Hello and thanks if you take the time to read and answer.
Fresh install of Manjaro, updated and ready to roll, I want to come back to GNU/Linux now that is mature for gaming.
Long story short
I’ve been using GNU/Linux since Slackware 8.0 came out (i believe it was 2001 or something like that.
Hopping distros here and there when i finally settled for ARCH around 2011, then due to work/life occurences i had to use windows.
Stuck with it for the time being.
All that to say, i’m not a newcomer and i know my way around the system, the shell and all the amenities that GNU/Linux brings differently from windows.
Hence i know how to ask for help (or i hope so)
First of all some info:
inxi -Fza
output:
This
System: Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=daa7a42e-505b-45b9-b761-ceff2694ea7c rw quiet apparmor=1
security=apparmor resume=UUID=be8b1070-0bf2-480a-a7f2-0ebc51168297 udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20351 v: Lenovo G50-70 serial: <superuser required> Chassis: type: 10
Mobo: LENOVO model: Lancer 5A2 v: 31900059STD serial: <superuser required> UEFI-[Legacy]: LENOVO v: 9ACN29WW
date: 10/20/2014
Battery: ID-1: BAT0 charge: 24.9 Wh (100.0%) condition: 24.9/31.7 Wh (78.6%) volts: 16.2 min: 14.4 model: Lenovo IdeaPad
type: Unknown serial: <filter> status: Full
CPU: Info: Dual Core model: Intel Core i3-4010U bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 45 (69)
stepping: 1 microcode: 26 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 13573
Speed: 1418 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 1366 2: 1489 3: 1392 4: 1127
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Sun LE [Radeon HD 8550M / R5 M230] vendor: Lenovo driver: radeon
v: kernel alternate: amdgpu bus-ID: 03:00.0 chip-ID: 1002:666f class-ID: 0380
Device-3: Realtek Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 2-6:7 chip-ID: 0bda:579a class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: ati,modesetting,radeon
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2") s-diag: 581mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 21.2.5 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 5000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lenovo Z50-75 driver: rtl8723be v: kernel
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:b723 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Bluetooth: Device-1: Realtek RTL8723B Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 2-7:8 chip-ID: 0bda:b728 class-ID: e001
serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives: Local Storage: total: 558.92 GiB used: 362.81 GiB (64.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: R022 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston model: N/A size: 111.79 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 0024 scheme: MBR
Partition: ID-1: / raw-size: 102.99 GiB size: 100.81 GiB (97.89%) used: 15.93 GiB (15.8%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 192.2 MiB (2.1%) priority: -2 dev: /dev/sdb2 maj-min: 8:18
Sensors: System Temperatures: cpu: 35.0 C mobo: N/A gpu: radeon temp: 35.0 C
Info: Processes: 229 Uptime: 2h 2m wakeups: 1 Memory: 5.7 GiB used: 3.01 GiB (52.8%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1277 lib: 357 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.09
glxinfo | grep "OpenGL renderer"
output:
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 4400 (HSW GT2)
DRI_PRIME=1 glxinfo | grep "OpenGL renderer"
output
OpenGL renderer string: AMD HAINAN (DRM 2.50.0, 5.13.19-2-MANJARO, LLVM 13.0.0)
According to common sense, i should be able to run wine and associated programs using the AMD card, right?
Yet anytime i launch wine, or skyrim or anything with wine, the output of the shell is:
MESA-INTEL: warning: Haswell Vulkan support is incomplete
For example, was trying to prepare a WINEPREFIX to run skyrim (and have a WINEPRERFIX separated for every game, to tidy them up) using the command:
DRI_PRIME=1 WINEARCH=win32 WINEPREFIX=/home/-redacted-/Games/.wine/skyrim wine wineinit
which gives me:
What I have tryed (without success so far):
- Ignore that output, prepare my WINEPREFIX and launch the .exe
- Using PlayOnLinux using the systemwide wine
- Using PlayOnLinux using an alternative custom wine downloaded by the application
- Using Lutris with all the settings correctly put
- Search for 2 days straight using google to see if all the settings on Lutris were correct
At this point i don’t know what else to try.
EDIT: I can confirm it’s a WINE issue:
- created another WINEPREFIX specifically for World of Warcraft 3.3.5 (i play on a private server)
- launched Wow.exe in that WINEPREFIX
same result
whille ANY other program that isn’t WINE does use the AMD GPU
