Wired 8bitdo Ultimate 2C only works in dinput mode
You can toggle the mode by pressing “X” or “B” when you plug it in, but if I press “X” the led flashes and it doesn’t work (in either steam games or in the browser gamepad tester). Googling tells me that I need a kernel module called “xpad” but when I search for it in software install GUI it doesn’t seem to exist? It works ok in dinput mode except rumble doesn’t work at all (and also the star and square buttons don’t register in gamepad stester. Did advice on how to support this change recently? I looked and didn’t find anything. How do I enable support for xinput devices?
You probably need the xone-dkms AUR package for these controllers. Just a wild guess.
