How to resolve dbus conflict
:: Replace python-dbus with extra/dbus-python? [Y/n]
:: Replace python-dbus-common with extra/dbus-python? [Y/n]
uninstall the package(s) requiring dbus-python - then reinstall them
Can you be more specific, thank you
You can find out what on your system requires dbus-python using pacman -Qi dbus-python
How more specific does it get? I listed the packages which depends on dbus-python - and I cannot possibly know which is installed on your system.
Depends On : dbus glib2 python-dbus-common python2
And
sudo pacman -Rs glib2 python-dbus-common python2
checking dependencies…
:: removing glib2 breaks dependency ‘glib2’ required by accountsservice
:: removing glib2 breaks dependency ‘glib2’ required by at-spi2-core
:: removing glib2 breaks dependency ‘glib2’ required by atk
:: removing glib2 breaks dependency ‘glib2’ required by audacious
:: removing glib2 breaks dependency ‘glib2’ required by avahi
And so on…
You need to be looking at Required By not Depends On
For example mine shows:
Required By : ibus lutris pulseaudio-equalizer system-config-printer
Okay,
Required By : python2-pyqt4
I removed it, and make a update.
Everything is fine, thank you all for your help.
