Wireless Wifi is too slow (should be ~200mbps but is ~9mbps)
Hello! I have been on Manjaro for around 2 weeks. Been trying to solve the issue by looking through previous forum posts and whatever duck duck go has shown me but it hasn’t worked.
My laptop is an inspiron 5593
inxi -Fza output:
 <b> System:
  Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
    root=UUID=9027d2f1-8e2e-472d-9051-3ec72f25dcd8 rw quiet splash
    resume=UUID=7c52e0be-bfb9-4b62-aeee-1eca7c29e4d4 udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Dell product: Inspiron 5593 v: N/A
  Mobo: Dell model: 09PY2G v: A00 serial: <superuser required> UEFI: Dell
    v: 1.24.0 date: 09/12/2022
  ID-1: BAT0 charge: 23.4 Wh (100.0%) condition: 23.4/42.0 Wh (55.6%)
    volts: 12.6 min: 11.4 model: Samsung SDI DELL 0FJMK9A type: Li-ion
    serial: <filter> status: full
  Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 1446 high: 1500 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1266 2: 1500 3: 1500
    4: 1500 5: 1500 6: 1500 7: 1305 8: 1500 bogomips: 23968
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel
    arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX230] vendor: Dell driver: nvidia
    v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
    status: current (as of 2022-12) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d11
    class-ID: 0302
  Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
    driver: uvcvideo bus-ID: 1-6:4 chip-ID: 1bcf:2b98 class-ID: 0e02
  Display: x11 server: X(.)Org v: 21.1.6 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e5 built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel Iris Plus Graphics
    (ICL GT2) direct render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
    chip-ID: 0cf3:e009 class-ID: e001
  Local Storage: total: 476.94 GiB used: 84.42 GiB (17.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 512GB
    lanes: 4 type: SSD serial: <filter> rev: 11004101 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 30 GiB size: 29.36 GiB (97.87%) used: 25.4 GiB (86.5%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 150.4 MiB (29.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-4: /home raw-size: 52.1 GiB size: 50.98 GiB (97.85%)
    used: 6.94 GiB (13.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 63.0 C mobo: 42.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 248 Uptime: 3m wakeups: 5512 Memory: 15.4 GiB
  used: 2.71 GiB (17.6%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1297 pm: dpkg
  pkgs: 0 pm: pacman pkgs: 1290 libs: 365 tools: pamac pm: flatpak pkgs: 7
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24 </b>
Linux kernel: 6.1.9-1
Edited by contributor. Please use proper formatting in future.
It’s because QCA9377 sucks.
Try deleting /usr/lib/firmware/ath10k/QCA9377/hw1.0/firmware-6.bin.
Reboot and test.
If still slow; try reloading ath10k_pci: (actually do this first, before deleting firmware, just in case)
sudo modprobe -r ath10k_pci && sudo modprobe ath10k_pci
@Tabs, please, always provide full output, in this case ideally
inxi -Fza
but at least
inxi -Nza
in combination with the kernel you are using.
Sadly that did not work, speedtest (from terminal) and Ookla speed test are still showing slow results, btw I did update the post to add more information by a mods request (not sure if you can see that or not, sorry if you already can)
Last thing you can try is downgrading kmod to kmod-git, commit: d29ed6ef9f0db54acda5a51993bba7ff6f8ca7cd.
At least this is what semi-works for me (with random module reloading).
Example PKGBUILD for what it’s worth:
# Maintainer:  Vincent Grande <shoober420@gmail.com>
# Contributor: Dave Reisner <dreisner@archlinux.org>
pkgname=kmod-git
pkgver=v29+22+gd29ed6e
pkgrel=1
pkgdesc="Linux kernel module management tools and library"
arch=('x86_64')
url='https://git.kernel.org/pub/scm/utils/kernel/kmod/kmod.git'
license=('GPL2')
depends=('glibc' 'zlib' 'openssl' 'xz' 'zstd')
checkdepends=('linux-headers' 'libelf')
provides=('module-init-tools=3.16' 'libkmod.so' 'kmod=30')
conflicts=('module-init-tools' 'kmod')
replaces=('module-init-tools')
_commit=('d29ed6ef9f0db54acda5a51993bba7ff6f8ca7cd')
source=("git+https://git.kernel.org/pub/scm/utils/kernel/kmod/kmod.git"
        'depmod-search.conf'
        'depmod.hook' 'depmod.script')
md5sums=('SKIP'
         'dd62cbf62bd8f212f51ef8c43bec9a77'
         'e179ace75721e92b04b2e145b69dab29'
         '18fb3d1f6024a5a84514c8276cb3ebff')
prepare() {
  cd kmod
  git checkout "${_commit}"
pkgver() {
  cd kmod
  git describe --tags | sed 's/-/+/g'
build() {
  cd kmod
  ./autogen.sh
  ./configure \
    --sysconfdir=/etc \
    --with-xz \
    --with-zlib \
    --with-zstd \
    --with-openssl
  make
package() {
  make -C kmod DESTDIR="$pkgdir" install
  # extra directories
  install -dm755 "$pkgdir"/{etc,usr/lib}/{depmod,modprobe}.d
  for tool in {ins,ls,rm,dep}mod mod{probe,info}; do
    ln -s kmod "$pkgdir/usr/bin/$tool"
  done
  # install depmod.d file for search/ dir
  install -Dm644 "$srcdir/depmod-search.conf" "$pkgdir/usr/lib/depmod.d/search.conf"
  # hook
  install -Dm644 "$srcdir/depmod.hook" "$pkgdir/usr/share/libalpm/hooks/60-depmod.hook"
  install -Dm755 "$srcdir/depmod.script" "$pkgdir/usr/share/libalpm/scripts/depmod"
