If I installed Manjaro on another partition, then deleted all but home on this ^ have the other use this as a /home partition?
Better to copy the content of /home elsewhere (to an ext4-formatted USB, for example), then setup your new installation however you like, with a separate /home partition (wherever is convenient), and copy your data back to the new /home.
Naturally, do all this copying from a Manjaro Installer ISO environment (or similar). I seem to recall some rather detailed instructions posted a few times.
The recent update has me thinking about it, I had to get it reinstalled because KDE breifly flashed up twice & went back to a black screen, only mouse & Psensors up. No idea what caused it, but it is btrfs now. So if I drag & drop/copy & paste that will copy all right? Show hidden files is checked. So anyone know what broke manjaro on this update?
Only if you move all of the /home/* directories on that partition into the root directory of that partition, or else you will be left with /home/home/.
However, moving /home — or rather, the contents of /home — onto another partition does not require installing Manjaro on that partition first. I’ve even written a tutorial/guide about it. ![]()
Rather than have a completely separate /home, I keep home as-is, using it only for the dotfiles and so forth. I have a separate partition named /Data, for the six user file directories, Desktop, Documents, Downloads, Music, Pictures, and Videos.
The trick is this is: In KDE System Settings, under Sessions, then Locations, change the folder locations from the default to your preferred location.
THIS WON’T BE PERMANENT UNTIL: After testing, you have to make the config immutible with:
sudo chattr +i ~/.config/user-dirs.dirs
I take it a step further with my desktop which has two nvme SSDs. On the first lives the standard installed filesystem in one partition, a second partition for /Timeshift, then a third partition, /Docs, that contains Desktop, Documents and Downloads. Then on a second 8TB nvme SSD named /MediaFiles, there lives Music, Pictures and Videos.
Works a charm.
It helps keep backups clean in case restores need to be made to a different machine, and it’s easier to not mess things up when I rsync across the LAN.
Why are you putting the mountpoint(s) for user-owned directories under the root directory? That’s Microsoft -think, going back to the volume-oriented approach to storage of DOS and Windows.
UNIX is a multi-user operating system. So why not create the mountpoints inside your $HOME, which is what $HOME is for?
Once the filesystems are mounted where you keep your documents, pictures, and so on, there won’t be any difference anymore between having their contents on separate filesystems or inside your home directory.
If you are planning to reinstall, then lay your plans in advance.
First, a note about mounting - for many years now I mount my HDD’s under /mnt.
I have a Toshiba 3TB, named ‘T3’ and mounted as ‘/mnt/T3’ and it shows up in Dolphin as ‘T3’… then there’s T4 and W2 (a very old 2TB WesternDigital).
First, take a full backup of your entire /home directory - you can use back-in-time or something similar - put the backup on an external HDD or storage drive. Mine goes to /mnt/T3/Backups.
The easiest and most reliable way of setting these mounts is using gnome-disks; this means you won’t mess up your fstab… then it’s very easy to set them up in exactly the same way in under 5 minutes if you reinstall.
Second, generate a pkglist and move that to your backup folder
⮞ pacman -Qqet | grep -v "$(pacman -Qqg)" | grep -v "$(pacman -Qqm)">~/Desktop/package-list.txt
Let’s not forget flatpak: flatpak list > ~/Desktop/flatpaks.txt
Then just reinstall. You can copy back folders from the backups, and you can selectively reinstall from your package-list.txt; deleting as you install, or deleting any you just don’t want to reinstall. You can selectively copy back any related files from your ~/.config folder.
