Well, it appears to be working after a couple of shutdown/startup cycles.
It doesn’t like to do a restart though.
If a software install say it needs to restart, it hangs just as it did before.
Strange.
Strange.
try different kernels, install the 5.15, boot with it, and test if it has also the same hangs
Will do, but I am traveling for 3 weeks beginning tomorrow. So, it will have to wait until I return.
Thanks again to your and everyone else for the help!
UEFI, create a profile for linux
recheck all option in your UEFI ( for linux)
SecureBoot off
Fast Boot off
No CSM
No Legacy
all disks on AHCI
boot only on UEFI:<partition 1> → EFI install manjaro
you can check in terminal , before install
inxi -Fxza
test -d /sys/firmware/efi && echo efi || echo bios
sudo efibootmgr -v
sudo parted -l
