Just wanted to inform you guys that winetricks is broken on Lutris. I am using the latest version from the repo on Manjaro gnome. This is the log
lutris
2022-06-15 13:00:45,915: Starting Lutris 0.5.10.1
2022-06-15 13:00:45,944: No folder at /home/corey/.local/share/lutris/runners/retroarch/
2022-06-15 13:00:45,976: Using NVIDIA drivers 515.48.07 for x86_64
2022-06-15 13:00:45,977: GPU: NVIDIA GeForce GTX 1060 6GB
2022-06-15 13:00:45,977: GPU: 10DE:1C03 10DE:11D7 (nvidia drivers)
2022-06-15 13:00:46,033: Startup complete
2022-06-15 13:00:55,658: The game doesn't have an executable
Started initial process 54478 from /home/corey/.local/share/lutris/runtime/winetricks/winetricks --unattended
Start monitoring process.
Executing mkdir -p /mnt/Game Drive
warning: You are using a 64-bit WINEPREFIX. Note that many verbs only install 32-bit versions of packages. If you encounter problems, please retest in a clean 32-bit WINEPREFIX before reporting a bug.
Using winetricks 20220411-next - sha256sum: 50b745d7f46ead56fd0c9e6d753d53ea0ae368c988434c25d65fec66307e5d4f with wine-7.2-1-g2b48f296545 (Staging) and WINEARCH=win64
zenity: symbol lookup error: /usr/lib/libwebkit2gtk-4.0.so.37: undefined symbol: gst_codec_utils_caps_get_mime_codec
winetricks GUI enabled, using zenity
Monitored process exited.
Initial process has exited (return code: 0)
Exit with return code 0
