Hi
Since a number of days my wired connection started to continuously connects and disconnects. This behavior does not happen when connected with wifi.
I am on a laptop and use a usb-c dongle with a ethernet port.
Checking sudo journalctl -e -u NetworkManager is weird, as sometimes at the moment of disconnection there is some output, but many other times there is nothing when it disconnects.
#################### inxi -Fxzc0 ########################
System: Kernel: 5.10.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: GNOME 3.38.3
Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: XPS 13 9360 v: N/A serial: <filter>
Mobo: Dell model: 05JK94 v: A00 serial: <filter> UEFI: Dell v: 2.13.0 date: 11/14/2019
Battery: ID-1: BAT0 charge: 47.5 Wh condition: 47.5/60.0 Wh (79%) model: SMP DELL TP1GT61
status: Full
CPU: Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check rev: 9 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
Speed: 2267 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 2267 2: 700 3: 2311 4: 2275
Graphics: Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo bus ID: 1-5:4
Display: x11 server: X.org 1.20.10 driver: loaded: intel unloaded: modesetting
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Device-2: Logitech HD Webcam C525 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 3-1.4:4
Sound Server: ALSA v: k5.10.18-1-MANJARO
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks driver: ath10k_pci v: kernel port: f040 bus ID: 3a:00.0
IF: wlp58s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb bus ID: 1-3:3
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 4-1.2:3
IF: enp57s0u1u2 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: vpn0 state: down mac: N/A
Bluetooth: Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus ID: 1-3:3
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 953.87 GiB used: 206.94 GiB (21.7%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 953.87 GiB temp: 39.9 C
Partition: ID-1: / size: 124.99 GiB used: 61.94 GiB (49.6%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4
ID-3: /home size: 803.53 GiB used: 144.97 GiB (18.0%) fs: ext4 dev: /dev/nvme0n1p3
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 36.2 MiB (0.4%) dev: /dev/nvme0n1p1
Sensors: System Temperatures: cpu: 56.5 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 245 Uptime: 3h 22m Memory: 7.5 GiB used: 5.31 GiB (70.8%) Init: systemd
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1589 Client: shell wrapper
v: 5.1.0-release inxi: 3.3.01
