2254afa, 0x0): PPR NX GT [5] IA GA PC GA_vAPIC
[ 0.472018] AMD-Vi: Interrupt remapping enabled
[ 0.553820] AMD-Vi: Virtual APIC enabled
[ 0.553828] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.553831] software IO TLB: mapped [mem 0x0000000064358000-0x0000000068358000] (64MB)
[ 0.553857] LVT offset 0 assigned for vector 0x400
[ 0.557105] perf: AMD IBS detected (0x00081bff)
[ 0.557110] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.568979] Freeing initrd memory: 95056K
[ 0.576188] Initialise system trusted keyrings
[ 0.576194] Key type blacklist registered
[ 0.576217] workingset: timestamp_bits=36 max_order=25 bucket_order=0
[ 0.576277] fuse: init (API version 7.41)
[ 0.576366] integrity: Platform Keyring initialized
[ 0.576367] integrity: Machine keyring initialized
[ 0.580135] Key type asymmetric registered
[ 0.580136] Asymmetric key parser 'x509' registered
[ 0.580147] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.580177] io scheduler mq-deadline registered
[ 0.580178] io scheduler kyber registered
[ 0.580181] io scheduler bfq registered
[ 0.581255] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.581342] pcieport 0000:00:01.1: PME: Signaling with IRQ 28
[ 0.581442] pcieport 0000:00:01.2: PME: Signaling with IRQ 29
[ 0.581532] pcieport 0000:00:01.3: PME: Signaling with IRQ 30
[ 0.581622] pcieport 0000:00:02.1: PME: Signaling with IRQ 31
[ 0.581710] pcieport 0000:00:02.2: PME: Signaling with IRQ 32
[ 0.581807] pcieport 0000:00:08.1: PME: Signaling with IRQ 33
[ 0.581880] pcieport 0000:00:08.3: PME: Signaling with IRQ 34
[ 0.582528] pcieport 0000:0d:00.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.582733] pcieport 0000:0d:01.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.582936] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.583025] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.583035] ACPI: button: Power Button [PWRB]
[ 0.583046] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.583679] ACPI: button: Power Button [PWRF]
[ 0.583963] Monitor-Mwait will be used to enter C-1 state
[ 0.585758] Estimated ratio of average max frequency by base frequency (times 1024): 1197
[ 0.585886] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.586166] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.587246] Non-volatile memory driver v1.3
[ 0.587247] Linux agpgart interface v0.103
[ 0.687503] tpm_crb MSFT0101:00: Disabling hwrng
[ 0.687877] ACPI: bus type drm_connector registered
[ 0.689730] ahci 0000:0b:00.0: version 3.0
[ 0.689843] ahci 0000:0b:00.0: SSS flag set, parallel bus scan disabled
[ 0.689867] ahci 0000:0b:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[ 0.689869] ahci 0000:0b:00.0: 4/6 ports implemented (port mask 0xf)
[ 0.689870] ahci 0000:0b:00.0: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 0.690066] scsi host0: ahci
[ 0.690130] scsi host1: ahci
[ 0.690170] scsi host2: ahci
[ 0.690207] scsi host3: ahci
[ 0.690244] scsi host4: ahci
[ 0.690284] scsi host5: ahci
[ 0.690299] ata1: SATA max UDMA/133 abar m1024@0xde680000 port 0xde680100 irq 43 lpm-pol 3
[ 0.690299] ata2: SATA max UDMA/133 abar m1024@0xde680000 port 0xde680180 irq 43 lpm-pol 3
[ 0.690301] ata3: SATA max UDMA/133 abar m1024@0xde680000 port 0xde680200 irq 43 lpm-pol 3
[ 0.690301] ata4: SATA max UDMA/133 abar m1024@0xde680000 port 0xde680280 irq 43 lpm-pol 3
[ 0.690302] ata5: DUMMY
[ 0.690302] ata6: DUMMY
[ 0.690376] xhci_hcd 0000:0a:00.0: xHCI Host Controller
[ 0.690379] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 1
[ 0.746366] xhci_hcd 0000:0a:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000010
[ 0.746576] xhci_hcd 0000:0a:00.0: xHCI Host Controller
[ 0.746576] xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 2
[ 0.746577] xhci_hcd 0000:0a:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 0.747351] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 0.747352] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.747353] usb usb1: Product: xHCI Host Controller
[ 0.747353] usb usb1: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.747354] usb usb1: SerialNumber: 0000:0a:00.0
[ 0.747452] hub 1-0:1.0: USB hub found
[ 0.747469] hub 1-0:1.0: 12 ports detected
[ 0.748282] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.748289] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 0.748289] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.748290] usb usb2: Product: xHCI Host Controller
[ 0.748290] usb usb2: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.748291] usb usb2: SerialNumber: 0000:0a:00.0
[ 0.748352] hub 2-0:1.0: USB hub found
[ 0.748357] hub 2-0:1.0: 5 ports detected
[ 0.748716] xhci_hcd 0000:72:00.0: xHCI Host Controller
[ 0.748717] xhci_hcd 0000:72:00.0: new USB bus registered, assigned bus number 3
[ 0.751531] xhci_hcd 0000:72:00.0: hcc params 0x0200ef81 hci version 0x120 quirks 0x0000000200000010
[ 0.752570] xhci_hcd 0000:72:00.0: xHCI Host Controller
[ 0.752571] xhci_hcd 0000:72:00.0: new USB bus registered, assigned bus number 4
[ 0.752571] xhci_hcd 0000:72:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 0.752590] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 0.752591] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.752591] usb usb3: Product: xHCI Host Controller
[ 0.752592] usb usb3: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.752592] usb usb3: SerialNumber: 0000:72:00.0
[ 0.752656] hub 3-0:1.0: USB hub found
[ 0.752839] hub 3-0:1.0: 2 ports detected
[ 0.753639] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.753645] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 0.753645] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.753646] usb usb4: Product: xHCI Host Controller
[ 0.753646] usb usb4: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.753646] usb usb4: SerialNumber: 0000:72:00.0
[ 0.753715] hub 4-0:1.0: USB hub found
[ 0.753898] hub 4-0:1.0: 2 ports detected
[ 0.754512] xhci_hcd 0000:74:00.3: xHCI Host Controller
[ 0.754513] xhci_hcd 0000:74:00.3: new USB bus registered, assigned bus number 5
[ 0.754860] xhci_hcd 0000:74:00.3: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000010
[ 0.755034] xhci_hcd 0000:74:00.3: xHCI Host Controller
[ 0.755034] xhci_hcd 0000:74:00.3: new USB bus registered, assigned bus number 6
[ 0.755035] xhci_hcd 0000:74:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.755044] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 0.755045] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.755045] usb usb5: Product: xHCI Host Controller
[ 0.755046] usb usb5: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.755046] usb usb5: SerialNumber: 0000:74:00.3
[ 0.755110] hub 5-0:1.0: USB hub found
[ 0.755112] hub 5-0:1.0: 2 ports detected
[ 0.755242] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.755248] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 0.755249] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.755249] usb usb6: Product: xHCI Host Controller
[ 0.755249] usb usb6: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.755250] usb usb6: SerialNumber: 0000:74:00.3
[ 0.755309] hub 6-0:1.0: USB hub found
[ 0.755313] hub 6-0:1.0: 2 ports detected
[ 0.755464] xhci_hcd 0000:74:00.4: xHCI Host Controller
[ 0.755467] xhci_hcd 0000:74:00.4: new USB bus registered, assigned bus number 7
[ 0.755806] xhci_hcd 0000:74:00.4: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000010
[ 0.755972] xhci_hcd 0000:74:00.4: xHCI Host Controller
[ 0.755973] xhci_hcd 0000:74:00.4: new USB bus registered, assigned bus number 8
[ 0.755974] xhci_hcd 0000:74:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.755983] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 0.755983] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.755984] usb usb7: Product: xHCI Host Controller
[ 0.755984] usb usb7: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.755985] usb usb7: SerialNumber: 0000:74:00.4
[ 0.756047] hub 7-0:1.0: USB hub found
[ 0.756053] hub 7-0:1.0: 2 ports detected
[ 0.756193] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.756199] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 0.756199] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.756200] usb usb8: Product: xHCI Host Controller
[ 0.756200] usb usb8: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.756200] usb usb8: SerialNumber: 0000:74:00.4
[ 0.756260] hub 8-0:1.0: USB hub found
[ 0.756266] hub 8-0:1.0: 2 ports detected
[ 0.756415] xhci_hcd 0000:75:00.0: xHCI Host Controller
[ 0.756416] xhci_hcd 0000:75:00.0: new USB bus registered, assigned bus number 9
[ 0.757678] xhci_hcd 0000:75:00.0: USB3 root hub has no ports
[ 0.757679] xhci_hcd 0000:75:00.0: hcc params 0x0110ffc5 hci version 0x120 quirks 0x0000000200000010
[ 0.757865] xhci_hcd 0000:75:00.0: xHCI Host Controller
[ 0.757866] xhci_hcd 0000:75:00.0: new USB bus registered, assigned bus number 10
[ 0.757867] xhci_hcd 0000:75:00.0: Host supports USB 3.0 SuperSpeed
[ 0.757880] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 0.757880] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.757880] usb usb9: Product: xHCI Host Controller
[ 0.757881] usb usb9: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.757882] usb usb9: SerialNumber: 0000:75:00.0
[ 0.757942] hub 9-0:1.0: USB hub found
[ 0.757948] hub 9-0:1.0: 1 port detected
[ 0.758029] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.758035] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 0.758036] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.758036] usb usb10: Product: xHCI Host Controller
[ 0.758036] usb usb10: Manufacturer: Linux 6.12.11-1-MANJARO xhci-hcd
[ 0.758037] usb usb10: SerialNumber: 0000:75:00.0
[ 0.758063] hub 10-0:1.0: USB hub found
[ 0.758064] hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ 0.758081] usbcore: registered new interface driver usbserial_generic
[ 0.758083] usbserial: USB Serial support registered for generic
[ 0.758130] rtc_cmos 00:02: RTC can wake from S4
[ 0.758267] rtc_cmos 00:02: registered as rtc0
[ 0.758297] rtc_cmos 00:02: setting system clock to 2025-02-10T18:19:33 UTC (1739211573)
[ 0.758312] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram
[ 0.759972] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[ 0.759973] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[ 0.761014] fbcon: Deferring console take-over
[ 0.761015] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 0.761071] hid: raw HID events driver (C) Jiri Kosina
[ 0.761128] drop_monitor: Initializing network drop monitor service
[ 0.761220] NET: Registered PF_INET6 protocol family
[ 0.764009] Segment Routing with IPv6
[ 0.764010] RPL Segment Routing with IPv6
[ 0.764013] In-situ OAM (IOAM) with IPv6
[ 0.764023] NET: Registered PF_PACKET protocol family
[ 0.765079] microcode: Current revision: 0x0b40401a
[ 0.765561] resctrl: L3 allocation detected
[ 0.765562] resctrl: MB allocation detected
[ 0.765563] resctrl: SMBA allocation detected
[ 0.765563] resctrl: L3 monitoring detected
[ 0.765579] IPI shorthand broadcast: enabled
[ 0.766122] sched_clock: Marking stable (765233703, 324810)->(799753579, -34195066)
[ 0.766239] registered taskstats version 1
[ 0.766695] Loading compiled-in X.509 certificates
[ 0.767962] Loaded X.509 cert 'Build time autogenerated kernel key: c8ae6e92d968a906ac76ab9266a4d8d6ba36a1d4'
[ 0.768511] Demotion targets for Node 0: null
[ 0.768602] Key type .fscrypt registered
[ 0.768603] Key type fscrypt-provisioning registered
[ 0.768630] AppArmor: AppArmor sha256 policy hashing enabled
[ 0.768682] integrity: Loading X.509 certificate: UEFI:db
[ 0.769893] integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
[ 0.769893] integrity: Loading X.509 certificate: UEFI:db
[ 0.769948] integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
[ 0.769949] integrity: Loading X.509 certificate: UEFI:db
[ 0.769955] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 0.769956] integrity: Loading X.509 certificate: UEFI:db
[ 0.769961] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 0.769961] integrity: Loading X.509 certificate: UEFI:db
[ 0.770017] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 0.770017] integrity: Loading X.509 certificate: UEFI:db
[ 0.770021] integrity: Loaded X.509 cert 'Microsoft UEFI CA 2023: 81aa6b3244c935bce0d6628af39827421e32497d'
[ 0.770021] integrity: Loading X.509 certificate: UEFI:db
[ 0.770026] integrity: Loaded X.509 cert 'Microsoft Corporation: Windows UEFI CA 2023: aefc5fbbbe055d8f8daa585473499417ab5a5272'
[ 0.770412] PM: Magic number: 13:905:341
[ 0.770422] usb usb1-port12: hash matches
[ 0.770481] acpi ACPI0007:03: hash matches
[ 0.771710] RAS: Correctable Errors collector initialized.
[ 0.997047] usb 7-1: new full-speed USB device number 2 using xhci_hcd
[ 0.998501] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.057601] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[ 1.152995] usb 7-1: New USB device found, idVendor=29ea, idProduct=0360, bcdDevice= 1.00
[ 1.153003] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.153005] usb 7-1: Product: Kinesis Adv360
[ 1.153006] usb 7-1: Manufacturer: Kinesis
[ 1.153007] usb 7-1: SerialNumber: 360555127546
[ 1.295167] usb 1-3: New USB device found, idVendor=174c, idProduct=2074, bcdDevice= 0.01
[ 1.295172] usb 1-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 1.295173] usb 1-3: Product: ASM107x
[ 1.295173] usb 1-3: Manufacturer: ASUS TEK.
[ 1.303722] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.304241] hub 1-3:1.0: USB hub found
[ 1.309275] hub 1-3:1.0: 4 ports detected
[ 1.388661] usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd
[ 1.440289] usb 2-3: New USB device found, idVendor=174c, idProduct=3074, bcdDevice= 0.01
[ 1.440298] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 1.440299] usb 2-3: Product: ASM107x
[ 1.440300] usb 2-3: Manufacturer: ASUS TEK.
[ 1.451812] hub 2-3:1.0: USB hub found
[ 1.455994] hub 2-3:1.0: 4 ports detected
[ 1.567390] tsc: Refined TSC clocksource calibration: 4291.917 MHz
[ 1.567401] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3ddd907869e, max_idle_ns: 440795398455 ns
[ 1.567447] clocksource: Switched to clocksource tsc
[ 1.600670] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[ 1.614808] ata3: SATA link down (SStatus 0 SControl 330)
[ 1.924287] ata4: SATA link down (SStatus 0 SControl 330)
[ 1.924466] clk: Disabling unused clocks
[ 1.924473] PM: genpd: Disabling unused power domains
[ 1.925198] Freeing unused decrypted memory: 2028K
[ 1.925457] Freeing unused kernel image (initmem) memory: 4268K
[ 1.925468] Write protecting the kernel read-only data: 32768k
[ 1.925680] Freeing unused kernel image (rodata/data gap) memory: 20K
[ 1.943623] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.943627] rodata_test: all tests were successful
[ 1.943631] Run /init as init process
[ 1.943632] with arguments:
[ 1.943632] /init
[ 1.943633] splash
[ 1.943633] with environment:
[ 1.943633] HOME=/
[ 1.943634] TERM=linux
[ 1.943634] BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
[ 1.962939] usb 1-7: config 1 has an invalid interface number: 2 but max is 1
[ 1.962945] usb 1-7: config 1 has no interface number 1
[ 1.967003] usb 1-3.4: new full-speed USB device number 4 using xhci_hcd
[ 1.976995] usb 1-7: New USB device found, idVendor=0b05, idProduct=19af, bcdDevice= 1.00
[ 1.976997] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.976998] usb 1-7: Product: AURA LED Controller
[ 1.976999] usb 1-7: Manufacturer: AsusTek Computer Inc.
[ 1.977000] usb 1-7: SerialNumber: 9876543210
[ 1.997292] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 1.997526] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/LNXVIDEO:00/input/input2
[ 2.002922] nvme nvme0: pci function 0000:03:00.0
[ 2.002922] nvme nvme1: pci function 0000:02:00.0
[ 2.009052] nvme nvme1: D3 entry latency set to 10 seconds
[ 2.009178] nvme nvme0: D3 entry latency set to 10 seconds
[ 2.011853] nvme nvme1: 16/0/0 default/read/poll queues
[ 2.012006] nvme nvme0: 16/0/0 default/read/poll queues
[ 2.013987] nvme0n1: p1 p2 p3 p4
[ 2.013998] nvme1n1: p1 p2 p3
[ 2.021075] usbcore: registered new interface driver usbhid
[ 2.021078] usbhid: USB HID core driver
[ 2.022554] input: Kinesis Kinesis Adv360 as /devices/pci0000:00/0000:00:08.1/0000:74:00.4/usb7/7-1/7-1:1.0/0003:29EA:0360.0001/input/input3
[ 2.022592] hid-generic 0003:29EA:0360.0001: input,hidraw0: USB HID v1.11 Mouse [Kinesis Kinesis Adv360] on usb-0000:74:00.4-1/input0
[ 2.022644] hid-generic 0003:0B05:19AF.0002: hiddev96,hidraw1: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:0a:00.0-7/input2
[ 2.022706] input: Kinesis Kinesis Adv360 as /devices/pci0000:00/0000:00:08.1/0000:74:00.4/usb7/7-1/7-1:1.1/0003:29EA:0360.0003/input/input4
[ 2.322134] usb 1-3.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
[ 2.322141] usb 1-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.322142] usb 1-3.4: Product: USB Receiver
[ 2.322144] usb 1-3.4: Manufacturer: Logitech
[ 2.347015] usb 1-11: new high-speed USB device number 5 using xhci_hcd
[ 2.381292] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0c.0/0000:0a:00.0/usb1/1-3/1-3.4/1-3.4:1.0/0003:046D:C52B.0005/input/input5
[ 2.470395] hid-generic 0003:29EA:0360.0003: input,hidraw2: USB HID v1.11 Keyboard [Kinesis Kinesis Adv360] on usb-0000:74:00.4-1/input1
[ 2.470452] input: Kinesis Kinesis Adv360 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:74:00.4/usb7/7-1/7-1:1.2/0003:29EA:0360.0004/input/input6
[ 2.570158] usb 1-11: New USB device found, idVendor=13d3, idProduct=3602, bcdDevice= 1.00
[ 2.570162] usb 1-11: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[ 2.570163] usb 1-11: Product: Wireless_Device
[ 2.570164] usb 1-11: Manufacturer: MediaTek Inc.
[ 2.570165] usb 1-11: SerialNumber: 000000000
[ 2.834674] [drm] amdgpu kernel modesetting enabled.
[ 2.834690] amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.GP17.VGA_.ATPX handle
[ 2.834791] amdgpu: ATPX version 1, functions 0x00000000
[ 2.837604] amdgpu: Virtual CRAT table created for CPU
[ 2.837609] amdgpu: Topology: Add CPU node
[ 2.837679] amdgpu 0000:74:00.0: enabling device (0006 -> 0007)
[ 2.837698] [drm] initializing kernel modesetting (IP DISCOVERY 0x1002:0x13C0 0x1043:0x8877 0xC1).
[ 2.837703] [drm] register mmio base: 0xDEF00000
[ 2.837703] [drm] register mmio size: 524288
[ 2.839232] [drm] add ip block number 0 <nv_common>
[ 2.839233] [drm] add ip block number 1 <gmc_v10_0>
[ 2.839234] [drm] add ip block number 2 <navi10_ih>
[ 2.839234] [drm] add ip block number 3 <psp>
[ 2.839235] [drm] add ip block number 4 <smu>
[ 2.839235] [drm] add ip block number 5 <dm>
[ 2.839236] [drm] add ip block number 6 <gfx_v10_0>
[ 2.839237] [drm] add ip block number 7 <sdma_v5_2>
[ 2.839238] [drm] add ip block number 8 <vcn_v3_0>
[ 2.839238] [drm] add ip block number 9 <jpeg_v3_0>
[ 2.839247] amdgpu 0000:74:00.0: amdgpu: Fetched VBIOS from VFCT
[ 2.839248] amdgpu: ATOM BIOS: 102-RAPHAEL-008
[ 2.843246] amdgpu 0000:74:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 2.843265] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 2.843268] amdgpu 0000:74:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used)
[ 2.843269] amdgpu 0000:74:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 2.843273] [drm] Detected VRAM RAM=2048M, BAR=2048M
[ 2.843274] [drm] RAM width 128bits DDR5
[ 2.843317] [drm] amdgpu: 2048M of VRAM memory ready
[ 2.843318] [drm] amdgpu: 47077M of GTT memory ready.
[ 2.843327] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.843425] [drm] PCIE GART of 1024M enabled (table at 0x000000F47FC00000).
[ 2.843677] [drm] Loading DMUB firmware via PSP: version=0x05001C00
[ 2.843923] [drm] use_doorbell being set to: [true]
[ 2.843932] [drm] Found VCN firmware Version ENC: 1.31 DEC: 3 VEP: 0 Revision: 3
[ 2.865988] amdgpu 0000:74:00.0: amdgpu: reserve 0xa00000 from 0xf47e000000 for PSP TMR
[ 2.890394] hid-generic 0003:046D:C52B.0005: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:0a:00.0-3.4/input0
[ 2.931034] amdgpu 0000:74:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 2.936297] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0c.0/0000:0a:00.0/usb1/1-3/1-3.4/1-3.4:1.1/0003:046D:C52B.0006/input/input8
[ 2.936806] amdgpu 0000:74:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 2.936807] amdgpu 0000:74:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 2.938050] amdgpu 0000:74:00.0: amdgpu: SMU is initialized successfully!
[ 2.938051] [drm] Seamless boot condition check passed
[ 2.938863] [drm] Display Core v3.2.301 initialized on DCN 3.1.5
[ 2.938864] [drm] DP-HDMI FRL PCON supported
[ 2.939623] [drm] DMUB hardware initialized: version=0x05001C00
[ 2.940526] [drm] kiq ring mec 2 pipe 1 q 0
[ 2.943337] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 2.943342] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[ 2.943708] input: Kinesis Kinesis Adv360 System Control as /devices/pci0000:00/0000:00:08.1/0000:74:00.4/usb7/7-1/7-1:1.2/0003:29EA:0360.0004/input/input7
[ 2.943743] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0c.0/0000:0a:00.0/usb1/1-3/1-3.4/1-3.4:1.1/0003:046D:C52B.0006/input/input9
[ 2.943747] hid-generic 0003:29EA:0360.0004: input,hidraw4: USB HID v1.11 Device [Kinesis Kinesis Adv360] on usb-0000:74:00.4-1/input2
[ 2.944018] amdgpu: Virtual CRAT table created for GPU
[ 2.944099] amdgpu: Topology: Add dGPU node [0x13c0:0x1002]
[ 2.944100] kfd kfd: amdgpu: added device 1002:13c0
[ 2.944109] amdgpu 0000:74:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 2, active_cu_number 2
[ 2.944111] amdgpu 0000:74:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 2.944111] amdgpu 0000:74:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
[ 2.944112] amdgpu 0000:74:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
[ 2.944112] amdgpu 0000:74:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
[ 2.944112] amdgpu 0000:74:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 2.944113] amdgpu 0000:74:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 2.944113] amdgpu 0000:74:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 2.944113] amdgpu 0000:74:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 2.944114] amdgpu 0000:74:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 2.944114] amdgpu 0000:74:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 2.944115] amdgpu 0000:74:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
[ 2.944115] amdgpu 0000:74:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
[ 2.944115] amdgpu 0000:74:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
[ 2.944116] amdgpu 0000:74:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
[ 2.944116] amdgpu 0000:74:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
[ 2.944116] amdgpu 0000:74:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
[ 2.944902] amdgpu 0000:74:00.0: amdgpu: Runtime PM not available
[ 2.945026] [drm] Initialized amdgpu 3.59.0 for 0000:74:00.0 on minor 1
[ 2.947210] amdgpu 0000:74:00.0: [drm] Cannot find any crtc or sizes
[ 2.947220] [drm] pre_validate_dsc:1589 MST_DSC dsc precompute is not needed
[ 2.997492] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0c.0/0000:0a:00.0/usb1/1-3/1-3.4/1-3.4:1.1/0003:046D:C52B.0006/input/input10
[ 2.997570] hid-generic 0003:046D:C52B.0006: input,hiddev97,hidraw5: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:0a:00.0-3.4/input1
[ 3.029766] hid-generic 0003:046D:C52B.0007: hiddev98,hidraw6: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:0a:00.0-3.4/input2
[ 3.374399] logitech-djreceiver 0003:046D:C52B.0007: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:0a:00.0-3.4/input2
[ 3.489727] input: Logitech Wireless Device PID:406f Keyboard as /devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0c.0/0000:0a:00.0/usb1/1-3/1-3.4/1-3.4:1.2/0003:046D:C52B.0007/0003:046D:406F.0008/input/input12
[ 3.540036] PM: Image not found (code -22)
[ 3.639337] EXT4-fs (nvme1n1p2): mounted filesystem c32e8e2e-8ec8-4a4f-aa28-10670708e38b r/w with ordered data mode. Quota mode: none.
[ 3.643727] input: Logitech Wireless Device PID:406f Mouse as /devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0c.0/0000:0a:00.0/usb1/1-3/1-3.4/1-3.4:1.2/0003:046D:C52B.0007/0003:046D:406F.0008/input/input13
[ 3.643769] hid-generic 0003:046D:406F.0008: input,hidraw5: USB HID v1.11 Keyboard [Logitech Wireless Device PID:406f] on usb-0000:0a:00.0-3.4/input2:1
[ 3.655453] input: Logitech MX Master 3 as /devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0c.0/0000:0a:00.0/usb1/1-3/1-3.4/1-3.4:1.2/0003:046D:C52B.0007/0003:046D:4082.0009/input/input17
[ 3.690481] systemd[1]: systemd 257.2-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 3.690486] systemd[1]: Detected architecture x86-64.
[ 3.691182] systemd[1]: Hostname set to <abraham-linux-woody>.
[ 3.811017] logitech-hidpp-device 0003:046D:4082.0009: input,hidraw6: USB HID v1.11 Keyboard [Logitech MX Master 3] on usb-0000:0a:00.0-3.4/input2:2
[ 3.950222] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 4.049346] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.075644] input: Logitech MX Ergo as /devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0c.0/0000:0a:00.0/usb1/1-3/1-3.4/1-3.4:1.2/0003:046D:C52B.0007/0003:046D:406F.0008/input/input18
[ 4.092040] systemd[1]: Created slice CUPS Slice.
[ 4.092226] systemd[1]: Created slice Slice /system/dirmngr.
[ 4.092351] systemd[1]: Created slice Slice /system/getty.
[ 4.092478] systemd[1]: Created slice Slice /system/gpg-agent.
[ 4.092602] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 4.092727] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 4.092849] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 4.092968] systemd[1]: Created slice Slice /system/keyboxd.
[ 4.093097] systemd[1]: Created slice Slice /system/modprobe.
[ 4.093221] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 4.093308] systemd[1]: Created slice User and Session Slice.
[ 4.093331] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.093422] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.093431] systemd[1]: Expecting device /dev/disk/by-uuid/33C0-EDAD...
[ 4.093434] systemd[1]: Expecting device /dev/disk/by-uuid/3528e895-dcd5-42d3-b7ad-2bcb7a3773a9...
[ 4.093443] systemd[1]: Reached target Login Prompts.
[ 4.093450] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 4.093465] systemd[1]: Reached target Remote File Systems.
[ 4.093469] systemd[1]: Reached target Slice Units.
[ 4.093484] systemd[1]: Reached target Local Verity Protected Volumes.
[ 4.093514] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.093554] systemd[1]: Listening on LVM2 poll daemon socket.
[ 4.094148] systemd[1]: Listening on Process Core Dump Socket.
[ 4.094438] systemd[1]: Listening on Credential Encryption/Decryption.
[ 4.094468] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.094495] systemd[1]: Listening on Journal Sockets.
[ 4.094513] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 4.094519] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 4.094541] systemd[1]: Listening on udev Control Socket.
[ 4.094556] systemd[1]: Listening on udev Kernel Socket.
[ 4.094573] systemd[1]: Listening on User Database Manager Socket.
[ 4.095089] systemd[1]: Mounting Huge Pages File System...
[ 4.095394] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.095670] systemd[1]: Mounting Kernel Debug File System...
[ 4.096263] systemd[1]: Mounting Kernel Trace File System...
[ 4.096916] systemd[1]: Starting Load AppArmor profiles...
[ 4.097527] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.097948] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 4.098333] systemd[1]: Starting Load Kernel Module configfs...
[ 4.098713] systemd[1]: Starting Load Kernel Module dm_mod...
[ 4.099193] systemd[1]: Starting Load Kernel Module drm...
[ 4.099512] systemd[1]: Starting Load Kernel Module fuse...
[ 4.099845] systemd[1]: Starting Load Kernel Module loop...
[ 4.099883] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 4.099899] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[ 4.100635] systemd[1]: Starting Journal Service...
[ 4.101173] systemd[1]: Starting Load Kernel Modules...
[ 4.101182] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 4.101508] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.101529] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 4.101864] systemd[1]: Starting Load udev Rules from Credentials...
[ 4.102134] systemd[1]: Starting Coldplug All udev Devices...
[ 4.102402] systemd[1]: Starting Virtual Console Setup...
[ 4.103015] systemd[1]: Mounted Huge Pages File System.
[ 4.103060] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.103080] systemd[1]: Mounted Kernel Debug File System.
[ 4.103105] systemd[1]: Mounted Kernel Trace File System.
[ 4.103206] systemd[1]: Finished Create List of Static Device Nodes.
[ 4.103460] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 4.103531] systemd[1]: Finished Load Kernel Module configfs.
[ 4.103734] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 4.103785] systemd[1]: Finished Load Kernel Module drm.
[ 4.103849] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 4.103897] systemd[1]: Finished Load Kernel Module fuse.
[ 4.104278] systemd[1]: Mounting FUSE Control File System...
[ 4.104561] loop: module loaded
[ 4.104605] systemd[1]: Mounting Kernel Configuration File System...
[ 4.104944] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 4.105141] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 4.105198] systemd[1]: Finished Load Kernel Module loop.
[ 4.106489] device-mapper: uevent: version 1.0.3
[ 4.106538] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[ 4.106647] systemd[1]: Finished Virtual Console Setup.
[ 4.106788] systemd[1]: Finished Load udev Rules from Credentials.
[ 4.106890] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 4.106954] systemd[1]: Finished Load Kernel Module dm_mod.
[ 4.107158] systemd[1]: Mounted FUSE Control File System.
[ 4.107226] systemd[1]: Mounted Kernel Configuration File System.
[ 4.107271] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 4.108512] systemd-journald[573]: Collecting audit messages is disabled.
[ 4.109594] audit: type=1400 audit(1739211576.845:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=603 comm="apparmor_parser"
[ 4.109597] audit: type=1400 audit(1739211576.845:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=606 comm="apparmor_parser"
[ 4.109598] audit: type=1400 audit(1739211576.845:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="kchmviewer" pid=625 comm="apparmor_parser"
[ 4.109599] audit: type=1400 audit(1739211576.845:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="goldendict" pid=622 comm="apparmor_parser"
[ 4.109611] audit: type=1400 audit(1739211576.845:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="evolution" pid=616 comm="apparmor_parser"
[ 4.109631] audit: type=1400 audit(1739211576.845:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=605 comm="apparmor_parser"
[ 4.109652] audit: type=1400 audit(1739211576.845:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="vscode" pid=611 comm="apparmor_parser"
[ 4.109661] audit: type=1400 audit(1739211576.845:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="chromium" pid=610 comm="apparmor_parser"
[ 4.109673] audit: type=1400 audit(1739211576.845:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=601 comm="apparmor_parser"
[ 4.112563] i2c_dev: i2c /dev entries driver
[ 4.120651] systemd[1]: Starting User Database Manager...
[ 4.150847] EXT4-fs (nvme1n1p2): re-mounted c32e8e2e-8ec8-4a4f-aa28-10670708e38b r/w. Quota mode: none.
[ 4.151570] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 4.151854] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[ 4.152702] systemd[1]: Starting Load/Save OS Random Seed...
[ 4.152719] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 4.157442] systemd[1]: Started User Database Manager.
[ 4.166301] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ 4.166977] systemd[1]: Starting Create System Users...
[ 4.167853] systemd[1]: Finished Load/Save OS Random Seed.
[ 4.168182] systemd[1]: Finished Coldplug All udev Devices.
[ 4.185709] systemd[1]: Finished Create System Users.
[ 4.186713] systemd[1]: Starting Network Time Synchronization...
[ 4.187252] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.194887] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 4.195324] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 4.199816] systemd[1]: Started Network Time Synchronization.
[ 4.199905] systemd[1]: Reached target System Time Set.
[ 4.208951] systemd[1]: Finished Load AppArmor profiles.
[ 4.218305] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 4.218347] systemd[1]: Reached target Preparation for Local File Systems.
[ 4.218859] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 4.219462] systemd[1]: Starting Show Plymouth Boot Screen...
[ 4.220461] nvidia: loading out-of-tree module taints kernel.
[ 4.220467] nvidia: module license 'NVIDIA' taints kernel.
[ 4.220468] Disabling lock debugging due to kernel taint
[ 4.220469] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 4.220469] nvidia: module license taints kernel.
[ 4.229804] systemd[1]: Condition check resulted in /dev/tpmrm0 being skipped.
[ 4.230377] systemd[1]: Reached target Trusted Platform Module.
[ 4.237859] systemd[1]: Started Show Plymouth Boot Screen.
[ 4.237935] systemd[1]: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[ 4.237978] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[ 4.237988] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.249012] systemd[1]: Found device Samsung SSD 990 PRO 4TB swap.
[ 4.250448] logitech-hidpp-device 0003:046D:406F.0008: input,hidraw5: USB HID v1.11 Keyboard [Logitech MX Ergo] on usb-0000:0a:00.0-3.4/input2:1
[ 4.255126] systemd[1]: Found device Samsung SSD 990 PRO 4TB 1.
[ 4.258326] systemd[1]: Started Journal Service.
[ 4.335836] systemd-journald[573]: Received client request to flush runtime journal.
[ 4.340144] Adding 106056556k swap on /dev/nvme1n1p3. Priority:-2 extents:1 across:106056556k SS
[ 4.400292] ccp 0000:74:00.2: enabling device (0000 -> 0002)
[ 4.400675] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 4.400678] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 4.401154] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 4.401687] ccp 0000:74:00.2: tee enabled
[ 4.401817] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 4.401867] ccp 0000:74:00.2: psp enabled
[ 4.404069] input: PC Speaker as /devices/platform/pcspkr/input/input19
[ 4.404071] ACPI: bus type thunderbolt registered
[ 4.404229] mousedev: PS/2 mouse device common for all mice
[ 4.404331] thunderbolt 0000:73:00.0: enabling device (0000 -> 0002)
[ 4.406461] cryptd: max_cpu_qlen set to 1000
[ 4.406701] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 4.406703] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 4.408341] i2c i2c-6: Successfully instantiated SPD at 0x51
[ 4.409488] i2c i2c-6: Successfully instantiated SPD at 0x53
[ 4.409524] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 4.411627] i8042: PNP: No PS/2 controller found.
[ 4.413452] AES CTR mode by8 optimization enabled
[ 4.413479] r8169 0000:07:00.0: error -ENODEV: unknown chip XID 688, contact r8169 maintainers (see MAINTAINERS file)
[ 4.417527] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 4.417747] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 4.417789] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 4.423747] Bluetooth: Core ver 2.22
[ 4.423765] NET: Registered PF_BLUETOOTH protocol family
[ 4.423766] Bluetooth: HCI device and connection manager initialized
[ 4.423768] Bluetooth: HCI socket layer initialized
[ 4.423770] Bluetooth: L2CAP socket layer initialized
[ 4.423771] Bluetooth: SCO socket layer initialized
[ 4.450579] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.144.03 Mon Dec 30 17:44:08 UTC 2024
[ 4.456690] asus_wmi: ASUS WMI generic driver loaded
[ 4.456838] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.456910] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.456965] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 4.458309] asus_wmi: failed to register LPS0 sleep handler in asus-wmi
[ 4.458367] asus_wmi: Initialization: 0x0
[ 4.458409] asus_wmi: BIOS WMI version: 0.0
[ 4.458444] asus_wmi: SFUN value: 0x0
[ 4.458445] eeepc-wmi eeepc-wmi: Detected AsusMbSwInterface, not ASUSWMI, use DSTS
[ 4.459479] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input20
[ 4.461136] spd5118 6-0051: DDR5 temperature sensor: vendor 0x06:0x32 revision 1.6
[ 4.467646] spd5118 6-0053: DDR5 temperature sensor: vendor 0x06:0x32 revision 1.6
[ 4.468035] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.144.03 Mon Dec 30 17:10:10 UTC 2024
[ 4.473036] usbcore: registered new interface driver btusb
[ 4.534490] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 4.594603] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 4.594676] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 4.594684] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 4.594783] snd_hda_intel 0000:74:00.1: enabling device (0000 -> 0002)
[ 4.594816] snd_hda_intel 0000:74:00.1: Handle vga_switcheroo audio client
[ 4.594843] snd_hda_intel 0000:74:00.6: enabling device (0000 -> 0002)
[ 4.604191] snd_hda_intel 0000:74:00.1: bound 0000:74:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 4.607782] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:74:00.1/sound/card1/input21
[ 4.608021] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:74:00.1/sound/card1/input22
[ 4.608258] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:74:00.1/sound/card1/input23
[ 4.627417] Bluetooth: hci0: HW/SW Version: 0x00000000, Build Time: 20241104133214
[ 4.643866] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input24
[ 4.643899] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input25
[ 4.643922] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input26
[ 4.643939] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input27
[ 4.663461] kvm_amd: TSC scaling supported
[ 4.663463] kvm_amd: Nested Virtualization enabled
[ 4.663464] kvm_amd: Nested Paging enabled
[ 4.663464] kvm_amd: LBR virtualization supported
[ 4.663467] kvm_amd: Virtual VMLOAD VMSAVE supported
[ 4.663467] kvm_amd: Virtual GIF supported
[ 4.663467] kvm_amd: Virtual NMI enabled
[ 4.699304] snd_hda_codec_realtek hdaudioC2D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 4.699306] snd_hda_codec_realtek hdaudioC2D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.699307] snd_hda_codec_realtek hdaudioC2D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 4.699308] snd_hda_codec_realtek hdaudioC2D0: mono: mono_out=0x0
[ 4.699308] snd_hda_codec_realtek hdaudioC2D0: inputs:
[ 4.699309] snd_hda_codec_realtek hdaudioC2D0: Rear Mic=0x18
[ 4.699310] snd_hda_codec_realtek hdaudioC2D0: Front Mic=0x19
[ 4.699310] snd_hda_codec_realtek hdaudioC2D0: Line=0x1a
[ 4.700273] mt7925e 0000:08:00.0: enabling device (0000 -> 0002)
[ 4.703682] mt7925e 0000:08:00.0: ASIC revision: 79250000
[ 4.711296] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:74:00.6/sound/card2/input28
[ 4.711340] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:74:00.6/sound/card2/input29
[ 4.711359] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:74:00.6/sound/card2/input30
[ 4.711381] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:74:00.6/sound/card2/input31
[ 4.711397] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:74:00.6/sound/card2/input32
[ 4.711415] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:74:00.6/sound/card2/input33
[ 4.711434] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:74:00.6/sound/card2/input34
[ 4.780999] mt7925e 0000:08:00.0: HW/SW Version: 0x8a108a10, Build Time: 20241104132949a
[ 4.871635] intel_rapl_common: Found RAPL domain package
[ 4.871636] intel_rapl_common: Found RAPL domain core
[ 4.871925] amd_atl: AMD Address Translation Library initialized
[ 5.119462] mt7925e 0000:08:00.0: WM Firmware Version: ____000000, Build Time: 20241104133053
[ 5.761631] mt7925e 0000:08:00.0 wlp8s0: renamed from wlan0
[ 6.278398] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 2
[ 6.330290] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 6.384617] nvidia-uvm: Loaded the UVM driver, major device number 511.
[ 6.459336] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.459338] Bluetooth: BNEP filters: protocol multicast
[ 6.459340] Bluetooth: BNEP socket layer initialized
[ 6.489760] NET: Registered PF_QIPCRTR protocol family
[ 11.730376] wlp8s0: authenticate with 04:09:86:49:ec:51 (local address=28:d0:43:33:ac:3e)
[ 11.860467] wlp8s0: send auth to 04:09:86:49:ec:51 (try 1/3)
[ 11.871051] wlp8s0: authenticated
[ 11.877005] wlp8s0: associate with 04:09:86:49:ec:51 (try 1/3)
[ 11.896529] wlp8s0: RX AssocResp from 04:09:86:49:ec:51 (capab=0x1c11 status=0 aid=6)
[ 11.929663] wlp8s0: associated
[ 12.039372] wlp8s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 04:09:86:49:ec:51
[ 12.655209] kauditd_printk_skb: 152 callbacks suppressed
[ 12.655213] audit: type=1400 audit(1739211585.392:163): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=1283 comm="apparmor_parser"
[ 12.770012] Initializing XFRM netlink socket
[ 12.784177] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 12.859486] br-d0e779c89bc9: port 1(vetha11537c) entered blocking state
[ 12.859492] br-d0e779c89bc9: port 1(vetha11537c) entered disabled state
[ 12.859499] vetha11537c: entered allmulticast mode
[ 12.859532] vetha11537c: entered promiscuous mode
[ 12.887716] br-d0e779c89bc9: port 1(vetha11537c) entered disabled state
[ 12.887842] vetha11537c (unregistering): left allmulticast mode
[ 12.887845] vetha11537c (unregistering): left promiscuous mode
[ 12.887846] br-d0e779c89bc9: port 1(vetha11537c) entered disabled state
[ 15.478454] rfkill: input handler disabled
[ 23.110274] Bluetooth: hci0: Device setup in 18200372 usecs
[ 23.110283] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 23.282336] Bluetooth: hci0: AOSP extensions version v1.00
[ 23.282342] Bluetooth: hci0: AOSP quality report is supported
[ 23.282489] Bluetooth: MGMT ver 1.23
[ 23.286278] NET: Registered PF_ALG protocol family
[ 23.302017] Bluetooth: RFCOMM TTY layer initialized
[ 23.302024] Bluetooth: RFCOMM socket layer initialized
[ 23.302026] Bluetooth: RFCOMM ver 1.11
[ 23.317706] rfkill: input handler enabled
[ 26.326729] rfkill: input handler disabled
[ 27.608080] xhci_hcd 0000:72:00.0: WARN: xHC CMD_RUN timeout
[ 27.663858] xhci_hcd 0000:72:00.0: PM: suspend_common(): xhci_pci_suspend returns -110
[ 27.663863] xhci_hcd 0000:72:00.0: can't suspend (hcd_pci_runtime_suspend returned -110)
[ 29.167814] logitech-hidpp-device 0003:046D:4082.0009: HID++ 4.5 device connected.
[ 39.077752] warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 45.303526] wlp8s0: disconnect from AP 04:09:86:49:ec:51 for new auth to 04:09:86:49:ec:50
[ 45.568654] wlp8s0: authenticate with 04:09:86:49:ec:50 (local address=28:d0:43:33:ac:3e)
[ 45.938370] wlp8s0: send auth to 04:09:86:49:ec:50 (try 1/3)
[ 45.948081] wlp8s0: authenticated
[ 45.948518] wlp8s0: associate with 04:09:86:49:ec:50 (try 1/3)
[ 45.973741] wlp8s0: RX ReassocResp from 04:09:86:49:ec:50 (capab=0x1911 status=0 aid=7)
[ 46.007265] wlp8s0: associated
[ 46.007325] wlp8s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 04:09:86:49:ec:50
[ 476.424848] rfkill: input handler enabled
[ 482.213610] rfkill: input handler disabled
[ 484.923746] BUG: unable to handle page fault for address: 0000000000001938
[ 484.923754] #PF: supervisor read access in kernel mode
[ 484.923756] #PF: error_code(0x0000) - not-present page
[ 484.923757] PGD 0 P4D 0
[ 484.923760] Oops: Oops: 0000 [#1] PREEMPT SMP NOPTI
[ 484.923763] CPU: 27 UID: 0 PID: 926 Comm: nvidia-modeset/ Tainted: P OE 6.12.11-1-MANJARO #1 8ef350656b9ecb44b3279f5506522b9740c6e80d
[ 484.923767] Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 484.923768] Hardware name: ASUS System Product Name/TUF GAMING X870-PLUS WIFI, BIOS 0237 07/22/2024
[ 484.923769] RIP: 0010:_nv019713rm+0x18d/0x310 [nvidia]
[ 484.923964] Code: ff e8 b7 0d fc ff 48 89 c7 48 c7 c6 c0 1e 79 c4 e8 78 ef 64 00 48 8b 4d 00 44 8b 91 3c 19 00 00 41 83 fa 02 0f 84 33 01 00 00 <44> 8b 80 38 19 00 00 41 ba 01 00 00 00 44 0f b6 4d 1d 41 8d 54 24
[ 484.923965] RSP: 0018:ffff9fcac1ba3b78 EFLAGS: 00010293
[ 484.923966] RAX: 0000000000000000 RBX: ffff8a6c79493008 RCX: ffff8a6c8c092008
[ 484.923967] RDX: 0000000000000008 RSI: 0000000000272cdd RDI: 0000000000000000
[ 484.923968] RBP: ffff8a6c4e7cdb50 R08: 0000000000000000 R09: 0000000000000001
[ 484.923968] R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000003
[ 484.923969] R13: 0000000000000001 R14: ffff8a6c8c092010 R15: ffff9fcac2871008
[ 484.923970] FS: 0000000000000000(0000) GS:ffff8a82dfb80000(0000) knlGS:0000000000000000
[ 484.923971] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 484.923972] CR2: 0000000000001938 CR3: 0000001213822000 CR4: 0000000000f50ef0
[ 484.923973] PKRU: 55555554
[ 484.923974] Call Trace:
[ 484.923977] <TASK>
[ 484.923979] ? __die_body.cold+0x19/0x27
[ 484.923983] ? page_fault_oops+0x15a/0x2d0
[ 484.923986] ? os_acquire_spinlock+0x12/0x30 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.924073] ? exc_page_fault+0x81/0x190
[ 484.924075] ? asm_exc_page_fault+0x26/0x30
[ 484.924079] ? _nv019713rm+0x18d/0x310 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.924251] ? _nv019713rm+0x178/0x310 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.924400] _nv019602rm+0x4b/0xf0 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.924544] _nv022156rm+0xd9b/0x1748 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.924699] _nv045276rm+0x19e/0x1b0 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.924881] _nv021857rm+0xd9/0x160 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.925043] _nv047237rm+0x374/0x410 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.925234] _nv014162rm+0x3f1/0x690 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.925359] _nv045428rm+0x69/0xd0 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.925488] _nv012641rm+0x83/0xa0 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.925597] _nv000584rm+0x5e/0x70 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.925725] rm_kernel_rmapi_op+0x127/0x213 [nvidia b476971613736e537fc15f9bc958ea3d9a9a9f63]
[ 484.925899] nvkms_call_rm+0x4a/0x80 [nvidia_modeset 497e7d6b56b037efd79a2531d86fded4ea048e95]
[ 484.925908] _nv002794kms+0x42/0x50 [nvidia_modeset 497e7d6b56b037efd79a2531d86fded4ea048e95]
[ 484.925921] ? _nv001312kms+0x1a5/0x350 [nvidia_modeset 497e7d6b56b037efd79a2531d86fded4ea048e95]
[ 484.925937] ? _nv001588kms+0xcb/0xe0 [nvidia_modeset 497e7d6b56b037efd79a2531d86fded4ea048e95]
[ 484.925949] ? __pfx__main_loop+0x10/0x10 [nvidia_modeset 497e7d6b56b037efd79a2531d86fded4ea048e95]
[ 484.925955] ? _nv001688kms+0x2d/0x80 [nvidia_modeset 497e7d6b56b037efd79a2531d86fded4ea048e95]
[ 484.925968] ? down+0x1e/0x60
[ 484.925969] ? nvkms_kthread_q_callback+0xc7/0x160 [nvidia_modeset 497e7d6b56b037efd79a2531d86fded4ea048e95]
[ 484.925976] ? _main_loop+0x95/0x150 [nvidia_modeset 497e7d6b56b037efd79a2531d86fded4ea048e95]
[ 484.925982] ? kthread+0xcf/0x100
[ 484.925984] ? __pfx_kthread+0x10/0x10
[ 484.925986] ? ret_from_fork+0x31/0x50
[ 484.925988] ? __pfx_kthread+0x10/0x10
[ 484.925989] ? ret_from_fork_asm+0x1a/0x30
[ 484.925991] </TASK>
[ 484.925992] Modules linked in: uhid rfcomm cmac algif_hash algif_skcipher af_alg snd_seq_dummy snd_hrtimer snd_seq snd_seq_device veth xt_conntrack xt_MASQUERADE bridge stp llc nf_conntrack_netlink xfrm_user xfrm_algo ip6table_nat ip6table_filter ip6_tables iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter ccm overlay qrtr bnep nvidia_uvm(POE) vfat fat amd_atl intel_rapl_msr intel_rapl_common mt7925e snd_hda_codec_realtek mt7925_common kvm_amd snd_hda_codec_generic mt792x_lib snd_hda_scodec_component mt76_connac_lib kvm snd_hda_codec_hdmi mt76 snd_hda_intel crct10dif_pclmul crc32_pclmul snd_intel_dspcfg nvidia_drm(POE) snd_intel_sdw_acpi btusb polyval_clmulni mac80211 snd_hda_codec btrtl polyval_generic btintel nvidia_modeset(POE) ghash_clmulni_intel snd_hda_core libarc4 btbcm eeepc_wmi sha512_ssse3 snd_hwdep btmtk asus_wmi spd5118 sha256_ssse3 sha1_ssse3 sp5100_tco snd_pcm platform_profile cfg80211 aesni_intel bluetooth r8169 i8042 snd_timer gf128mul sparse_keymap
[ 484.926024] crypto_simd joydev snd ucsi_acpi i2c_piix4 serio realtek cryptd mdio_devres wmi_bmof rapl thunderbolt pcspkr k10temp ccp rfkill mousedev i2c_smbus typec_ucsi libphy soundcore typec gpio_amdpt roles gpio_generic mac_hid nvidia(POE) i2c_dev sg crypto_user dm_mod loop nfnetlink ip_tables x_tables ext4 crc32c_generic mbcache jbd2 hid_logitech_hidpp hid_logitech_dj amdgpu amdxcp i2c_algo_bit drm_ttm_helper hid_generic ttm drm_exec gpu_sched drm_suballoc_helper drm_buddy nvme drm_display_helper nvme_core cec crc32c_intel usbhid video crc16 nvme_auth wmi
[ 484.926049] CR2: 0000000000001938
[ 484.926051] ---[ end trace 0000000000000000 ]---
[ 484.926052] RIP: 0010:_nv019713rm+0x18d/0x310 [nvidia]
[ 484.926231] Code: ff e8 b7 0d fc ff 48 89 c7 48 c7 c6 c0 1e 79 c4 e8 78 ef 64 00 48 8b 4d 00 44 8b 91 3c 19 00 00 41 83 fa 02 0f 84 33 01 00 00 <44> 8b 80 38 19 00 00 41 ba 01 00 00 00 44 0f b6 4d 1d 41 8d 54 24
[ 484.926232] RSP: 0018:ffff9fcac1ba3b78 EFLAGS: 00010293
[ 484.926233] RAX: 0000000000000000 RBX: ffff8a6c79493008 RCX: ffff8a6c8c092008
[ 484.926234] RDX: 0000000000000008 RSI: 0000000000272cdd RDI: 0000000000000000
[ 484.926234] RBP: ffff8a6c4e7cdb50 R08: 0000000000000000 R09: 0000000000000001
[ 484.926235] R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000003
[ 484.926235] R13: 0000000000000001 R14: ffff8a6c8c092010 R15: ffff9fcac2871008
[ 484.926236] FS: 0000000000000000(0000) GS:ffff8a82dfb80000(0000) knlGS:0000000000000000
[ 484.926237] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 484.926237] CR2: 0000000000001938 CR3: 0000001213822000 CR4: 0000000000f50ef0
[ 484.926238] PKRU: 55555554
[ 484.926239] note: nvidia-modeset/[926] exited with irqs disabled
Any help is super appreciated!
