Hi Guys,
Need help, im newbie to use arch linux. My RAM laptop is 8G but it only showing only 5,78G. Is there any issue on this?
- Manjaro 20.1.2 Nibia
- x86_64
- xfce 4.16.1
- 5.9.16-1 Kernel
command : inxi -m
Memory: RAM: total: 5.78 GiB used: 3.24 GiB (56.1%)
Array-1: capacity: 32 GiB slots: 2 EC: None
Device-1: Bottom - Slot 1 (left) size: No Module Installed
Device-2: Bottom - Slot 2 (right) size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s
Thank you in advance
Looks right to me
I assume you have an iGPU and it is reserving RAM for that iGPU.
One of the reason why I only buy 16GB laptops, or ones I can upgrade to 16GB.
Hi @revanhernandy, and welcome!
This to me sounds a lot like RAM Available is 5.8 GB out of 8 GB.
And since it’s a laptop, you must keep in mind that some of your RAM will only be available to integrated graphics, so this plays a role as well!
Hi @Mirdarthos ,
Thank you for it, i solved this with configure the UMA Setting on BIOS to set 512M and my memory useful
system
Closed
5
