The problem is specifically with only dark themes.
Whenever the application theme is set to a dark theme in the Tweaks, the problem occurs.
The Formula bar is working seamlessly.
Now when the theme is set to Matcha Dark Sea the formula bar texts are not visible.
The same occurs with all dark themes.
And also the options in the menu of WPS shows the same problems.
Is there any solution??
I would prefer to use Matcha Dark themes.
