Workaround to fix Microsoft Edge based Web Apps not having there own icon when Wayland is enabled
I had this issues when I enabled WAYLAND for ms-edge using the ~/.config/microsoft-edge-stable-flags.conf file
--enable-features=WebRTCPipeWireCapturer
--enable-features=UseOzonePlatform
--ozone-platform=wayland
I was able to find the WMClass for the “App” after opening it using this
unix[dot]stackexchange[dot]com/questions/362731/how-to-identify-window-by-clicking-in-wayland
Once I knew that, all I had to do was rename the .desktop file based on it. Which was just adding _ to the name e.g.
mv msedge-hpfldicfbfomlpcikngkocigghgafkph-Default.desktop msedge-_hpfldicfbfomlpcikngkocigghgafkph-Default.desktop
And I got the “Icons” like how it was before. :slight_smile:
PS: (29-11-2022)
This worked but when the “App” receives a notification, clicking on it doesn’t focus to the app window.
For now, just switched to Firefox.
PS: (12-12-2022)
Seems like this issue is only present in MS Edge and works as expected in Chrome, Brave.
On KDE Plasma, there is also one more thing that can lead to PWAs using MS Edge icon…
If you have your task-manager in panel with option to group icons based on the app name, since PWAs got ‘msedge’ prefix, they get grouped with MS Edge icon as a same app…
This tutorial may be useful to you:
Yeah, this is annoying as well. Hope this gets sorted out across all the chromium browsers. i.e. PWA being treated as its own application
Yeah. thanks… This is helpful, when using a GTK application.
Not sure why this is a thing. why not all the apps have the name set correctly. :sleepy:
