Your 3D accelerator card is not supported by World of Warcraft.
Please install a 3d accelerator card with dudal-TMU support.
prime-run lutris -d
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 50
Current serial number in output stream: 51
2021-08-03 15:34:41,743: glxinfo call failed: Command '['glxinfo', '-B']' returned non-zero exit status 1.
2021-08-03 15:34:41,744: No available glxinfo output
2021-08-03 15:34:41,744: Invalid glxinfo received
2021-08-03 15:34:41,938: No cores found
2021-08-03 15:34:41,992: Initializing lutris
2021-08-03 15:34:42,341: Downloading DXVK releases to /home/skyhead/.local/share/lutris/runtime/dxvk/dxvk_versions.json
2021-08-03 15:34:42,520: Writing to /home/skyhead/.local/share/lutris/runtime/dxvk/dxvk_versions.json
2021-08-03 15:34:42,522: Runtime updated. Initialization complete.
INFO 2021-08-03 15:34:42,524 [application.do_command_line:315]:Lutris 0.5.8.4
WARNING 2021-08-03 15:34:42,524 [startup.check_driver:64]:glxinfo is not available on your system, unable to detect driver version
INFO 2021-08-03 15:34:42,525 [startup.check_driver:69]:GPU: 8086:191B 17AA:3802 (i915 drivers)
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
DEBUG 2021-08-03 15:34:46,961 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/system32/dxgi with DXVK version
DEBUG 2021-08-03 15:34:46,962 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/system32/d3d11 with DXVK version
DEBUG 2021-08-03 15:34:46,963 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/system32/d3d10core with DXVK version
DEBUG 2021-08-03 15:34:46,964 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/system32/d3d9 with DXVK version
DEBUG 2021-08-03 15:34:46,965 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/system32/d3d12 with DXVK version
DEBUG 2021-08-03 15:34:46,967 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/syswow64/dxgi with DXVK version
DEBUG 2021-08-03 15:34:46,967 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/syswow64/d3d11 with DXVK version
DEBUG 2021-08-03 15:34:46,968 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/syswow64/d3d10core with DXVK version
DEBUG 2021-08-03 15:34:46,969 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/syswow64/d3d9 with DXVK version
DEBUG 2021-08-03 15:34:46,970 [dxvk.enable_dxvk_dll:145]:Replacing /home/skyhead/Games/world-of-warcraft-classic/drive_c/windows/syswow64/d3d12 with DXVK version
DEBUG 2021-08-03 15:34:47,859 [xrandr._get_vidmodes:15]:Retrieving video modes from XrandR
DEBUG 2021-08-03 15:34:47,873 [command.start:131]:SDL_VIDEO_FULLSCREEN_DISPLAY="off"
DEBUG 2021-08-03 15:34:47,873 [command.start:131]:__NV_PRIME_RENDER_OFFLOAD="1"
DEBUG 2021-08-03 15:34:47,873 [command.start:131]:__GLX_VENDOR_LIBRARY_NAME="nvidia"
DEBUG 2021-08-03 15:34:47,873 [command.start:131]:__VK_LAYER_NV_optimus="NVIDIA_only"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:VK_ICD_FILENAMES="/usr/share/vulkan/icd.d/nvidia_icd.json"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:STEAM_RUNTIME="/home/skyhead/.local/share/lutris/runtime/steam"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:LD_LIBRARY_PATH="/home/skyhead/.local/share/lutris/runners/wine/lutris-6.0-x86_64/lib:/home/skyhead/.local/share/lutris/runners/wine/lutris-6.0-x86_64/lib64:/usr/lib/libfakeroot:/usr/lib/openmpi:/usr/lib32:/usr/lib:/usr/lib64:/home/skyhead/.local/share/lutris/runtime/lib32:/home/skyhead/.local/share/lutris/runtime/steam/i386/lib/i386-linux-gnu:/home/skyhead/.local/share/lutris/runtime/steam/i386/lib:/home/skyhead/.local/share/lutris/runtime/steam/i386/usr/lib/i386-linux-gnu:/home/skyhead/.local/share/lutris/runtime/steam/i386/usr/lib:/home/skyhead/.local/share/lutris/runtime/lib64:/home/skyhead/.local/share/lutris/runtime/steam/amd64/lib/x86_64-linux-gnu:/home/skyhead/.local/share/lutris/runtime/steam/amd64/lib:/home/skyhead/.local/share/lutris/runtime/steam/amd64/usr/lib/x86_64-linux-gnu:/home/skyhead/.local/share/lutris/runtime/steam/amd64/usr/lib:$LD_LIBRARY_PATH"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:DXVK_HUD="compiler"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:DXVK_STATE_CACHE_PATH="/home/skyhead/Games/world-of-warcraft-classic"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:STAGING_SHARED_MEMORY="1"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:__GL_SHADER_DISK_CACHE="1"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:__GL_SHADER_DISK_CACHE_PATH="/home/skyhead/Games/world-of-warcraft-classic"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:WINEDEBUG="-all"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:WINEARCH="win64"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:WINE="/home/skyhead/.local/share/lutris/runners/wine/lutris-6.0-x86_64/bin/wine"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:GST_PLUGIN_SYSTEM_PATH_1_0="/home/skyhead/.local/share/lutris/runners/wine/lutris-6.0-x86_64/lib64/gstreamer-1.0/:/home/skyhead/.local/share/lutris/runners/wine/lutris-6.0-x86_64/lib/gstreamer-1.0/"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:WINEPREFIX="/home/skyhead/Games/world-of-warcraft-classic"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:WINEESYNC="1"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:WINEFSYNC="1"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:WINEDLLOVERRIDES="d3d10core,d3d11,d3d12,d3d9,dxgi=n;winemenubuilder.exe=d;nvapi,nvapi64="
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:WINE_LARGE_ADDRESS_AWARE="1"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:game_name="World of Warcraft (Classic)"
DEBUG 2021-08-03 15:34:47,874 [command.start:131]:PYTHONPATH="/usr/lib/lutris:/usr/bin:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/lib/python3.9/site-packages"
DEBUG 2021-08-03 15:34:47,874 [command.start:132]:/usr/share/lutris/bin/lutris-wrapper World of Warcraft (Classic) 0 2 Agent.exe Battle.net Helper.exe /home/skyhead/.local/share/lutris/runners/wine/lutris-6.0-x86_64/bin/wine /home/skyhead/Games/world-of-warcraft-classic/drive_c/Program Files (x86)/Battle.net/Battle.net.exe
lutris-wrapper: World of Warcraft (Classic)
Running /home/skyhead/.local/share/lutris/runners/wine/lutris-6.0-x86_64/bin/wine /home/skyhead/Games/world-of-warcraft-classic/drive_c/Program Files (x86)/Battle.net/Battle.net.exe
Initial process has started with pid 7068
Start monitoring process.
fsync: up and running.
info: Game: Battle.net.exe
info: DXVK: v1.8.1
info: Built-in extension providers:
info: Win32 WSI
info: OpenVR
info: OpenXR
info: OpenVR: could not open registry key, status 2
warn: OpenVR: Failed to locate module
info: Required Vulkan extension VK_KHR_surface not supported
err: DxvkInstance: Failed to create instance
err: D3D11CreateDevice: Failed to create a DXGI factory
[0803/153455.789:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
[0803/153457.364:ERROR:network_change_notifier_win.cc(142)] WSALookupServiceBegin failed with: 0
[0803/153501.764:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0803/153501.766:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
[0803/153505.870:ERROR:gl_surface_egl.cc(787)] EGL Driver message (Critical) eglInitialize: No available renderers.
[0803/153505.870:ERROR:gl_surface_egl.cc(1273)] eglInitialize D3D11 failed with error EGL_NOT_INITIALIZED, trying next display type
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
terminate called after throwing an instance of 'dxvk::DxvkError'
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
[0803/153515.639:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0803/153515.641:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
[0803/153520.104:ERROR:gl_surface_egl.cc(787)] EGL Driver message (Critical) eglInitialize: No available renderers.
[0803/153520.104:ERROR:gl_surface_egl.cc(1273)] eglInitialize D3D11 failed with error EGL_NOT_INITIALIZED, trying next display type
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
[0803/153529.982:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0803/153529.984:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
[0803/153534.386:ERROR:gl_surface_egl.cc(787)] EGL Driver message (Critical) eglInitialize: No available renderers.
[0803/153534.386:ERROR:gl_surface_egl.cc(1273)] eglInitialize D3D11 failed with error EGL_NOT_INITIALIZED, trying next display type
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
info: DXVK: v1.8.1
info: Win32 WSI
info: OpenVR
info: OpenXR
[0803/153544.773:ERROR:dxva_video_decode_accelerator_win.cc(1397)] DXVAVDA fatal error: could not LoadLibrary: msmpeg2vdec.dll: Module not found. (0x7E)
[0803/153544.775:ERROR:dxva_video_decode_accelerator_win.cc(1405)] DXVAVDA fatal error: could not LoadLibrary: msvproc.dll: Module not found. (0x7E)
[0803/153615.894:INFO:cef_logging.h(628)] BNET, sending query, close window
Initial process has exited (return code: 0)
