Wireplumber: Unable to populate media device, permission denied
Hi,
I installed recently Hyprland from an initial Manjaro i3 distro, on a Dell XPS 9530.
Currently I installed manjaro-pipewire with Wireplumber, but I get permission issues, which no one seemed to have when I searched for it.
Here is the output of systemctl --user status pipewire{,-pulse} wireplumber:
● pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
     Active: active (running) since Sun 2024-03-10 16:24:46 AST; 12min ago
TriggeredBy: ● pipewire.socket
   Main PID: 1451 (pipewire)
      Tasks: 3 (limit: 76640)
     Memory: 8.5M (peak: 8.9M)
        CPU: 48ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─1451 /usr/bin/pipewire
Mar 10 16:24:46 isos9-xps159530 systemd[1439]: Started PipeWire Multimedia Service.
● pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
TriggeredBy: ● pipewire-pulse.socket
   Main PID: 1454 (pipewire-pulse)
     Memory: 4.3M (peak: 4.6M)
        CPU: 22ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
             └─1454 /usr/bin/pipewire-pulse
Mar 10 16:24:46 isos9-xps159530 systemd[1439]: Started PipeWire PulseAudio.
● wireplumber.service - Multimedia Service Session Manager
     Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
   Main PID: 1452 (wireplumber)
      Tasks: 7 (limit: 76640)
     Memory: 14.2M (peak: 16.1M)
        CPU: 238ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
             └─1452 /usr/bin/wireplumber
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.026780814] [1452] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.026792546] [1452] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.026810946] [1452]  INFO Camera camera_manager.cpp:284 libcamera v0.2.0
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.028756131] [1483] ERROR MediaDevice media_device.cpp:483 /dev/media0[]: Failed to open media device at /dev/media0: Permission denied
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.028781919] [1483]  INFO DeviceEnumerator device_enumerator.cpp:224 Unable to populate media device /dev/media0 (Permission denied), skipping
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.028790930] [1483]  WARN DeviceEnumerator device_enumerator_udev.cpp:174 Failed to add device for '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.0/media0', skipping
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.028938200] [1483] ERROR MediaDevice media_device.cpp:483 /dev/media1[]: Failed to open media device at /dev/media1: Permission denied
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.028947762] [1483]  INFO DeviceEnumerator device_enumerator.cpp:224 Unable to populate media device /dev/media1 (Permission denied), skipping
Mar 10 16:24:46 isos9-xps159530 wireplumber[1452]: [0:00:27.028953884] [1483]  WARN DeviceEnumerator device_enumerator_udev.cpp:174 Failed to add device for '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.2/media1', skipping
Mar 10 16:25:04 isos9-xps159530 wireplumber[1452]: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
From my research it seems that the libcamera error can be ignored, but the permission issues with /dev/media, I can’t find where this is coming from, because both (wireplumber & /dev/media) seems to have the correct permissions set for it.
Permissions Size User Date Modified Name
.rw-r--r--   473 root  3 Dec  2023  /usr/lib/systemd/user/wireplumber.service
crw-rw----@ 506,0 root 10 Mar 16:24  /dev/media0
crw-rw----@ 506,1 root 10 Mar 16:24  /dev/media1
Here is other informations that could be useful if that can help resolve this:
OS: Manjaro 23.1.3 Vulcan
Kernel: x86_64 Linux 6.8.0-1-MANJARO
Uptime: 17m
Packages: 1605
Shell: zsh 5.9
Resolution: No X Server
WM: wlroots wm
GTK Theme: Adapta-Nokto-Eta-Maia [GTK2/3]
Icon Theme: Papirus-Adapta-Nokto-Maia
Font: Noto Sans 10
Disk: 104G / 903G (13%)
CPU: 13th Gen Intel Core i7-13700H @ 20x 4.8GHz [56.0°C]
GPU: NVIDIA GeForce RTX 4060 Laptop GPU
RAM: 4373MiB / 63975MiB
> sudo fuser -v /dev/snd/*
                     USER        PID ACCESS COMMAND
/dev/snd/controlC0:  isos9     F.... pipewire
                     isos9     F.... wireplumber
/dev/snd/seq:        isos9     F.... pipewire
> pactl list cards
Card #47
	Driver: alsa
	Owner Module: n/a
	Properties:
		api.acp.auto-port = "false"
		api.alsa.card = "0"
		api.alsa.card.longname = "DellInc.-XPS159530--0P6GXD"
		api.alsa.card.name = "sof-hda-dsp"
		api.alsa.path = "hw:0"
		api.alsa.use-acp = "true"
		device.api = "alsa"
		device.bus = "pci"
		device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
		device.description = "Raptor Lake-P/U/H cAVS"
		device.enum.api = "udev"
		device.icon_name = "audio-card-analog-pci"
		device.name = "alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic"
		device.nick = "sof-hda-dsp"
		device.plugged.usec = "21894362"
		device.product.id = "0x51ca"
		device.product.name = "Raptor Lake-P/U/H cAVS"
		device.subsystem = "sound"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
		device.vendor.id = "0x8086"
		media.class = "Audio/Device"
		factory.id = "14"
		client.id = "34"
		object.id = "47"
		object.serial = "47"
		object.path = "alsa:pcm:0"
		alsa.card = "0"
		alsa.card_name = "sof-hda-dsp"
		alsa.long_card_name = "DellInc.-XPS159530--0P6GXD"
		alsa.driver_name = "snd_soc_skl_hda_dsp"
		device.string = "0"
	Profiles:
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
		HiFi: Play HiFi quality Music (sinks: 4, sources: 2, priority: 8000, available: yes)
		pro-audio: Pro Audio (sinks: 5, sources: 3, priority: 1, available: yes)
	Active Profile: HiFi
	Ports:
		[Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, latency offset: 0 usec, availability group: HDMI/DP,pcm=5, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "HDMI/DP,pcm=5"
				card.profile.port = "0"
			Part of profile(s): HiFi
		[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, latency offset: 0 usec, availability group: HDMI/DP,pcm=4, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "HDMI/DP,pcm=4"
				card.profile.port = "1"
		[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, latency offset: 0 usec, availability group: HDMI/DP,pcm=3, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "HDMI/DP,pcm=3"
				card.profile.port = "2"
		[Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "speaker"
				card.profile.port = "3"
		[Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, availability group: Headphone Mic, not available)
			Properties:
				port.type = "headphones"
				port.availability-group = "Headphone Mic"
				card.profile.port = "4"
		[In] Headset: Headset Mono Microphone (type: Headset, priority: 300, latency offset: 0 usec, availability group: Headphone Mic, not available)
			Properties:
				port.type = "headset"
				device.icon_name = "audio-headset"
				card.profile.port = "5"
		[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, availability group: Headphone Mic, not available)
			Properties:
				port.type = "mic"
				card.profile.port = "6"
		[In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "mic"
				card.profile.port = "7"
> > pactl list sinks
Sink #48
	State: SUSPENDED
	Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink
	Description: Raptor Lake-P/U/H cAVS HDMI / DisplayPort 3 Output
	Driver: PipeWire
	Sample Specification: s24-32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "0"
		alsa.class = "generic"
		alsa.device = "5"
		alsa.id = "HDMI3 (*)"
		alsa.mixer_device = "_ucm0001.hw:sofhdadsp"
		alsa.name = ""
		alsa.resolution_bits = "16"
		alsa.subclass = "generic-mix"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		api.alsa.open.ucm = "true"
		api.alsa.path = "hw:sofhdadsp,5"
		api.alsa.pcm.card = "0"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		card.profile.device = "0"
		device.api = "alsa"
		device.class = "sound"
		device.id = "47"
		device.profile.description = "HDMI / DisplayPort 3 Output"
		device.profile.name = "HiFi: hw:sofhdadsp,5: sink"
		device.routes = "1"
		factory.name = "api.alsa.pcm.sink"
		media.class = "Audio/Sink"
		node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink"
		node.nick = "HDMI / DisplayPort 3 Output"
		node.pause-on-idle = "false"
		object.path = "alsa:pcm:0:hw:sofhdadsp,5:playback"
		priority.driver = "664"
		priority.session = "664"
		factory.id = "18"
		clock.quantum-limit = "8192"
		client.id = "34"
		node.driver = "true"
		factory.mode = "merge"
		audio.adapt.follower = ""
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "48"
		object.serial = "48"
		api.alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Ports:
		[Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, availability group: HDMI/DP,pcm=5, not available)
	Active Port: [Out] HDMI3
	Formats:
		pcm
Sink #49
	State: SUSPENDED
	Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink
	Description: Raptor Lake-P/U/H cAVS HDMI / DisplayPort 2 Output
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor
	Properties:
		alsa.card = "0"
		alsa.device = "4"
		alsa.id = "HDMI2 (*)"
		alsa.name = ""
		api.alsa.path = "hw:sofhdadsp,4"
		card.profile.device = "1"
		device.api = "alsa"
		device.id = "47"
		device.profile.description = "HDMI / DisplayPort 2 Output"
		device.profile.name = "HiFi: hw:sofhdadsp,4: sink"
		device.routes = "1"
		node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink"
		node.nick = "HDMI / DisplayPort 2 Output"
		object.path = "alsa:pcm:0:hw:sofhdadsp,4:playback"
		priority.driver = "680"
		priority.session = "680"
		factory.id = "18"
		client.id = "34"
		object.id = "49"
		object.serial = "49"
		api.alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Ports:
		[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, availability group: HDMI/DP,pcm=4, not available)
	Active Port: [Out] HDMI2
	Formats:
		pcm
Sink #50
	State: SUSPENDED
	Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink
	Description: Raptor Lake-P/U/H cAVS HDMI / DisplayPort 1 Output
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor
	Properties:
		alsa.card = "0"
		alsa.device = "3"
		alsa.id = "HDMI1 (*)"
		alsa.name = ""
		api.alsa.path = "hw:sofhdadsp,3"
		card.profile.device = "2"
		device.api = "alsa"
		device.id = "47"
		device.profile.description = "HDMI / DisplayPort 1 Output"
		device.profile.name = "HiFi: hw:sofhdadsp,3: sink"
		device.routes = "1"
		node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink"
		node.nick = "HDMI / DisplayPort 1 Output"
		object.path = "alsa:pcm:0:hw:sofhdadsp,3:playback"
		priority.driver = "696"
		priority.session = "696"
		factory.id = "18"
		client.id = "34"
		object.id = "50"
		object.serial = "50"
		api.alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Ports:
		[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, availability group: HDMI/DP,pcm=3, not available)
	Active Port: [Out] HDMI1
	Formats:
		pcm
Sink #51
	State: SUSPENDED
	Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
	Description: Raptor Lake-P/U/H cAVS Speaker + Headphones
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Mute: no
	Volume: front-left: 36047 /  55% / -15.58 dB,   front-right: 36047 /  55% / -15.58 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "0"
		alsa.device = "0"
		alsa.id = "HDA Analog (*)"
		alsa.name = ""
		api.alsa.path = "hw:sofhdadsp"
		card.profile.device = "3"
		device.api = "alsa"
		device.id = "47"
		device.profile.description = "Speaker + Headphones"
		device.profile.name = "HiFi: hw:sofhdadsp: sink"
		device.routes = "2"
		node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink"
		node.nick = "Speaker + Headphones"
		object.path = "alsa:pcm:0:hw:sofhdadsp:playback"
		priority.driver = "1000"
		priority.session = "1000"
		factory.id = "18"
		client.id = "34"
		object.id = "51"
		object.serial = "51"
		api.alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Ports:
		[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
		[Out] Headphones: Headphones (type: Headphones, priority: 200, availability group: Headphone Mic, not available)
	Active Port: [Out] Speaker
	Formats:
		pcm
pactl list sink-inputs doesn’t return me anything, I don’t know if that suppose to mean something.
Any hep would be really appreciated, it seems that I can’t screen share on Hyprland because of this, so I try to resolve this.
Thanks
pulse-cli-syntax(5) — Arch manual pages
list-sink-inputs
Show all currently active inputs to sinks a.k.a. playback streams
pactl list sinks shows all 3 sinks are suspended that suggests no audio is playing
Null response from pactl list sink-inputs confirms no active audio playback streams
What could suspend them? What does that mean for the playback stream? is there anything to do to have playback stream?
And also I can play audio on my computer in this state
Sinks are usually suspended when idle (no audio streams playing) to save battery power on laptops
PulseAudio uses module-suspend-on-idle to suspend sinks when no audio is playing
PipeWire uses session.suspend-timeout-seconds property in the session manager (wireplumber or pipewire-media-session)
Sinks are de-suspended automatically when needed to play an audio stream
pactl list sinks will show a different State: for the active sink
and pactl list sink-inputs will show information about the audio stream playing to the active sink
Ok understood, thanks.
So here is the outputs with active audio
Sink Input #190
	Driver: PipeWire
	Owner Module: n/a
	Client: 189
	Sink: 160
	Sample Specification: float32le 2ch 48000Hz
	Format: pcm, format.sample_format = "\"float32le\""  format.rate = "48000"  format.channels = "2"  format.channel_map = "\"front-left,front-right\""
	Corked: no
	Mute: no
	        balance 0.00
	Buffer Latency: 0 usec
	Sink Latency: 0 usec
	Resample method: PipeWire
	Properties:
		client.api = "pipewire-pulse"
		pulse.server.type = "unix"
		application.name = "Google Chrome"
		application.process.id = "3893"
		application.process.user = "isos9"
		application.process.host = "isos9-xps159530"
		application.process.binary = "chrome"
		application.language = "en_US.UTF-8"
		window.x11.display = ":1"
		application.process.machine_id = "146ead07481b4d48af29f2684dbcea3c"
		application.process.session_id = "2"
		application.icon_name = "google-chrome"
		media.name = "Playback"
		node.rate = "1/48000"
		node.latency = "1024/48000"
		stream.is-live = "true"
		node.name = "Google Chrome"
		node.want-driver = "true"
		node.autoconnect = "true"
		media.class = "Stream/Output/Audio"
		adapt.follower.spa-node = ""
		object.register = "false"
		factory.id = "6"
		factory.mode = "split"
		client.id = "77"
		object.id = "79"
		object.serial = "190"
		pulse.attr.maxlength = "4194304"
		pulse.attr.tlength = "16384"
		pulse.attr.prebuf = "12296"
		pulse.attr.minreq = "4096"
		module-stream-restore.id = "sink-input-by-application-name:Google Chrome"
> pactl list sinks
Sink #157
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		alsa.card = "0"
		alsa.device = "5"
		alsa.mixer_device = "_ucm0003.hw:sofhdadsp"
		alsa.name = ""
		device.api = "alsa"
		device.id = "63"
		device.routes = "1"
		factory.id = "18"
		client.id = "34"
		object.id = "38"
		object.serial = "157"
		api.alsa.card = "0"
		device.bus = "pci"
		device.plugged.usec = "21917842"
		device.string = "0"
	Ports:
	Formats:
		pcm
Sink #158
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		alsa.card = "0"
		alsa.device = "4"
		alsa.name = ""
		device.api = "alsa"
		device.id = "63"
		device.routes = "1"
		factory.id = "18"
		client.id = "34"
		object.id = "48"
		object.serial = "158"
		api.alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Ports:
	Formats:
		pcm
Sink #159
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		alsa.card = "0"
		alsa.device = "3"
		alsa.name = ""
		device.api = "alsa"
		device.id = "63"
		device.routes = "1"
		factory.id = "18"
		client.id = "34"
		object.id = "55"
		object.serial = "159"
		api.alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Ports:
	Formats:
		pcm
Sink #160
	State: RUNNING
	Driver: PipeWire
	Mute: no
	Volume: front-left: 55709 /  85% / -4.23 dB,   front-right: 55709 /  85% / -4.23 dB
	        balance 0.00
	Properties:
		alsa.card = "0"
		alsa.device = "0"
		alsa.name = ""
		device.api = "alsa"
		device.id = "63"
		device.routes = "2"
		factory.id = "18"
		client.id = "34"
		object.id = "62"
		object.serial = "160"
		node.max-latency = "4096/48000"
		api.alsa.period-size = "1024"
		api.alsa.period-num = "8"
		api.alsa.headroom = "0"
		api.alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Ports:
	Formats:
		pcm
pactl list sinks shows analog sink for speakers/headphones has been de-suspended to play audio stream from Google Chrome
Sink #160
	State: RUNNING
Yes, that’s correct, I think you misunderstood my issue, the audio playing is not the issue.
The issue is the errors from wireplumber on the initialization, which I mentioned on my initial post.
do you know what could cause this ?
You arent entirely alone, though this doesnt illuminate much
