My system freezes, sometimes a few times a day. There is no obvious pattern that I can see - sometimes the system will freeze while I’m using it, sometimes while I’m AFK, sometimes while the system has been suspended. When the system freezes, usually the keyboard and mouse are no longer powered up, the machine is no longer pingable on the network.
I have been checking journalctl -b -1 after these freezes recently, but there is nothing obvious to me there.
I have had some hassles with the PCIe wifi adapter in the past and, following some advice,
- blacklisted r8168 kernel module
- loaded r8169 kernel module
Despite this change I do sometimes get erratic network connectivity which sudo systemctl restart NetworkManager sometimes resolves.
I have mostly kept up-to-date on kernel version and mobo BIOS.
I generally run the following programs:
- i3wm
- firefox (heavily)
- alacritty (many instances)
I do sometimes hear a very feint clicking sound (~0.5Hz) when the system has frozen, like there is a relay or a solenoid activating, or a fan spinning up and then down again.
Please let me know if you have any hints that can help me try to find the culprit. What can I monitor? Which logs should I be checking?
inxi:
System: Kernel: 5.14.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: i3 4.20.1 info: i3bar dm: LightDM 1.30.0
Machine: Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: N/A
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: N/A UEFI: American Megatrends v: F50 date: 11/27/2019
CPU: Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+ rev: 2 cache: L1: 768 KiB L2: 4 MiB
L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 102227
Speed: 2454 MHz min/max: 1550/3200 MHz boost: enabled volts: 1.0 V ext-clock: 100 MHz Core speeds (MHz): 1: 2962
2: 1535 3: 1424 4: 1482 5: 1619 6: 1381 7: 1379 8: 1321 9: 1486 10: 1469 11: 1539 12: 1398 13: 1269 14: 1338
15: 2769 16: 1612
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Gigabyte
driver: amdgpu v: kernel bus-ID: 07:00.0 chip-ID: 1002:67df class-ID: 0300
Device-2: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-4:5 chip-ID: 046d:082b
class-ID: 0102
Display: server: X.Org 1.21.1.1 compositor: picom v: git-dac85 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa resolution: 3840x2160~60Hz s-dpi: 96
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.42.0 5.14.18-1-MANJARO LLVM 13.0.0) v: 4.6 Mesa 21.2.5
direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 07:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Asahi Kasei Microsystems AK5370 I/F A/D Converter type: USB driver: snd-usb-audio bus-ID: 3-2:3
chip-ID: 0556:0001 class-ID: 0102
Device-4: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-4:5 chip-ID: 046d:082b
class-ID: 0102
Sound Server-1: ALSA v: k5.14.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK driver: rtl8192ce v: kernel port: d000
bus-ID: 06:00.0 chip-ID: 10ec:8178 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus-ID: 3-3:4
chip-ID: 0a12:0001 class-ID: e001
Drives: Local Storage: total: 342.81 GiB used: 156.07 GiB (45.5%)
ID-1: /dev/nvme0n1 vendor: Gigabyte model: GP-GSM2NE8128GNTD size: 119.24 GiB speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: E8TM14.2 temp: 40.9 C scheme: GPT
ID-2: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB speed: 6.0 Gb/s type: SSD serial: <filter>
rev: R013 scheme: GPT
Partition: ID-1: / size: 116.58 GiB used: 98.14 GiB (84.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 7.9 MiB (2.6%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 50.9 C mobo: 16.8 C gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 708
Info: Processes: 305 Uptime: 10m wakeups: 0 Memory: 31.3 GiB used: 2.13 GiB (6.8%) Init: systemd v: 249 Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1467 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8
running-in: alacritty inxi: 3.3.09
