After the latest update, some icons are not using the correct colour in the “help text” when I hover mouse pointer over them. It looks empty, but zooming in shows the text is there, its just the same colour as the background of the help text box.
Example:
When I open tray, click on bluetooth and then hover mouse over the"+" Icon, it appears to be an empty box. If i take a screenshot and zoom in on the “help text”, i can see the text faintly.
Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=021ac587-2598-4e39-b7e0-5634da992ec8 rw apparmor=1
security=apparmor resume=UUID=3c820242-6b38-4805-ba9a-bda2db7c6952
udev.log_priority=3
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Notebook
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8216 v: 83.18 serial: <filter> UEFI: Insyde v: F.52
date: 05/02/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
status: Discharging
Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6
L2 cache: 4096 KiB
bogomips: 23209
Speed: 638 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nvidia v: 455.38 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:134d
Device-3: Sunplus Innovation HP Wide Vision HD type: USB driver: uvcvideo
bus ID: 1-3:5 chip ID: 1bcf:2c87
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting,nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 652x366mm (25.7x14.4")
s-diag: 748mm (29.4")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.3-1-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus ID: 03:00.0 chip ID: 10ec:8136
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: 3000 bus ID: 05:00.0 chip ID: 8086:24fb
IF: wlo1 state: down mac: <filter>
Local Storage: total: 2.26 TiB used: 715.25 GiB (31.0%)
ID-1: /dev/sda vendor: Seagate model: ST2000LM003 HN-M201RAD size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WDS480G2G0A-00JH30
size: 447.13 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0400 scheme: GPT
ID-1: / raw size: 429.75 GiB size: 422.01 GiB (98.20%)
used: 94.15 GiB (22.3%) fs: ext4 dev: /dev/sdb2
ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 41 C
Processes: 212 Uptime: 24m Memory: 15.53 GiB used: 1.87 GiB (12.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1534 lib: 386 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.08
