Wrong pacman.conf on fresh install (sway)
I just installed manjaro sway from the 26.1.1-unstable-iso and pacman won’t work:
❯ sudo pacman -Syu
:: Paketdatenbanken werden synchronisiert …
Warnung: Ausführen von XferCommand: Fork fehlgeschlagen!
Fehler: Keine Datenbank konnte synchronisiert werden (Fehler beim Aufruf eines externen Downloaders)
This is what my pacman.conf looks like:
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
XferCommand = /var/cache/pacman/pkg/.manjaro-iso/pacman-xfer.sh %o %u
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
ParallelDownloads = 4
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
Include = /etc/pacman.d/manjaro-sway.repo.conf
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
What would be the best way to fix it?
Remember, the Sway edition is a community edition, maybe it is not exactly up to date.
Try commenting the line XferCommand with # in front - no idea why it uses custom script for download…maybe has something to do with the custom conf file…i have no idea what can break. But at least a # is easily reversible.
As far as I understand the pacman-xfer.sh script is a temporary utility on the live ISO. It is typically only used to redirect downloads during system setup. If this line is active on a system that has already been installed, it may cause problems, so I agree it should be commented by adding # in front of the line. The question is, how could this come to an installed system?
