mzuniga
October 14, 2022, 10:02am
#1
When I try starting Shotcut (AppImage) I get the error message:
$ ./shotcut-linux-x86_64-220923.AppImage
X connection to :0 broken (explicit kill or server shutdown).
When I searched for this error message, I found the page Permanent solution for X connection to localhost:10.0 broken , where it is written that: “For local host it’s value should be set as "hostname:0.0" ”.
For my system, I get the following value:
$ echo $DISPLAY
:0
Do I need to update DISPLAY, or is there something else that can be done to fix this issue?
And the one from official repositories works?
For giggles I just downloaded the latest Shotcut .AppImage
from the Github link on this page . I then gave it executeable permissions:
$ chmod u+x shotcut-linux-x86_64-220923.AppImage
And was able to launch it with no obvious ill effects:
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
formats:
- a64
- ac3
- adts
- adx
- aiff
- alp
- amr
- amv
- apm
- apng
- aptx
- aptx_hd
- argo_asf
- argo_cvg
- asf
- ass
- ast
- asf_stream
- au
- avi
- avif
- avm2
- avs2
- avs3
- bit
- caf
- cavsvideo
- codec2
- codec2raw
- crc
- dash
- data
- daud
- dfpwm
- dirac
- dnxhd
- dts
- dv
- eac3
- f4v
- ffmetadata
- fifo
- fifo_test
- filmstrip
- fits
- flac
- flv
- framecrc
- framehash
- framemd5
- g722
- g723_1
- g726
- g726le
- gif
- gsm
- gxf
- h261
- h263
- h264
- hash
- hds
- hevc
- hls
- ico
- ilbc
- image2
- image2pipe
- ipod
- ircam
- ismv
- ivf
- jacosub
- kvag
- latm
- lrc
- m4v
- md5
- matroska
- matroska
- microdvd
- mjpeg
- mlp
- mmf
- mov
- mp2
- mp3
- mp4
- mpeg
- vcd
- mpeg1video
- dvd
- svcd
- mpeg2video
- vob
- mpegts
- mpjpeg
- mxf
- mxf_d10
- mxf_opatom
- null
- nut
- obu
- oga
- ogg
- ogv
- oma
- opus
- alaw
- mulaw
- vidc
- f64be
- f64le
- f32be
- f32le
- s32be
- s32le
- s24be
- s24le
- s16be
- s16le
- s8
- u32be
- u32le
- u24be
- u24le
- u16be
- u16le
- u8
- psp
- rawvideo
- rm
- roq
- rso
- rtp
- rtp_mpegts
- rtsp
- sap
- sbc
- scc
- film_cpk
- segment
- stream_segment,ssegment
- smjpeg
- smoothstreaming
- sox
- spx
- spdif
- srt
- streamhash
- sup
- swf
- tee
- 3g2
- 3gp
- mkvtimestamp_v2
- truehd
- tta
- ttml
- uncodedframecrc
- vc1
- vc1test
- voc
- w64
- wav
- webm
- webm_dash_manifest
- webm_chunk
- webp
- webvtt
- wsaud
- wtv
- wv
- yuv4mpegpipe
- alsa
- fbdev
- oss
- pulse
- sdl,sdl2
- sndio
- video4linux2,v4l2
- xv
audio_codecs:
- comfortnoise
- s302m
- aac
- ac3
- ac3_fixed
- alac
- aptx
- aptx_hd
- dca
- dfpwm
- eac3
- flac
- g723_1
- mlp
- mp2
- mp2fixed
- nellymoser
- opus
- real_144
- sbc
- sonic
- sonicls
- truehd
- tta
- vorbis
- wavpack
- wmav1
- wmav2
- pcm_alaw
- pcm_bluray
- pcm_dvd
- pcm_f32be
- pcm_f32le
- pcm_f64be
- pcm_f64le
- pcm_mulaw
- pcm_s8
- pcm_s8_planar
- pcm_s16be
- pcm_s16be_planar
- pcm_s16le
- pcm_s16le_planar
- pcm_s24be
- pcm_s24daud
- pcm_s24le
- pcm_s24le_planar
- pcm_s32be
- pcm_s32le
- pcm_s32le_planar
- pcm_s64be
- pcm_s64le
- pcm_u8
- pcm_u16be
- pcm_u16le
- pcm_u24be
- pcm_u24le
- pcm_u32be
- pcm_u32le
- pcm_vidc
- roq_dpcm
- adpcm_adx
- adpcm_argo
- g722
- g726
- g726le
- adpcm_ima_amv
- adpcm_ima_alp
- adpcm_ima_apm
- adpcm_ima_qt
- adpcm_ima_ssi
- adpcm_ima_wav
- adpcm_ima_ws
- adpcm_ms
- adpcm_swf
- adpcm_yamaha
- libmp3lame
- libopus
- libvorbis
video_codecs:
- a64multi
- a64multi5
- alias_pix
- amv
- apng
- asv1
- asv2
- avrp
- avui
- ayuv
- bitpacked
- bmp
- cfhd
- cinepak
- cljr
- dnxhd
- dpx
- dvvideo
- exr
- ffv1
- ffvhuff
- fits
- flashsv
- flashsv2
- flv
- gif
- h261
- h263
- h263p
- huffyuv
- jpeg2000
- jpegls
- ljpeg
- magicyuv
- mjpeg
- mpeg1video
- mpeg2video
- mpeg4
- msmpeg4v2
- msmpeg4
- msvideo1
- pam
- pbm
- pcx
- pfm
- pgm
- pgmyuv
- phm
- png
- ppm
- prores
- prores_aw
- prores_ks
- qoi
- qtrle
- r10k
- r210
- rawvideo
- roqvideo
- rpza
- rv10
- rv20
- sgi
- smc
- snow
- speedhq
- sunrast
- svq1
- targa
- tiff
- utvideo
- v210
- v308
- v408
- v410
- vbn
- vc2
- wrapped_avframe
- wmv1
- wmv2
- xbm
- xface
- xwd
- y41p
- yuv4
- zlib
- zmbv
- libaom-av1
- libtheora
- libvpx
- libvpx-vp9
- libwebp_anim
- libwebp
- libx264
- libx264rgb
- libx265
- h263_v4l2m2m
- h264_nvenc
- h264_v4l2m2m
- h264_vaapi
- hevc_nvenc
- hevc_v4l2m2m
- hevc_vaapi
- mjpeg_vaapi
- mpeg2_vaapi
- mpeg4_v4l2m2m
- vp8_v4l2m2m
- vp8_vaapi
- vp9_vaapi
So I checked:
$ echo $DISPLAY
:0
Which leads me to think the reason is 1 of two thing:
Your .AppImage
is old; and/or
You are overriding your $DISPLAY
environment variable somewhere.
But honestly? I suspect it’s #1 .
mzuniga
October 15, 2022, 3:36pm
#4
Unfortunately not. The one from the official library gives me this:
$ shotcut
Cannot mix incompatible Qt library (5.15.5) with this library (5.15.6)
Aborted (core dumped)
mzuniga
October 15, 2022, 3:42pm
#5
Thanks!
It was the latest AppImage I was trying to execute. However, I tried restarting my system (something I seldom do), and then I could successfully execute the Shotcut AppImage. It does not loot like my $DISPLAY
value had been overwritten, as I get the same result after the reboot as I did before I rebooted.
$ echo $DISPLAY
:0
Maybe this same error will happen again, after a little while. If that is the case, I will report back.
Either you are into some partial update state with the system, or a reboot was not done after an update.
mzuniga
October 16, 2022, 10:13am
#7
Weird. As far as I can see there is nothing to update, and I have rebooted twice after last update. I still get the same error. Is there a way to check if I am in a partial update state?
[ ~]$ sudo pacman -Syyu
[sudo] password for poq:
:: Synchronising package databases...
core 162,9 KiB 224 KiB/s 00:01 [######################################] 100%
extra 1834,1 KiB 3,68 MiB/s 00:00 [######################################] 100%
community 7,4 MiB 7,35 MiB/s 00:01 [######################################] 100%
multilib 175,4 KiB 1117 KiB/s 00:00 [######################################] 100%
there is nothing to do
[ ~]$ shotcut
Then the only conclusion is that you are maybe using the qt5-styleplugins
from AUR, hence, even tho there is no update for it, you need to rebuild it.
pamac build qt5-styleplugins
zbe
October 16, 2022, 10:27am
#9
mzuniga:
Weird.
No, it’s not weird. You have something from AUR installed that you don’t maintain.
mzuniga
October 16, 2022, 1:37pm
#10
Thank you! You were completely correct about that. After rebuilding the qt5-styleplugins
the official repo Shotcut version runs as well.
I will see if I run into the same problem (X connection broken
) again, with just the AppImage, or also the official version. And, I will report back.
