Hi, I am trying to start wotlk 3.3.5a on warmane server. Have download client and trying to start it with “wine wow.exe”. After login screen it just freezes. Also did trying with lutris where it fully occupied my ssd with 250GB while copying files( donnt know why). using wine 5.22
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=de8d00fc-3d0b-42da-9a90-cbc1c646ee82 rw quiet apparmor=1
security=apparmor resume=UUID=b6638aa8-33ae-4d62-a9b4-fef3c99b1fcb udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: AB350M-DS3H V2 v: N/A serial: <filter>
Mobo: Gigabyte model: AB350M-DS3H V2-CF v: x.x serial: <filter> UEFI: American Megatrends v: F51 date: 08/03/2020
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 81468
Speed: 2933 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 2933 2: 1371 3: 1358 4: 1286 5: 1441
6: 1424 7: 1378 8: 1365 9: 1630 10: 1413 11: 1416 12: 1616
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus ID: 07:00.0 chip ID: 1002:67df
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x237mm (16.7x9.3") s-diag: 485mm (19.1")
Monitor-1: HDMI-A-0 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8") diag: 508mm (20")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.39.0 5.9.11-3-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.2.3
direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Sapphire Limited driver: snd_hda_intel
v: kernel bus ID: 07:00.1 chip ID: 1002:aaf0
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 09:00.3 chip ID: 1022:1457
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus ID: 05:00.0 chip ID: 10ec:8168
IF: enp5s0 state: down mac: <filter>
Device-2: TP-Link TL-WN822N Version 4 RTL8192EU type: USB driver: rtl8192eu bus ID: 3-3:2 chip ID: 2357:0108
serial: <filter>
IF: wlp8s0f3u3 state: up mac: <filter>
Drives: Local Storage: total: 465.76 GiB used: 202.35 GiB (43.4%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8500G size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: S5Z42105 scheme: GPT
Partition: ID-1: / raw size: 456.66 GiB size: 448.50 GiB (98.21%) used: 202.35 GiB (45.1%) fs: ext4 dev: /dev/nvme0n1p2
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 33.6 C mobo: N/A gpu: amdgpu temp: 26.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 768
Info: Processes: 280 Uptime: 15m Memory: 7.78 GiB used: 1.40 GiB (18.0%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1283 lib: 377 flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.08
some wine output
0024:err:module:open_builtin_file failed to load .so lib "/usr/lib32/wine/l3codeca.acm.so"
archive Data\enUS\patch-enUS.MPQ opened
archive Data\patch.MPQ opened
archive Data\enUS\patch-enUS-2.MPQ opened
archive Data\enUS\patch-enUS-3.MPQ opened
archive Data\patch-2.MPQ opened
archive Data\patch-3.MPQ opened
archive Data\expansion.MPQ opened
archive Data\lichking.MPQ opened
archive Data\common.MPQ opened
archive Data\common-2.MPQ opened
archive Data\enUS\locale-enUS.MPQ opened
archive Data\enUS\speech-enUS.MPQ opened
archive Data\enUS\expansion-locale-enUS.MPQ opened
archive Data\enUS\lichking-locale-enUS.MPQ opened
archive Data\enUS\expansion-speech-enUS.MPQ opened
archive Data\enUS\lichking-speech-enUS.MPQ opened
0024:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
00fc:fixme:d3d:state_linepattern_w Setting line patterns is not supported in OpenGL core cntexts.
0024:fixme:imm:ImmReleaseContext (00030054, 001DDBC8): stub
0128:err:winediag:gnutls_initialize failed to load libgnutls, no support for encryption
0128:err:winediag:gnutls_initialize failed to load libgnutls, no support for pfx import/exort
0024:err:ntdll:RtlpWaitForCriticalSection section 7BC60340 "../wine/dlls/ntdll/loader.c: lader_section" wait timed out in thread 0024, blocked by 0128, retrying (60 sec)
tnx
