Wireless network show but does not connect
Greetings All
After upgrade on a Beelink BT3 model wireless connection and also ethernet do not work
I have following hardware
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
	Subsystem: Realtek Semiconductor Co., Ltd. Device [10ec:0123]
	Flags: bus master, fast devsel, latency 0, IRQ 16
	I/O ports at e000 [size=256]
	Memory at 91804000 (64-bit, non-prefetchable) [size=4K]
	Memory at 91800000 (64-bit, prefetchable) [size=16K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, IntMsgNum 1
	Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
	Capabilities: [d0] Vital Product Data
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [140] Virtual Channel
	Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
	Capabilities: [170] Latency Tolerance Reporting
	Kernel driver in use: r8169
	Kernel modules: r8169
And following error in dmesg:
Jan 27 17:56:22 manjaro kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried:
Jan 27 17:56:22 manjaro kernel: Bluetooth: hci0: BCM: 'brcm/BCM4345C0.hcd'
Jan 27 17:56:22 manjaro kernel: Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
Jan 27 17:56:14 manjaro kernel: EXT4-fs (mmcblk0): VFS: Can't find ext4 filesystem
Jan 27 17:56:14 manjaro kernel: EXT4-fs (mmcblk0boot0): VFS: Can't find ext4 filesystem
Jan 27 17:56:14 manjaro kernel: FAT-fs (mmcblk0boot0): bogus number of reserved sectors
Jan 27 17:56:14 manjaro kernel: EXT4-fs (mmcblk0boot1): VFS: Can't find ext4 filesystem
Jan 27 17:56:14 manjaro kernel: FAT-fs (mmcblk0boot1): bogus number of reserved sectors
Jan 27 17:56:23 manjaro kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Jan 27 17:56:23 manjaro kernel: brcmfmac: brcmf_fw_nvram_from_efi: Using nvram EFI variable
Jan 27 17:56:23 manjaro kernel: ieee80211 phy0: brcmf_c_preinit_dcmds: Default MAC is used, replacing with random MAC to avoid conflicts
Jan 27 17:56:24 manjaro kernel: brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
Jan 27 17:56:24 manjaro kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
Jan 27 17:56:27 manjaro kernel: intel_atomisp2_pm 0000:00:03.0: Unable to change power state from D3cold to D0, device inaccessible
Jan 27 17:56:28 manjaro kernel: intel_atomisp2_pm 0000:00:03.0: Unable to change power state from D3cold to D0, device inaccessible
Jan 27 17:57:02 manjaro lightdm[1399]: pam_systemd(lightdm-autologin:session): Failed to get user record: No such process
Jan 27 17:57:02 manjaro lightdm[1399]: gkr-pam: unable to locate daemon control file
Jan 27 17:58:00 manjaro lightdm[1747]: pam_systemd(lightdm-greeter:session): Failed to get user record: No such process
Jan 27 17:58:06 manjaro kernel: ath: phy1: Failed to wakeup in 500us
Jan 27 17:58:13 manjaro lightdm[1831]: gkr-pam: unable to locate daemon control file
Jan 27 17:58:13 manjaro lightdm[1831]: pam_systemd(lightdm:session): Failed to get user record: No such process
Jan 27 17:58:18 manjaro lightdm[1946]: pam_systemd(lightdm-greeter:session): Failed to get user record: No such process
Jan 27 17:58:39 manjaro lightdm[2094]: pam_systemd_home(lightdm:auth): User name not set.
Jan 27 20:29:43 manjaro lightdm[2149]: gkr-pam: unable to locate daemon control file
Jan 27 20:30:37 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0x100e fail, reason -52
Jan 27 20:30:37 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
Jan 27 20:30:37 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
Jan 27 20:30:37 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
Jan 27 20:30:38 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
Jan 27 20:30:38 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd034 fail, reason -52
Jan 27 20:30:38 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd038 fail, reason -52
Jan 27 20:30:38 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd03c fail, reason -52
Jan 27 20:30:38 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd040 fail, reason -52
I can see the network but I cannot connect to it
Can you help?
Thank you
Welcome to the Manjaro Community @lnxpwr78
First, thank-you for providing the above information - I’m sure it will be very helpful to our network experts.
However, could you please also provide some system information by posting the output of:
inxi --filter --verbosity=8
inxi -zv8
Running `inxi` in `chroot`
None of this, and everything in between, has anything to do with your wifi chipset. Which uses the r8169 module.
Find when it gets initialised in journactl -b, that will list everything since you last booted. Find the relevant Realtek module.
Then there might be more information when attempting to use it.
Watch the logs with:
journalctl -f
Then attempt to connect to your network.
Hi! Thank you for you reply.
here is inxi -Fx report:
  Host: manjaro Kernel: 6.18.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 15.2.1
  Desktop: Xfce v: 4.20.1 Distro: Manjaro base: Arch Linux
  Type: Laptop System: AZW product: BT3 PRO v: BT3 PRO serial: N/A
  Mobo: AZW model: BT3 PRO v: BT3 PRO serial: N/A Firmware: UEFI
    vendor: Z85_D303 v: 5.11 date: 11/08/2019
  ID-1: axp288_fuel_gauge charge: 100% condition: N/A health: over voltage
    volts: 4.49 min: N/A model: N/A status: discharging
  Info: quad core model: Intel Atom x5-Z8350 bits: 64 type: MCP arch: Airmont
    rev: 4 cache: L1: 224 KiB L2: 2 MiB
  Speed (MHz): avg: 560 min/max: 480/1920 cores: 1: 560 2: 560 3: 560 4: 560
    bogomips: 11520
  Flags-basic: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
    Integrated Graphics driver: i915 v: kernel arch: Gen-8 bus-ID: 00:02.0
  Display: x11 server: X.org v: 1.21.1.21 driver: X: loaded: modesetting
    dri: crocus gpu: i915 resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: crocus,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics (CHV)
    x11: xprop,xrandr
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
    Imaging Unit driver: intel_atomisp2_pm v: kernel bus-ID: 00:03.0
  API: ALSA v: k6.18.4-1-MANJARO status: kernel-api
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.4.9 status: n/a (root, process)
    driver: r8169 v: kernel port: e000 bus-ID: 01:00.0
  IF: enp1s0 state: down mac: 84:39:c0:0b:01:d6
  Device-2: Qualcomm Atheros AR9271 802.11n driver: ath9k_htc type: USB
    bus-ID: 1-3:5
  IF: wlp0s20u3 state: up mac: d8:5d:4c:90:f1:a8
  IF-ID-1: wlan0 state: down mac: 26:b8:11:76:cf:2f
  Local Storage: total: 65.07 GiB used: 0 KiB (0.0%)
  ID-1: /dev/mmcblk2 vendor: Generic model: SLD64G size: 57.62 GiB
    type: Removable
  ID-2: /dev/sda vendor: SanDisk model: Cruzer Edge size: 7.45 GiB type: USB
  Message: No partition data found.
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 4 GiB available: 3.75 GiB used: 2.2 GiB (58.7%) igpu: 32 MiB
  Processes: 243 Uptime: 14m Init: systemd
  Packages: 1146 Compilers: N/A Shell: Sudo v: 1.9.17p2 inxi: 3.3.40
Note: Actually I am using a wifi dongle to connect: the Atheros
Booting a Mint XFCE Live USB network is connecting without problem, both eth and wifi
Hi Thank you for your reply.
here below journalctl -f output from when I start connection since it stops and fail:
Jan 28 12:22:51 manjaro NetworkManager[768]: <info>  [1769602971.9241] device (wlan0): Activation: starting connection 'Moonbay-Home' (3000cdb1-99a5-4c7b-a9e0-65adb5757699)
Jan 28 12:22:51 manjaro NetworkManager[768]: <info>  [1769602971.9244] audit: op="connection-activate" uuid="3000cdb1-99a5-4c7b-a9e0-65adb5757699" name="Moonbay-Home" pid=2274 uid=1000 result="success"
Jan 28 12:22:51 manjaro NetworkManager[768]: <info>  [1769602971.9247] device (wlan0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Jan 28 12:22:51 manjaro NetworkManager[768]: <info>  [1769602971.9252] manager: NetworkManager state is now CONNECTING
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd034 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd038 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd03c fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd040 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd064 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd068 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd06c fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd070 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd074 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd078 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd07c fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd080 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd084 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd088 fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd08c fail, reason -52
Jan 28 12:22:52 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd090 fail, reason -52
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4406] device (wlan0): set-hw-addr: reset MAC address to C0:84:7D:7D:1E:DA (preserve)
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4477] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full')
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4486] device (wlan0): Activation: (wifi) access point 'Moonbay-Home' has security, but secrets are required.
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4487] device (wlan0): state change: config -> need-auth (reason 'none', managed-type: 'full')
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4504] sup-iface[92d08bdb923d60c9,0,wlan0]: wps: type pbc start...
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4694] device (wlan0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4707] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full')
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4719] device (wlan0): Activation: (wifi) connection 'Moonbay-Home' has security, and secrets exist.  No new secrets needed.
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4724] Config: added 'ssid' value 'Moonbay-Home'
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4726] Config: added 'scan_ssid' value '1'
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4728] Config: added 'bgscan' value 'simple:30:-70:86400'
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4729] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4729] Config: added 'auth_alg' value 'OPEN'
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4730] Config: added 'psk' value '<hidden>'
Jan 28 12:22:53 manjaro wpa_supplicant[1007]: wlan0: WPS-PBC-ACTIVE
Jan 28 12:22:53 manjaro wpa_supplicant[1007]: wlan0: WPS-CANCEL
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4817] device (wlan0): supplicant interface state: inactive -> scanning
Jan 28 12:22:53 manjaro NetworkManager[768]: <info>  [1769602973.4818] device (p2p-dev-wlan0): supplicant management interface state: inactive -> scanning
Jan 28 12:22:54 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0x100e fail, reason -52
Jan 28 12:22:54 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd034 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd038 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd03c fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd040 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd064 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd068 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd06c fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd070 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd074 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd078 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd07c fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd080 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd084 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd088 fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd08c fail, reason -52
Jan 28 12:22:55 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd090 fail, reason -52
Jan 28 12:22:55 manjaro wpa_supplicant[1007]: wlan0: Trying to associate with SSID 'Moonbay-Home'
Jan 28 12:22:56 manjaro NetworkManager[768]: <info>  [1769602976.2459] device (wlan0): supplicant interface state: scanning -> associating
Jan 28 12:22:56 manjaro NetworkManager[768]: <info>  [1769602976.2461] device (p2p-dev-wlan0): supplicant management interface state: scanning -> associating
Jan 28 12:22:56 manjaro wpa_supplicant[1007]: wlan0: Associated with fc:40:09:d9:20:29
Jan 28 12:22:56 manjaro wpa_supplicant[1007]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Jan 28 12:22:56 manjaro wpa_supplicant[1007]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=IT
Jan 28 12:22:56 manjaro NetworkManager[768]: <info>  [1769602976.4066] device (wlan0): supplicant interface state: associating -> associated
Jan 28 12:22:56 manjaro NetworkManager[768]: <info>  [1769602976.4069] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated
Jan 28 12:23:06 manjaro wpa_supplicant[1007]: wlan0: Authentication with fc:40:09:d9:20:29 timed out.
Jan 28 12:23:06 manjaro wpa_supplicant[1007]: wlan0: Added BSSID fc:40:09:d9:20:29 into ignore list, ignoring for 10 seconds
Jan 28 12:23:06 manjaro wpa_supplicant[1007]: nl80211: send_event_marker failed: Source based routing not supported
Jan 28 12:23:06 manjaro wpa_supplicant[1007]: wlan0: CTRL-EVENT-DISCONNECTED bssid=fc:40:09:d9:20:29 reason=3 locally_generated=1
Jan 28 12:23:06 manjaro wpa_supplicant[1007]: wlan0: BSSID fc:40:09:d9:20:29 ignore list count incremented to 2, ignoring for 10 seconds
Jan 28 12:23:06 manjaro wpa_supplicant[1007]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Moonbay-Home" auth_failures=1 duration=10 reason=CONN_FAILED
Jan 28 12:23:06 manjaro wpa_supplicant[1007]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 28 12:23:06 manjaro NetworkManager[768]: <info>  [1769602986.2760] device (wlan0): supplicant interface state: associated -> disconnected
Jan 28 12:23:06 manjaro NetworkManager[768]: <info>  [1769602986.2763] device (p2p-dev-wlan0): supplicant management interface state: associated -> disconnected
Jan 28 12:23:06 manjaro wpa_supplicant[1007]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Jan 28 12:23:06 manjaro NetworkManager[768]: <info>  [1769602986.3678] device (wlan0): supplicant interface state: disconnected -> scanning
Jan 28 12:23:06 manjaro NetworkManager[768]: <info>  [1769602986.3681] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
Jan 28 12:23:08 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0x100e fail, reason -52
Jan 28 12:23:08 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
Jan 28 12:23:08 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
Jan 28 12:23:08 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd034 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd038 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd03c fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd040 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd064 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd068 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd06c fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd070 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd074 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd078 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd07c fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd080 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd084 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd088 fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd08c fail, reason -52
Jan 28 12:23:09 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd090 fail, reason -52
Jan 28 12:23:18 manjaro NetworkManager[768]: <warn>  [1769602998.8343] device (wlan0): Activation: (wifi) association took too long
Jan 28 12:23:18 manjaro NetworkManager[768]: <info>  [1769602998.8346] device (wlan0): state change: config -> need-auth (reason 'none', managed-type: 'full')
Jan 28 12:23:18 manjaro NetworkManager[768]: <warn>  [1769602998.8367] device (wlan0): Activation: (wifi) asking for new secrets
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0x100e fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
Jan 28 12:23:19 manjaro systemd[1]: Starting Hostname Service...
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd034 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd038 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd03c fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd040 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd064 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd068 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd06c fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd070 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd074 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd078 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd07c fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd080 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd084 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd088 fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd08c fail, reason -52
Jan 28 12:23:19 manjaro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd090 fail, reason -52
Jan 28 12:23:19 manjaro systemd[1]: Started Hostname Service.
Jan 28 12:23:20 manjaro wpa_supplicant[1007]: wlan0: CTRL-EVENT-SSID-REENABLED id=0 ssid="Moonbay-Home"
Jan 28 12:23:20 manjaro wpa_supplicant[1007]: wlan0: BSSID fc:40:09:d9:20:29 ignore list count incremented to 3, ignoring for 60 seconds
Jan 28 12:23:20 manjaro wpa_supplicant[1007]: wlan0: Removed BSSID fc:40:09:d9:20:29 from ignore list (clear)
Jan 28 12:23:34 manjaro kernel: perf: interrupt took too long (3144 > 3132), lowering kernel.perf_event_max_sample_rate to 63000
Jan 28 12:23:49 manjaro systemd[1]: systemd-hostnamed.service: Deactivated successfully.
I confirm driver is correct the r8169 is working fine in Mint XFCE
None of these logs are relevant, except the NetworkManager stuff. But there is not quite enough to go on here.
If you are unsure about logs, and what’s relevant, you can post the entire: journalctl -b --no-pager
You just reboot and run that command and it won’t be too much to look at, few hundred lines or so? It’s just since you started your computer, so it would be a lot if you’ve had your PC on a while.
Did this just stop working? Did you do anything, update or something? That both wired and wireless went down can’t be a coincidence.
I admit I confused which chipsets you are using. I think it’s your r8169 for Ethernet, and ath9k_htc for wifi? We need to know which kernel module were looking for in all these logs.
In your dmesg, there was nothing about either of these. :thinking:
The state is down on your LAN, up on one wifi? I would back up and make sure the modules are properly loading (which is normally in the logs and/or dmesg). You should see them loaded in lsmod as well. (r8169 for your GigEthernet.)
If the modules are loading successfully.. Then I would probably start with your NetworkManager config. It is a lot to dump here. But did you try to make a new connection, as a simple wired connection takes seconds.
Thanks for your reply.
I will send better logs in next days.
What I’m actually sure:
It is a problem after update.
Manjaro live usb WiFi show but not connect
Endeavour live usb WiFi show but not connect
Mint live usb WiFi works well.
Brcmfmac is the broadcom driver journalctl show for the wireless card in beelink bt3
Log picture attached here.
I will update you next
Thanks for your help
Greetings All
Here is my boot log:
feb 09 14:22:22 montronc-bt3pro kernel: Linux version 6.18.8-1-MANJARO (linux618@manjaro) (gcc (GCC) 15.2.1 20260103, GNU ld (GNU Binutils) 2.45.1) #1 SMP PREEMPT_DYNAMIC Fri, 30 Jan 2026 23:06:21 +0000
feb 09 14:22:22 montronc-bt3pro kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=5e957f79-01ca-49b0-b817-c5ff513096d2 rw quiet splash apparmor=1 security=apparmor resume=UUID=2124267b-6ba6-4a5e-9f16-130cf47cd804 udev.log_priority=3
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-provided physical RAM map:
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x000000000008f000-0x000000000008ffff] ACPI NVS
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x0000000000090000-0x000000000009dfff] usable
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x0000000020200000-0x000000007b40ffff] usable
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x000000007b410000-0x000000007b43ffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x000000007b440000-0x000000007b44ffff] ACPI data
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x000000007b450000-0x000000007b54cfff] ACPI NVS
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x000000007b54d000-0x000000007b87afff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x000000007b87b000-0x000000007bffffff] usable
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000e3ffffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000feafffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fed03000-0x00000000fed03fff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fed06000-0x00000000fed06fff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fed08000-0x00000000fed09fff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1cfff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fedbffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x00000000ffa00000-0x00000000ffffffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
feb 09 14:22:22 montronc-bt3pro kernel: NX (Execute Disable) protection: active
feb 09 14:22:22 montronc-bt3pro kernel: APIC: Static calls initialized
feb 09 14:22:22 montronc-bt3pro kernel: efi: EFI v2.4 by American Megatrends
feb 09 14:22:22 montronc-bt3pro kernel: efi: ESRT=0x7b43e000 ACPI=0x7b4a7000 ACPI 2.0=0x7b4a7000 SMBIOS=0x7b70a000 SMBIOS 3.0=0x7b709000 INITRD=0x786cec18 RNG=0x7b44ff98 TPMEventLog=0x7b44e718
feb 09 14:22:22 montronc-bt3pro kernel: random: crng init done
feb 09 14:22:22 montronc-bt3pro kernel: TPM Final Events table not present
feb 09 14:22:22 montronc-bt3pro kernel: efi: Remove mem29: MMIO range=[0xfea00000-0xfeafffff] (1MB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: e820: remove [mem 0xfea00000-0xfeafffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: efi: Not removing mem30: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: efi: Not removing mem31: MMIO range=[0xfed01000-0xfed01fff] (4KB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: efi: Not removing mem32: MMIO range=[0xfed03000-0xfed03fff] (4KB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: efi: Not removing mem33: MMIO range=[0xfed06000-0xfed06fff] (4KB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: efi: Not removing mem34: MMIO range=[0xfed08000-0xfed09fff] (8KB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: efi: Not removing mem35: MMIO range=[0xfed1c000-0xfed1cfff] (4KB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: efi: Remove mem36: MMIO range=[0xfed80000-0xfedbffff] (0MB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: e820: remove [mem 0xfed80000-0xfedbffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: efi: Not removing mem37: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: efi: Remove mem38: MMIO range=[0xffa00000-0xffffffff] (6MB) from e820 map
feb 09 14:22:22 montronc-bt3pro kernel: e820: remove [mem 0xffa00000-0xffffffff] reserved
feb 09 14:22:22 montronc-bt3pro kernel: SMBIOS 3.0.0 present.
feb 09 14:22:22 montronc-bt3pro kernel: DMI: AZW BT3 PRO/BT3 PRO, BIOS 5.11 11/08/2019
feb 09 14:22:22 montronc-bt3pro kernel: DMI: Memory slots populated: 1/2
feb 09 14:22:22 montronc-bt3pro kernel: tsc: Detected 1440.000 MHz processor
feb 09 14:22:22 montronc-bt3pro kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
feb 09 14:22:22 montronc-bt3pro kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
feb 09 14:22:22 montronc-bt3pro kernel: last_pfn = 0x180000 max_arch_pfn = 0x400000000
feb 09 14:22:22 montronc-bt3pro kernel: total RAM covered: 4036M
feb 09 14:22:22 montronc-bt3pro kernel: Found optimal setting for mtrr clean up
feb 09 14:22:22 montronc-bt3pro kernel:  gran_size: 64K         chunk_size: 64M         num_reg: 6          lose cover RAM: 0G
feb 09 14:22:22 montronc-bt3pro kernel: MTRR map: 5 entries (2 fixed + 3 variable; max 18), built from 8 variable MTRRs
feb 09 14:22:22 montronc-bt3pro kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
feb 09 14:22:22 montronc-bt3pro kernel: e820: update [mem 0x7c400000-0xffffffff] usable ==> reserved
feb 09 14:22:22 montronc-bt3pro kernel: last_pfn = 0x7c000 max_arch_pfn = 0x400000000
feb 09 14:22:22 montronc-bt3pro kernel: esrt: ESRT header is not in the memory map.
feb 09 14:22:22 montronc-bt3pro kernel: Secure boot disabled
feb 09 14:22:22 montronc-bt3pro kernel: RAMDISK: [mem 0x747c3000-0x76724fff]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Early table checksum verification disabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: RSDP 0x000000007B4A7000 000024 (v02 ALASKA)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: XSDT 0x000000007B4A70A8 0000D4 (v01 ALASKA A M I    01072009 AMI  00010013)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: FACP 0x000000007B4C4060 00010C (v05 ALASKA A M I    01072009 AMI  00010013)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: DSDT 0x000000007B4A7218 01CE44 (v02 ALASKA A M I    01072009 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: FACS 0x000000007B54CF80 000040
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: APIC 0x000000007B4C4170 000084 (v03 ALASKA A M I    01072009 AMI  00010013)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: FPDT 0x000000007B4C41F8 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: FIDT 0x000000007B4C4240 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: MCFG 0x000000007B4C42E0 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0x000000007B4C4320 0041C7 (v01 DptfTb DptfTab  00001000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0x000000007B4C84E8 000645 (v01 CpuDpf CpuDptf  00001000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0x000000007B4C8B30 000058 (v01 LowPM  LowPwrM  00001000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: UEFI 0x000000007B4C8B88 000042 (v01 ALASKA A M I    00000000      00000000)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0x000000007B4C8BD0 000269 (v01 UsbCTb UsbCTab  00001000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: HPET 0x000000007B4C8E40 000038 (v01 ALASKA A M I    01072009 AMI. 00000005)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0x000000007B4C8E78 000763 (v01 PmRef  CpuPm    00003000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0x000000007B4C95E0 000290 (v01 PmRef  Cpu0Tst  00003000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0x000000007B4C9870 00017A (v01 PmRef  ApTst    00003000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0x000000007B4C99F0 00043A (v01 Intel_ Tpm2Tabl 00001000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: TPM2 0x000000007B4C9E30 000034 (v03                 00000000      00000000)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: LPIT 0x000000007B4C9E68 000104 (v01 ALASKA A M I    00000005 MSFT 0100000D)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: BCFG 0x000000007B4C9F70 000139 (v01 INTEL  BATTCONF 00000001 ACPI 00000000)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PRAM 0x000000007B4CA0B0 000030 (v01                 00000001      00000000)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: BGRT 0x000000007B4CA0E0 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: CSRT 0x000000007B4CA118 00014C (v00 INTEL  LANFORDC 00000005 MSFT 0100000D)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: WDAT 0x000000007B4CA268 000104 (v01                 00000000      00000000)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving FACP table memory at [mem 0x7b4c4060-0x7b4c416b]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving DSDT table memory at [mem 0x7b4a7218-0x7b4c405b]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving FACS table memory at [mem 0x7b54cf80-0x7b54cfbf]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving APIC table memory at [mem 0x7b4c4170-0x7b4c41f3]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving FPDT table memory at [mem 0x7b4c41f8-0x7b4c423b]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving FIDT table memory at [mem 0x7b4c4240-0x7b4c42db]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving MCFG table memory at [mem 0x7b4c42e0-0x7b4c431b]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving SSDT table memory at [mem 0x7b4c4320-0x7b4c84e6]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving SSDT table memory at [mem 0x7b4c84e8-0x7b4c8b2c]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving SSDT table memory at [mem 0x7b4c8b30-0x7b4c8b87]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving UEFI table memory at [mem 0x7b4c8b88-0x7b4c8bc9]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving SSDT table memory at [mem 0x7b4c8bd0-0x7b4c8e38]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving HPET table memory at [mem 0x7b4c8e40-0x7b4c8e77]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving SSDT table memory at [mem 0x7b4c8e78-0x7b4c95da]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving SSDT table memory at [mem 0x7b4c95e0-0x7b4c986f]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving SSDT table memory at [mem 0x7b4c9870-0x7b4c99e9]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving SSDT table memory at [mem 0x7b4c99f0-0x7b4c9e29]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving TPM2 table memory at [mem 0x7b4c9e30-0x7b4c9e63]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving LPIT table memory at [mem 0x7b4c9e68-0x7b4c9f6b]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving BCFG table memory at [mem 0x7b4c9f70-0x7b4ca0a8]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving PRAM table memory at [mem 0x7b4ca0b0-0x7b4ca0df]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving BGRT table memory at [mem 0x7b4ca0e0-0x7b4ca117]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving CSRT table memory at [mem 0x7b4ca118-0x7b4ca263]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Reserving WDAT table memory at [mem 0x7b4ca268-0x7b4ca36b]
feb 09 14:22:22 montronc-bt3pro kernel: No NUMA configuration found
feb 09 14:22:22 montronc-bt3pro kernel: Faking a node at [mem 0x0000000000000000-0x000000017fffffff]
feb 09 14:22:22 montronc-bt3pro kernel: NODE_DATA(0) allocated [mem 0x17ffd3280-0x17fffdfff]
feb 09 14:22:22 montronc-bt3pro kernel: Zone ranges:
feb 09 14:22:22 montronc-bt3pro kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
feb 09 14:22:22 montronc-bt3pro kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
feb 09 14:22:22 montronc-bt3pro kernel:   Normal   [mem 0x0000000100000000-0x000000017fffffff]
feb 09 14:22:22 montronc-bt3pro kernel:   Device   empty
feb 09 14:22:22 montronc-bt3pro kernel: Movable zone start for each node
feb 09 14:22:22 montronc-bt3pro kernel: Early memory node ranges
feb 09 14:22:22 montronc-bt3pro kernel:   node   0: [mem 0x0000000000001000-0x000000000008efff]
feb 09 14:22:22 montronc-bt3pro kernel:   node   0: [mem 0x0000000000090000-0x000000000009dfff]
feb 09 14:22:22 montronc-bt3pro kernel:   node   0: [mem 0x0000000000100000-0x000000001fffffff]
feb 09 14:22:22 montronc-bt3pro kernel:   node   0: [mem 0x0000000020200000-0x000000007b40ffff]
feb 09 14:22:22 montronc-bt3pro kernel:   node   0: [mem 0x000000007b87b000-0x000000007bffffff]
feb 09 14:22:22 montronc-bt3pro kernel:   node   0: [mem 0x0000000100000000-0x000000017fffffff]
feb 09 14:22:22 montronc-bt3pro kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000017fffffff]
feb 09 14:22:22 montronc-bt3pro kernel: On node 0, zone DMA: 1 pages in unavailable ranges
feb 09 14:22:22 montronc-bt3pro kernel: On node 0, zone DMA: 98 pages in unavailable ranges
feb 09 14:22:22 montronc-bt3pro kernel: On node 0, zone DMA32: 512 pages in unavailable ranges
feb 09 14:22:22 montronc-bt3pro kernel: On node 0, zone DMA32: 1131 pages in unavailable ranges
feb 09 14:22:22 montronc-bt3pro kernel: On node 0, zone Normal: 16384 pages in unavailable ranges
feb 09 14:22:22 montronc-bt3pro kernel: Reserving Intel graphics memory at [mem 0x7ce00000-0x7edfffff]
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PM-Timer IO Port: 0x408
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
feb 09 14:22:22 montronc-bt3pro kernel: IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-114
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Using ACPI (MADT) for SMP configuration information
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
feb 09 14:22:22 montronc-bt3pro kernel: e820: update [mem 0x79b36000-0x79d76fff] usable ==> reserved
feb 09 14:22:22 montronc-bt3pro kernel: TSC deadline timer available
feb 09 14:22:22 montronc-bt3pro kernel: CPU topo: Max. logical packages:   1
feb 09 14:22:22 montronc-bt3pro kernel: CPU topo: Max. logical dies:       1
feb 09 14:22:22 montronc-bt3pro kernel: CPU topo: Max. dies per package:   1
feb 09 14:22:22 montronc-bt3pro kernel: CPU topo: Max. threads per core:   1
feb 09 14:22:22 montronc-bt3pro kernel: CPU topo: Num. cores per package:     4
feb 09 14:22:22 montronc-bt3pro kernel: CPU topo: Num. threads per package:   4
feb 09 14:22:22 montronc-bt3pro kernel: CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
feb 09 14:22:22 montronc-bt3pro kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
feb 09 14:22:22 montronc-bt3pro kernel: PM: hibernation: Registered nosave memory: [mem 0x0008f000-0x0008ffff]
feb 09 14:22:22 montronc-bt3pro kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
feb 09 14:22:22 montronc-bt3pro kernel: PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
feb 09 14:22:22 montronc-bt3pro kernel: PM: hibernation: Registered nosave memory: [mem 0x79b36000-0x79d76fff]
feb 09 14:22:22 montronc-bt3pro kernel: PM: hibernation: Registered nosave memory: [mem 0x7b410000-0x7b87afff]
feb 09 14:22:22 montronc-bt3pro kernel: PM: hibernation: Registered nosave memory: [mem 0x7c000000-0xffffffff]
feb 09 14:22:22 montronc-bt3pro kernel: [mem 0x7ee00000-0xdfffffff] available for PCI devices
feb 09 14:22:22 montronc-bt3pro kernel: Booting paravirtualized kernel on bare hardware
feb 09 14:22:22 montronc-bt3pro kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
feb 09 14:22:22 montronc-bt3pro kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
feb 09 14:22:22 montronc-bt3pro kernel: percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u524288
feb 09 14:22:22 montronc-bt3pro kernel: pcpu-alloc: s217088 r8192 d28672 u524288 alloc=1*2097152
feb 09 14:22:22 montronc-bt3pro kernel: pcpu-alloc: [0] 0 1 2 3
feb 09 14:22:22 montronc-bt3pro kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=5e957f79-01ca-49b0-b817-c5ff513096d2 rw quiet splash apparmor=1 security=apparmor resume=UUID=2124267b-6ba6-4a5e-9f16-130cf47cd804 udev.log_priority=3
feb 09 14:22:22 montronc-bt3pro kernel: Unknown kernel command line parameters "splash", will be passed to user space.
feb 09 14:22:22 montronc-bt3pro kernel: printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
feb 09 14:22:22 montronc-bt3pro kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: software IO TLB: area num 4.
feb 09 14:22:22 montronc-bt3pro kernel: Fallback order for Node 0: 0
feb 09 14:22:22 montronc-bt3pro kernel: Built 1 zonelists, mobility grouping on.  Total pages: 1030449
feb 09 14:22:22 montronc-bt3pro kernel: Policy zone: Normal
feb 09 14:22:22 montronc-bt3pro kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
feb 09 14:22:22 montronc-bt3pro kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
feb 09 14:22:22 montronc-bt3pro kernel: Kernel/User page tables isolation: enabled
feb 09 14:22:22 montronc-bt3pro kernel: ftrace: allocating 57190 entries in 224 pages
feb 09 14:22:22 montronc-bt3pro kernel: ftrace: allocated 224 pages with 3 groups
feb 09 14:22:22 montronc-bt3pro kernel: Dynamic Preempt: full
feb 09 14:22:22 montronc-bt3pro kernel: rcu: Preemptible hierarchical RCU implementation.
feb 09 14:22:22 montronc-bt3pro kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
feb 09 14:22:22 montronc-bt3pro kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
feb 09 14:22:22 montronc-bt3pro kernel:         Trampoline variant of Tasks RCU enabled.
feb 09 14:22:22 montronc-bt3pro kernel:         Rude variant of Tasks RCU enabled.
feb 09 14:22:22 montronc-bt3pro kernel:         Tracing variant of Tasks RCU enabled.
feb 09 14:22:22 montronc-bt3pro kernel: rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
feb 09 14:22:22 montronc-bt3pro kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
feb 09 14:22:22 montronc-bt3pro kernel: RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
feb 09 14:22:22 montronc-bt3pro kernel: RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
feb 09 14:22:22 montronc-bt3pro kernel: RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
feb 09 14:22:22 montronc-bt3pro kernel: NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
feb 09 14:22:22 montronc-bt3pro kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
feb 09 14:22:22 montronc-bt3pro kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
feb 09 14:22:22 montronc-bt3pro kernel: Console: colour dummy device 80x25
feb 09 14:22:22 montronc-bt3pro kernel: printk: legacy console [tty0] enabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Core revision 20250807
feb 09 14:22:22 montronc-bt3pro kernel: hpet: HPET dysfunctional in PC10. Force disabled.
feb 09 14:22:22 montronc-bt3pro kernel: APIC: Switch to symmetric I/O mode setup
feb 09 14:22:22 montronc-bt3pro kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x14c1baf3789, max_idle_ns: 440795266465 ns
feb 09 14:22:22 montronc-bt3pro kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 2880.00 BogoMIPS (lpj=1440000)
feb 09 14:22:22 montronc-bt3pro kernel: CPU0: Thermal monitoring enabled (TM1)
feb 09 14:22:22 montronc-bt3pro kernel: Last level iTLB entries: 4KB 48, 2MB 0, 4MB 0
feb 09 14:22:22 montronc-bt3pro kernel: Last level dTLB entries: 4KB 256, 2MB 16, 4MB 16, 1GB 0
feb 09 14:22:22 montronc-bt3pro kernel: process: using mwait in idle threads
feb 09 14:22:22 montronc-bt3pro kernel: mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
feb 09 14:22:22 montronc-bt3pro kernel: Spectre V2 : Mitigation: Retpolines
feb 09 14:22:22 montronc-bt3pro kernel: MDS: Mitigation: Clear CPU buffers
feb 09 14:22:22 montronc-bt3pro kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
feb 09 14:22:22 montronc-bt3pro kernel: Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
feb 09 14:22:22 montronc-bt3pro kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
feb 09 14:22:22 montronc-bt3pro kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
feb 09 14:22:22 montronc-bt3pro kernel: x86/fpu: x87 FPU will use FXSAVE
feb 09 14:22:22 montronc-bt3pro kernel: Freeing SMP alternatives memory: 56K
feb 09 14:22:22 montronc-bt3pro kernel: pid_max: default: 32768 minimum: 301
feb 09 14:22:22 montronc-bt3pro kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
feb 09 14:22:22 montronc-bt3pro kernel: landlock: Up and running.
feb 09 14:22:22 montronc-bt3pro kernel: Yama: becoming mindful.
feb 09 14:22:22 montronc-bt3pro kernel: LSM support for eBPF active
feb 09 14:22:22 montronc-bt3pro kernel: AppArmor: AppArmor initialized
feb 09 14:22:22 montronc-bt3pro kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: smpboot: CPU0: Intel(R) Atom(TM) x5-Z8350  CPU @ 1.44GHz (family: 0x6, model: 0x4c, stepping: 0x4)
feb 09 14:22:22 montronc-bt3pro kernel: Performance Events: PEBS fmt2+, 8-deep LBR, Silvermont events, 8-deep LBR, full-width counters, Intel PMU driver.
feb 09 14:22:22 montronc-bt3pro kernel: ... version:                   3
feb 09 14:22:22 montronc-bt3pro kernel: ... bit width:                 40
feb 09 14:22:22 montronc-bt3pro kernel: ... generic counters:          2
feb 09 14:22:22 montronc-bt3pro kernel: ... generic bitmap:            0000000000000003
feb 09 14:22:22 montronc-bt3pro kernel: ... fixed-purpose counters:    3
feb 09 14:22:22 montronc-bt3pro kernel: ... fixed-purpose bitmap:      0000000000000007
feb 09 14:22:22 montronc-bt3pro kernel: ... value mask:                000000ffffffffff
feb 09 14:22:22 montronc-bt3pro kernel: ... max period:                0000007fffffffff
feb 09 14:22:22 montronc-bt3pro kernel: ... global_ctrl mask:          0000000700000003
feb 09 14:22:22 montronc-bt3pro kernel: signal: max sigframe size: 1440
feb 09 14:22:22 montronc-bt3pro kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1365
feb 09 14:22:22 montronc-bt3pro kernel: rcu: Hierarchical SRCU implementation.
feb 09 14:22:22 montronc-bt3pro kernel: rcu:         Max phase no-delay instances is 400.
feb 09 14:22:22 montronc-bt3pro kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
feb 09 14:22:22 montronc-bt3pro kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
feb 09 14:22:22 montronc-bt3pro kernel: smp: Bringing up secondary CPUs ...
feb 09 14:22:22 montronc-bt3pro kernel: smpboot: x86: Booting SMP configuration:
feb 09 14:22:22 montronc-bt3pro kernel: .... node  #0, CPUs:      #1 #2 #3
feb 09 14:22:22 montronc-bt3pro kernel: smp: Brought up 1 node, 4 CPUs
feb 09 14:22:22 montronc-bt3pro kernel: smpboot: Total of 4 processors activated (11520.00 BogoMIPS)
feb 09 14:22:22 montronc-bt3pro kernel: Memory: 3881604K/4121796K available (20256K kernel code, 2954K rwdata, 16372K rodata, 4732K init, 4772K bss, 231956K reserved, 0K cma-reserved)
feb 09 14:22:22 montronc-bt3pro kernel: devtmpfs: initialized
feb 09 14:22:22 montronc-bt3pro kernel: x86/mm: Memory block size: 128MB
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PM: Registering ACPI NVS region [mem 0x0008f000-0x0008ffff] (4096 bytes)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PM: Registering ACPI NVS region [mem 0x7b450000-0x7b54cfff] (1036288 bytes)
feb 09 14:22:22 montronc-bt3pro kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
feb 09 14:22:22 montronc-bt3pro kernel: posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
feb 09 14:22:22 montronc-bt3pro kernel: pinctrl core: initialized pinctrl subsystem
feb 09 14:22:22 montronc-bt3pro kernel: PM: RTC time: 13:22:10, date: 2026-02-09
feb 09 14:22:22 montronc-bt3pro kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
feb 09 14:22:22 montronc-bt3pro kernel: DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
feb 09 14:22:22 montronc-bt3pro kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
feb 09 14:22:22 montronc-bt3pro kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
feb 09 14:22:22 montronc-bt3pro kernel: audit: initializing netlink subsys (disabled)
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=2000 audit(1770643330.026:1): state=initialized audit_enabled=0 res=1
feb 09 14:22:22 montronc-bt3pro kernel: thermal_sys: Registered thermal governor 'fair_share'
feb 09 14:22:22 montronc-bt3pro kernel: thermal_sys: Registered thermal governor 'bang_bang'
feb 09 14:22:22 montronc-bt3pro kernel: thermal_sys: Registered thermal governor 'step_wise'
feb 09 14:22:22 montronc-bt3pro kernel: thermal_sys: Registered thermal governor 'user_space'
feb 09 14:22:22 montronc-bt3pro kernel: thermal_sys: Registered thermal governor 'power_allocator'
feb 09 14:22:22 montronc-bt3pro kernel: cpuidle: using governor ladder
feb 09 14:22:22 montronc-bt3pro kernel: cpuidle: using governor menu
feb 09 14:22:22 montronc-bt3pro kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
feb 09 14:22:22 montronc-bt3pro kernel: PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
feb 09 14:22:22 montronc-bt3pro kernel: PCI: Using configuration type 1 for base access
feb 09 14:22:22 montronc-bt3pro kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
feb 09 14:22:22 montronc-bt3pro kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
feb 09 14:22:22 montronc-bt3pro kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
feb 09 14:22:22 montronc-bt3pro kernel: raid6: skipped pq benchmark and selected sse2x4
feb 09 14:22:22 montronc-bt3pro kernel: raid6: using ssse3x2 recovery algorithm
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Added _OSI(Module Device)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Added _OSI(Processor Device)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Added _OSI(Processor Aggregator Device)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: 9 ACPI AML tables successfully acquired and loaded
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Dynamic OEM Table Load:
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0xFFFF8D47812F9800 00059C (v01 PmRef  Cpu0Ist  00003000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0xFFFF8D4781271C00 0003A5 (v01 PmRef  Cpu0Cst  00003001 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0xFFFF8D4780B11A00 00015F (v01 PmRef  ApIst    00003000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: SSDT 0xFFFF8D478135C3C0 00008D (v01 PmRef  ApCst    00003000 INTL 20120913)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Interpreter enabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PM: (supports S0 S4 S5)
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: Using IOAPIC for interrupt routing
feb 09 14:22:22 montronc-bt3pro kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
feb 09 14:22:22 montronc-bt3pro kernel: PCI: Using E820 reservations for host bridge windows
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P06X: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.ISP3.ID3C: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.USBC: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.XHC1.RHUB.HS03.WWPR: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.XHC1.RHUB.HS13.WWPR: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.XHC1.RHUB.SSC1.WWPR: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.XHC1.RHUB.SSCW.WWPR: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.XHC1.RHUB.HSC1.WWPR: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.XHC1.RHUB.HSC3.WWPR: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C1.CLK2: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P28P: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P18P: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C1.CLK4: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C2.CLK2: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C2.CLK3: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C2.CLK4: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C3.CLK2: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C3.CLK1: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C5.CLK5: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P28X: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P18X: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P12X: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P12P: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P19X: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P12A: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P28T: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P18D: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P18T: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P3P3: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P12T: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P28W: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P18W: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P12W: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P33W: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P33X: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.P4BW: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
feb 09 14:22:22 montronc-bt3pro kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
feb 09 14:22:22 montronc-bt3pro kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
feb 09 14:22:22 montronc-bt3pro kernel: PCI host bridge to bus 0000:00
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [io  0x0070-0x0077]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x006f window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [io  0x0078-0x0cf7 window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [mem 0x20000000-0x201fffff window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [mem 0x7ce00001-0x7ee00000 window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:00.0: [8086:2280] type 00 class 0x060000 conventional PCI endpoint
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:02.0: [8086:22b0] type 00 class 0x030000 conventional PCI endpoint
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:02.0: BAR 0 [mem 0x90000000-0x90ffffff 64bit]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:02.0: BAR 2 [mem 0x80000000-0x8fffffff 64bit pref]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:02.0: BAR 4 [io  0xf000-0xf03f]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:03.0: [8086:22b8] type 00 class 0x048000 conventional PCI endpoint
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:03.0: BAR 0 [mem 0x91000000-0x913fffff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:0b.0: [8086:22dc] type 00 class 0x118000 conventional PCI endpoint
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:0b.0: BAR 0 [mem 0x9193b000-0x9193bfff 64bit]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:14.0: [8086:22b5] type 00 class 0x0c0330 conventional PCI endpoint
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:14.0: BAR 0 [mem 0x91900000-0x9190ffff 64bit]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1a.0: [8086:2298] type 00 class 0x108000 conventional PCI endpoint
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1a.0: BAR 0 [mem 0x91700000-0x917fffff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1a.0: BAR 1 [mem 0x91600000-0x916fffff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1c.0: [8086:22c8] type 01 class 0x060400 PCIe Root Port
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1c.0:   bridge window [io  0xe000-0xefff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1c.0:   bridge window [mem 0x91800000-0x918fffff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:1f.0: [8086:229c] type 00 class 0x060100 conventional PCI endpoint
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:01:00.0: BAR 0 [io  0xe000-0xe0ff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:01:00.0: BAR 2 [mem 0x91804000-0x91804fff 64bit]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:01:00.0: BAR 4 [mem 0x91800000-0x91803fff 64bit pref]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:01:00.0: supports D1 D2
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
feb 09 14:22:22 montronc-bt3pro kernel: Low-power S0 idle used by default for system suspend
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKA disabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKB disabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKC disabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKD disabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKE disabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKF disabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKG disabled
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: PCI: Interrupt link LNKH disabled
feb 09 14:22:22 montronc-bt3pro kernel: cherryview-pinctrl INT33FF:04: probe with driver cherryview-pinctrl failed with error -61
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C4.CLK0: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: \_SB_.PCI0.I2C4.CLK1: New power resource
feb 09 14:22:22 montronc-bt3pro kernel: iommu: Default domain type: Translated
feb 09 14:22:22 montronc-bt3pro kernel: iommu: DMA domain TLB invalidation policy: lazy mode
feb 09 14:22:22 montronc-bt3pro kernel: SCSI subsystem initialized
feb 09 14:22:22 montronc-bt3pro kernel: libata version 3.00 loaded.
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: bus type USB registered
feb 09 14:22:22 montronc-bt3pro kernel: usbcore: registered new interface driver usbfs
feb 09 14:22:22 montronc-bt3pro kernel: usbcore: registered new interface driver hub
feb 09 14:22:22 montronc-bt3pro kernel: usbcore: registered new device driver usb
feb 09 14:22:22 montronc-bt3pro kernel: EDAC MC: Ver: 3.0.0
feb 09 14:22:22 montronc-bt3pro kernel: efivars: Registered efivars operations
feb 09 14:22:22 montronc-bt3pro kernel: NetLabel: Initializing
feb 09 14:22:22 montronc-bt3pro kernel: NetLabel:  domain hash size = 128
feb 09 14:22:22 montronc-bt3pro kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
feb 09 14:22:22 montronc-bt3pro kernel: NetLabel:  unlabeled traffic allowed by default
feb 09 14:22:22 montronc-bt3pro kernel: mctp: management component transport protocol core
feb 09 14:22:22 montronc-bt3pro kernel: NET: Registered PF_MCTP protocol family
feb 09 14:22:22 montronc-bt3pro kernel: PCI: Using ACPI for IRQ routing
feb 09 14:22:22 montronc-bt3pro kernel: PCI: pci_cache_line_size set to 64 bytes
feb 09 14:22:22 montronc-bt3pro kernel: resource: Expanded resource Reserved due to conflict with PCI Bus 0000:00
feb 09 14:22:22 montronc-bt3pro kernel: e820: reserve RAM buffer [mem 0x0008f000-0x0008ffff]
feb 09 14:22:22 montronc-bt3pro kernel: e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
feb 09 14:22:22 montronc-bt3pro kernel: e820: reserve RAM buffer [mem 0x79b36000-0x7bffffff]
feb 09 14:22:22 montronc-bt3pro kernel: e820: reserve RAM buffer [mem 0x7b410000-0x7bffffff]
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:02.0: vgaarb: bridge control possible
feb 09 14:22:22 montronc-bt3pro kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
feb 09 14:22:22 montronc-bt3pro kernel: vgaarb: loaded
feb 09 14:22:22 montronc-bt3pro kernel: clocksource: Switched to clocksource tsc-early
feb 09 14:22:22 montronc-bt3pro kernel: VFS: Disk quotas dquot_6.6.0
feb 09 14:22:22 montronc-bt3pro kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
feb 09 14:22:22 montronc-bt3pro kernel: AppArmor: AppArmor Filesystem Enabled
feb 09 14:22:22 montronc-bt3pro kernel: pnp: PnP ACPI init
feb 09 14:22:22 montronc-bt3pro kernel: system 00:00: [io  0x0680-0x069f] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:00: [io  0x0400-0x047f] could not be reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:00: [io  0x0500-0x05fe] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91939000-0x91939fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91937000-0x91937fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91935000-0x91935fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91924000-0x91924fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91922000-0x91922fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91920000-0x91920fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x9191e000-0x9191efff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x9191c000-0x9191cfff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x9191a000-0x9191afff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91918000-0x91918fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91933000-0x91933fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91931000-0x91931fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x9192f000-0x9192ffff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x9192d000-0x9192dfff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x9192b000-0x9192bfff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91929000-0x91929fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91927000-0x91927fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:02: [mem 0x91925000-0x91925fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xe0000000-0xefffffff] could not be reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xfea00000-0xfeafffff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xfed01000-0xfed01fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xfed03000-0xfed03fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xfed06000-0xfed06fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xfed08000-0xfed09fff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xfed80000-0xfedbffff] could not be reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xfed1c000-0xfed1cfff] has been reserved
feb 09 14:22:22 montronc-bt3pro kernel: system 00:03: [mem 0xfee00000-0xfeefffff] could not be reserved
feb 09 14:22:22 montronc-bt3pro kernel: pnp: PnP ACPI: found 5 devices
feb 09 14:22:22 montronc-bt3pro kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
feb 09 14:22:22 montronc-bt3pro kernel: NET: Registered PF_INET protocol family
feb 09 14:22:22 montronc-bt3pro kernel: IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: TCP: Hash tables configured (established 32768 bind 32768)
feb 09 14:22:22 montronc-bt3pro kernel: MPTCP token hash table entries: 4096 (order: 5, 98304 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear)
feb 09 14:22:22 montronc-bt3pro kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
feb 09 14:22:22 montronc-bt3pro kernel: NET: Registered PF_XDP protocol family
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: resource 4 [io  0x0070-0x0077]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: resource 5 [io  0x0000-0x006f window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: resource 6 [io  0x0078-0x0cf7 window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000fffff window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: resource 9 [mem 0x20000000-0x201fffff window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: resource 10 [mem 0x7ce00001-0x7ee00000 window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:00: resource 11 [mem 0x80000000-0xdfffffff window]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
feb 09 14:22:22 montronc-bt3pro kernel: pci_bus 0000:01: resource 1 [mem 0x91800000-0x918fffff]
feb 09 14:22:22 montronc-bt3pro kernel: PCI: CLS 64 bytes, default 64
feb 09 14:22:22 montronc-bt3pro kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
feb 09 14:22:22 montronc-bt3pro kernel: software IO TLB: mapped [mem 0x000000006e000000-0x0000000072000000] (64MB)
feb 09 14:22:22 montronc-bt3pro kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x14c1baf3789, max_idle_ns: 440795266465 ns
feb 09 14:22:22 montronc-bt3pro kernel: Trying to unpack rootfs image as initramfs...
feb 09 14:22:22 montronc-bt3pro kernel: Initialise system trusted keyrings
feb 09 14:22:22 montronc-bt3pro kernel: Key type blacklist registered
feb 09 14:22:22 montronc-bt3pro kernel: workingset: timestamp_bits=36 max_order=20 bucket_order=0
feb 09 14:22:22 montronc-bt3pro kernel: fuse: init (API version 7.45)
feb 09 14:22:22 montronc-bt3pro kernel: integrity: Platform Keyring initialized
feb 09 14:22:22 montronc-bt3pro kernel: integrity: Machine keyring initialized
feb 09 14:22:22 montronc-bt3pro kernel: xor: measuring software checksum speed
feb 09 14:22:22 montronc-bt3pro kernel:    prefetch64-sse  :  5433 MB/sec
feb 09 14:22:22 montronc-bt3pro kernel:    generic_sse     :  4770 MB/sec
feb 09 14:22:22 montronc-bt3pro kernel: xor: using function: prefetch64-sse (5433 MB/sec)
feb 09 14:22:22 montronc-bt3pro kernel: Key type asymmetric registered
feb 09 14:22:22 montronc-bt3pro kernel: Asymmetric key parser 'x509' registered
feb 09 14:22:22 montronc-bt3pro kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
feb 09 14:22:22 montronc-bt3pro kernel: io scheduler mq-deadline registered
feb 09 14:22:22 montronc-bt3pro kernel: io scheduler kyber registered
feb 09 14:22:22 montronc-bt3pro kernel: io scheduler bfq registered
feb 09 14:22:22 montronc-bt3pro kernel: ledtrig-cpu: registered to indicate activity on CPUs
feb 09 14:22:22 montronc-bt3pro kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 118
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: found native INT33F4 PMIC, skipping ACPI AC and battery devices
feb 09 14:22:22 montronc-bt3pro kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: button: Power Button [PWRB]
feb 09 14:22:22 montronc-bt3pro kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: button: Power Button [PWRF]
feb 09 14:22:22 montronc-bt3pro kernel: thermal LNXTHERM:00: registered as thermal_zone0
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: thermal: Thermal Zone [TZ00] (0 C)
feb 09 14:22:22 montronc-bt3pro kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
feb 09 14:22:22 montronc-bt3pro kernel: 00:01: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
feb 09 14:22:22 montronc-bt3pro kernel: hpet: number irqs doesn't agree with number of timers
feb 09 14:22:22 montronc-bt3pro kernel: Non-volatile memory driver v1.3
feb 09 14:22:22 montronc-bt3pro kernel: Linux agpgart interface v0.103
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: bus type drm_connector registered
feb 09 14:22:22 montronc-bt3pro kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
feb 09 14:22:22 montronc-bt3pro kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
feb 09 14:22:22 montronc-bt3pro kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081509810
feb 09 14:22:22 montronc-bt3pro kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
feb 09 14:22:22 montronc-bt3pro kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
feb 09 14:22:22 montronc-bt3pro kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
feb 09 14:22:22 montronc-bt3pro kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
feb 09 14:22:22 montronc-bt3pro kernel: usb usb1: Product: xHCI Host Controller
feb 09 14:22:22 montronc-bt3pro kernel: usb usb1: Manufacturer: Linux 6.18.8-1-MANJARO xhci-hcd
feb 09 14:22:22 montronc-bt3pro kernel: usb usb1: SerialNumber: 0000:00:14.0
feb 09 14:22:22 montronc-bt3pro kernel: hub 1-0:1.0: USB hub found
feb 09 14:22:22 montronc-bt3pro kernel: hub 1-0:1.0: 7 ports detected
feb 09 14:22:22 montronc-bt3pro kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
feb 09 14:22:22 montronc-bt3pro kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
feb 09 14:22:22 montronc-bt3pro kernel: usb usb2: Product: xHCI Host Controller
feb 09 14:22:22 montronc-bt3pro kernel: usb usb2: Manufacturer: Linux 6.18.8-1-MANJARO xhci-hcd
feb 09 14:22:22 montronc-bt3pro kernel: usb usb2: SerialNumber: 0000:00:14.0
feb 09 14:22:22 montronc-bt3pro kernel: hub 2-0:1.0: USB hub found
feb 09 14:22:22 montronc-bt3pro kernel: hub 2-0:1.0: 6 ports detected
feb 09 14:22:22 montronc-bt3pro kernel: usbcore: registered new interface driver usbserial_generic
feb 09 14:22:22 montronc-bt3pro kernel: usbserial: USB Serial support registered for generic
feb 09 14:22:22 montronc-bt3pro kernel: i8042: PNP: No PS/2 controller found.
feb 09 14:22:22 montronc-bt3pro kernel: rtc_cmos 00:04: registered as rtc0
feb 09 14:22:22 montronc-bt3pro kernel: rtc_cmos 00:04: setting system clock to 2026-02-09T13:22:11 UTC (1770643331)
feb 09 14:22:22 montronc-bt3pro kernel: rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram
feb 09 14:22:22 montronc-bt3pro kernel: intel_pstate: Intel P-state driver initializing
feb 09 14:22:22 montronc-bt3pro kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
feb 09 14:22:22 montronc-bt3pro kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
feb 09 14:22:22 montronc-bt3pro kernel: fbcon: Deferring console take-over
feb 09 14:22:22 montronc-bt3pro kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
feb 09 14:22:22 montronc-bt3pro kernel: hid: raw HID events driver (C) Jiri Kosina
feb 09 14:22:22 montronc-bt3pro kernel: usbcore: registered new interface driver usbhid
feb 09 14:22:22 montronc-bt3pro kernel: usbhid: USB HID core driver
feb 09 14:22:22 montronc-bt3pro kernel: drop_monitor: Initializing network drop monitor service
feb 09 14:22:22 montronc-bt3pro kernel: NET: Registered PF_INET6 protocol family
feb 09 14:22:22 montronc-bt3pro kernel: Segment Routing with IPv6
feb 09 14:22:22 montronc-bt3pro kernel: RPL Segment Routing with IPv6
feb 09 14:22:22 montronc-bt3pro kernel: In-situ OAM (IOAM) with IPv6
feb 09 14:22:22 montronc-bt3pro kernel: NET: Registered PF_PACKET protocol family
feb 09 14:22:22 montronc-bt3pro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
feb 09 14:22:22 montronc-bt3pro kernel: microcode: Current revision: 0x00000411
feb 09 14:22:22 montronc-bt3pro kernel: microcode: Updated early from: 0x0000040a
feb 09 14:22:22 montronc-bt3pro kernel: IPI shorthand broadcast: enabled
feb 09 14:22:22 montronc-bt3pro kernel: sched_clock: Marking stable (1187005682, 2700050)->(1273051488, -83345756)
feb 09 14:22:22 montronc-bt3pro kernel: registered taskstats version 1
feb 09 14:22:22 montronc-bt3pro kernel: Loading compiled-in X.509 certificates
feb 09 14:22:22 montronc-bt3pro kernel: Freeing initrd memory: 32136K
feb 09 14:22:22 montronc-bt3pro kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 26e36e9229ec2f0c39eb1d5061bda3ff1178ec33'
feb 09 14:22:22 montronc-bt3pro kernel: zswap: loaded using pool zstd
feb 09 14:22:22 montronc-bt3pro kernel: Demotion targets for Node 0: null
feb 09 14:22:22 montronc-bt3pro kernel: Key type .fscrypt registered
feb 09 14:22:22 montronc-bt3pro kernel: Key type fscrypt-provisioning registered
feb 09 14:22:22 montronc-bt3pro kernel: Btrfs loaded, zoned=yes, fsverity=yes
feb 09 14:22:22 montronc-bt3pro kernel: Key type big_key registered
feb 09 14:22:22 montronc-bt3pro kernel: AppArmor: AppArmor sha256 policy hashing enabled
feb 09 14:22:22 montronc-bt3pro kernel: i2c_designware 808622C1:05: I2C bus managed by PUNIT
feb 09 14:22:22 montronc-bt3pro kernel: PM:   Magic number: 14:850:381
feb 09 14:22:22 montronc-bt3pro kernel: RAS: Correctable Errors collector initialized.
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-2: new low-speed USB device number 2 using xhci_hcd
feb 09 14:22:22 montronc-bt3pro kernel: clk: Disabling unused clocks
feb 09 14:22:22 montronc-bt3pro kernel: PM: genpd: Disabling unused power domains
feb 09 14:22:22 montronc-bt3pro kernel: Freeing unused decrypted memory: 2028K
feb 09 14:22:22 montronc-bt3pro kernel: Freeing unused kernel image (initmem) memory: 4732K
feb 09 14:22:22 montronc-bt3pro kernel: Write protecting the kernel read-only data: 36864k
feb 09 14:22:22 montronc-bt3pro kernel: Freeing unused kernel image (text/rodata gap) memory: 220K
feb 09 14:22:22 montronc-bt3pro kernel: Freeing unused kernel image (rodata/data gap) memory: 12K
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-2: New USB device found, idVendor=0e8f, idProduct=00a4, bcdDevice= 3.11
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-2: Product: 2.4G RX
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-2: Manufacturer: DKTEK
feb 09 14:22:22 montronc-bt3pro kernel: input: DKTEK 2.4G RX as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:0E8F:00A4.0001/input/input2
feb 09 14:22:22 montronc-bt3pro kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
feb 09 14:22:22 montronc-bt3pro kernel: rodata_test: all tests were successful
feb 09 14:22:22 montronc-bt3pro kernel: x86/mm: Checking user space page tables
feb 09 14:22:22 montronc-bt3pro kernel: hid-generic 0003:0E8F:00A4.0001: input,hidraw0: USB HID v1.10 Keyboard [DKTEK 2.4G RX] on usb-0000:00:14.0-2/input0
feb 09 14:22:22 montronc-bt3pro kernel: input: DKTEK 2.4G RX Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:0E8F:00A4.0002/input/input3
feb 09 14:22:22 montronc-bt3pro kernel: input: DKTEK 2.4G RX System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:0E8F:00A4.0002/input/input4
feb 09 14:22:22 montronc-bt3pro kernel: Run /init as init process
feb 09 14:22:22 montronc-bt3pro kernel:   with arguments:
feb 09 14:22:22 montronc-bt3pro kernel:     /init
feb 09 14:22:22 montronc-bt3pro kernel:     splash
feb 09 14:22:22 montronc-bt3pro kernel:   with environment:
feb 09 14:22:22 montronc-bt3pro kernel:     HOME=/
feb 09 14:22:22 montronc-bt3pro kernel:     TERM=linux
feb 09 14:22:22 montronc-bt3pro kernel: input: DKTEK 2.4G RX Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:0E8F:00A4.0002/input/input5
feb 09 14:22:22 montronc-bt3pro kernel: input: DKTEK 2.4G RX as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:0E8F:00A4.0002/input/input6
feb 09 14:22:22 montronc-bt3pro kernel: hid-generic 0003:0E8F:00A4.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [DKTEK 2.4G RX] on usb-0000:00:14.0-2/input1
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-4: new low-speed USB device number 3 using xhci_hcd
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-4: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
feb 09 14:22:22 montronc-bt3pro kernel: usb 1-4: Product: Dell KB216 Wired Keyboard
feb 09 14:22:22 montronc-bt3pro kernel: input: Dell KB216 Wired Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:413C:2113.0003/input/input7
feb 09 14:22:22 montronc-bt3pro kernel: hid-generic 0003:413C:2113.0003: input,hidraw2: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-0000:00:14.0-4/input0
feb 09 14:22:22 montronc-bt3pro kernel: input: Dell KB216 Wired Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:413C:2113.0004/input/input8
feb 09 14:22:22 montronc-bt3pro kernel: input: Dell KB216 Wired Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:413C:2113.0004/input/input9
feb 09 14:22:22 montronc-bt3pro kernel: hid-generic 0003:413C:2113.0004: input,hidraw3: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-0000:00:14.0-4/input1
feb 09 14:22:22 montronc-bt3pro kernel: sdhci: Secure Digital Host Controller Interface driver
feb 09 14:22:22 montronc-bt3pro kernel: sdhci: Copyright(c) Pierre Ossman
feb 09 14:22:22 montronc-bt3pro kernel: dw_dmac INTL9C60:00: DesignWare DMA Controller, 8 channels
feb 09 14:22:22 montronc-bt3pro kernel: axp20x-i2c i2c-INT33F4:00: AXP20x variant AXP288 found
feb 09 14:22:22 montronc-bt3pro kernel: dw_dmac INTL9C60:01: DesignWare DMA Controller, 8 channels
feb 09 14:22:22 montronc-bt3pro kernel: mmc1: SDHCI controller on ACPI [80860F14:00] using ADMA
feb 09 14:22:22 montronc-bt3pro kernel: mmc0: SDHCI controller on ACPI [80860F14:02] using ADMA
feb 09 14:22:22 montronc-bt3pro kernel: mmc2: SDHCI controller on ACPI [80860F14:03] using ADMA
feb 09 14:22:22 montronc-bt3pro kernel: axp20x-i2c i2c-INT33F4:00: AXP20X driver loaded
feb 09 14:22:22 montronc-bt3pro kernel: mmc1: new HS200 MMC card at address 0001
feb 09 14:22:22 montronc-bt3pro kernel: mmc0: new UHS-I speed SDR104 SDIO card at address 0001
feb 09 14:22:22 montronc-bt3pro kernel: mmcblk1: mmc1:0001 SLD64G 57.6 GiB
feb 09 14:22:22 montronc-bt3pro kernel:  mmcblk1: p1 p2 p3
feb 09 14:22:22 montronc-bt3pro kernel: mmcblk1boot0: mmc1:0001 SLD64G 4.00 MiB
feb 09 14:22:22 montronc-bt3pro kernel: mmcblk1boot1: mmc1:0001 SLD64G 4.00 MiB
feb 09 14:22:22 montronc-bt3pro kernel: mmcblk1rpmb: mmc1:0001 SLD64G 4.00 MiB, chardev (239:0)
feb 09 14:22:22 montronc-bt3pro kernel: i915 0000:00:02.0: [drm] Found cherryview (device ID 22b0) integrated display version 8.00 stepping N/A
feb 09 14:22:22 montronc-bt3pro kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
feb 09 14:22:22 montronc-bt3pro kernel: i915 0000:00:02.0: [drm] Registered 3 planes with drm panic
feb 09 14:22:22 montronc-bt3pro kernel: [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
feb 09 14:22:22 montronc-bt3pro kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
feb 09 14:22:22 montronc-bt3pro kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10
feb 09 14:22:22 montronc-bt3pro kernel: i915 0000:00:02.0: [drm] HDaudio controller not detected, using LPE audio instead
feb 09 14:22:22 montronc-bt3pro kernel: fbcon: i915drmfb (fb0) is primary device
feb 09 14:22:22 montronc-bt3pro kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
feb 09 14:22:22 montronc-bt3pro kernel: PM: Image not found (code -22)
feb 09 14:22:22 montronc-bt3pro kernel: EXT4-fs (mmcblk1p2): mounted filesystem 5e957f79-01ca-49b0-b817-c5ff513096d2 r/w with ordered data mode. Quota mode: none.
feb 09 14:22:22 montronc-bt3pro systemd[1]: systemd 258.3-1-manjaro running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
feb 09 14:22:22 montronc-bt3pro systemd[1]: Detected architecture x86-64.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Hostname set to <montronc-bt3pro>.
feb 09 14:22:22 montronc-bt3pro systemd[1]: bpf-restrict-fs: LSM BPF program attached
feb 09 14:22:22 montronc-bt3pro systemd[1]: Queued start job for default target Graphical Interface.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice CUPS Slice.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/dirmngr.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/getty.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/gpg-agent.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/gpg-agent-browser.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/gpg-agent-extra.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/gpg-agent-ssh.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/keyboxd.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/modprobe.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice Slice /system/systemd-fsck.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Created slice User and Session Slice.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Started Forward Password Requests to Wall Directory Watch.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Expecting device /dev/disk/by-uuid/07F3-497A...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Expecting device /dev/disk/by-uuid/2124267b-6ba6-4a5e-9f16-130cf47cd804...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Login Prompts.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Image Downloads.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Local Integrity Protected Volumes.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Remote File Systems.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Slice Units.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Mounting snaps.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Mounted snaps.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Local Verity Protected Volumes.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on Device-mapper event daemon FIFOs.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on LVM2 poll daemon socket.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on Query the User Interactively for a Password.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on Process Core Dump Socket.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on Credential Encryption/Decryption.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on Factory Reset Management.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on Journal Socket (/dev/log).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on Journal Sockets.
feb 09 14:22:22 montronc-bt3pro systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on udev Control Socket.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on udev Kernel Socket.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Listening on udev Varlink Socket.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounting Huge Pages File System...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounting POSIX Message Queue File System...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounting Kernel Debug File System...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounting Kernel Trace File System...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Load AppArmor profiles...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Create List of Static Device Nodes...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Load Kernel Module configfs was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!configfs).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounting Kernel Configuration File System...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Load Kernel Module dm_mod...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Load Kernel Module drm was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!drm).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Load Kernel Module fuse was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!fuse).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounting FUSE Control File System...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Load Kernel Module loop...
feb 09 14:22:22 montronc-bt3pro systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Journal Service...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Load Kernel Modules...
feb 09 14:22:22 montronc-bt3pro systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Remount Root and Kernel File Systems...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:22 montronc-bt3pro kernel: loop: module loaded
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Load udev Rules from Credentials...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Coldplug All udev Devices...
feb 09 14:22:22 montronc-bt3pro kernel: device-mapper: uevent: version 1.0.3
feb 09 14:22:22 montronc-bt3pro kernel: device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Virtual Console Setup...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounted Huge Pages File System.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounted POSIX Message Queue File System.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounted Kernel Debug File System.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounted Kernel Trace File System.
feb 09 14:22:22 montronc-bt3pro kernel: EXT4-fs (mmcblk1p2): re-mounted 5e957f79-01ca-49b0-b817-c5ff513096d2.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Create List of Static Device Nodes.
feb 09 14:22:22 montronc-bt3pro kernel: i2c_dev: i2c /dev entries driver
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounted Kernel Configuration File System.
feb 09 14:22:22 montronc-bt3pro systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Load Kernel Module dm_mod.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Mounted FUSE Control File System.
feb 09 14:22:22 montronc-bt3pro systemd[1]: modprobe@loop.service: Deactivated successfully.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Load Kernel Module loop.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Remount Root and Kernel File Systems.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Load udev Rules from Credentials.
feb 09 14:22:22 montronc-bt3pro systemd-journald[309]: Collecting audit messages is disabled.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.120:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=325 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro kernel: Asymmetric key parser 'pkcs8' registered
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.121:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=324 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Load/Save OS Random Seed...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.130:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=327 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
feb 09 14:22:22 montronc-bt3pro systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.137:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=326 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.142:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=333 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Load Kernel Modules.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Apply Kernel Variables...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Virtual Console Setup.
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.164:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=337 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.168:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=338 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Load/Save OS Random Seed.
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.222:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=341 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.223:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=340 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro kernel: audit: type=1400 audit(1770643342.238:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=343 comm="apparmor_parser"
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Apply Kernel Variables.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting CLI Netfilter Manager...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished CLI Netfilter Manager.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Create System Users was skipped because no trigger condition checks were met.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Network Time Synchronization...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Create Static Device Nodes in /dev...
feb 09 14:22:22 montronc-bt3pro systemd-journald[309]: Journal started
feb 09 14:22:22 montronc-bt3pro systemd-journald[309]: Runtime Journal (/run/log/journal/2a98b3739f3843569cac43f5fa97e058) is 8M, max 191.8M, 183.8M free.
feb 09 14:22:22 montronc-bt3pro systemd-modules-load[310]: Inserted module 'crypto_user'
feb 09 14:22:22 montronc-bt3pro systemd-modules-load[310]: Inserted module 'i2c_dev'
feb 09 14:22:22 montronc-bt3pro systemd-modules-load[310]: Inserted module 'pkcs8_key_parser'
feb 09 14:22:22 montronc-bt3pro systemd[1]: Started Journal Service.
feb 09 14:22:22 montronc-bt3pro systemd-vconsole-setup[321]: All allocated virtual consoles are busy, will not configure key mapping and font.
feb 09 14:22:22 montronc-bt3pro apparmor.systemd[301]: Restarting AppArmor
feb 09 14:22:22 montronc-bt3pro apparmor.systemd[301]: Reloading AppArmor profiles
feb 09 14:22:22 montronc-bt3pro ufw-init[362]: Skip starting firewall: ufw (not enabled)
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Flush Journal to Persistent Storage...
feb 09 14:22:22 montronc-bt3pro systemd-journald[309]: Time spent on flushing to /var/log/journal/2a98b3739f3843569cac43f5fa97e058 is 200.559ms for 772 entries.
feb 09 14:22:22 montronc-bt3pro systemd-journald[309]: System Journal (/var/log/journal/2a98b3739f3843569cac43f5fa97e058) is 518M, max 4G, 3.4G free.
feb 09 14:22:23 montronc-bt3pro systemd-journald[309]: Received client request to flush runtime journal.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Finished Create Static Device Nodes in /dev.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target Preparation for Local File Systems.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Starting Rule-based Manager for Device Events and Files...
feb 09 14:22:22 montronc-bt3pro systemd[1]: Started Network Time Synchronization.
feb 09 14:22:22 montronc-bt3pro systemd[1]: Reached target System Time Set.
feb 09 14:22:23 montronc-bt3pro systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
feb 09 14:22:23 montronc-bt3pro systemd-timesyncd[372]: Network configuration changed, trying to establish connection.
feb 09 14:22:23 montronc-bt3pro systemd[1]: Listening on Disk Image Download Service Socket.
feb 09 14:22:23 montronc-bt3pro systemd[1]: Finished Flush Journal to Persistent Storage.
feb 09 14:22:23 montronc-bt3pro systemd[1]: Started Rule-based Manager for Device Events and Files.
feb 09 14:22:24 montronc-bt3pro systemd[1]: Finished Coldplug All udev Devices.
feb 09 14:22:24 montronc-bt3pro systemd[1]: Starting Show Plymouth Boot Screen...
feb 09 14:22:24 montronc-bt3pro systemd[1]: Started Show Plymouth Boot Screen.
feb 09 14:22:24 montronc-bt3pro systemd[1]: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
feb 09 14:22:24 montronc-bt3pro systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
feb 09 14:22:24 montronc-bt3pro systemd[1]: Reached target Local Encrypted Volumes.
feb 09 14:22:24 montronc-bt3pro systemd[1]: Expecting device /dev/tpm0...
feb 09 14:22:25 montronc-bt3pro mtp-probe[508]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4"
feb 09 14:22:25 montronc-bt3pro mtp-probe[511]: checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2"
feb 09 14:22:25 montronc-bt3pro mtp-probe[511]: bus: 1, device: 2 was not an MTP device
feb 09 14:22:25 montronc-bt3pro mtp-probe[508]: bus: 1, device: 3 was not an MTP device
feb 09 14:22:25 montronc-bt3pro systemd[1]: Found device /dev/disk/by-uuid/07F3-497A.
feb 09 14:22:25 montronc-bt3pro systemd[1]: Found device /dev/disk/by-uuid/2124267b-6ba6-4a5e-9f16-130cf47cd804.
feb 09 14:22:25 montronc-bt3pro systemd[1]: Activating swap /dev/disk/by-uuid/2124267b-6ba6-4a5e-9f16-130cf47cd804...
feb 09 14:22:25 montronc-bt3pro systemd[1]: Starting File System Check on /dev/disk/by-uuid/07F3-497A...
feb 09 14:22:25 montronc-bt3pro kernel: Adding 6010312k swap on /dev/mmcblk1p3.  Priority:-2 extents:1 across:6010312k SS
feb 09 14:22:25 montronc-bt3pro systemd[1]: Activated swap /dev/disk/by-uuid/2124267b-6ba6-4a5e-9f16-130cf47cd804.
feb 09 14:22:25 montronc-bt3pro systemd[1]: Reached target Swaps.
feb 09 14:22:25 montronc-bt3pro systemd[1]: Mounting /tmp...
feb 09 14:22:25 montronc-bt3pro systemd-fsck[519]: fsck.fat 4.2 (2021-01-31)
feb 09 14:22:25 montronc-bt3pro systemd-fsck[519]: /dev/mmcblk1p1: 5 files, 74/76646 clusters
feb 09 14:22:25 montronc-bt3pro systemd[1]: Finished File System Check on /dev/disk/by-uuid/07F3-497A.
feb 09 14:22:25 montronc-bt3pro systemd[1]: Mounting /boot/efi...
feb 09 14:22:25 montronc-bt3pro systemd[1]: Mounted /tmp.
feb 09 14:22:26 montronc-bt3pro kernel: mousedev: PS/2 mouse device common for all mice
feb 09 14:22:26 montronc-bt3pro systemd[1]: Mounted /boot/efi.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Reached target Local File Systems.
feb 09 14:22:26 montronc-bt3pro systemd-timesyncd[372]: Network configuration changed, trying to establish connection.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Listening on Boot Entries Service Socket.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Listening on System Extension Image Management.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
feb 09 14:22:26 montronc-bt3pro systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Update Boot Loader Random Seed was skipped because no trigger condition checks were met.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Starting Create System Files and Directories...
feb 09 14:22:26 montronc-bt3pro systemd[1]: Received SIGRTMIN+20 from PID 199 (plymouthd).
feb 09 14:22:26 montronc-bt3pro systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Found device /dev/tpm0.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Reached target Trusted Platform Module.
feb 09 14:22:26 montronc-bt3pro kernel: 8086228A:00: ttyS4 at MMIO 0x91921000 (irq = 39, base_baud = 2764800) is a 16550A
feb 09 14:22:26 montronc-bt3pro kernel: serial serial0: tty port ttyS4 registered
feb 09 14:22:26 montronc-bt3pro systemd[1]: Finished Create System Files and Directories.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
feb 09 14:22:26 montronc-bt3pro systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
feb 09 14:22:26 montronc-bt3pro systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
feb 09 14:22:26 montronc-bt3pro systemd[1]: Rebuild Journal Catalog was skipped because of an unmet condition check (ConditionNeedsUpdate=/var).
feb 09 14:22:26 montronc-bt3pro systemd[1]: Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
feb 09 14:22:26 montronc-bt3pro systemd[1]: Update is Completed was skipped because no trigger condition checks were met.
feb 09 14:22:26 montronc-bt3pro systemd[1]: Starting Record System Boot/Shutdown in UTMP...
feb 09 14:22:26 montronc-bt3pro kernel: 8086228A:01: ttyS5 at MMIO 0x9191f000 (irq = 40, base_baud = 2764800) is a 16550A
feb 09 14:22:26 montronc-bt3pro systemd[1]: Finished Record System Boot/Shutdown in UTMP.
feb 09 14:22:27 montronc-bt3pro kernel: kauditd_printk_skb: 102 callbacks suppressed
feb 09 14:22:27 montronc-bt3pro kernel: audit: type=1400 audit(1770643347.248:114): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-deliver" pid=538 comm="apparmor_parser"
feb 09 14:22:27 montronc-bt3pro kernel: audit: type=1400 audit(1770643347.473:115): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-director" pid=544 comm="apparmor_parser"
feb 09 14:22:27 montronc-bt3pro kernel: Bluetooth: Core ver 2.22
feb 09 14:22:27 montronc-bt3pro kernel: NET: Registered PF_BLUETOOTH protocol family
feb 09 14:22:27 montronc-bt3pro kernel: Bluetooth: HCI device and connection manager initialized
feb 09 14:22:27 montronc-bt3pro kernel: Bluetooth: HCI socket layer initialized
feb 09 14:22:27 montronc-bt3pro kernel: Bluetooth: L2CAP socket layer initialized
feb 09 14:22:27 montronc-bt3pro kernel: Bluetooth: SCO socket layer initialized
feb 09 14:22:27 montronc-bt3pro kernel: audit: type=1400 audit(1770643347.674:116): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-doveadm-server" pid=545 comm="apparmor_parser"
feb 09 14:22:27 montronc-bt3pro kernel: input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=0 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card0/input11
feb 09 14:22:27 montronc-bt3pro kernel: input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card0/input12
feb 09 14:22:27 montronc-bt3pro kernel: input: Intel HDMI/DP LPE Audio HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:02.0/hdmi-lpe-audio/sound/card0/input13
feb 09 14:22:27 montronc-bt3pro kernel: audit: type=1400 audit(1770643347.827:117): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-dict" pid=539 comm="apparmor_parser"
feb 09 14:22:27 montronc-bt3pro kernel: r8168: loading out-of-tree module taints kernel.
feb 09 14:22:27 montronc-bt3pro kernel: r8168: module verification failed: signature and/or required key missing - tainting kernel
feb 09 14:22:28 montronc-bt3pro kernel: r8168 Gigabit Ethernet driver 8.055.00 loaded
feb 09 14:22:28 montronc-bt3pro kernel: r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
feb 09 14:22:28 montronc-bt3pro kernel: r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
                                         This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                                         This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
feb 09 14:22:28 montronc-bt3pro kernel: axp288_extcon axp288_extcon: controlling USB role based on Vbus presence
feb 09 14:22:28 montronc-bt3pro kernel: spi-nor spi0.0: supply vcc not found, using dummy regulator
feb 09 14:22:28 montronc-bt3pro kernel: Creating 1 MTD partitions on "intel-spi":
feb 09 14:22:28 montronc-bt3pro kernel: 0x000000000000-0x000000800000 : "BIOS"
feb 09 14:22:28 montronc-bt3pro kernel: audit: type=1400 audit(1770643348.441:118): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-dovecot-auth" pid=550 comm="apparmor_parser"
feb 09 14:22:28 montronc-bt3pro kernel: audit: type=1400 audit(1770643348.553:119): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-imap" pid=553 comm="apparmor_parser"
feb 09 14:22:28 montronc-bt3pro kernel: audit: type=1400 audit(1770643348.645:120): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-imap-login" pid=557 comm="apparmor_parser"
feb 09 14:22:28 montronc-bt3pro kernel: audit: type=1400 audit(1770643348.796:121): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-log" pid=560 comm="apparmor_parser"
feb 09 14:22:28 montronc-bt3pro kernel: audit: type=1400 audit(1770643348.857:122): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-dovecot-lda" pid=552 comm="apparmor_parser"
feb 09 14:22:28 montronc-bt3pro kernel: audit: type=1400 audit(1770643348.906:123): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-dovecot-lda//sendmail" pid=552 comm="apparmor_parser"
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART driver ver 2.3
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol H4 registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol BCSP registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol LL registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol ATH3K registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol Intel registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol Broadcom registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol QCA registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol AG6XX registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol Marvell registered
feb 09 14:22:28 montronc-bt3pro kernel: Bluetooth: HCI UART protocol AML registered
feb 09 14:22:28 montronc-bt3pro kernel: hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
feb 09 14:22:28 montronc-bt3pro kernel: hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
feb 09 14:22:28 montronc-bt3pro kernel: input: PC Speaker as /devices/platform/pcspkr/input/input14
feb 09 14:22:28 montronc-bt3pro kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
feb 09 14:22:29 montronc-bt3pro kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
feb 09 14:22:29 montronc-bt3pro kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
feb 09 14:22:29 montronc-bt3pro kernel: cherryview-pinctrl INT33FF:00: interrupt line 0 is used by both pin 78 and pin 80
feb 09 14:22:29 montronc-bt3pro kernel: cherryview-pinctrl INT33FF:00: changing the interrupt line for pin 80 to 7
feb 09 14:22:29 montronc-bt3pro kernel: input: gpio-keys as /devices/platform/ACPI0011:00/gpio-keys.1.auto/input/input15
feb 09 14:22:29 montronc-bt3pro kernel: cherryview-pinctrl INT33FF:02: interrupt line 0 is used by both pin 24 and pin 8
feb 09 14:22:29 montronc-bt3pro kernel: cherryview-pinctrl INT33FF:02: changing the interrupt line for pin 8 to 15
feb 09 14:22:29 montronc-bt3pro systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
feb 09 14:22:29 montronc-bt3pro kernel: input: gpio-keys as /devices/platform/ACPI0011:00/gpio-keys.2.auto/input/input16
feb 09 14:22:29 montronc-bt3pro systemd[1]: Stopped Virtual Console Setup.
feb 09 14:22:29 montronc-bt3pro systemd[1]: Stopping Virtual Console Setup...
feb 09 14:22:29 montronc-bt3pro systemd[1]: Starting Virtual Console Setup...
feb 09 14:22:29 montronc-bt3pro systemd-vconsole-setup[575]: All allocated virtual consoles are busy, will not configure key mapping and font.
feb 09 14:22:29 montronc-bt3pro systemd[1]: Finished Virtual Console Setup.
feb 09 14:22:29 montronc-bt3pro kernel: Bluetooth: hci0: BCM: chip id 107
feb 09 14:22:29 montronc-bt3pro kernel: Bluetooth: hci0: BCM: features 0x2f
feb 09 14:22:29 montronc-bt3pro kernel: Bluetooth: hci0: BCM4345C0
feb 09 14:22:29 montronc-bt3pro kernel: Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
feb 09 14:22:29 montronc-bt3pro kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried:
feb 09 14:22:29 montronc-bt3pro kernel: Bluetooth: hci0: BCM: 'brcm/BCM4345C0.hcd'
feb 09 14:22:29 montronc-bt3pro kernel: Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
feb 09 14:22:29 montronc-bt3pro systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
feb 09 14:22:29 montronc-bt3pro systemd[1]: Starting Load/Save RF Kill Switch Status...
feb 09 14:22:29 montronc-bt3pro kernel: r8168 0000:01:00.0 enp1s0: renamed from eth0
feb 09 14:22:29 montronc-bt3pro kernel: proc_thermal 0000:00:0b.0: enabling device (0000 -> 0002)
feb 09 14:22:29 montronc-bt3pro kernel: brcmfmac: F1 signature read @0x18000000=0x15264345
feb 09 14:22:29 montronc-bt3pro kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
feb 09 14:22:29 montronc-bt3pro kernel: brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.AZW-BT3 PRO.bin failed with error -2
feb 09 14:22:29 montronc-bt3pro kernel: intel_rapl_common: Found RAPL domain package
feb 09 14:22:29 montronc-bt3pro kernel: intel_rapl_common: Found RAPL domain core
feb 09 14:22:29 montronc-bt3pro kernel: usbcore: registered new interface driver brcmfmac
feb 09 14:22:30 montronc-bt3pro kernel: intel_sst_acpi 808622A8:00: LPE base: 0x91400000 size:0x200000
feb 09 14:22:30 montronc-bt3pro kernel: intel_sst_acpi 808622A8:00: IRAM base: 0x914c0000
feb 09 14:22:30 montronc-bt3pro kernel: intel_sst_acpi 808622A8:00: DRAM base: 0x91500000
feb 09 14:22:30 montronc-bt3pro kernel: intel_sst_acpi 808622A8:00: SHIM base: 0x91540000
feb 09 14:22:30 montronc-bt3pro kernel: intel_sst_acpi 808622A8:00: Mailbox base: 0x91544000
feb 09 14:22:30 montronc-bt3pro kernel: intel_sst_acpi 808622A8:00: DDR base: 0x20000000
feb 09 14:22:30 montronc-bt3pro kernel: intel_sst_acpi 808622A8:00: Got drv data max stream 25
feb 09 14:22:30 montronc-bt3pro systemd[1]: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
feb 09 14:22:30 montronc-bt3pro systemd[1]: Load Kernel Module dm_mod was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!dm_mod).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Load Kernel Module loop was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!loop).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
feb 09 14:22:30 montronc-bt3pro systemd[1]: Update Boot Loader Random Seed was skipped because no trigger condition checks were met.
feb 09 14:22:30 montronc-bt3pro systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Rebuild Journal Catalog was skipped because of an unmet condition check (ConditionNeedsUpdate=/var).
feb 09 14:22:30 montronc-bt3pro systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Create System Users was skipped because no trigger condition checks were met.
feb 09 14:22:30 montronc-bt3pro systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
feb 09 14:22:30 montronc-bt3pro systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
feb 09 14:22:30 montronc-bt3pro systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:30 montronc-bt3pro systemd[1]: Update is Completed was skipped because no trigger condition checks were met.
feb 09 14:22:30 montronc-bt3pro kernel: brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
feb 09 14:22:30 montronc-bt3pro kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
feb 09 14:22:30 montronc-bt3pro systemd[1]: Started Load/Save RF Kill Switch Status.
feb 09 14:22:31 montronc-bt3pro kernel: bytcr_rt5651 bytcr_rt5651: quirk IN2_MAP enabled
feb 09 14:22:31 montronc-bt3pro kernel: bytcr_rt5651 bytcr_rt5651: quirk realtek,jack-detect-source 1
feb 09 14:22:31 montronc-bt3pro kernel: bytcr_rt5651 bytcr_rt5651: quirk realtek,over-current-threshold-microamp 2000
feb 09 14:22:31 montronc-bt3pro kernel: bytcr_rt5651 bytcr_rt5651: quirk realtek,over-current-scale-factor 1
feb 09 14:22:31 montronc-bt3pro kernel: bytcr_rt5651 bytcr_rt5651: quirk MCLK_EN enabled
feb 09 14:22:31 montronc-bt3pro kernel: input: bytcr-rt5651 Headset as /devices/pci0000:00/808622A8:00/bytcr_rt5651/sound/card1/input17
feb 09 14:22:31 montronc-bt3pro systemd[1]: Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
feb 09 14:22:31 montronc-bt3pro systemd[1]: Load Kernel Module dm_mod was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!dm_mod).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Load Kernel Module loop was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!loop).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
feb 09 14:22:31 montronc-bt3pro systemd[1]: Update Boot Loader Random Seed was skipped because no trigger condition checks were met.
feb 09 14:22:31 montronc-bt3pro systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Rebuild Journal Catalog was skipped because of an unmet condition check (ConditionNeedsUpdate=/var).
feb 09 14:22:31 montronc-bt3pro systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Create System Users was skipped because no trigger condition checks were met.
feb 09 14:22:31 montronc-bt3pro systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
feb 09 14:22:31 montronc-bt3pro systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
feb 09 14:22:31 montronc-bt3pro systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:31 montronc-bt3pro systemd[1]: Update is Completed was skipped because no trigger condition checks were met.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Finished Load AppArmor profiles.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
feb 09 14:22:32 montronc-bt3pro systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 634 (snapd-apparmor)
feb 09 14:22:32 montronc-bt3pro systemd[1]: Mounting Arbitrary Executable File Formats File System...
feb 09 14:22:32 montronc-bt3pro systemd[1]: Mounted Arbitrary Executable File Formats File System.
feb 09 14:22:32 montronc-bt3pro snapd-apparmor[634]: main.go:143: No profiles to load
feb 09 14:22:32 montronc-bt3pro systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Reached target System Initialization.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started CUPS Scheduler.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Refresh existing PGP keys of archlinux-keyring regularly.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Discard unused filesystem blocks once a week.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Daily rotation of log files.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Daily man-db regeneration.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Monthly clean packages cache.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Generate mirrorlist weekly.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Update the plocate database daily.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Daily verification of password and group files.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started Daily Cleanup of Temporary Directories.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Reached target Path Units.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Reached target Timer Units.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on CUPS Scheduler.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on D-Bus System Message Bus Socket.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on GnuPG public key management service for /etc/pacman.d/gnupg.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on Authorization Manager Agent Helper.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting Socket activation for snappy daemon...
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on Hostname Service Socket.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on User Login Management Varlink Socket.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on Virtual Machine and Container Registration Service Socket.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting D-Bus System Message Bus...
feb 09 14:22:32 montronc-bt3pro systemd[1]: TPM PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:32 montronc-bt3pro systemd[1]: Listening on Socket activation for snappy daemon.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Reached target Socket Units.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started D-Bus System Message Bus.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Reached target Basic System.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting Network Manager...
feb 09 14:22:32 montronc-bt3pro dbus-broker-launch[646]: Ready
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting Save/Restore Sound Card State...
feb 09 14:22:32 montronc-bt3pro systemd[1]: Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting Bluetooth service...
feb 09 14:22:32 montronc-bt3pro systemd[1]: Started DHCP/ IPv4LL/ IPv6RA/ DHCPv6 client on all interfaces.
feb 09 14:22:32 montronc-bt3pro alsactl[649]: alsa-lib main.c:1804:(snd_use_case_mgr_open) [error.ucm] failed to import hw:0 use case configuration -2
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting Authorization Manager...
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting Snap Daemon...
feb 09 14:22:32 montronc-bt3pro systemd[1]: Starting User Login Management...
feb 09 14:22:32 montronc-bt3pro systemd[1]: TPM PCR Barrier (User) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
feb 09 14:22:32 montronc-bt3pro systemd[1]: Finished Save/Restore Sound Card State.
feb 09 14:22:32 montronc-bt3pro systemd[1]: Reached target Sound Card.
feb 09 14:22:32 montronc-bt3pro dhcpcd[652]: dhcpcd-10.3.0 starting
feb 09 14:22:32 montronc-bt3pro dhcpcd[663]: dev: loaded udev
feb 09 14:22:32 montronc-bt3pro dhcpcd[663]: DUID 00:01:00:01:30:cb:f4:99:84:39:c0:0b:01:d6
feb 09 14:22:32 montronc-bt3pro NetworkManager[648]: <info>  [1770643352.9099] NetworkManager (version 1.54.3-1) is starting... (boot:23a7a34e-b93f-473c-9e0c-d62ed6bea972)
feb 09 14:22:32 montronc-bt3pro NetworkManager[648]: <info>  [1770643352.9141] Read config: /etc/NetworkManager/NetworkManager.conf, /usr/lib/NetworkManager/conf.d/20-connectivity.conf, /etc/NetworkManager/conf.d/powersave.conf
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.0043] manager[0x563fc11a8f70]: monitoring kernel firmware directory '/lib/firmware'.
feb 09 14:22:33 montronc-bt3pro bluetoothd[651]: Bluetooth daemon 5.85
feb 09 14:22:33 montronc-bt3pro kernel: 8021q: 802.1Q VLAN Support v1.8
feb 09 14:22:33 montronc-bt3pro bluetoothd[651]: Starting SDP server
feb 09 14:22:33 montronc-bt3pro systemd[1]: Starting Hostname Service...
feb 09 14:22:33 montronc-bt3pro systemd[1]: Started Bluetooth service.
feb 09 14:22:33 montronc-bt3pro systemd[1]: Reached target Bluetooth Support.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Found user 'avahi' (UID 968) and group 'avahi' (GID 968).
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Successfully dropped root privileges.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: avahi-daemon 0.9-rc3 starting up.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Successfully called chroot().
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Successfully dropped remaining capabilities.
feb 09 14:22:33 montronc-bt3pro systemd[1]: Started Avahi mDNS/DNS-SD Stack.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: No service file found in /etc/avahi/services.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: New relevant interface lo.IPv6 for mDNS.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: New relevant interface lo.IPv4 for mDNS.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Network interface enumeration completed.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Registering new address record for ::1 on lo.*.
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Registering new address record for 127.0.0.1 on lo.IPv4.
feb 09 14:22:33 montronc-bt3pro kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
feb 09 14:22:33 montronc-bt3pro kernel: Bluetooth: BNEP filters: protocol multicast
feb 09 14:22:33 montronc-bt3pro kernel: Bluetooth: BNEP socket layer initialized
feb 09 14:22:33 montronc-bt3pro bluetoothd[651]: Bluetooth management interface 1.23 initialized
feb 09 14:22:33 montronc-bt3pro kernel: Bluetooth: MGMT ver 1.23
feb 09 14:22:33 montronc-bt3pro bluetoothd[651]: Battery Provider Manager created
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: New seat seat0.
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: Watching system buttons on /dev/input/event1 (Power Button)
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: Watching system buttons on /dev/input/event0 (Power Button)
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: Watching system buttons on /dev/input/event2 (DKTEK 2.4G RX)
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: Watching system buttons on /dev/input/event4 (DKTEK 2.4G RX System Control)
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: Watching system buttons on /dev/input/event5 (DKTEK 2.4G RX Consumer Control)
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: Watching system buttons on /dev/input/event7 (Dell KB216 Wired Keyboard)
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: Watching system buttons on /dev/input/event8 (Dell KB216 Wired Keyboard System Control)
feb 09 14:22:33 montronc-bt3pro kernel: NET: Registered PF_ALG protocol family
feb 09 14:22:33 montronc-bt3pro polkitd[653]: Started polkitd version 127
feb 09 14:22:33 montronc-bt3pro systemd-logind[658]: Watching system buttons on /dev/input/event16 (gpio-keys)
feb 09 14:22:33 montronc-bt3pro systemd[1]: Started User Login Management.
feb 09 14:22:33 montronc-bt3pro dhcpcd[663]: no interfaces have a carrier
feb 09 14:22:33 montronc-bt3pro kernel: enp1s0: 0xffffd4b280c4d000, 84:39:c0:0b:01:d6, IRQ 170
feb 09 14:22:33 montronc-bt3pro systemd[1]: Started Authorization Manager.
feb 09 14:22:33 montronc-bt3pro systemd[1]: Starting Modem Manager...
feb 09 14:22:33 montronc-bt3pro systemd[1]: Started Hostname Service.
feb 09 14:22:33 montronc-bt3pro dhcpcd[663]: enp1s0: waiting for carrier
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.3715] hostname: hostname: using hostnamed
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.3716] hostname: static hostname changed from (none) to "montronc-bt3pro"
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.3732] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
feb 09 14:22:33 montronc-bt3pro dhcpcd[663]: wlan0: waiting for carrier
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.3965] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/80860F14:02/mmc_host/mmc0/mmc0:0001/mmc0:0001:1/ieee80211/phy0/rfkill1) (driver brcmfmac)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.3994] manager[0x563fc11a8f70]: rfkill: Wi-Fi hardware radio set enabled
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.3995] manager[0x563fc11a8f70]: rfkill: WWAN hardware radio set enabled
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.4666] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-ovs.so)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.4708] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-adsl.so)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.4903] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-bluetooth.so)
feb 09 14:22:33 montronc-bt3pro ModemManager[725]: <msg> ModemManager (version 1.24.2-1) starting in system bus...
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6295] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-team.so)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6375] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-wifi.so)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6399] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-wwan.so)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6418] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6420] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6422] manager: Networking is enabled by state file
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6446] settings: Loaded settings plugin: keyfile (internal)
feb 09 14:22:33 montronc-bt3pro systemd[1]: Starting Network Manager Script Dispatcher Service...
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6808] dhcp: init: Using DHCP client 'internal'
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6817] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6864] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', managed-type: 'external')
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6882] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', managed-type: 'external')
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6916] device (lo): Activation: starting connection 'lo' (96cae7f7-1cb6-48c8-9d36-30ed2edbdf0e)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6961] manager: (enp1s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.6973] device (enp1s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.7071] device (wlan0): driver supports Access Point (AP) mode
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.7105] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
feb 09 14:22:33 montronc-bt3pro NetworkManager[648]: <info>  [1770643353.7119] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
feb 09 14:22:33 montronc-bt3pro systemd[1]: Started Network Manager Script Dispatcher Service.
feb 09 14:22:33 montronc-bt3pro kernel: NET: Registered PF_QIPCRTR protocol family
feb 09 14:22:33 montronc-bt3pro systemd[1]: Started Modem Manager.
feb 09 14:22:33 montronc-bt3pro snapd[655]: overlord.go:294: Acquiring state lock file
feb 09 14:22:33 montronc-bt3pro snapd[655]: overlord.go:299: Acquired state lock file
feb 09 14:22:33 montronc-bt3pro avahi-daemon[650]: Server startup complete. Host name is montronc-bt3pro.local. Local service cookie is 2395710208.
feb 09 14:22:33 montronc-bt3pro snapd[655]: daemon.go:276: started snapd/2.73-1 (series 16; classic; devmode) manjaro/ (amd64) linux/6.18.8-1-MANJARO.
feb 09 14:22:33 montronc-bt3pro kernel: loop0: detected capacity change from 0 to 8
feb 09 14:22:33 montronc-bt3pro kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
feb 09 14:22:33 montronc-bt3pro systemd[1]: tmp-syscheck\x2dmountpoint\x2d983668928.mount: Deactivated successfully.
feb 09 14:22:33 montronc-bt3pro snapd[655]: daemon.go:370: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
feb 09 14:22:33 montronc-bt3pro snapd[655]: backends.go:70: AppArmor status: apparmor is enabled but some kernel features are missing: network
feb 09 14:22:34 montronc-bt3pro snapd[655]: backend.go:145: reloading profiles for snap-confine
feb 09 14:22:34 montronc-bt3pro dhcpcd[663]: wlan0: old hardware address: c0:84:7d:7d:1e:da
feb 09 14:22:34 montronc-bt3pro dhcpcd[663]: wlan0: new hardware address: 66:94:c3:f1:f5:42
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2250] device (wlan0): set-hw-addr: set MAC address to 66:94:C3:F1:F5:42 (scanning)
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2641] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2706] ovsdb: disconnected from ovsdb
feb 09 14:22:34 montronc-bt3pro systemd[1]: Started Network Manager.
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2730] device (lo): state change: disconnected -> prepare (reason 'none', managed-type: 'external')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2741] device (lo): state change: prepare -> config (reason 'none', managed-type: 'external')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2755] device (lo): state change: config -> ip-config (reason 'none', managed-type: 'external')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2794] device (lo): state change: ip-config -> ip-check (reason 'none', managed-type: 'external')
feb 09 14:22:34 montronc-bt3pro systemd[1]: Starting WPA supplicant...
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2869] manager: (FC:B9:DF:CF:1A:50): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/4)
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2892] device (FC:B9:DF:CF:1A:50): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <warn>  [1770643354.2897] device (FC:B9:DF:CF:1A:50): error setting IPv4 forwarding to '0': Argomento non valido
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2917] device (FC:B9:DF:CF:1A:50): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2938] device (lo): state change: ip-check -> secondaries (reason 'none', managed-type: 'external')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2949] device (lo): state change: secondaries -> activated (reason 'none', managed-type: 'external')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2969] device (lo): Activation: successful, device activated.
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.2995] modem-manager: ModemManager available
feb 09 14:22:34 montronc-bt3pro systemd[1]: Started WPA supplicant.
feb 09 14:22:34 montronc-bt3pro wpa_supplicant[785]: Successfully initialized wpa_supplicant
feb 09 14:22:34 montronc-bt3pro systemd[1]: Reached target Network.
feb 09 14:22:34 montronc-bt3pro systemd[1]: Starting CUPS Scheduler...
feb 09 14:22:34 montronc-bt3pro systemd[1]: Starting Permit User Sessions...
feb 09 14:22:34 montronc-bt3pro systemd[1]: Finished Permit User Sessions.
feb 09 14:22:34 montronc-bt3pro systemd[1]: Started Command Scheduler.
feb 09 14:22:34 montronc-bt3pro systemd[1]: Starting Hold until boot process finishes up...
feb 09 14:22:34 montronc-bt3pro systemd[1]: Starting Terminate Plymouth Boot Screen...
feb 09 14:22:34 montronc-bt3pro crond[790]: (CRON) STARTUP (1.7.2)
feb 09 14:22:34 montronc-bt3pro crond[790]: (CRON) INFO (Syslog will be used instead of sendmail.)
feb 09 14:22:34 montronc-bt3pro crond[790]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 91% if used.)
feb 09 14:22:34 montronc-bt3pro crond[790]: (CRON) INFO (running with inotify support)
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.5299] device (wlan0): supplicant interface state: internal-starting -> disconnected
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.5303] Wi-Fi P2P device controlled by interface wlan0 created
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.5310] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.5321] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <warn>  [1770643354.5325] device (p2p-dev-wlan0): error setting IPv4 forwarding to '0': Risorsa temporaneamente non disponibile
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.5345] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', managed-type: 'full')
feb 09 14:22:34 montronc-bt3pro NetworkManager[648]: <info>  [1770643354.5372] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
feb 09 14:22:34 montronc-bt3pro systemd[1]: Started CUPS Scheduler.
feb 09 14:22:34 montronc-bt3pro kernel: kauditd_printk_skb: 43 callbacks suppressed
feb 09 14:22:34 montronc-bt3pro kernel: audit: type=1400 audit(1770643354.604:167): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=784 comm="apparmor_parser"
feb 09 14:22:34 montronc-bt3pro kernel: audit: type=1400 audit(1770643354.617:168): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=784 comm="apparmor_parser"
feb 09 14:22:34 montronc-bt3pro systemd[1]: Started Snap Daemon.
feb 09 14:22:34 montronc-bt3pro systemd[1]: Starting Time & Date Service...
feb 09 14:22:34 montronc-bt3pro systemd[1]: Started Time & Date Service.
feb 09 14:22:35 montronc-bt3pro systemd[1]: Received SIGRTMIN+21 from PID 199 (plymouthd).
feb 09 14:22:35 montronc-bt3pro systemd[1]: Finished Hold until boot process finishes up.
feb 09 14:22:35 montronc-bt3pro systemd[1]: Finished Terminate Plymouth Boot Screen.
feb 09 14:22:35 montronc-bt3pro systemd[1]: Reached target Multi-User System.
feb 09 14:22:35 montronc-bt3pro systemd[1]: Starting Light Display Manager...
feb 09 14:22:35 montronc-bt3pro systemd[1]: Reached target User and Group Name Lookups.
feb 09 14:22:35 montronc-bt3pro systemd[1]: Starting Accounts Service...
feb 09 14:22:35 montronc-bt3pro systemd[1]: systemd-rfkill.service: Deactivated successfully.
feb 09 14:22:35 montronc-bt3pro accounts-daemon[817]: started daemon version 23.13.0
feb 09 14:22:35 montronc-bt3pro systemd[1]: Started Accounts Service.
feb 09 14:22:36 montronc-bt3pro systemd[1]: Started Light Display Manager.
feb 09 14:22:36 montronc-bt3pro systemd[1]: Reached target Graphical Interface.
feb 09 14:22:36 montronc-bt3pro systemd[1]: Startup finished in 6.551s (firmware) + 12.959s (loader) + 8.136s (kernel) + 17.616s (userspace) = 45.263s.
feb 09 14:22:37 montronc-bt3pro NetworkManager[648]: <info>  [1770643357.9883] policy: auto-activating connection 'Moonbay-Home' (fac190d3-4dfc-4c50-813a-325140b0aa47)
feb 09 14:22:37 montronc-bt3pro NetworkManager[648]: <info>  [1770643357.9919] device (wlan0): Activation: starting connection 'Moonbay-Home' (fac190d3-4dfc-4c50-813a-325140b0aa47)
feb 09 14:22:37 montronc-bt3pro NetworkManager[648]: <info>  [1770643357.9927] device (wlan0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
feb 09 14:22:37 montronc-bt3pro NetworkManager[648]: <info>  [1770643357.9948] manager: NetworkManager state is now CONNECTING
feb 09 14:22:38 montronc-bt3pro ModemManager[725]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:01:00.0': not supported by any plugin
feb 09 14:22:38 montronc-bt3pro ModemManager[725]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/80860F14:02/mmc_host/mmc0/mmc0:0001/mmc0:0001:1': not supported by any plugin
feb 09 14:22:38 montronc-bt3pro dhcpcd[663]: wlan0: old hardware address: 66:94:c3:f1:f5:42
feb 09 14:22:38 montronc-bt3pro dhcpcd[663]: wlan0: new hardware address: c0:84:7d:7d:1e:da
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5112] device (wlan0): set-hw-addr: reset MAC address to C0:84:7D:7D:1E:DA (preserve)
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5248] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full')
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5278] device (wlan0): Activation: (wifi) access point 'Moonbay-Home' has security, but secrets are required.
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5281] device (wlan0): state change: config -> need-auth (reason 'none', managed-type: 'full')
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5303] sup-iface[e46812a00c29f367,0,wlan0]: wps: type pbc start...
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5325] device (wlan0): supplicant interface state: disconnected -> inactive
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5327] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> inactive
feb 09 14:22:38 montronc-bt3pro wpa_supplicant[785]: wlan0: WPS-PBC-ACTIVE
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5419] device (wlan0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5458] device (wlan0): state change: prepare -> config (reason 'none', managed-type: 'full')
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5483] device (wlan0): Activation: (wifi) connection 'Moonbay-Home' has security, and secrets exist.  No new secrets needed.
feb 09 14:22:38 montronc-bt3pro wpa_supplicant[785]: wlan0: WPS-CANCEL
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5578] Config: added 'ssid' value 'Moonbay-Home'
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5580] Config: added 'scan_ssid' value '1'
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5582] Config: added 'bgscan' value 'simple:30:-70:86400'
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5583] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5585] Config: added 'auth_alg' value 'OPEN'
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5586] Config: added 'psk' value '<hidden>'
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5619] device (wlan0): supplicant interface state: inactive -> scanning
feb 09 14:22:38 montronc-bt3pro NetworkManager[648]: <info>  [1770643358.5621] device (p2p-dev-wlan0): supplicant management interface state: inactive -> scanning
feb 09 14:22:40 montronc-bt3pro lightdm[832]: pam_succeed_if(lightdm-autologin:auth): requirement "user ingroup autologin" was met by user "montronc"
feb 09 14:22:40 montronc-bt3pro lightdm[832]: gkr-pam: no password is available for user
feb 09 14:22:40 montronc-bt3pro dbus-broker-launch[646]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
feb 09 14:22:40 montronc-bt3pro lightdm[832]: pam_unix(lightdm-autologin:session): session opened for user montronc(uid=1000) by montronc(uid=0)
feb 09 14:22:40 montronc-bt3pro systemd[1]: Created slice User Slice of UID 1000.
feb 09 14:22:40 montronc-bt3pro systemd[1]: Starting User Runtime Directory /run/user/1000...
feb 09 14:22:40 montronc-bt3pro systemd-logind[658]: New session '1' of user 'montronc' with class 'user' and type 'x11'.
feb 09 14:22:40 montronc-bt3pro systemd-user-runtime-dir[838]: Successfully configured disk quota for UID 1000 on /dev/shm to 1.4G
feb 09 14:22:40 montronc-bt3pro systemd[1]: Finished User Runtime Directory /run/user/1000.
feb 09 14:22:40 montronc-bt3pro systemd[1]: Starting User Manager for UID 1000...
feb 09 14:22:40 montronc-bt3pro (systemd)[845]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[montronc] ruser=[<unknown>] rhost=[<unknown>]
feb 09 14:22:40 montronc-bt3pro (systemd)[845]: pam_unix(systemd-user:session): session opened for user montronc(uid=1000) by montronc(uid=0)
feb 09 14:22:40 montronc-bt3pro systemd-logind[658]: New session '2' of user 'montronc' with class 'manager' and type 'unspecified'.
feb 09 14:22:40 montronc-bt3pro NetworkManager[648]: <info>  [1770643360.9475] device (wlan0): supplicant interface state: scanning -> inactive
feb 09 14:22:40 montronc-bt3pro NetworkManager[648]: <info>  [1770643360.9476] device (p2p-dev-wlan0): supplicant management interface state: scanning -> inactive
feb 09 14:22:40 montronc-bt3pro wpa_supplicant[785]: wlan0: Trying to associate with SSID 'Moonbay-Home'
feb 09 14:22:40 montronc-bt3pro NetworkManager[648]: <info>  [1770643360.9610] device (wlan0): supplicant interface state: inactive -> associating
feb 09 14:22:40 montronc-bt3pro NetworkManager[648]: <info>  [1770643360.9612] device (p2p-dev-wlan0): supplicant management interface state: inactive -> associating
feb 09 14:22:41 montronc-bt3pro systemd-xdg-autostart-generator[866]: Configuration file /home/montronc/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
feb 09 14:22:41 montronc-bt3pro wpa_supplicant[785]: wlan0: Associated with fc:40:09:d9:20:29
feb 09 14:22:41 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
feb 09 14:22:41 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=IT
feb 09 14:22:41 montronc-bt3pro NetworkManager[648]: <info>  [1770643361.1418] device (wlan0): supplicant interface state: associating -> associated
feb 09 14:22:41 montronc-bt3pro NetworkManager[648]: <info>  [1770643361.1420] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated
feb 09 14:22:41 montronc-bt3pro systemd[845]: Queued start job for default target Main User Target.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Created slice User Application Slice.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Reached target Paths.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Reached target Timers.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Starting D-Bus User Message Bus Socket...
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on GnuPG network certificate management daemon.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Starting GCR ssh-agent wrapper...
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on GNOME Keyring daemon.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on GnuPG cryptographic agent and passphrase cache.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on GnuPG public key management service.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on p11-kit server.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on PipeWire PulseAudio.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on PipeWire Multimedia System Sockets.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on Query the User Interactively for a Password.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on D-Bus User Message Bus Socket.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Listening on GCR ssh-agent wrapper.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Reached target Sockets.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Reached target Basic System.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Reached target Main User Target.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Startup finished in 934ms.
feb 09 14:22:41 montronc-bt3pro systemd[1]: Started User Manager for UID 1000.
feb 09 14:22:41 montronc-bt3pro systemd[1]: Started Session 1 of User montronc.
feb 09 14:22:41 montronc-bt3pro systemd[845]: Started GNOME Keyring daemon.
feb 09 14:22:41 montronc-bt3pro gnome-keyring-daemon[872]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
feb 09 14:22:41 montronc-bt3pro gnome-keyring-daemon[872]: GNOME_KEYRING_CONTROL=/run/user/1000/keyring
feb 09 14:22:42 montronc-bt3pro systemd[845]: Created slice User Core Session Slice.
feb 09 14:22:42 montronc-bt3pro systemd[845]: Starting D-Bus User Message Bus...
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
feb 09 14:22:42 montronc-bt3pro systemd[845]: Started D-Bus User Message Bus.
feb 09 14:22:42 montronc-bt3pro dbus-broker-launch[877]: Ready
feb 09 14:22:42 montronc-bt3pro lightdm[832]: gkr-pam: couldn't unlock the login keyring.
feb 09 14:22:43 montronc-bt3pro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
feb 09 14:22:44 montronc-bt3pro systemd[845]: Starting Virtual filesystem service...
feb 09 14:22:44 montronc-bt3pro systemd[845]: Started Virtual filesystem service.
feb 09 14:22:44 montronc-bt3pro systemd[845]: Starting Accessibility services bus...
feb 09 14:22:44 montronc-bt3pro systemd[845]: Started Accessibility services bus.
feb 09 14:22:44 montronc-bt3pro dbus-broker-launch[933]: Ready
feb 09 14:22:44 montronc-bt3pro systemd[845]: Starting Xfce configuration service...
feb 09 14:22:44 montronc-bt3pro systemd[845]: Started Xfce configuration service.
feb 09 14:22:44 montronc-bt3pro systemd[845]: Created slice Slice /app/dbus-:1.11-org.a11y.atspi.Registry.
feb 09 14:22:44 montronc-bt3pro systemd[845]: Started dbus-:1.11-org.a11y.atspi.Registry@0.service.
feb 09 14:22:44 montronc-bt3pro at-spi2-registryd[941]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
feb 09 14:22:44 montronc-bt3pro systemd[845]: Started GnuPG cryptographic agent and passphrase cache.
feb 09 14:22:44 montronc-bt3pro gpg-agent[951]: gpg-agent (GnuPG) 2.4.9 starting in supervised mode.
feb 09 14:22:44 montronc-bt3pro gpg-agent[951]: using fd 3 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
feb 09 14:22:44 montronc-bt3pro gpg-agent[951]: using fd 4 for std socket (/run/user/1000/gnupg/S.gpg-agent)
feb 09 14:22:44 montronc-bt3pro gpg-agent[951]: using fd 5 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
feb 09 14:22:44 montronc-bt3pro gpg-agent[951]: using fd 6 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
feb 09 14:22:44 montronc-bt3pro gpg-agent[951]: listening on: std=4 extra=5 browser=3 ssh=6
feb 09 14:22:45 montronc-bt3pro gpg-agent[955]: gpg-agent (GnuPG) 2.4.9 starting in supervised mode.
feb 09 14:22:45 montronc-bt3pro gpg-agent[955]: using fd 3 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
feb 09 14:22:45 montronc-bt3pro gpg-agent[955]: using fd 4 for std socket (/run/user/1000/gnupg/S.gpg-agent)
feb 09 14:22:45 montronc-bt3pro gpg-agent[955]: using fd 5 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
feb 09 14:22:45 montronc-bt3pro gpg-agent[955]: using fd 6 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
feb 09 14:22:45 montronc-bt3pro gpg-agent[955]: listening on: std=4 extra=5 browser=3 ssh=6
feb 09 14:22:45 montronc-bt3pro wpa_supplicant[785]: RRM: Ignoring radio measurement request: Not associated
feb 09 14:22:46 montronc-bt3pro systemd[845]: Started PipeWire Multimedia Service.
feb 09 14:22:46 montronc-bt3pro systemd[845]: Started Multimedia Service Session Manager.
feb 09 14:22:46 montronc-bt3pro systemd[845]: Started PipeWire PulseAudio.
feb 09 14:22:47 montronc-bt3pro systemd[1]: Starting RealtimeKit Scheduling Policy Service...
feb 09 14:22:47 montronc-bt3pro systemd[1]: Started RealtimeKit Scheduling Policy Service.
feb 09 14:22:47 montronc-bt3pro rtkit-daemon[993]: Handling system-suspend using logind.
feb 09 14:22:47 montronc-bt3pro rtkit-daemon[993]: Successfully made thread 986 of process 986 owned by '1000' high priority at nice level -11.
feb 09 14:22:47 montronc-bt3pro rtkit-daemon[993]: Successfully made thread 985 of process 985 owned by '1000' high priority at nice level -11.
feb 09 14:22:47 montronc-bt3pro rtkit-daemon[993]: Successfully made thread 992 of process 985 owned by '1000' RT at priority 20.
feb 09 14:22:47 montronc-bt3pro rtkit-daemon[993]: Successfully made thread 1002 of process 986 owned by '1000' RT at priority 20.
feb 09 14:22:47 montronc-bt3pro rtkit-daemon[993]: Successfully made thread 987 of process 987 owned by '1000' high priority at nice level -11.
feb 09 14:22:47 montronc-bt3pro rtkit-daemon[993]: Successfully made thread 994 of process 987 owned by '1000' RT at priority 20.
feb 09 14:22:47 montronc-bt3pro systemd[845]: Starting User preferences database...
feb 09 14:22:47 montronc-bt3pro systemd[845]: Started User preferences database.
feb 09 14:22:47 montronc-bt3pro kernel: intel_sst_acpi 808622A8:00: FW Version 01.0b.02.02
feb 09 14:22:48 montronc-bt3pro wireplumber[986]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
feb 09 14:22:48 montronc-bt3pro wireplumber[986]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
feb 09 14:22:48 montronc-bt3pro kernel: Bluetooth: RFCOMM TTY layer initialized
feb 09 14:22:48 montronc-bt3pro wireplumber[986]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
feb 09 14:22:48 montronc-bt3pro kernel: Bluetooth: RFCOMM socket layer initialized
feb 09 14:22:48 montronc-bt3pro kernel: Bluetooth: RFCOMM ver 1.11
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/ldac
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSink/aptx_hd
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_hd
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSink/aac
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aac
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSink/opus_g
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/opus_g
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSink/sbc
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/sbc
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_ll_1
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_ll_0
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/faststream
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/faststream_duplex
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSink/opus_05
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/opus_05
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSink/opus_05_duplex
feb 09 14:22:48 montronc-bt3pro bluetoothd[651]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource/opus_05_duplex
feb 09 14:22:49 montronc-bt3pro systemd[845]: Starting Virtual filesystem metadata service...
feb 09 14:22:49 montronc-bt3pro systemd[845]: Started Virtual filesystem metadata service.
feb 09 14:22:50 montronc-bt3pro systemd[845]: Starting XFCE notifications service...
feb 09 14:22:50 montronc-bt3pro systemd[845]: Started XFCE notifications service.
feb 09 14:22:51 montronc-bt3pro wpa_supplicant[785]: wlan0: Authentication with fc:40:09:d9:20:29 timed out.
feb 09 14:22:51 montronc-bt3pro wpa_supplicant[785]: wlan0: Added BSSID fc:40:09:d9:20:29 into ignore list, ignoring for 10 seconds
feb 09 14:22:51 montronc-bt3pro wpa_supplicant[785]: nl80211: send_event_marker failed: Source based routing not supported
feb 09 14:22:51 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-DISCONNECTED bssid=fc:40:09:d9:20:29 reason=3 locally_generated=1
feb 09 14:22:51 montronc-bt3pro wpa_supplicant[785]: wlan0: BSSID fc:40:09:d9:20:29 ignore list count incremented to 2, ignoring for 10 seconds
feb 09 14:22:51 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
feb 09 14:22:51 montronc-bt3pro NetworkManager[648]: <info>  [1770643371.1467] device (wlan0): supplicant interface state: associated -> disconnected
feb 09 14:22:51 montronc-bt3pro NetworkManager[648]: <info>  [1770643371.1468] device (p2p-dev-wlan0): supplicant management interface state: associated -> disconnected
feb 09 14:22:51 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
feb 09 14:22:51 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=IT
feb 09 14:22:51 montronc-bt3pro NetworkManager[648]: <info>  [1770643371.2481] device (wlan0): supplicant interface state: disconnected -> scanning
feb 09 14:22:51 montronc-bt3pro NetworkManager[648]: <info>  [1770643371.2487] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
feb 09 14:22:53 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
feb 09 14:22:53 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
feb 09 14:22:53 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
feb 09 14:22:53 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd034 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd038 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd03c fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd040 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd064 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd068 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd06c fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd070 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd074 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd078 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd07c fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd080 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd084 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd088 fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd08c fail, reason -52
feb 09 14:22:54 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd090 fail, reason -52
Last row:
feb 09 14:22:54 montronc-bt3pro systemd[1]: Starting Manage, Install and Generate Color Profiles...
feb 09 14:22:54 montronc-bt3pro wpa_supplicant[785]: wlan0: Removed BSSID fc:40:09:d9:20:29 from ignore list (clear)
feb 09 14:22:54 montronc-bt3pro wpa_supplicant[785]: wlan0: Trying to associate with SSID 'Moonbay-Home'
feb 09 14:22:54 montronc-bt3pro NetworkManager[648]: <info>  [1770643374.6207] device (wlan0): supplicant interface state: scanning -> associating
feb 09 14:22:54 montronc-bt3pro NetworkManager[648]: <info>  [1770643374.6209] device (p2p-dev-wlan0): supplicant management interface state: scanning -> associating
feb 09 14:22:54 montronc-bt3pro systemd[1]: Started Manage, Install and Generate Color Profiles.
feb 09 14:22:54 montronc-bt3pro wpa_supplicant[785]: wlan0: Associated with fc:40:09:d9:20:29
feb 09 14:22:54 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
feb 09 14:22:54 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=IT
feb 09 14:22:54 montronc-bt3pro NetworkManager[648]: <info>  [1770643374.7969] device (wlan0): supplicant interface state: associating -> associated
feb 09 14:22:54 montronc-bt3pro NetworkManager[648]: <info>  [1770643374.7986] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated
feb 09 14:22:55 montronc-bt3pro systemd[845]: Starting Thumbnailing service...
feb 09 14:22:55 montronc-bt3pro tumblerd[1312]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: impossibile aprire il file oggetto condiviso: File o directory non esistente
feb 09 14:22:55 montronc-bt3pro systemd[845]: Starting Virtual filesystem service - disk device monitor...
feb 09 14:22:56 montronc-bt3pro systemd[845]: Starting Portal service...
feb 09 14:22:56 montronc-bt3pro systemd[1]: Starting Disk Manager...
feb 09 14:22:56 montronc-bt3pro systemd[845]: Starting sandboxed app permission store...
feb 09 14:22:56 montronc-bt3pro systemd[1]: Starting Daemon for power management...
feb 09 14:22:56 montronc-bt3pro systemd[845]: Started sandboxed app permission store.
feb 09 14:22:56 montronc-bt3pro systemd[845]: Starting flatpak document portal service...
feb 09 14:22:56 montronc-bt3pro systemd[845]: Started flatpak document portal service.
feb 09 14:22:56 montronc-bt3pro systemd[845]: Starting Portal service (GTK/GNOME implementation)...
feb 09 14:22:56 montronc-bt3pro systemd[1]: Started Disk Manager.
feb 09 14:22:56 montronc-bt3pro systemd[845]: Started Virtual filesystem service - disk device monitor.
feb 09 14:22:56 montronc-bt3pro systemd[845]: Starting Virtual filesystem service - Apple File Conduit monitor...
feb 09 14:22:57 montronc-bt3pro systemd[845]: Started Virtual filesystem service - Apple File Conduit monitor.
feb 09 14:22:57 montronc-bt3pro systemd[845]: Started Portal service (GTK/GNOME implementation).
feb 09 14:22:57 montronc-bt3pro systemd[845]: Starting Virtual filesystem service - digital camera monitor...
feb 09 14:22:57 montronc-bt3pro systemd[845]: Started Portal service.
feb 09 14:22:57 montronc-bt3pro systemd[845]: Started Virtual filesystem service - digital camera monitor.
feb 09 14:22:57 montronc-bt3pro systemd[845]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
feb 09 14:22:57 montronc-bt3pro NetworkManager[648]: <info>  [1770643377.5698] agent-manager: agent[4d775dca508e87e0,:1.41/org.freedesktop.nm-applet/1000]: agent registered
feb 09 14:22:57 montronc-bt3pro systemd[845]: Started Virtual filesystem service - Media Transfer Protocol monitor.
feb 09 14:22:57 montronc-bt3pro systemd[845]: Started Thumbnailing service.
feb 09 14:22:57 montronc-bt3pro upowerd[1374]: USB power supply /sys/devices/pci0000:00/808622C1:05/i2c-6/i2c-INT33F4:00/axp288_charger/power_supply/axp288_charger without usb_type property, please report
feb 09 14:22:58 montronc-bt3pro systemd[1]: Started Daemon for power management.
feb 09 14:23:03 montronc-bt3pro NetworkManager[648]: <warn>  [1770643383.3669] device (wlan0): Activation: (wifi) association took too long
feb 09 14:23:03 montronc-bt3pro NetworkManager[648]: <info>  [1770643383.3672] device (wlan0): state change: config -> need-auth (reason 'none', managed-type: 'full')
feb 09 14:23:03 montronc-bt3pro wpa_supplicant[785]: nl80211: send_event_marker failed: Source based routing not supported
feb 09 14:23:03 montronc-bt3pro NetworkManager[648]: <info>  [1770643383.3691] sup-iface[e46812a00c29f367,0,wlan0]: wps: type pbc start...
feb 09 14:23:03 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-DISCONNECTED bssid=fc:40:09:d9:20:29 reason=3 locally_generated=1
feb 09 14:23:03 montronc-bt3pro NetworkManager[648]: <warn>  [1770643383.3702] device (wlan0): Activation: (wifi) asking for new secrets
feb 09 14:23:03 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
feb 09 14:23:03 montronc-bt3pro NetworkManager[648]: <info>  [1770643383.3853] device (wlan0): supplicant interface state: associated -> disconnected
feb 09 14:23:03 montronc-bt3pro NetworkManager[648]: <info>  [1770643383.3854] device (p2p-dev-wlan0): supplicant management interface state: associated -> disconnected
feb 09 14:23:03 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
feb 09 14:23:03 montronc-bt3pro wpa_supplicant[785]: wlan0: WPS-PBC-ACTIVE
feb 09 14:23:03 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=IT
feb 09 14:23:03 montronc-bt3pro NetworkManager[648]: <info>  [1770643383.4026] device (wlan0): supplicant interface state: disconnected -> scanning
feb 09 14:23:03 montronc-bt3pro NetworkManager[648]: <info>  [1770643383.4027] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
feb 09 14:23:03 montronc-bt3pro systemd[1]: systemd-hostnamed.service: Deactivated successfully.
feb 09 14:23:04 montronc-bt3pro systemd[1]: Starting Hostname Service...
feb 09 14:23:04 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
feb 09 14:23:04 montronc-bt3pro systemd[1]: Started Hostname Service.
feb 09 14:23:04 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
feb 09 14:23:05 montronc-bt3pro systemd[1]: systemd-timedated.service: Deactivated successfully.
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd034 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd038 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd03c fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd040 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd064 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd068 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd06c fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd070 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd074 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd078 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd07c fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd080 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd084 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd088 fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd08c fail, reason -52
feb 09 14:23:05 montronc-bt3pro kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd090 fail, reason -52
feb 09 14:23:06 montronc-bt3pro NetworkManager[648]: <warn>  [1770643386.7792] device (wlan0): no secrets: User canceled the secrets request.
feb 09 14:23:06 montronc-bt3pro NetworkManager[648]: <info>  [1770643386.7794] device (wlan0): state change: need-auth -> failed (reason 'no-secrets', managed-type: 'full')
feb 09 14:23:06 montronc-bt3pro NetworkManager[648]: <info>  [1770643386.7816] manager: NetworkManager state is now DISCONNECTED
feb 09 14:23:07 montronc-bt3pro dhcpcd[663]: wlan0: carrier lost
feb 09 14:23:07 montronc-bt3pro NetworkManager[648]: <info>  [1770643387.3043] device (wlan0): set-hw-addr: set MAC address to C2:DB:88:CC:B2:6B (scanning)
feb 09 14:23:07 montronc-bt3pro dhcpcd[663]: wlan0: old hardware address: c0:84:7d:7d:1e:da
feb 09 14:23:07 montronc-bt3pro dhcpcd[663]: wlan0: new hardware address: c2:db:88:cc:b2:6b
feb 09 14:23:07 montronc-bt3pro snapd[655]: stateengine.go:161: state ensure error: persistent network error: Get "https://api.snapcraft.io/api/v1/snaps/sections": dial tcp: lookup api.snapcraft.io: Temporary failure in name resolution
feb 09 14:23:07 montronc-bt3pro kernel: ieee80211 phy0: brcmf_fw_crashed: Firmware has halted or crashed
feb 09 14:23:09 montronc-bt3pro snapd[655]: daemon.go:556: gracefully waiting for running hooks
feb 09 14:23:09 montronc-bt3pro snapd[655]: daemon.go:558: done waiting for running hooks
feb 09 14:23:09 montronc-bt3pro kernel: brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
feb 09 14:23:09 montronc-bt3pro kernel: brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
feb 09 14:23:09 montronc-bt3pro kernel: brcmfmac: dongle trap info: type 0x4 @ epc 0x001c43ce
                                          cpsr 0x2000019f spsr 0x200001bf sp 0x0025fe50
                                          lr   0x00049bd7 pc   0x001c43ce offset 0x25fdf8
                                          r0   0x002567d8 r1   0x00000001 r2 0x00010000 r3 0x18001000
                                          r4   0x002567d8 r5   0xffffffff r6 0x00000000 r7 0x00000001
feb 09 14:23:09 montronc-bt3pro kernel: brcmfmac: brcmf_dump_obss: dump_obss error (-110)
feb 09 14:23:09 montronc-bt3pro kernel: ieee80211 phy0: brcmf_fil_cmd_data: bus is down. we have nothing to do.
feb 09 14:23:09 montronc-bt3pro kernel: ieee80211 phy0: brcmf_set_mpc: fail to set mpc
feb 09 14:23:09 montronc-bt3pro kernel: ieee80211 phy0: brcmf_cfg80211_set_power_mgmt: error (-5)
feb 09 14:23:09 montronc-bt3pro kernel: ieee80211 phy0: brcmf_cfg80211_set_power_mgmt: Unable to set pm timeout, (-5)
feb 09 14:23:09 montronc-bt3pro kernel: ieee80211 phy0: brcmf_cfg80211_get_tx_power: error (-5)
feb 09 14:23:10 montronc-bt3pro NetworkManager[648]: <warn>  [1770643390.4529] device (wlan0): Activation: failed for connection 'Moonbay-Home'
feb 09 14:23:10 montronc-bt3pro NetworkManager[648]: <info>  [1770643390.4561] device (wlan0): state change: failed -> disconnected (reason 'none', managed-type: 'full')
feb 09 14:23:10 montronc-bt3pro NetworkManager[648]: <error> [1770643390.4577] platform-linux: sysctl: failed to set '/proc/sys/net/ipv6/conf/wlan0/disable_ipv6' to '1': (2) File o directory non esistente
feb 09 14:23:10 montronc-bt3pro NetworkManager[648]: <warn>  [1770643390.4583] device (wlan0): error setting IPv4 forwarding to '0': File o directory non esistente
feb 09 14:23:10 montronc-bt3pro NetworkManager[648]: <info>  [1770643390.4753] manager: startup complete
feb 09 14:23:10 montronc-bt3pro NetworkManager[648]: <info>  [1770643390.4768] device (wlan0): state change: disconnected -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
feb 09 14:23:10 montronc-bt3pro NetworkManager[648]: <info>  [1770643390.4837] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
feb 09 14:23:10 montronc-bt3pro systemd[1]: Starting Load/Save RF Kill Switch Status...
feb 09 14:23:10 montronc-bt3pro wpa_supplicant[785]: l2_packet_init: ioctl[SIOCGIFHWADDR]: No such device
feb 09 14:23:10 montronc-bt3pro ModemManager[725]: <msg> [base-manager] port wlan0 released by device '/sys/devices/pci0000:00/80860F14:02/mmc_host/mmc0/mmc0:0001/mmc0:0001:1'
feb 09 14:23:10 montronc-bt3pro kernel: mmc0: card 0001 removed
feb 09 14:23:10 montronc-bt3pro NetworkManager[648]: <info>  [1770643390.5225] radio killswitch /sys/devices/pci0000:00/80860F14:02/mmc_host/mmc0/mmc0:0001/mmc0:0001:1/ieee80211/phy0/rfkill1 disappeared
feb 09 14:23:10 montronc-bt3pro dhcpcd[663]: wlan0: removing interface
feb 09 14:23:10 montronc-bt3pro systemd[1]: Started Load/Save RF Kill Switch Status.
feb 09 14:23:10 montronc-bt3pro wpa_supplicant[785]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
feb 09 14:23:10 montronc-bt3pro wpa_supplicant[785]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
feb 09 14:23:10 montronc-bt3pro wpa_supplicant[785]: Could not read interface p2p-dev-wlan0 flags: No such device
feb 09 14:23:10 montronc-bt3pro wpa_supplicant[785]: wlan0: WPS-CANCEL
feb 09 14:23:10 montronc-bt3pro wpa_supplicant[785]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
feb 09 14:23:10 montronc-bt3pro wpa_supplicant[785]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
