I have a wired headphone connected from back of motherboard “Line Out”. In sound settings, output device shows “Line Out - Starship/Matisse HD Audio” and indicator shows there’s sound when I play something. However, I cannot hear anything.
AlsaMixer shows:
Auto-Mute and Loopback are disabled.
UPDATE: the front 3.5mm jack works with the headphone. but still no sound from it connected to the motherboard directly.
Motherboard: Gigabyte Aorus Master x570
Motherboard X570 Aorus Master has dual audio codecs
X570 AORUS MASTER (rev. 1.0) Specification | Motherboard - GIGABYTE Global
- Realtek® ALC1220-VB codec
- ESS SABRE9118 DAC chip
The SABRE9118 DAC requires an ALSA kernel patch to work correctly with the main ALC1220 audio codec
ALSA: hda/realtek - Fix silent output on Gigabyte X570 Aorus Master · torvalds/linux@0d45e86 · GitHub
To add the model option clevo-p950 use this command
echo 'options snd_hda_intel model=clevo-p950' | sudo tee -a /etc/modprobe.d/alsa-realtek.conf
and reboot system to reload audio devices
