I have successful connected to the wireguard, and it seems like it’s transporting traffic.
transfer: 5.61 KiB received, 2.89 KiB sent
However, I could not access any websites. It just hangs trying to connect. ping works fine with 1.1.1.1. What may be a root issue and how can I find it? I also tried to setup it via network manager, but result is the same. Configurations files are okay, they work fine on
my mac.
UPD: It looks like it’s DNS issue, because all websites are accessible by direct IP. Is there anything I can do about it?
They are indeed different, but just in order. Before connecting:
nameserver 192.168.0.1
nameserver 2001:730:3ed2::53
nameserver 2001:730:3ed2:1000::53
# Too many DNS servers configured, the following entries may be ignored.
nameserver xxx.xx.0.1
search .
After:
search .
$ ip route
default via 192.168.0.1 dev wlo1 proto dhcp src 192.168.0.194 metric 600
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.18.0.0/16 dev br-c1b7041ba63c proto kernel scope link src 172.18.0.1 linkdown
172.19.0.0/16 dev br-8d4bb2e36deb proto kernel scope link src 172.19.0.1 linkdown
172.20.0.0/16 dev br-1af474e41be2 proto kernel scope link src 172.20.0.1 linkdown
172.21.0.0/16 dev br-0b7dd881cf37 proto kernel scope link src 172.21.0.1 linkdown
172.22.0.0/16 dev br-2beb254c9d5b proto kernel scope link src 172.22.0.1 linkdown
172.24.0.0/16 dev br-fd2a368731eb proto kernel scope link src 172.24.0.1 linkdown
192.168.0.0/24 dev wlo1 proto kernel scope link src 192.168.0.194 metric 600
$ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default _gateway 0.0.0.0 UG 600 0 0 wlo1
172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
172.18.0.0 0.0.0.0 255.255.0.0 U 0 0 0 br-c1b7041ba63c
172.19.0.0 0.0.0.0 255.255.0.0 U 0 0 0 br-8d4bb2e36deb
172.20.0.0 0.0.0.0 255.255.0.0 U 0 0 0 br-1af474e41be2
172.21.0.0 0.0.0.0 255.255.0.0 U 0 0 0 br-0b7dd881cf37
172.22.0.0 0.0.0.0 255.255.0.0 U 0 0 0 br-2beb254c9d5b
172.24.0.0 0.0.0.0 255.255.0.0 U 0 0 0 br-fd2a368731eb
192.168.0.0 0.0.0.0 255.255.255.0 U 600 0 0 wlo1
After:
$ ip route
xx.xx.0.0/16 dev wg scope link
172.20.0.1 dev gitlab scope link
$ route # this command is slow
xx.xx.0.0 0.0.0.0 255.255.0.0 U 0 0 0 wg
pcpcpc 0.0.0.0 255.255.255.255 UH 0 0 0 wg
