So I basically followed the instructions here, using r8168 instead of r8169 and that kinda “fixes” something, at least when I restart or shutdown I get the network adapter working.
What I noticed though is that every single time the system goes to sleep and wakes up, the problem replicates.
Trying to unload-load the module does not work
sudo modprobe -r r8168
sleep 1
sudo modprobe r8168
Checking dmesg I don’t see anything weird but I’m no expert…
[ 0.000000] Linux version 5.15.12-1-MANJARO (builduser@fv-az39-353) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Dec 29 18:08:07 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=f4c6bb24-478c-48a2-971d-322c7b45762d rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[ 0.000000] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[ 0.000000] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[ 0.000000] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 3632
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000005f729fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000005f72a000-0x000000005f84cfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000005f84d000-0x0000000063510fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000063511000-0x0000000063d71fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000063d72000-0x0000000063ffefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000063fff000-0x0000000063ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000064000000-0x0000000067ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000069400000-0x00000000695fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000069e00000-0x00000000707fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000088f7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by Dell
[ 0.000000] efi: ACPI=0x63ffe000 ACPI 2.0=0x63ffe014 SMBIOS=0x5fdd8000 TPMFinalLog=0x63ca8000 ESRT=0x5fd5fa98 MEMATTR=0x5a7d4018
[ 0.000000] SMBIOS 3.2 present.
[ 0.000000] DMI: Dell Inc. Latitude 5421/0DF8RX, BIOS 1.5.0 08/05/2021
[ 0.000000] tsc: Detected 2500.000 MHz processor
[ 0.000000] tsc: Detected 2496.000 MHz TSC
[ 0.000004] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000006] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000009] last_pfn = 0x88f800 max_arch_pfn = 0x400000000
[ 0.000136] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000974] last_pfn = 0x64000 max_arch_pfn = 0x400000000
[ 0.007162] esrt: Reserving ESRT space from 0x000000005fd5fa98 to 0x000000005fd5fb20.
[ 0.007172] Using GB pages for direct mapping
[ 0.007244] Secure boot disabled
[ 0.007245] RAMDISK: [mem 0x363e1000-0x371e7fff]
[ 0.007247] ACPI: Early table checksum verification disabled
[ 0.007249] ACPI: RSDP 0x0000000063FFE014 000024 (v02 DELL )
[ 0.007251] ACPI: XSDT 0x0000000063F76188 000124 (v01 DELL Dell Inc 00000002 01000013)
[ 0.007254] ACPI: FACP 0x0000000063FF4000 000114 (v06 DELL Dell Inc 00000002 01000013)
[ 0.007257] ACPI: DSDT 0x0000000063F92000 05E97C (v02 DELL Dell Inc 00000002 01000013)
[ 0.007259] ACPI: FACS 0x0000000063CDB000 000040
[ 0.007261] ACPI: SSDT 0x0000000063FFA000 0024D0 (v02 CpuRef CpuSsdt 00003000 INTL 20191018)
[ 0.007263] ACPI: SSDT 0x0000000063FF5000 0047CC (v02 DptfTb DptfTabl 00001000 INTL 20191018)
[ 0.007265] ACPI: HPET 0x0000000063FF3000 000038 (v01 DELL Dell Inc 00000002 01000013)
[ 0.007267] ACPI: APIC 0x0000000063FF2000 00012C (v04 DELL Dell Inc 00000002 01000013)
[ 0.007268] ACPI: MCFG 0x0000000063FF1000 00003C (v01 DELL Dell Inc 00000002 01000013)
[ 0.007270] ACPI: SSDT 0x0000000063F91000 000A54 (v02 DELL DellRtd3 00001000 INTL 20191018)
[ 0.007272] ACPI: NHLT 0x0000000063F90000 00002D (v00 DELL Dell Inc 00000002 01000013)
[ 0.007274] ACPI: SSDT 0x0000000063F8F000 00007B (v02 SaSsdt SaSsdt 00003000 INTL 20191018)
[ 0.007276] ACPI: SSDT 0x0000000063F8D000 0012D2 (v02 INTEL IgfxSsdt 00003000 INTL 20191018)
[ 0.007277] ACPI: SSDT 0x0000000063F81000 00B396 (v02 INTEL TcssSsdt 00001000 INTL 20191018)
[ 0.007280] ACPI: SSDT 0x0000000063F80000 000CFC (v02 DELL UsbCTabl 00001000 INTL 20191018)
[ 0.007281] ACPI: LPIT 0x0000000063F7F000 0000CC (v01 DELL Dell Inc 00000002 01000013)
[ 0.007283] ACPI: WSMT 0x0000000063F7E000 000028 (v01 DELL Dell Inc 00000002 01000013)
[ 0.007285] ACPI: SSDT 0x0000000063F7D000 000B75 (v02 DELL PtidDevc 00001000 INTL 20191018)
[ 0.007286] ACPI: SSDT 0x0000000063F7C000 00012A (v02 DELL TbtTypeC 00000000 INTL 20191018)
[ 0.007288] ACPI: DBGP 0x0000000063F7B000 000034 (v01 DELL Dell Inc 00000002 01000013)
[ 0.007290] ACPI: DBG2 0x0000000063F7A000 000054 (v00 DELL Dell Inc 00000002 01000013)
[ 0.007292] ACPI: BOOT 0x0000000063F79000 000028 (v01 DELL CBX3 00000002 01000013)
[ 0.007293] ACPI: SSDT 0x0000000063F78000 00060E (v02 DELL Tpm2Tabl 00001000 INTL 20191018)
[ 0.007296] ACPI: TPM2 0x0000000063F77000 00004C (v04 DELL Dell Inc 00000002 01000013)
[ 0.007297] ACPI: MSDM 0x0000000063FFD000 000055 (v03 DELL CBX3 06222004 AMI 00010013)
[ 0.007299] ACPI: DMAR 0x0000000063F75000 0000B8 (v02 INTEL Dell Inc 00000002 01000013)
[ 0.007301] ACPI: SSDT 0x0000000063F6E000 00528D (v02 DELL NvdTable 00001000 INTL 20191018)
[ 0.007303] ACPI: SSDT 0x0000000063F74000 000DE4 (v02 DELL xh_Dell_ 00000000 INTL 20191018)
[ 0.007305] ACPI: SSDT 0x0000000063F6D000 000144 (v02 Intel ADebTabl 00001000 INTL 20191018)
[ 0.007306] ACPI: UEFI 0x0000000063C62000 00063A (v01 INTEL RstVmdE 00000000 ?? 00000000)
[ 0.007308] ACPI: UEFI 0x0000000063C61000 00005C (v01 INTEL RstVmdV 00000000 ?? 00000000)
[ 0.007310] ACPI: ASF! 0x0000000063F6C000 0000A0 (v32 DELL Dell Inc 00000002 01000013)
[ 0.007312] ACPI: PTDT 0x0000000063F6B000 000D44 (v00 DELL Dell Inc 00000005 MSFT 0100000D)
[ 0.007314] ACPI: BGRT 0x0000000063F6A000 000038 (v01 DELL Dell Inc 00000002 01000013)
[ 0.007315] ACPI: FPDT 0x0000000063F69000 000034 (v01 DELL Dell Inc 00000002 01000013)
[ 0.007317] ACPI: Reserving FACP table memory at [mem 0x63ff4000-0x63ff4113]
[ 0.007317] ACPI: Reserving DSDT table memory at [mem 0x63f92000-0x63ff097b]
[ 0.007318] ACPI: Reserving FACS table memory at [mem 0x63cdb000-0x63cdb03f]
[ 0.007318] ACPI: Reserving SSDT table memory at [mem 0x63ffa000-0x63ffc4cf]
[ 0.007319] ACPI: Reserving SSDT table memory at [mem 0x63ff5000-0x63ff97cb]
[ 0.007319] ACPI: Reserving HPET table memory at [mem 0x63ff3000-0x63ff3037]
[ 0.007320] ACPI: Reserving APIC table memory at [mem 0x63ff2000-0x63ff212b]
[ 0.007320] ACPI: Reserving MCFG table memory at [mem 0x63ff1000-0x63ff103b]
[ 0.007321] ACPI: Reserving SSDT table memory at [mem 0x63f91000-0x63f91a53]
[ 0.007321] ACPI: Reserving NHLT table memory at [mem 0x63f90000-0x63f9002c]
[ 0.007322] ACPI: Reserving SSDT table memory at [mem 0x63f8f000-0x63f8f07a]
[ 0.007322] ACPI: Reserving SSDT table memory at [mem 0x63f8d000-0x63f8e2d1]
[ 0.007323] ACPI: Reserving SSDT table memory at [mem 0x63f81000-0x63f8c395]
[ 0.007323] ACPI: Reserving SSDT table memory at [mem 0x63f80000-0x63f80cfb]
[ 0.007324] ACPI: Reserving LPIT table memory at [mem 0x63f7f000-0x63f7f0cb]
[ 0.007324] ACPI: Reserving WSMT table memory at [mem 0x63f7e000-0x63f7e027]
[ 0.007325] ACPI: Reserving SSDT table memory at [mem 0x63f7d000-0x63f7db74]
[ 0.007325] ACPI: Reserving SSDT table memory at [mem 0x63f7c000-0x63f7c129]
[ 0.007325] ACPI: Reserving DBGP table memory at [mem 0x63f7b000-0x63f7b033]
[ 0.007326] ACPI: Reserving DBG2 table memory at [mem 0x63f7a000-0x63f7a053]
[ 0.007326] ACPI: Reserving BOOT table memory at [mem 0x63f79000-0x63f79027]
[ 0.007327] ACPI: Reserving SSDT table memory at [mem 0x63f78000-0x63f7860d]
[ 0.007327] ACPI: Reserving TPM2 table memory at [mem 0x63f77000-0x63f7704b]
[ 0.007328] ACPI: Reserving MSDM table memory at [mem 0x63ffd000-0x63ffd054]
[ 0.007328] ACPI: Reserving DMAR table memory at [mem 0x63f75000-0x63f750b7]
[ 0.007329] ACPI: Reserving SSDT table memory at [mem 0x63f6e000-0x63f7328c]
[ 0.007329] ACPI: Reserving SSDT table memory at [mem 0x63f74000-0x63f74de3]
[ 0.007330] ACPI: Reserving SSDT table memory at [mem 0x63f6d000-0x63f6d143]
[ 0.007330] ACPI: Reserving UEFI table memory at [mem 0x63c62000-0x63c62639]
[ 0.007331] ACPI: Reserving UEFI table memory at [mem 0x63c61000-0x63c6105b]
[ 0.007331] ACPI: Reserving ASF! table memory at [mem 0x63f6c000-0x63f6c09f]
[ 0.007332] ACPI: Reserving PTDT table memory at [mem 0x63f6b000-0x63f6bd43]
[ 0.007332] ACPI: Reserving BGRT table memory at [mem 0x63f6a000-0x63f6a037]
[ 0.007333] ACPI: Reserving FPDT table memory at [mem 0x63f69000-0x63f69033]
[ 0.007493] No NUMA configuration found
[ 0.007494] Faking a node at [mem 0x0000000000000000-0x000000088f7fffff]
[ 0.007496] NODE_DATA(0) allocated [mem 0x88f7fc000-0x88f7fffff]
[ 0.007517] Zone ranges:
[ 0.007517] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.007518] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.007519] Normal [mem 0x0000000100000000-0x000000088f7fffff]
[ 0.007520] Device empty
[ 0.007520] Movable zone start for each node
[ 0.007521] Early memory node ranges
[ 0.007521] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.007522] node 0: [mem 0x0000000000100000-0x000000005f729fff]
[ 0.007523] node 0: [mem 0x0000000063fff000-0x0000000063ffffff]
[ 0.007523] node 0: [mem 0x0000000100000000-0x000000088f7fffff]
[ 0.007525] Initmem setup node 0 [mem 0x0000000000001000-0x000000088f7fffff]
[ 0.007527] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.007544] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.009452] On node 0, zone DMA32: 18645 pages in unavailable ranges
[ 0.046956] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.046967] On node 0, zone Normal: 2048 pages in unavailable ranges
[ 0.047001] Reserving Intel graphics memory at [mem 0x6c800000-0x707fffff]
[ 0.047341] ACPI: PM-Timer IO Port: 0x1808
[ 0.047345] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.047346] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.047347] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.047347] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.047347] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.047348] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.047348] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.047348] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.047349] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.047349] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.047350] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.047350] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.047350] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.047351] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.047351] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.047351] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.047391] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.047393] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.047394] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.047396] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.047397] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.047402] e820: update [mem 0x5a74b000-0x5a7d3fff] usable ==> reserved
[ 0.047407] TSC deadline timer available
[ 0.047407] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[ 0.047416] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.047417] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.047418] PM: hibernation: Registered nosave memory: [mem 0x5a74b000-0x5a7d3fff]
[ 0.047419] PM: hibernation: Registered nosave memory: [mem 0x5f72a000-0x5f84cfff]
[ 0.047419] PM: hibernation: Registered nosave memory: [mem 0x5f84d000-0x63510fff]
[ 0.047420] PM: hibernation: Registered nosave memory: [mem 0x63511000-0x63d71fff]
[ 0.047420] PM: hibernation: Registered nosave memory: [mem 0x63d72000-0x63ffefff]
[ 0.047421] PM: hibernation: Registered nosave memory: [mem 0x64000000-0x67ffffff]
[ 0.047421] PM: hibernation: Registered nosave memory: [mem 0x68000000-0x693fffff]
[ 0.047422] PM: hibernation: Registered nosave memory: [mem 0x69400000-0x695fffff]
[ 0.047422] PM: hibernation: Registered nosave memory: [mem 0x69600000-0x69dfffff]
[ 0.047423] PM: hibernation: Registered nosave memory: [mem 0x69e00000-0x707fffff]
[ 0.047423] PM: hibernation: Registered nosave memory: [mem 0x70800000-0xbfffffff]
[ 0.047423] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xcfffffff]
[ 0.047424] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xfed1ffff]
[ 0.047424] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[ 0.047424] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfeffffff]
[ 0.047425] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.047426] [mem 0x70800000-0xbfffffff] available for PCI devices
[ 0.047426] Booting paravirtualized kernel on bare hardware
[ 0.047428] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.050212] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[ 0.050430] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
[ 0.050433] pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
[ 0.050435] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.050450] Built 1 zonelists, mobility grouping on. Total pages: 8188526
[ 0.050451] Policy zone: Normal
[ 0.050452] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=f4c6bb24-478c-48a2-971d-322c7b45762d rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.050493] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
[ 0.051339] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.051773] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.051925] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.104389] Memory: 32462896K/33274660K available (14344K kernel code, 2097K rwdata, 10884K rodata, 1864K init, 3784K bss, 811504K reserved, 0K cma-reserved)
[ 0.104391] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[ 0.104467] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.104474] ftrace: allocating 44515 entries in 174 pages
[ 0.112656] ftrace: allocated 174 pages with 5 groups
[ 0.112724] rcu: Preemptible hierarchical RCU implementation.
[ 0.112725] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.112725] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[ 0.112726] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.112726] Trampoline variant of Tasks RCU enabled.
[ 0.112727] Rude variant of Tasks RCU enabled.
[ 0.112727] Tracing variant of Tasks RCU enabled.
[ 0.112727] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.112728] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.114822] NR_IRQS: 20736, nr_irqs: 2184, preallocated irqs: 16
[ 0.115251] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.115347] Console: colour dummy device 80x25
[ 0.115354] printk: console [tty0] enabled
[ 0.115365] ACPI: Core revision 20210730
[ 0.115567] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.115568] APIC: Switch to symmetric I/O mode setup
[ 0.115569] DMAR: Host address width 39
[ 0.115569] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.115572] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
[ 0.115574] DMAR: DRHD base: 0x000000fed84000 flags: 0x0
[ 0.115577] DMAR: dmar1: reg_base_addr fed84000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.115578] DMAR: DRHD base: 0x000000fed85000 flags: 0x0
[ 0.115581] DMAR: dmar2: reg_base_addr fed85000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.115582] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.115586] DMAR: dmar3: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.115588] DMAR: RMRR base: 0x0000006c000000 end: 0x000000707fffff
[ 0.115590] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 3
[ 0.115590] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.115591] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.117526] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.117527] x2apic enabled
[ 0.117559] Switched APIC routing to cluster x2apic.
[ 0.121945] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x23fa772cf26, max_idle_ns: 440795269835 ns
[ 0.121949] Calibrating delay loop (skipped), value calculated using timer frequency.. 4993.00 BogoMIPS (lpj=8320000)
[ 0.121951] pid_max: default: 32768 minimum: 301
[ 0.123749] LSM: Security Framework initializing
[ 0.123754] landlock: Up and running.
[ 0.123754] Yama: becoming mindful.
[ 0.123767] AppArmor: AppArmor initialized
[ 0.123823] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.123868] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.124016] x86/tme: not enabled by BIOS
[ 0.124022] CPU0: Thermal monitoring enabled (TM1)
[ 0.124023] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.124113] process: using mwait in idle threads
[ 0.124113] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.124114] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.124116] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.124117] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.124118] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.124119] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.124119] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.125281] Freeing SMP alternatives memory: 36K
[ 0.125281] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1966
[ 0.125281] smpboot: CPU0: 11th Gen Intel(R) Core(TM) i7-11850H @ 2.50GHz (family: 0x6, model: 0x8d, stepping: 0x1)
[ 0.125281] Performance Events: PEBS fmt4+-baseline, AnyThread deprecated, Icelake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.125281] ... version: 5
[ 0.125281] ... bit width: 48
[ 0.125281] ... generic registers: 8
[ 0.125281] ... value mask: 0000ffffffffffff
[ 0.125281] ... max period: 00007fffffffffff
[ 0.125281] ... fixed-purpose events: 4
[ 0.125281] ... event mask: 0001000f000000ff
[ 0.125281] rcu: Hierarchical SRCU implementation.
[ 0.125281] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.125281] smp: Bringing up secondary CPUs ...
[ 0.125281] x86: Booting SMP configuration:
[ 0.125281] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.150378] smp: Brought up 1 node, 16 CPUs
[ 0.150378] smpboot: Max logical packages: 1
[ 0.150378] smpboot: Total of 16 processors activated (79903.00 BogoMIPS)
[ 0.152696] devtmpfs: initialized
[ 0.152696] x86/mm: Memory block size: 128MB
[ 0.152861] ACPI: PM: Registering ACPI NVS region [mem 0x63511000-0x63d71fff] (8785920 bytes)
[ 0.152861] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.152861] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.152861] pinctrl core: initialized pinctrl subsystem
[ 0.152861] PM: RTC time: 17:09:26, date: 2022-01-19
[ 0.152861] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.152861] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.152861] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.152995] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.153000] audit: initializing netlink subsys (disabled)
[ 0.153004] audit: type=2000 audit(1642612166.029:1): state=initialized audit_enabled=0 res=1
[ 0.153004] thermal_sys: Registered thermal governor 'fair_share'
[ 0.153004] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.153004] thermal_sys: Registered thermal governor 'step_wise'
[ 0.153004] thermal_sys: Registered thermal governor 'user_space'
[ 0.153004] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.153004] cpuidle: using governor ladder
[ 0.153004] cpuidle: using governor menu
[ 0.153004] Simple Boot Flag at 0x47 set to 0x80
[ 0.153004] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[ 0.153004] ACPI: bus type PCI registered
[ 0.153004] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.153004] PCI: MMCONFIG for domain 0000 [bus 00-e0] at [mem 0xc0000000-0xce0fffff] (base 0xc0000000)
[ 0.153004] PCI: MMCONFIG at [mem 0xc0000000-0xce0fffff] reserved in E820
[ 0.153004] PCI: Using configuration type 1 for base access
[ 0.155452] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.155866] Kprobes globally optimized
[ 0.155868] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[ 0.155868] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.155868] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.155868] ACPI: Added _OSI(Module Device)
[ 0.155868] ACPI: Added _OSI(Processor Device)
[ 0.155868] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.155868] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.155868] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.155868] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.155868] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.216301] ACPI: 14 ACPI AML tables successfully acquired and loaded
[ 0.229261] ACPI: Dynamic OEM Table Load:
[ 0.229268] ACPI: SSDT 0xFFFF9EEF80293800 0001CB (v02 PmRef Cpu0Psd 00003000 INTL 20191018)
[ 0.230012] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.231978] ACPI: Dynamic OEM Table Load:
[ 0.231984] ACPI: SSDT 0xFFFF9EEF82C78000 000496 (v02 PmRef Cpu0Cst 00003001 INTL 20191018)
[ 0.232867] ACPI: Dynamic OEM Table Load:
[ 0.232872] ACPI: SSDT 0xFFFF9EEF82C78800 000560 (v02 PmRef Cpu0Ist 00003000 INTL 20191018)
[ 0.233820] ACPI: Dynamic OEM Table Load:
[ 0.233824] ACPI: SSDT 0xFFFF9EEF81EDAC00 00028B (v02 PmRef Cpu0Hwp 00003000 INTL 20191018)
[ 0.234829] ACPI: Dynamic OEM Table Load:
[ 0.234835] ACPI: SSDT 0xFFFF9EEF82C89000 0008E7 (v02 PmRef ApIst 00003000 INTL 20191018)
[ 0.235816] ACPI: Dynamic OEM Table Load:
[ 0.235820] ACPI: SSDT 0xFFFF9EEF82C7E000 00048A (v02 PmRef ApHwp 00003000 INTL 20191018)
[ 0.236711] ACPI: Dynamic OEM Table Load:
[ 0.236715] ACPI: SSDT 0xFFFF9EEF82C7A000 0004D4 (v02 PmRef ApPsd 00003000 INTL 20191018)
[ 0.237605] ACPI: Dynamic OEM Table Load:
[ 0.237609] ACPI: SSDT 0xFFFF9EEF82C7F000 00048A (v02 PmRef ApCst 00003000 INTL 20191018)
[ 0.244414] ACPI: EC: EC started
[ 0.244415] ACPI: EC: interrupt blocked
[ 0.246793] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.246794] ACPI: \_SB_.PC00.LPCB.ECDV: Boot DSDT EC used to handle transactions
[ 0.246795] ACPI: Interpreter enabled
[ 0.246837] ACPI: PM: (supports S0 S4 S5)
[ 0.246837] ACPI: Using IOAPIC for interrupt routing
[ 0.246869] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.248512] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.249021] ACPI: PM: Power Resource [PG00]
[ 0.249288] ACPI: PM: Power Resource [PG01]
[ 0.259478] ACPI: PM: Power Resource [PG02]
[ 0.259725] ACPI: PM: Power Resource [PG03]
[ 0.262563] ACPI: PM: Power Resource [BTRT]
[ 0.264759] ACPI: PM: Power Resource [PXP]
[ 0.265030] ACPI: PM: Power Resource [MRST]
[ 0.265038] ACPI: PM: Power Resource [DRST]
[ 0.270964] ACPI: PM: Power Resource [V0PR]
[ 0.271060] ACPI: PM: Power Resource [V1PR]
[ 0.271154] ACPI: PM: Power Resource [V2PR]
[ 0.274712] ACPI: PM: Power Resource [WRST]
[ 0.277419] ACPI: PM: Power Resource [V0PR]
[ 0.277459] ACPI: PM: Power Resource [V1PR]
[ 0.277500] ACPI: PM: Power Resource [V2PR]
[ 0.277538] ACPI: PM: Power Resource [V3PR]
[ 0.277568] ACPI: PM: Power Resource [TBT0]
[ 0.277576] ACPI: PM: Power Resource [TBT1]
[ 0.277584] ACPI: PM: Power Resource [D3C]
[ 0.510048] ACPI: PM: Power Resource [PIN]
[ 0.510337] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-e0])
[ 0.510342] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.512043] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.515278] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[ 0.518513] PCI host bridge to bus 0000:00
[ 0.518514] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.518516] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.518517] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.518517] pci_bus 0000:00: root bus resource [mem 0x70800000-0xbfffffff window]
[ 0.518518] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.518519] pci_bus 0000:00: root bus resource [bus 00-e0]
[ 0.519614] pci 0000:00:00.0: [8086:9a36] type 00 class 0x060000
[ 0.522762] pci 0000:00:01.0: [8086:9a01] type 01 class 0x060400
[ 0.522818] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.522839] pci 0000:00:01.0: PTM enabled (root), 4ns granularity
[ 0.525260] pci 0000:00:02.0: [8086:9a60] type 00 class 0x030000
[ 0.525266] pci 0000:00:02.0: reg 0x10: [mem 0x6074000000-0x6074ffffff 64bit]
[ 0.525271] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[ 0.525275] pci 0000:00:02.0: reg 0x20: [io 0x4000-0x403f]
[ 0.525293] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.525294] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[ 0.525316] pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
[ 0.525317] pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
[ 0.525321] pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
[ 0.525321] pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
[ 0.527438] pci 0000:00:04.0: [8086:9a03] type 00 class 0x118000
[ 0.527453] pci 0000:00:04.0: reg 0x10: [mem 0x6075240000-0x607525ffff 64bit]
[ 0.529707] pci 0000:00:06.0: [8086:09ab] type 00 class 0x088000
[ 0.532133] pci 0000:00:07.0: [8086:9a2b] type 01 class 0x060400
[ 0.532197] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.532217] pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
[ 0.534794] pci 0000:00:07.1: [8086:9a2d] type 01 class 0x060400
[ 0.534857] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.534876] pci 0000:00:07.1: DPC: RP PIO log size 0 is invalid
[ 0.536480] pci 0000:00:0a.0: [8086:9a0d] type 00 class 0x118000
[ 0.536487] pci 0000:00:0a.0: reg 0x10: [mem 0x6075290000-0x6075297fff 64bit]
[ 0.536507] pci 0000:00:0a.0: enabling Extended Tags
[ 0.539592] pci 0000:00:0d.0: [8086:9a17] type 00 class 0x0c0330
[ 0.539605] pci 0000:00:0d.0: reg 0x10: [mem 0x6075280000-0x607528ffff 64bit]
[ 0.539662] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[ 0.541904] pci 0000:00:0d.2: [8086:9a1f] type 00 class 0x0c0340
[ 0.541914] pci 0000:00:0d.2: reg 0x10: [mem 0x6075200000-0x607523ffff 64bit]
[ 0.541921] pci 0000:00:0d.2: reg 0x18: [mem 0x60752a9000-0x60752a9fff 64bit]
[ 0.541954] pci 0000:00:0d.2: supports D1 D2
[ 0.541955] pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.544087] pci 0000:00:0e.0: [8086:9a0b] type 00 class 0x010400
[ 0.544098] pci 0000:00:0e.0: reg 0x10: [mem 0x6072000000-0x6073ffffff 64bit]
[ 0.544104] pci 0000:00:0e.0: reg 0x18: [mem 0x72000000-0x73ffffff]
[ 0.544117] pci 0000:00:0e.0: reg 0x20: [mem 0x6075100000-0x60751fffff 64bit]
[ 0.546268] pci 0000:00:12.0: [8086:43fc] type 00 class 0x070000
[ 0.546287] pci 0000:00:12.0: reg 0x10: [mem 0x6075270000-0x607527ffff 64bit]
[ 0.546354] pci 0000:00:12.0: PME# supported from D0 D3hot
[ 0.548639] pci 0000:00:14.0: [8086:43ed] type 00 class 0x0c0330
[ 0.548656] pci 0000:00:14.0: reg 0x10: [mem 0x6075260000-0x607526ffff 64bit]
[ 0.548729] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.549986] pci 0000:00:14.2: [8086:43ef] type 00 class 0x050000
[ 0.550003] pci 0000:00:14.2: reg 0x10: [mem 0x60752a0000-0x60752a3fff 64bit]
[ 0.550015] pci 0000:00:14.2: reg 0x18: [mem 0x60752a8000-0x60752a8fff 64bit]
[ 0.553147] pci 0000:00:14.3: [8086:43f0] type 00 class 0x028000
[ 0.553166] pci 0000:00:14.3: reg 0x10: [mem 0x607529c000-0x607529ffff 64bit]
[ 0.553279] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.555486] pci 0000:00:15.0: [8086:43e8] type 00 class 0x0c8000
[ 0.555510] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.557896] pci 0000:00:15.1: [8086:43e9] type 00 class 0x0c8000
[ 0.557923] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.560288] pci 0000:00:16.0: [8086:43e0] type 00 class 0x078000
[ 0.560310] pci 0000:00:16.0: reg 0x10: [mem 0x60752a5000-0x60752a5fff 64bit]
[ 0.560388] pci 0000:00:16.0: PME# supported from D3hot
[ 0.561642] pci 0000:00:16.3: [8086:43e3] type 00 class 0x070002
[ 0.561654] pci 0000:00:16.3: reg 0x10: [io 0x4060-0x4067]
[ 0.561659] pci 0000:00:16.3: reg 0x14: [mem 0xa11a1000-0xa11a1fff]
[ 0.564805] pci 0000:00:1c.0: [8086:43ba] type 01 class 0x060400
[ 0.564903] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.564938] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[ 0.567481] pci 0000:00:1f.0: [8086:4389] type 00 class 0x060100
[ 0.569768] pci 0000:00:1f.3: [8086:43c8] type 00 class 0x040380
[ 0.569809] pci 0000:00:1f.3: reg 0x10: [mem 0x6075298000-0x607529bfff 64bit]
[ 0.569861] pci 0000:00:1f.3: reg 0x20: [mem 0x6075000000-0x60750fffff 64bit]
[ 0.569960] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.572240] pci 0000:00:1f.4: [8086:43a3] type 00 class 0x0c0500
[ 0.572260] pci 0000:00:1f.4: reg 0x10: [mem 0x60752a4000-0x60752a40ff 64bit]
[ 0.572281] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.573487] pci 0000:00:1f.5: [8086:43a4] type 00 class 0x0c8000
[ 0.573504] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.576615] pci 0000:00:1f.6: [8086:15f9] type 00 class 0x020000
[ 0.576648] pci 0000:00:1f.6: reg 0x10: [mem 0xa1180000-0xa119ffff]
[ 0.576824] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[ 0.577058] pci 0000:01:00.0: [10de:1f97] type 00 class 0x030200
[ 0.577069] pci 0000:01:00.0: reg 0x10: [mem 0xa0000000-0xa0ffffff]
[ 0.577078] pci 0000:01:00.0: reg 0x14: [mem 0x6000000000-0x600fffffff 64bit pref]
[ 0.577087] pci 0000:01:00.0: reg 0x1c: [mem 0x6010000000-0x6011ffffff 64bit pref]
[ 0.577093] pci 0000:01:00.0: reg 0x24: [io 0x3000-0x307f]
[ 0.577099] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 0.577152] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.577216] pci 0000:01:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.577349] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.577351] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.577353] pci 0000:00:01.0: bridge window [mem 0xa0000000-0xa0ffffff]
[ 0.577355] pci 0000:00:01.0: bridge window [mem 0x6000000000-0x6011ffffff 64bit pref]
[ 0.577382] pci 0000:00:07.0: PCI bridge to [bus 02-39]
[ 0.577386] pci 0000:00:07.0: bridge window [mem 0x8a000000-0x9fdfffff]
[ 0.577389] pci 0000:00:07.0: bridge window [mem 0x6020000000-0x6041ffffff 64bit pref]
[ 0.577418] pci 0000:00:07.1: PCI bridge to [bus 3a-71]
[ 0.577421] pci 0000:00:07.1: bridge window [mem 0x74000000-0x89dfffff]
[ 0.577424] pci 0000:00:07.1: bridge window [mem 0x6050000000-0x6071ffffff 64bit pref]
[ 0.577512] pci 0000:72:00.0: [10ec:525a] type 00 class 0xff0000
[ 0.577539] pci 0000:72:00.0: reg 0x14: [mem 0xa1000000-0xa1000fff]
[ 0.577669] pci 0000:72:00.0: supports D1 D2
[ 0.577670] pci 0000:72:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.577843] pci 0000:00:1c.0: PCI bridge to [bus 72]
[ 0.577847] pci 0000:00:1c.0: bridge window [mem 0xa1000000-0xa10fffff]
[ 0.602504] ACPI: EC: interrupt unblocked
[ 0.602504] ACPI: EC: event unblocked
[ 0.602514] ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.602514] ACPI: EC: GPE=0x6e
[ 0.602515] ACPI: \_SB_.PC00.LPCB.ECDV: Boot DSDT EC initialization complete
[ 0.602517] ACPI: \_SB_.PC00.LPCB.ECDV: EC: Used to handle transactions and events
[ 0.602575] iommu: Default domain type: Translated
[ 0.602575] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.602582] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.602582] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.602582] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.602582] vgaarb: loaded
[ 0.602582] SCSI subsystem initialized
[ 0.602582] libata version 3.00 loaded.
[ 0.602582] ACPI: bus type USB registered
[ 0.602582] usbcore: registered new interface driver usbfs
[ 0.602582] usbcore: registered new interface driver hub
[ 0.602582] usbcore: registered new device driver usb
[ 0.602582] pps_core: LinuxPPS API ver. 1 registered
[ 0.602582] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.602582] PTP clock support registered
[ 0.602582] EDAC MC: Ver: 3.0.0
[ 0.602582] Registered efivars operations
[ 0.602582] NetLabel: Initializing
[ 0.602582] NetLabel: domain hash size = 128
[ 0.602582] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.602582] NetLabel: unlabeled traffic allowed by default
[ 0.602582] PCI: Using ACPI for IRQ routing
[ 0.615840] PCI: pci_cache_line_size set to 64 bytes
[ 0.615946] pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[ 0.616042] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.616043] e820: reserve RAM buffer [mem 0x5a74b000-0x5bffffff]
[ 0.616044] e820: reserve RAM buffer [mem 0x5f72a000-0x5fffffff]
[ 0.616044] e820: reserve RAM buffer [mem 0x88f800000-0x88fffffff]
[ 0.616047] clocksource: Switched to clocksource tsc-early
[ 0.619937] VFS: Disk quotas dquot_6.6.0
[ 0.619946] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.620002] AppArmor: AppArmor Filesystem Enabled
[ 0.620018] pnp: PnP ACPI init
[ 0.620153] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.620155] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.620234] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.621268] pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.621284] system 00:05: [mem 0xfedc0000-0xfedc7fff] has been reserved
[ 0.621285] system 00:05: [mem 0xfeda0000-0xfeda0fff] has been reserved
[ 0.621286] system 00:05: [mem 0xfeda1000-0xfeda1fff] has been reserved
[ 0.621287] system 00:05: [mem 0xfed20000-0xfed7ffff] could not be reserved
[ 0.621288] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.621289] system 00:05: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.621290] system 00:05: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.622094] system 00:06: [io 0x1800-0x18fe] could not be reserved
[ 0.622095] system 00:06: [mem 0xfe000000-0xfe01ffff] has been reserved
[ 0.622096] system 00:06: [mem 0xfe04c000-0xfe04ffff] has been reserved
[ 0.622097] system 00:06: [mem 0xfe050000-0xfe0affff] has been reserved
[ 0.622098] system 00:06: [mem 0xfe0d0000-0xfe0fffff] has been reserved
[ 0.622099] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.622100] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.622101] system 00:06: [mem 0xfd000000-0xfd68ffff] has been reserved
[ 0.622103] system 00:06: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.622104] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.622337] system 00:07: [io 0x2000-0x20fe] has been reserved
[ 0.625211] pnp: PnP ACPI: found 9 devices
[ 0.630300] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.630329] NET: Registered PF_INET protocol family
[ 0.630427] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.631379] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.631494] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.631675] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.631710] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.631789] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[ 0.631845] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.631896] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.631964] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.631968] NET: Registered PF_XDP protocol family
[ 0.631970] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ 0.631972] pci 0000:00:07.0: bridge window [io 0x1000-0x0fff] to [bus 02-39] add_size 1000
[ 0.631974] pci 0000:00:07.1: bridge window [io 0x1000-0x0fff] to [bus 3a-71] add_size 1000
[ 0.631980] pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
[ 0.631983] pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
[ 0.631985] pci 0000:00:07.0: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.631986] pci 0000:00:07.1: BAR 13: assigned [io 0x6000-0x6fff]
[ 0.631987] pci 0000:00:15.0: BAR 0: assigned [mem 0x4017000000-0x4017000fff 64bit]
[ 0.632041] pci 0000:00:15.1: BAR 0: assigned [mem 0x4017001000-0x4017001fff 64bit]
[ 0.632056] pci 0000:00:1f.5: BAR 0: assigned [mem 0x70800000-0x70800fff]
[ 0.632067] pci 0000:01:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[ 0.632068] pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
[ 0.632069] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.632070] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.632073] pci 0000:00:01.0: bridge window [mem 0xa0000000-0xa0ffffff]
[ 0.632075] pci 0000:00:01.0: bridge window [mem 0x6000000000-0x6011ffffff 64bit pref]
[ 0.632077] pci 0000:00:07.0: PCI bridge to [bus 02-39]
[ 0.632079] pci 0000:00:07.0: bridge window [io 0x5000-0x5fff]
[ 0.632081] pci 0000:00:07.0: bridge window [mem 0x8a000000-0x9fdfffff]
[ 0.632083] pci 0000:00:07.0: bridge window [mem 0x6020000000-0x6041ffffff 64bit pref]
[ 0.632087] pci 0000:00:07.1: PCI bridge to [bus 3a-71]
[ 0.632088] pci 0000:00:07.1: bridge window [io 0x6000-0x6fff]
[ 0.632090] pci 0000:00:07.1: bridge window [mem 0x74000000-0x89dfffff]
[ 0.632093] pci 0000:00:07.1: bridge window [mem 0x6050000000-0x6071ffffff 64bit pref]
[ 0.632096] pci 0000:00:1c.0: PCI bridge to [bus 72]
[ 0.632104] pci 0000:00:1c.0: bridge window [mem 0xa1000000-0xa10fffff]
[ 0.632111] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.632112] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.632112] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.632113] pci_bus 0000:00: resource 7 [mem 0x70800000-0xbfffffff window]
[ 0.632114] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
[ 0.632114] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.632115] pci_bus 0000:01: resource 1 [mem 0xa0000000-0xa0ffffff]
[ 0.632116] pci_bus 0000:01: resource 2 [mem 0x6000000000-0x6011ffffff 64bit pref]
[ 0.632117] pci_bus 0000:02: resource 0 [io 0x5000-0x5fff]
[ 0.632117] pci_bus 0000:02: resource 1 [mem 0x8a000000-0x9fdfffff]
[ 0.632118] pci_bus 0000:02: resource 2 [mem 0x6020000000-0x6041ffffff 64bit pref]
[ 0.632119] pci_bus 0000:3a: resource 0 [io 0x6000-0x6fff]
[ 0.632119] pci_bus 0000:3a: resource 1 [mem 0x74000000-0x89dfffff]
[ 0.632120] pci_bus 0000:3a: resource 2 [mem 0x6050000000-0x6071ffffff 64bit pref]
[ 0.632121] pci_bus 0000:72: resource 1 [mem 0xa1000000-0xa10fffff]
[ 0.632249] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.632583] PCI: CLS 0 bytes, default 64
[ 0.632601] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.632602] software IO TLB: mapped [mem 0x0000000051a1e000-0x0000000055a1e000] (64MB)
[ 0.632620] Trying to unpack rootfs image as initramfs...
[ 0.632620] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23fa772cf26, max_idle_ns: 440795269835 ns
[ 0.632654] clocksource: Switched to clocksource tsc
[ 0.642925] Initialise system trusted keyrings
[ 0.642933] Key type blacklist registered
[ 0.642950] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[ 0.643508] zbud: loaded
[ 0.649925] Key type asymmetric registered
[ 0.649926] Asymmetric key parser 'x509' registered
[ 0.649932] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.649961] io scheduler mq-deadline registered
[ 0.649961] io scheduler kyber registered
[ 0.649977] io scheduler bfq registered
[ 0.652013] pcieport 0000:00:01.0: PME: Signaling with IRQ 124
[ 0.652160] pcieport 0000:00:07.0: PME: Signaling with IRQ 125
[ 0.652171] pcieport 0000:00:07.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.652347] pcieport 0000:00:07.1: PME: Signaling with IRQ 126
[ 0.652359] pcieport 0000:00:07.1: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.652539] pcieport 0000:00:1c.0: PME: Signaling with IRQ 127
[ 0.652615] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.652777] Monitor-Mwait will be used to enter C-1 state
[ 0.652779] Monitor-Mwait will be used to enter C-2 state
[ 0.652781] Monitor-Mwait will be used to enter C-3 state
[ 0.652782] ACPI: \_SB_.PR00: Found 3 idle states
[ 0.653920] ACPI: AC: AC Adapter [AC] (on-line)
[ 0.653959] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.655354] ACPI: button: Lid Switch [LID0]
[ 0.655376] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.655504] ACPI: button: Power Button [PBTN]
[ 0.655515] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.655522] ACPI: button: Sleep Button [SBTN]
[ 0.655611] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1966
[ 0.658264] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.658918] serial 0000:00:12.0: enabling device (0000 -> 0002)
[ 0.659135] serial 0000:00:16.3: enabling device (0000 -> 0003)
[ 0.659731] 0000:00:16.3: ttyS4 at I/O 0x4060 (irq = 19, base_baud = 115200) is a 16550A
[ 0.660182] hpet_acpi_add: no address or irqs in _CRS
[ 0.660203] Non-volatile memory driver v1.3
[ 0.660203] Linux agpgart interface v0.103
[ 0.660204] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.661801] ahci 0000:00:0e.0: version 3.0
[ 0.661808] ahci: probe of 0000:00:0e.0 failed with error -22
[ 0.661821] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.661822] ehci-pci: EHCI PCI platform driver
[ 0.661826] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.661827] ohci-pci: OHCI PCI platform driver
[ 0.661830] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.661845] usbcore: registered new interface driver usbserial_generic
[ 0.661847] usbserial: USB Serial support registered for generic
[ 0.661896] rtc_cmos 00:01: RTC can wake from S4
[ 0.662554] rtc_cmos 00:01: registered as rtc0
[ 0.662740] rtc_cmos 00:01: setting system clock to 2022-01-19T17:09:27 UTC (1642612167)
[ 0.662746] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
[ 0.663628] intel_pstate: Intel P-state driver initializing
[ 0.665304] intel_pstate: HWP enabled
[ 0.665867] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.665972] efifb: probing for efifb
[ 0.665980] efifb: showing boot graphics
[ 0.667133] efifb: framebuffer at 0x4000000000, using 8128k, total 8128k
[ 0.667134] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.667135] efifb: scrolling: redraw
[ 0.667135] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.667154] fbcon: Deferring console take-over
[ 0.667154] fb0: EFI VGA frame buffer device
[ 0.667168] hid: raw HID events driver (C) Jiri Kosina
[ 0.667201] ashmem: initialized
[ 0.667481] intel_pmc_core INT33A1:00: initialized
[ 0.667520] drop_monitor: Initializing network drop monitor service
[ 0.667552] Initializing XFRM netlink socket
[ 0.667591] NET: Registered PF_INET6 protocol family
[ 0.685249] ACPI: battery: Slot [BAT0] (battery present)
[ 0.725374] Freeing initrd memory: 14364K
[ 0.729017] Segment Routing with IPv6
[ 0.729018] RPL Segment Routing with IPv6
[ 0.729023] In-situ OAM (IOAM) with IPv6
[ 0.729036] NET: Registered PF_PACKET protocol family
[ 0.731178] microcode: sig=0x806d1, pf=0x2, revision=0x34
[ 0.731858] microcode: Microcode Update Driver: v2.2.
[ 0.732813] resctrl: L2 allocation detected
[ 0.732816] IPI shorthand broadcast: enabled
[ 0.732822] sched_clock: Marking stable (726041815, 6764878)->(747216160, -14409467)
[ 0.733309] registered taskstats version 1
[ 0.734535] Loading compiled-in X.509 certificates
[ 0.736138] Loaded X.509 cert 'Build time autogenerated kernel key: 9612dc616146eeaafd46db77e26f033f23e1efc3'
[ 0.737960] zswap: loaded using pool zstd/z3fold
[ 0.738870] Key type ._fscrypt registered
[ 0.738871] Key type .fscrypt registered
[ 0.738871] Key type fscrypt-provisioning registered
[ 0.738894] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.739054] PM: Magic number: 6:815:188
[ 0.739096] acpi device:47: hash matches
[ 0.739101] acpi device:1a: hash matches
[ 0.739268] RAS: Correctable Errors collector initialized.
[ 0.741520] Freeing unused decrypted memory: 2036K
[ 0.741869] Freeing unused kernel image (initmem) memory: 1864K
[ 0.802083] Write protecting the kernel read-only data: 28672k
[ 0.802947] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.803339] Freeing unused kernel image (rodata/data gap) memory: 1404K
[ 0.813114] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.813117] rodata_test: all tests were successful
[ 0.813120] Run /init as init process
[ 0.813121] with arguments:
[ 0.813122] /init
[ 0.813122] splash
[ 0.813123] with environment:
[ 0.813123] HOME=/
[ 0.813123] TERM=linux
[ 0.813124] BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
[ 0.922641] rtsx_pci 0000:72:00.0: enabling device (0000 -> 0002)
[ 0.922658] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 0.922665] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[ 0.923146] vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
[ 0.923148] pci_bus 10000:e0: root bus resource [bus e0-ff]
[ 0.923149] pci_bus 10000:e0: root bus resource [mem 0x72000000-0x73ffffff]
[ 0.923150] pci_bus 10000:e0: root bus resource [mem 0x6075102000-0x60751fffff 64bit]
[ 0.923267] pci 10000:e0:06.0: [8086:9a0f] type 01 class 0x060400
[ 0.923323] pci 10000:e0:06.0: PME# supported from D0 D3hot D3cold
[ 0.923347] pci 10000:e0:06.0: PTM enabled (root), 4ns granularity
[ 0.923411] pci 10000:e0:06.0: Primary bus is hard wired to 0
[ 0.923485] pci 10000:e1:00.0: [1c5c:174a] type 00 class 0x010802
[ 0.923503] pci 10000:e1:00.0: reg 0x10: [mem 0x72000000-0x72003fff 64bit]
[ 0.923512] pci 10000:e1:00.0: reg 0x18: [mem 0x00000000-0x00000fff]
[ 0.923520] pci 10000:e1:00.0: reg 0x1c: [mem 0x00000000-0x00000fff]
[ 0.923733] pci 10000:e0:06.0: PCI bridge to [bus e1]
[ 0.923735] pci 10000:e0:06.0: bridge window [io 0x0000-0x0fff]
[ 0.923736] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
[ 0.923737] pci 10000:e0:06.0: bridge window [mem 0x72000000-0x720fffff]
[ 0.923741] pci 10000:e0:06.0: Primary bus is hard wired to 0
[ 0.923747] pci 10000:e0:06.0: BAR 14: assigned [mem 0x72000000-0x720fffff]
[ 0.923748] pci 10000:e0:06.0: BAR 13: no space for [io size 0x1000]
[ 0.923750] pci 10000:e0:06.0: BAR 13: failed to assign [io size 0x1000]
[ 0.923752] pci 10000:e1:00.0: BAR 0: assigned [mem 0x72000000-0x72003fff 64bit]
[ 0.923761] pci 10000:e1:00.0: BAR 2: assigned [mem 0x72004000-0x72004fff]
[ 0.923764] pci 10000:e1:00.0: BAR 3: assigned [mem 0x72005000-0x72005fff]
[ 0.923767] pci 10000:e0:06.0: PCI bridge to [bus e1]
[ 0.923770] pci 10000:e0:06.0: bridge window [mem 0x72000000-0x720fffff]
[ 0.923782] pcieport 10000:e0:06.0: can't derive routing for PCI INT D
[ 0.923783] pcieport 10000:e0:06.0: PCI INT D: no GSI
[ 0.923817] pcieport 10000:e0:06.0: PME: Signaling with IRQ 149
[ 0.923869] pcieport 10000:e0:06.0: AER: enabled with IRQ 149
[ 0.923881] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.923883] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.923884] usb usb1: Product: xHCI Host Controller
[ 0.923886] usb usb1: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[ 0.923886] usb usb1: SerialNumber: 0000:00:0d.0
[ 0.923896] pcieport 10000:e0:06.0: DPC: enabled with IRQ 149
[ 0.923897] pcieport 10000:e0:06.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.923975] hub 1-0:1.0: USB hub found
[ 0.923983] hub 1-0:1.0: 1 port detected
[ 0.923997] nvme nvme0: pci function 10000:e1:00.0
[ 0.924007] vmd 0000:00:0e.0: Bound to PCI domain 10000
[ 0.924010] pcieport 10000:e0:06.0: can't derive routing for PCI INT A
[ 0.924012] nvme 10000:e1:00.0: PCI INT A: not connected
[ 0.924422] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 0.924426] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[ 0.924429] xhci_hcd 0000:00:0d.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.924469] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 0.924471] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.924472] usb usb2: Product: xHCI Host Controller
[ 0.924474] usb usb2: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[ 0.924475] usb usb2: SerialNumber: 0000:00:0d.0
[ 0.924583] hub 2-0:1.0: USB hub found
[ 0.924594] hub 2-0:1.0: 4 ports detected
[ 0.925067] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.925071] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.926164] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
[ 0.926323] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.926324] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.926325] usb usb3: Product: xHCI Host Controller
[ 0.926326] usb usb3: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[ 0.926326] usb usb3: SerialNumber: 0000:00:14.0
[ 0.926373] hub 3-0:1.0: USB hub found
[ 0.926396] hub 3-0:1.0: 16 ports detected
[ 0.927011] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.927231] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.927233] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.927234] xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 0.927254] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 0.927255] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.927256] usb usb4: Product: xHCI Host Controller
[ 0.927256] usb usb4: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[ 0.927257] usb usb4: SerialNumber: 0000:00:14.0
[ 0.927296] hub 4-0:1.0: USB hub found
[ 0.927311] hub 4-0:1.0: 6 ports detected
[ 0.927362] i8042: Warning: Keylock active
[ 0.927486] usb: port power management may be unreliable
[ 0.929728] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.929760] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.933625] rtsx_pci 0000:72:00.0: Unbalanced pm_runtime_enable!
[ 0.940249] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.999590] nvme nvme0: 16/0/0 default/read/poll queues
[ 1.005258] nvme0n1: p1 p2
[ 1.149912] random: fast init done
[ 1.153204] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.175287] usb 3-3: new high-speed USB device number 2 using xhci_hcd
[ 1.211280] systemd[1]: systemd 250-5-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 1.225511] systemd[1]: Detected architecture x86-64.
[ 1.225877] systemd[1]: Hostname set to <internetmosquito-latitude5421>.
[ 1.287683] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 1.321425] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.322235] systemd[1]: Created slice Slice /system/getty.
[ 1.322394] systemd[1]: Created slice Slice /system/modprobe.
[ 1.322519] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 1.322592] systemd[1]: Created slice User and Session Slice.
[ 1.322621] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.322685] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.322703] systemd[1]: Reached target Login Prompts.
[ 1.322709] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 1.322720] systemd[1]: Reached target Remote File Systems.
[ 1.322725] systemd[1]: Reached target Slice Units.
[ 1.322734] systemd[1]: Reached target Swaps.
[ 1.322742] systemd[1]: Reached target Local Verity Protected Volumes.
[ 1.322772] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.322806] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.323268] systemd[1]: Listening on Process Core Dump Socket.
[ 1.323319] systemd[1]: Listening on Journal Audit Socket.
[ 1.323352] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.323385] systemd[1]: Listening on Journal Socket.
[ 1.324014] systemd[1]: Listening on udev Control Socket.
[ 1.324066] systemd[1]: Listening on udev Kernel Socket.
[ 1.324444] systemd[1]: Mounting Huge Pages File System...
[ 1.324763] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.325115] systemd[1]: Mounting Kernel Debug File System...
[ 1.325487] systemd[1]: Mounting Kernel Trace File System...
[ 1.326238] systemd[1]: Mounting Temporary Directory /tmp...
[ 1.326548] systemd[1]: Starting Load AppArmor profiles...
[ 1.326917] systemd[1]: Starting Create List of Static Device Nodes...
[ 1.327248] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 1.327567] systemd[1]: Starting Load Kernel Module configfs...
[ 1.327899] systemd[1]: Starting Load Kernel Module drm...
[ 1.328275] systemd[1]: Starting Load Kernel Module fuse...
[ 1.328314] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 1.328836] random: lvm: uninitialized urandom read (4 bytes read)
[ 1.328950] systemd[1]: Starting Load Kernel Modules...
[ 1.329294] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.329347] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 1.329704] systemd[1]: Starting Coldplug All udev Devices...
[ 1.330362] systemd[1]: Mounted Huge Pages File System.
[ 1.330411] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.330453] systemd[1]: Mounted Kernel Debug File System.
[ 1.330480] systemd[1]: Mounted Kernel Trace File System.
[ 1.330532] systemd[1]: Mounted Temporary Directory /tmp.
[ 1.330650] systemd[1]: Finished Create List of Static Device Nodes.
[ 1.330782] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 1.330829] systemd[1]: Finished Load Kernel Module configfs.
[ 1.330918] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 1.330957] systemd[1]: Finished Load Kernel Module drm.
[ 1.331368] systemd[1]: Mounting Kernel Configuration File System...
[ 1.332249] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null). Quota mode: none.
[ 1.332551] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 1.332626] systemd[1]: Mounted Kernel Configuration File System.
[ 1.332664] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 1.333165] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 1.333557] systemd[1]: Starting Load/Save Random Seed...
[ 1.333585] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 1.334002] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 1.334350] systemd[1]: Starting Setup Virtual Console...
[ 1.337392] fuse: init (API version 7.34)
[ 1.337706] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 1.337773] systemd[1]: Finished Load Kernel Module fuse.
[ 1.338144] systemd[1]: Mounting FUSE Control File System...
[ 1.338953] systemd[1]: Mounted FUSE Control File System.
[ 1.339070] IPMI message handler: version 39.2
[ 1.341618] ipmi device interface
[ 1.344736] audit: type=1400 audit(1642612168.176:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=379 comm="apparmor_parser"
[ 1.344740] audit: type=1400 audit(1642612168.176:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=379 comm="apparmor_parser"
[ 1.346024] systemd[1]: Finished Setup Virtual Console.
[ 1.346155] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 1.346220] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 1.346253] ipmi_si: IPMI System Interface driver
[ 1.346294] ipmi_si: Unable to find any System Interface(s)
[ 1.346860] systemd[1]: Starting Journal Service...
[ 1.347435] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 1.348302] usb 3-3: New USB device found, idVendor=1bcf, idProduct=28cc, bcdDevice=11.21
[ 1.348304] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.348306] usb 3-3: Product: Integrated_Webcam_HD
[ 1.348307] usb 3-3: Manufacturer: CN07JXD18LG0017PAN4DA01
[ 1.348308] usb 3-3: SerialNumber: 01.00.00
[ 1.368277] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 1.368313] audit: type=1130 audit(1642612168.199:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.368915] audit: type=1400 audit(1642612168.203:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=376 comm="apparmor_parser"
[ 1.369491] audit: type=1400 audit(1642612168.203:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=376 comm="apparmor_parser"
[ 1.371047] systemd[1]: Started Journal Service.
[ 1.371090] audit: type=1130 audit(1642612168.203:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.375875] systemd-journald[384]: Received client request to flush runtime journal.
[ 1.377508] audit: type=1130 audit(1642612168.209:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.379705] audit: type=1400 audit(1642612168.213:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=375 comm="apparmor_parser"
[ 1.387405] audit: type=1130 audit(1642612168.219:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.395425] ACPI Error: Thread 2184390208 cannot release Mutex [ECMX] acquired by thread 2167360640 (20210730/exmutex-378)
[ 1.395431] ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20210730/psparse-529)
[ 1.412886] input: Intel HID events as /devices/platform/INTC1051:00/input/input5
[ 1.413219] intel-hid INTC1051:00: platform supports 5 button array
[ 1.413302] input: Intel HID 5 button array as /devices/platform/INTC1051:00/input/input6
[ 1.415512] mc: Linux media interface: v0.10
[ 1.478738] usb 3-11: new full-speed USB device number 3 using xhci_hcd
[ 1.499663] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.499741] wmi_bus wmi_bus-PNP0C14:02: WQBC data block query control method not found
[ 1.499743] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.500239] videodev: Linux video capture interface: v2.00
[ 1.502520] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.504025] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.504078] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.504132] acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.508930] intel-pmt 0000:00:0a.0: Watcher not supported
[ 1.508934] intel-pmt 0000:00:0a.0: Crashlog not supported
[ 1.518823] tpm_tis STM0125:00: 2.0 TPM (device-id 0x0, rev-id 78)
[ 1.535343] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ 1.536003] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 1.565442] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[ 1.565777] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 1.602467] ioremap error for 0x63cc3000-0x63cc4000, requested 0x2, got 0x0
[ 1.605311] ucsi_acpi: probe of USBC000:00 failed with error -12
[ 1.621328] usb 3-11: New USB device found, idVendor=046d, idProduct=c52f, bcdDevice=30.00
[ 1.621330] usb 3-11: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.621331] usb 3-11: Product: USB Receiver
[ 1.621332] usb 3-11: Manufacturer: Logitech
[ 1.637207] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[ 1.644735] intel_rapl_common: Found RAPL domain package
[ 1.653760] input: PC Speaker as /devices/platform/pcspkr/input/input8
[ 1.653791] i801_smbus 0000:00:1f.4: enabling device (0000 -> 0003)
[ 1.653843] ACPI: bus type thunderbolt registered
[ 1.654015] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.654098] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 1.654143] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 1.654600] ACPI Warning: \_SB.PC00.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[ 1.654957] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 1.654985] ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[ 1.655005] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.655007] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.655506] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.655588] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[ 1.655613] VGA switcheroo: detected Optimus DSM method \_SB_.PC00.PEG1.PEGP handle
[ 1.655614] nouveau: detected PR support, will not use DSM
[ 1.655773] checking generic (4000000000 7f0000) vs hw (a0000000 1000000)
[ 1.655774] checking generic (4000000000 7f0000) vs hw (6000000000 10000000)
[ 1.655775] checking generic (4000000000 7f0000) vs hw (6010000000 2000000)
[ 1.655847] nouveau 0000:01:00.0: NVIDIA TU117 (167000a1)
[ 1.655848] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.657102] usb 3-3: Found UVC 1.00 device Integrated_Webcam_HD (1bcf:28cc)
[ 1.666085] resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
[ 1.666088] caller tgl_uncore_imc_freerunning_init_box+0xbf/0x100 [intel_uncore] mapping multiple BARs
[ 1.670416] i2c i2c-2: 2/2 memory slots populated (from DMI)
[ 1.670779] i2c i2c-2: Successfully instantiated SPD at 0x50
[ 1.693997] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/input/input9
[ 1.694120] usbcore: registered new interface driver uvcvideo
[ 1.713351] checking generic (4000000000 7f0000) vs hw (6074000000 1000000)
[ 1.713353] checking generic (4000000000 7f0000) vs hw (4000000000 10000000)
[ 1.713354] fb0: switching to i915 from EFI VGA
[ 1.713405] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 1.715095] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.716670] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_12.bin (v2.12)
[ 1.722852] input: DELL0A66:00 0488:101A Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0A66:00/0018:0488:101A.0001/input/input10
[ 1.722885] input: DELL0A66:00 0488:101A Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0A66:00/0018:0488:101A.0001/input/input11
[ 1.722921] hid-generic 0018:0488:101A.0001: input,hidraw0: I2C HID v1.00 Mouse [DELL0A66:00 0488:101A] on i2c-DELL0A66:00
[ 1.732610] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[ 1.745296] usb 3-14: new full-speed USB device number 4 using xhci_hcd
[ 1.746469] intel-spi 0000:00:1f.5: gd25q256 (32768 Kbytes)
[ 1.746498] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 1.747933] Creating 1 MTD partitions on "0000:00:1f.5":
[ 1.747935] 0x000000000000-0x000002000000 : "BIOS"
[ 1.747985] ACPI: video: Video Device [PEGP] (multi-head: no rom: yes post: no)
[ 1.748166] nouveau 0000:01:00.0: bios: version 90.17.74.00.5d
[ 1.748207] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/LNXVIDEO:00/input/input13
[ 1.749707] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 1.750220] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input14
[ 1.750498] nouveau 0000:01:00.0: pmu: firmware unavailable
[ 1.752491] fbcon: i915drmfb (fb0) is primary device
[ 1.752492] fbcon: Deferring console take-over
[ 1.752493] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 1.752966] nouveau 0000:01:00.0: fb: 2048 MiB GDDR6
[ 1.764442] nouveau 0000:01:00.0: sec2: unhandled intr 00000010
[ 1.799996] vga_switcheroo: enabled
[ 1.800003] nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
[ 1.800004] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[ 1.800005] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[ 1.800006] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[ 1.800007] nouveau 0000:01:00.0: DRM: Pointer to TMDS table not found
[ 1.800007] nouveau 0000:01:00.0: DRM: DCB version 4.1
[ 1.800368] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 1.800484] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[ 1.802115] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) a0:29:19:0f:05:bc
[ 1.802119] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[ 1.802247] e1000e 0000:00:1f.6 eth0: MAC: 14, PHY: 12, PBA No: FFFFFF-0FF
[ 1.816223] cryptd: max_cpu_qlen set to 1000
[ 1.833828] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[ 1.843021] Intel(R) Wireless WiFi driver for Linux
[ 1.843134] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 1.855312] AVX2 version of gcm_enc/dec engaged.
[ 1.855374] AES CTR mode by8 optimization enabled
[ 1.867681] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-66.ucode failed with error -2
[ 1.867694] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-65.ucode failed with error -2
[ 1.867703] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-64.ucode failed with error -2
[ 1.869094] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 1.869107] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 1.869349] iwlwifi 0000:00:14.3: loaded firmware version 63.c04f3485.0 QuZ-a0-hr-b0-63.ucode op_mode iwlmvm
[ 1.887005] usb 3-14: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[ 1.887009] usb 3-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.990618] dell_smm_hwmon: unable to get SMM Dell signature
[ 2.005478] loop: module loaded
[ 2.005778] loop0: detected capacity change from 0 to 8
[ 2.005999] NET: Registered PF_QIPCRTR protocol family
[ 2.021134] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.117778] intel_rapl_common: Found RAPL domain package
[ 2.117781] intel_rapl_common: Found RAPL domain core
[ 2.117782] intel_rapl_common: Found RAPL domain uncore
[ 2.117784] intel_rapl_common: Found RAPL domain psys
[ 2.145507] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb3/3-11/3-11:1.0/0003:046D:C52F.0002/input/input15
[ 2.145550] hid-generic 0003:046D:C52F.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-11/input0
[ 2.146633] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-11/3-11:1.1/0003:046D:C52F.0003/input/input16
[ 2.159095] iTCO_vendor_support: vendor-support=0
[ 2.170714] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 2.176254] input: Dell Privacy Driver as /devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/PNP0C14:02-6932965F-1671-4CEB-B988-D3AB0A901919/input/input19
[ 2.180963] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 2.181042] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 2.181146] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 2.181442] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 2.205861] hid-generic 0003:046D:C52F.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-11/input1
[ 2.205947] usbcore: registered new interface driver usbhid
[ 2.205948] usbhid: USB HID core driver
[ 2.206107] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 2.207306] input: Dell WMI hotkeys as /devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/PNP0C14:02-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input20
[ 2.236502] e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
[ 2.256190] ee1004 2-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 2.260801] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 2.273782] thermal thermal_zone6: failed to read out thermal zone (-61)
[ 2.328280] ish-hid {33AECD58-B679-4E54-9BD9-A04D34F0C226}: [hid-ish]: enum_devices_done OK, num_hid_devices=1
[ 2.332108] intel_tcc_cooling: Programmable TCC Offset detected
[ 2.339316] hid-generic 001F:8087:0AC2.0004: hidraw3: <UNKNOWN> HID v2.00 Device [hid-ishtp 8087:0AC2] on
[ 2.368787] logitech-djreceiver 0003:046D:C52F.0002: hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-11/input0
[ 2.373546] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3204: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 2.373549] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.373550] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 2.373551] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 2.373551] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 2.373552] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19
[ 2.373553] snd_hda_codec_realtek hdaudioC0D0: Headphone Mic=0x1a
[ 2.373553] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 2.401412] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input7
[ 2.411290] input: DELL0A66:00 0488:101A Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0A66:00/0018:0488:101A.0001/input/input21
[ 2.411342] input: DELL0A66:00 0488:101A Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DELL0A66:00/0018:0488:101A.0001/input/input22
[ 2.411363] hid-multitouch 0018:0488:101A.0001: input,hidraw0: I2C HID v1.00 Mouse [DELL0A66:00 0488:101A] on i2c-DELL0A66:00
[ 2.425748] dell_laptop: Using i8042 filter function for receiving events
[ 2.430297] Bluetooth: Core ver 2.22
[ 2.430312] NET: Registered PF_BLUETOOTH protocol family
[ 2.430313] Bluetooth: HCI device and connection manager initialized
[ 2.430316] Bluetooth: HCI socket layer initialized
[ 2.430317] Bluetooth: L2CAP socket layer initialized
[ 2.430319] Bluetooth: SCO socket layer initialized
[ 2.461683] mousedev: PS/2 mouse device common for all mice
[ 2.461694] logitech-djreceiver 0003:046D:C52F.0003: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-11/input1
[ 2.494413] usbcore: registered new interface driver btusb
[ 2.494849] Bluetooth: hci0: Bootloader revision 0.4 build 0 week 30 2018
[ 2.495832] Bluetooth: hci0: Device revision is 2
[ 2.495834] Bluetooth: hci0: Secure boot is enabled
[ 2.495834] Bluetooth: hci0: OTP lock is enabled
[ 2.495835] Bluetooth: hci0: API lock is enabled
[ 2.495835] Bluetooth: hci0: Debug lock is disabled
[ 2.495835] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 2.496758] Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
[ 2.515786] logitech-djreceiver 0003:046D:C52F.0003: device of type eQUAD step 4 DJ (0x04) connected on slot 1
[ 2.515944] input: Logitech Wireless Mouse PID:4080 Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-11/3-11:1.1/0003:046D:C52F.0003/0003:046D:4080.0005/input/input25
[ 2.516021] input: Logitech Wireless Mouse PID:4080 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-11/3-11:1.1/0003:046D:C52F.0003/0003:046D:4080.0005/input/input26
[ 2.516049] hid-generic 0003:046D:4080.0005: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4080] on usb-0000:00:14.0-11/input1:1
[ 2.562201] iwlwifi 0000:00:14.3: reporting RF_KILL (radio disabled)
[ 2.562214] iwlwifi 0000:00:14.3: Detected RF HR B5, rfid=0x10a100
[ 2.566357] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 2.566391] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[ 2.566452] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[ 2.566575] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input32
[ 2.566710] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.566712] Bluetooth: BNEP filters: protocol multicast
[ 2.566714] Bluetooth: BNEP socket layer initialized
[ 2.566735] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input33
[ 2.566777] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input34
[ 2.566812] input: HDA Intel PCH HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input35
[ 2.615362] input: HDA Intel PCH HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input36
[ 2.628552] iwlwifi 0000:00:14.3: base HW address: 44:e5:17:19:9e:5c
[ 2.643732] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[ 2.678724] input: HDA Intel PCH HDMI/DP,pcm=13 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input37
[ 2.678776] input: HDA Intel PCH HDMI/DP,pcm=14 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input38
[ 2.678808] input: HDA Intel PCH HDMI/DP,pcm=15 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input39
[ 2.678834] input: HDA Intel PCH HDMI/DP,pcm=16 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input40
[ 2.678861] input: HDA Intel PCH HDMI/DP,pcm=17 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input41
[ 2.683867] input: Logitech M350 as /devices/pci0000:00/0000:00:14.0/usb3/3-11/3-11:1.1/0003:046D:C52F.0003/0003:046D:4080.0005/input/input42
[ 2.683911] logitech-hidpp-device 0003:046D:4080.0005: input,hidraw3: USB HID v1.11 Mouse [Logitech M350] on usb-0000:00:14.0-11/input1:1
[ 2.755349] random: crng init done
[ 2.755351] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.935293] nouveau 0000:01:00.0: sec2: cmdq: timeout waiting for queue ready
[ 3.935297] nouveau 0000:01:00.0: gr: init failed, -110
[ 4.338076] Bluetooth: hci0: Waiting for firmware download to complete
[ 4.338812] Bluetooth: hci0: Firmware loaded in 1798879 usecs
[ 4.338862] Bluetooth: hci0: Waiting for device to boot
[ 4.353980] Bluetooth: hci0: Device booted in 14794 usecs
[ 4.354360] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-4.ddc
[ 4.356006] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 4.358931] Bluetooth: hci0: Firmware revision 0.4 build 5 week 39 2021
[ 4.422685] NET: Registered PF_ALG protocol family
[ 5.198218] nouveau 0000:01:00.0: gr: fecs falcon already acquired by gr!
[ 5.198221] nouveau 0000:01:00.0: gr: init failed, -16
[ 5.245008] nouveau 0000:01:00.0: gr: fecs falcon already acquired by gr!
[ 5.245012] nouveau 0000:01:00.0: gr: init failed, -16
[ 5.278835] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 5.278935] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s31f6: link becomes ready
[ 5.348357] kauditd_printk_skb: 64 callbacks suppressed
[ 5.348363] audit: type=1334 audit(1642612172.179:69): prog-id=20 op=LOAD
[ 5.348581] audit: type=1334 audit(1642612172.179:70): prog-id=21 op=LOAD
[ 5.348843] audit: type=1334 audit(1642612172.183:71): prog-id=22 op=LOAD
[ 5.368165] audit: type=1130 audit(1642612172.199:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.407395] audit: type=1334 audit(1642612172.239:73): prog-id=23 op=LOAD
[ 5.407447] audit: type=1334 audit(1642612172.239:74): prog-id=24 op=LOAD
[ 5.417360] audit: type=1130 audit(1642612172.249:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=power-profiles-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.434122] audit: type=1130 audit(1642612172.266:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.453335] audit: type=1130 audit(1642612172.286:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.454393] audit: type=1130 audit(1642612172.286:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.486860] rfkill: input handler disabled
[ 5.730217] nouveau 0000:01:00.0: gr: fecs falcon already acquired by gr!
[ 5.730221] nouveau 0000:01:00.0: gr: init failed, -16
[ 12.013183] kauditd_printk_skb: 6 callbacks suppressed
[ 12.013188] audit: type=1131 audit(1642612178.846:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.702699] audit: type=1130 audit(1642612179.536:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.091486] audit: type=1131 audit(1642612183.923:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.171208] audit: type=1100 audit(1642612185.003:88): pid=1140 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="internetmosquito" exe="/usr/lib/gdm-session-worker" hostname=internetmosquito-latitude5421 addr=? terminal=/dev/tty1 res=success'
[ 18.171673] audit: type=1101 audit(1642612185.003:89): pid=1140 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/lib/gdm-session-worker" hostname=internetmosquito-latitude5421 addr=? terminal=/dev/tty1 res=success'
[ 18.172674] audit: type=1103 audit(1642612185.006:90): pid=1140 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="internetmosquito" exe="/usr/lib/gdm-session-worker" hostname=internetmosquito-latitude5421 addr=? terminal=/dev/tty1 res=success'
[ 18.173140] audit: type=1006 audit(1642612185.006:91): pid=1140 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 18.173143] audit: type=1300 audit(1642612185.006:91): arch=c000003e syscall=1 success=yes exit=4 a0=a a1=7ffdba41e8c0 a2=4 a3=3e8 items=0 ppid=553 pid=1140 auid=1000 uid=0 gid=1000 euid=0 suid=0 fsuid=0 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=3 comm="gdm-session-wor" exe="/usr/lib/gdm-session-worker" subj==unconfined key=(null)
[ 18.173144] audit: type=1327 audit(1642612185.006:91): proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D70617373776F72645D
[ 18.196822] audit: type=1130 audit(1642612185.029:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.199559] audit: type=1101 audit(1642612185.033:93): pid=1158 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.199571] audit: type=1103 audit(1642612185.033:94): pid=1158 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="internetmosquito" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 18.533277] rfkill: input handler enabled
[ 19.193919] nouveau 0000:01:00.0: sec2: unhandled intr 00000010
[ 20.228785] nouveau 0000:01:00.0: sec2: cmdq: timeout waiting for queue ready
[ 20.228796] nouveau 0000:01:00.0: gr: init failed, -110
[ 22.134844] rfkill: input handler disabled
[ 22.204263] nouveau 0000:01:00.0: gr: fecs falcon already acquired by gr!
[ 22.204267] nouveau 0000:01:00.0: gr: init failed, -16
[ 22.238492] nouveau 0000:01:00.0: gr: fecs falcon already acquired by gr!
[ 22.238495] nouveau 0000:01:00.0: gr: init failed, -16
[ 22.441735] Bluetooth: RFCOMM TTY layer initialized
[ 22.441742] Bluetooth: RFCOMM socket layer initialized
[ 22.441745] Bluetooth: RFCOMM ver 1.11
[ 22.524976] nouveau 0000:01:00.0: gr: fecs falcon already acquired by gr!
[ 22.524979] nouveau 0000:01:00.0: gr: init failed, -16
[ 22.570678] kauditd_printk_skb: 11 callbacks suppressed
[ 22.570680] audit: type=1106 audit(1642612189.403:102): pid=641 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=internetmosquito-latitude5421 addr=? terminal=/dev/tty1 res=success'
[ 22.570721] audit: type=1104 audit(1642612189.403:103): pid=641 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=internetmosquito-latitude5421 addr=? terminal=/dev/tty1 res=success'
[ 23.016519] audit: type=1131 audit(1642612189.849:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.906106] logitech-hidpp-device 0003:046D:4080.0005: HID++ 4.5 device connected.
[ 32.139467] audit: type=1131 audit(1642612198.973:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.175962] audit: type=1334 audit(1642612199.009:106): prog-id=0 op=UNLOAD
[ 32.175973] audit: type=1334 audit(1642612199.009:107): prog-id=0 op=UNLOAD
[ 32.175977] audit: type=1334 audit(1642612199.009:108): prog-id=0 op=UNLOAD
[ 32.820606] audit: type=1131 audit(1642612199.645:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.824163] audit: type=1131 audit(1642612199.648:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.090540] audit: type=1131 audit(1642612202.868:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.130959] audit: type=1334 audit(1642612202.908:112): prog-id=0 op=UNLOAD
[ 46.597037] audit: type=1334 audit(1642612213.307:113): prog-id=27 op=LOAD
[ 46.597178] audit: type=1334 audit(1642612213.307:114): prog-id=28 op=LOAD
[ 46.597204] audit: type=1334 audit(1642612213.307:115): prog-id=29 op=LOAD
[ 46.620413] audit: type=1130 audit(1642612213.330:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.605975] audit: type=1131 audit(1642612219.305:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.624414] audit: type=1131 audit(1642612219.325:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.719871] audit: type=1334 audit(1642612219.422:119): prog-id=0 op=UNLOAD
[ 52.719879] audit: type=1334 audit(1642612219.422:120): prog-id=0 op=UNLOAD
[ 52.719882] audit: type=1334 audit(1642612219.422:121): prog-id=0 op=UNLOAD
[ 52.870020] audit: type=1334 audit(1642612219.572:122): prog-id=0 op=UNLOAD
[ 52.870030] audit: type=1334 audit(1642612219.572:123): prog-id=0 op=UNLOAD
[ 52.870033] audit: type=1334 audit(1642612219.572:124): prog-id=0 op=UNLOAD
[ 54.331100] audit: type=1334 audit(1642612221.027:125): prog-id=30 op=LOAD
[ 54.331230] audit: type=1334 audit(1642612221.027:126): prog-id=31 op=LOAD
[ 66.161882] kauditd_printk_skb: 2 callbacks suppressed
[ 66.161887] audit: type=1131 audit(1642612232.854:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 84.261005] audit: type=1131 audit(1642612250.950:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 84.281286] audit: type=1334 audit(1642612250.974:131): prog-id=0 op=UNLOAD
[ 84.281288] audit: type=1334 audit(1642612250.974:132): prog-id=0 op=UNLOAD
[ 84.281289] audit: type=1334 audit(1642612250.974:133): prog-id=0 op=UNLOAD
[ 84.387766] audit: type=1131 audit(1642612251.077:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 84.518024] audit: type=1334 audit(1642612251.210:135): prog-id=0 op=UNLOAD
[ 84.518033] audit: type=1334 audit(1642612251.210:136): prog-id=0 op=UNLOAD
[ 84.518037] audit: type=1334 audit(1642612251.210:137): prog-id=0 op=UNLOAD
[ 330.746695] audit: type=1130 audit(1642612497.434:138): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 333.589267] audit: type=1334 audit(1642612500.278:139): prog-id=33 op=LOAD
[ 333.619098] audit: type=1130 audit(1642612500.308:140): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 336.695878] audit: type=1100 audit(1642612503.384:141): pid=3305 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="internetmosquito" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 336.696711] audit: type=1101 audit(1642612503.384:142): pid=3305 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 364.184898] audit: type=1131 audit(1642612530.874:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 364.230877] audit: type=1334 audit(1642612530.921:144): prog-id=0 op=UNLOAD
[ 516.874703] audit: type=1334 audit(1642612683.560:145): prog-id=34 op=LOAD
[ 516.908324] audit: type=1130 audit(1642612683.593:146): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 519.640049] audit: type=1100 audit(1642612686.326:147): pid=4120 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 519.640611] audit: type=1101 audit(1642612686.326:148): pid=4120 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 519.640978] audit: type=1110 audit(1642612686.326:149): pid=4120 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 519.642363] audit: type=1105 audit(1642612686.330:150): pid=4120 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 519.647901] audit: type=1106 audit(1642612686.333:151): pid=4120 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 519.647976] audit: type=1104 audit(1642612686.333:152): pid=4120 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 533.188828] audit: type=1101 audit(1642612699.876:153): pid=4146 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 533.189147] audit: type=1110 audit(1642612699.876:154): pid=4146 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 533.190617] audit: type=1105 audit(1642612699.876:155): pid=4146 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 533.414140] audit: type=1106 audit(1642612700.099:156): pid=4146 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 533.414144] audit: type=1104 audit(1642612700.099:157): pid=4146 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 547.186562] audit: type=1131 audit(1642612713.873:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 547.242333] audit: type=1334 audit(1642612713.929:159): prog-id=0 op=UNLOAD
[ 615.682617] audit: type=1101 audit(1642612782.365:160): pid=4212 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 615.682886] audit: type=1110 audit(1642612782.369:161): pid=4212 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 615.684231] audit: type=1105 audit(1642612782.369:162): pid=4212 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 615.686937] audit: type=1106 audit(1642612782.372:163): pid=4212 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 615.686949] audit: type=1104 audit(1642612782.372:164): pid=4212 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 619.715236] audit: type=1101 audit(1642612786.399:165): pid=4219 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 619.715416] audit: type=1110 audit(1642612786.399:166): pid=4219 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 619.716725] audit: type=1105 audit(1642612786.402:167): pid=4219 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 619.719413] audit: type=1106 audit(1642612786.405:168): pid=4219 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 619.719417] audit: type=1104 audit(1642612786.405:169): pid=4219 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 625.163008] audit: type=1101 audit(1642612791.849:170): pid=4226 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 625.163438] audit: type=1110 audit(1642612791.849:171): pid=4226 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 625.164790] audit: type=1105 audit(1642612791.849:172): pid=4226 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 625.497897] audit: type=1106 audit(1642612792.182:173): pid=4226 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 625.497908] audit: type=1104 audit(1642612792.182:174): pid=4226 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 678.517546] audit: type=1101 audit(1642612845.205:175): pid=4258 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 678.517963] audit: type=1110 audit(1642612845.205:176): pid=4258 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 678.519323] audit: type=1105 audit(1642612845.205:177): pid=4258 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 678.564152] audit: type=1106 audit(1642612845.252:178): pid=4258 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 678.564177] audit: type=1104 audit(1642612845.252:179): pid=4258 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 686.693802] audit: type=1101 audit(1642612853.381:180): pid=4271 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 686.694021] audit: type=1110 audit(1642612853.381:181): pid=4271 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 686.695267] audit: type=1105 audit(1642612853.381:182): pid=4271 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 750.258930] device-mapper: uevent: version 1.0.3
[ 750.258989] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 751.562065] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[ 751.573462] JFS: nTxBlock = 8192, nTxLock = 65536
[ 751.616364] raid6: skip pq benchmark and using algorithm avx512x4
[ 751.616366] raid6: using avx512x2 recovery algorithm
[ 751.618647] xor: automatically using best checksumming function avx
[ 751.677241] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[ 752.183805] audit: type=1106 audit(1642612918.871:183): pid=4271 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 752.183818] audit: type=1104 audit(1642612918.871:184): pid=4271 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 805.265972] nouveau 0000:01:00.0: sec2: unhandled intr 00000010
[ 806.194108] ACPI: button: The lid device is not compliant to SW_LID.
[ 806.497683] PM: suspend entry (s2idle)
[ 806.499279] Filesystems sync: 0.001 seconds
[ 806.610099] Freezing user space processes ... (elapsed 0.002 seconds) done.
[ 806.612881] OOM killer disabled.
[ 806.612883] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 806.614202] printk: Suspending console(s) (use no_console_suspend to debug)
[ 806.667145] e1000e: EEE TX LPI TIMER: 00000011
[ 807.304059] ACPI: EC: interrupt blocked
[ 999.396918] ACPI: EC: interrupt unblocked
[ 1000.110979] pcieport 10000:e0:06.0: can't derive routing for PCI INT A
[ 1000.110984] nvme 10000:e1:00.0: PCI INT A: no GSI
[ 1000.130079] nouveau 0000:01:00.0: sec2: unhandled intr 00000010
[ 1000.184352] nvme nvme0: 16/0/0 default/read/poll queues
[ 1000.443458] OOM killer enabled.
[ 1000.443459] Restarting tasks ...
[ 1000.443962] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 1000.445039] done.
[ 1000.454069] thermal thermal_zone6: failed to read out thermal zone (-61)
[ 1000.529544] PM: suspend exit
[ 1000.530619] audit: type=1130 audit(1642613166.666:185): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1000.530622] audit: type=1131 audit(1642613166.666:186): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1000.627037] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Down
[ 1000.640934] audit: type=1130 audit(1642613166.776:187): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1001.918473] audit: type=1334 audit(1642613168.056:188): prog-id=35 op=LOAD
[ 1001.956920] audit: type=1130 audit(1642613168.093:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1003.669384] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 1000 Mbps Half Duplex, Flow Control: Rx/Tx
[ 1003.687190] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Down
[ 1006.158387] audit: type=1100 audit(1642613172.293:190): pid=8354 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="internetmosquito" exe="/usr/lib/gdm-session-worker" hostname=internetmosquito-latitude5421 addr=? terminal=/dev/tty1 res=success'
[ 1006.159866] audit: type=1101 audit(1642613172.296:191): pid=8354 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/lib/gdm-session-worker" hostname=internetmosquito-latitude5421 addr=? terminal=/dev/tty1 res=success'
[ 1006.162309] audit: type=1110 audit(1642613172.299:192): pid=8354 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="internetmosquito" exe="/usr/lib/gdm-session-worker" hostname=internetmosquito-latitude5421 addr=? terminal=/dev/tty1 res=success'
[ 1007.194944] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
[ 1007.195080] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s31f6: link becomes ready
[ 1010.057706] e1000e 0000:00:1f.6 enp0s31f6: Detected Hardware Unit Hang:
TDH <3>
TDT <5>
next_to_use <5>
next_to_clean <3>
buffer_info[next_to_clean]:
time_stamp <100025d50>
next_to_watch <3>
jiffies <100025f80>
next_to_watch.status <0>
MAC Status <40080283>
PHY Status <796d>
PHY 1000BASE-T Status <3800>
PHY Extended Status <3000>
PCI Status <10>
[ 1010.544614] audit: type=1131 audit(1642613176.679:193): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1011.975603] e1000e 0000:00:1f.6 enp0s31f6: Detected Hardware Unit Hang:
TDH <3>
TDT <5>
next_to_use <5>
next_to_clean <3>
next_to_watch <3>
jiffies <1000261c0>
PHY Status <796d>
PCI Status <10>
[ 1013.895634] e1000e 0000:00:1f.6 enp0s31f6: Detected Hardware Unit Hang:
TDH <3>
TDT <5>
next_to_use <5>
next_to_clean <3>
next_to_watch <3>
jiffies <100026400>
PHY Status <796d>
PCI Status <10>
[ 1016.029034] e1000e 0000:00:1f.6 enp0s31f6: Detected Hardware Unit Hang:
TDH <3>
TDT <5>
next_to_use <5>
next_to_clean <3>
next_to_watch <3>
jiffies <100026680>
PHY Status <796d>
PCI Status <10>
[ 1017.948593] ------------[ cut here ]------------
[ 1017.948618] NETDEV WATCHDOG: enp0s31f6 (e1000e): transmit queue 0 timed out
[ 1017.948644] WARNING: CPU: 12 PID: 0 at net/sched/sch_generic.c:477 dev_watchdog+0x29a/0x2b0
[ 1017.948661] Modules linked in: btrfs blake2b_generic xor raid6_pq ufs hfsplus hfs cdrom minix msdos jfs xfs libcrc32c dm_mod rfcomm cmac algif_hash algif_skcipher af_alg snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp hid_logitech_hidpp bnep snd_sof snd_soc_hdac_hda hid_sensor_custom snd_hda_ext_core snd_hda_codec_hdmi btusb snd_soc_acpi_intel_match btrtl snd_soc_acpi hid_sensor_hub btbcm soundwire_bus btintel cros_ec_ishtp joydev mousedev cros_ec snd_ctl_led bluetooth dell_rbtn intel_ishtp_loader snd_soc_core intel_tcc_cooling snd_hda_codec_realtek snd_compress x86_pkg_temp_thermal intel_powerclamp intel_ishtp_hid hid_logitech_dj ecdh_generic dell_laptop snd_hda_codec_generic hid_multitouch ac97_bus coretemp iwlmvm ee1004 snd_pcm_dmaengine mei_hdcp mei_wdt kvm_intel iTCO_wdt snd_hda_intel dell_wmi intel_pmc_bxt snd_intel_dspcfg iTCO_vendor_support snd_intel_sdw_acpi
[ 1017.948925] pmt_telemetry ledtrig_audio usbhid mac80211 pmt_class kvm intel_rapl_msr snd_hda_codec dell_smbios squashfs dcdbas dell_wmi_sysman qrtr firmware_attributes_class irqbypass ns loop dell_wmi_descriptor wmi_bmof crct10dif_pclmul libarc4 snd_hda_core crc32_pclmul ghash_clmulni_intel aesni_intel snd_hwdep crypto_simd cryptd intel_spi_pci intel_cstate iwlwifi snd_pcm vfat intel_spi intel_uncore spi_nor fat snd_timer pcspkr tpm_crb nouveau e1000e i915 psmouse cfg80211 uvcvideo i2c_i801 processor_thermal_device_pci_legacy mtd mei_me thunderbolt snd videobuf2_vmalloc processor_thermal_device i2c_smbus mei mxm_wmi intel_lpss_pci intel_ish_ipc videobuf2_memops processor_thermal_rfim tpm_tis ucsi_acpi soundcore drm_ttm_helper processor_thermal_mbox intel_lpss videobuf2_v4l2 tpm_tis_core typec_ucsi processor_thermal_rapl intel_ishtp rfkill ttm idma64 intel_pmt intel_rapl_common tpm videobuf2_common typec intel_gtt intel_soc_dts_iosf i2c_hid_acpi roles rng_core mac_hid wmi i2c_hid
[ 1017.949248] videodev int3403_thermal int340x_thermal_zone video mc intel_hid int3400_thermal acpi_thermal_rel sparse_keymap acpi_tad acpi_pad ipmi_devintf ipmi_msghandler fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw rtsx_pci_sdmmc atkbd mmc_core libps2 i8042 crc32c_intel rtsx_pci vmd xhci_pci serio
[ 1017.949385] CPU: 12 PID: 0 Comm: swapper/12 Not tainted 5.15.12-1-MANJARO #1 571dd42c8dc9cd64db8c196fe0197a839c671c46
[ 1017.949398] Hardware name: Dell Inc. Latitude 5421/0DF8RX, BIOS 1.5.0 08/05/2021
[ 1017.949403] RIP: 0010:dev_watchdog+0x29a/0x2b0
[ 1017.949416] Code: ff ff 48 8b 1c 24 c6 05 4d 21 3e 01 01 48 89 df e8 bb 86 f9 ff 44 89 e9 48 89 de 48 c7 c7 88 62 55 a8 48 89 c2 e8 28 19 19 00 <0f> 0b e9 5b ff ff ff 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 40 00
[ 1017.949423] RSP: 0018:ffffc019804b0ea0 EFLAGS: 00010246
[ 1017.949434] RAX: 0000000000000000 RBX: ffff9eef8534c000 RCX: 0000000000000000
[ 1017.949441] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[ 1017.949447] RBP: ffff9eef8534c41c R08: 0000000000000000 R09: 0000000000000000
[ 1017.949453] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9eef85320880
[ 1017.949459] R13: 0000000000000000 R14: ffff9eef8534c4c0 R15: 0000000000000001
[ 1017.949465] FS: 0000000000000000(0000) GS:ffff9ef6ef700000(0000) knlGS:0000000000000000
[ 1017.949473] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1017.949479] CR2: 00007fc58a3a1800 CR3: 0000000264010006 CR4: 0000000000770ee0
[ 1017.949487] PKRU: 55555554
[ 1017.949492] Call Trace:
[ 1017.949498] <IRQ>
[ 1017.949505] ? pfifo_fast_reset+0x140/0x140
[ 1017.949516] ? pfifo_fast_reset+0x140/0x140
[ 1017.949525] call_timer_fn+0x24/0x130
[ 1017.949539] __run_timers+0x1fc/0x290
[ 1017.949552] run_timer_softirq+0x19/0x30
[ 1017.949563] __do_softirq+0xcd/0x2ca
[ 1017.949576] irq_exit_rcu+0x9b/0xc0
[ 1017.949586] sysvec_apic_timer_interrupt+0x72/0x90
[ 1017.949597] </IRQ>
[ 1017.949602] <TASK>
[ 1017.949606] asm_sysvec_apic_timer_interrupt+0x12/0x20
[ 1017.949616] RIP: 0010:cpuidle_enter_state+0xc7/0x380
[ 1017.949627] Code: 8b 3d 25 ac 71 58 e8 48 fe 7d ff 49 89 c5 0f 1f 44 00 00 31 ff e8 e9 0b 7e ff 45 84 ff 0f 85 e8 01 00 00 fb 66 0f 1f 44 00 00 <45> 85 f6 0f 88 1f 01 00 00 49 63 d6 4c 2b 2c 24 48 8d 04 52 48 8d
[ 1017.949634] RSP: 0018:ffffc019801c3ea8 EFLAGS: 00000246
[ 1017.949643] RAX: 0000000000000000 RBX: 0000000000000003 RCX: 0000000000000000
[ 1017.949648] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[ 1017.949653] RBP: ffff9ef6ef73c108 R08: 0000000000000000 R09: 0000000000000000
[ 1017.949659] R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffa8d48740
[ 1017.949664] R13: 000000ed02761eb0 R14: 0000000000000003 R15: 0000000000000000
[ 1017.949677] ? cpuidle_enter_state+0xb7/0x380
[ 1017.949687] cpuidle_enter+0x29/0x40
[ 1017.949697] do_idle+0x1e9/0x280
[ 1017.949709] cpu_startup_entry+0x19/0x20
[ 1017.949717] secondary_startup_64_no_verify+0xc2/0xcb
[ 1017.949733] </TASK>
[ 1017.949738] ---[ end trace 94b16bb8f4f30c0a ]---
[ 1017.949914] e1000e 0000:00:1f.6 enp0s31f6: Reset adapter unexpectedly
[ 1021.204213] audit: type=1130 audit(1642613187.339:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1021.968550] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[ 1024.827788] audit: type=1100 audit(1642613190.963:195): pid=8421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1024.828775] audit: type=1101 audit(1642613190.966:196): pid=8421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="internetmosquito" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1024.829306] audit: type=1110 audit(1642613190.966:197): pid=8421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1024.833823] audit: type=1105 audit(1642613190.969:198): pid=8421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Honestly I’m starting to think this is not related with the r8169 module but something wrong when waking up instead, but since I blacklisted r8169 I’m not sure how to install it again with mhwd
