Winecfg crashed on Manjaro Linux
Whenever I start winecfg on manjaro linux and click on display, it crashes with an error.
This is my system info.
█  ████████    cz@cz
██████████████████  ████████    OS: Manjaro Linux x86_64
██████████████████  ████████    Host: 21LF (ThinkBook 14 G6+ AHP)
████████            ████████    Kernel: Linux 6.12.44-3-MANJARO
████████  ████████  ████████    Uptime: 30 mins
████████  ████████  ████████    Packages: 1107 (pacman)[stable]
████████  ████████  ████████    Shell: zsh 5.9
████████  ████████  ████████    Display (LEN8AAF): 3072x1920 @ 60 Hz (as 1536x960)]
████████  ████████  ████████    DE: GNOME 48.4
████████  ████████  ████████    WM: Mutter (Wayland)
████████  ████████  ████████    WM Theme: default-pure
████████  ████████  ████████    Theme: KvLibadwaitaMaiaDark [Qt], adw-gtk3-dark [G]
████████  ████████  ████████    Icons: Papirus-Dark-Maia [Qt], Papirus-Dark-Maia []
                                Font: Noto Sans (11pt) [GTK2/3/4]
                                Cursor: Bibata-Modern-Classic (24px)
                                Terminal: GNOME Terminal 3.56.2
                                Terminal Font: Hack Nerd Font (11pt)
                                CPU: AMD Ryzen 7 8845H (16) @ 5.14 GHz
                                GPU: AMD Radeon 780M Graphics [Integrated]
                                Memory: 6.93 GiB / 27.21 GiB (25%)
                                Swap: 0 B / 6.00 GiB (0%)
                                Disk (/): 33.42 GiB / 488.70 GiB (7%) - ext4
                                Disk (/mnt): 378.10 GiB / 448.99 GiB (84%) - fusebk
                                Local IP (enp2s0): 10.40.40.175/16
                                Battery (L23N4PG11L0): 97% [AC Connected]
                                Locale: zh_CN.UTF-8
I have restarted it several times, but the problem still cannot be resolved.
Here is the crash debugging information I used with the winedbg --gdb winecfg command.
winedbg --gdb winecfg  ✔
WineDbg starting on pid 02e4
02e4:02e8: create process 'C:\windows\system32\winecfg.exe'/0000000000000000 @00000
00140012780 (1527808<11221>)
02e0:fixme:dbghelp:elf_search_auxv can't find symbol in module
02e4:02e8: create thread I @0000000140012780
GNU gdb (GDB) 16.3
Copyright (C) 2024 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word".
02e4:02e8: loads DLL C:\windows\system32\ntdll.dll @00006FFFFFBF0000 (4145152<12952
02e4:02e8: loads DLL C:\windows\system32\kernel32.dll @00006FFFFFA10000 (1839104<24
228>)
02e4:02e8: loads DLL C:\windows\system32\kernelbase.dll @00006FFFFF3C0000 (6520832<
26018>)
02e4:02e8: loads DLL C:\windows\system32\advapi32.dll @00006FFFFF290000 (1171456<10
097>)
02e4:02e8: loads DLL C:\windows\system32\msvcrt.dll @00006FFFFEEE0000 (3735552<1851
2>)
02e4:02e8: loads DLL C:\windows\system32\sechost.dll @00006FFFFEE40000 (573440<4041
02e4:02e8: loads DLL C:\windows\system32\ucrtbase.dll @00006FFFFE9F0000 (4386816<23
664>)
02e4:02e8: loads DLL C:\windows\winsxs\amd64_microsoft.windows.common-controls_6595
b64144ccf1df_6.0.2600.2982_none_deadbeef\comctl32.dll @00006FFFFAA30000 (5931008<23
464>)
02e4:02e8: loads DLL C:\windows\system32\gdi32.dll @00006FFFFE080000 (2924544<12326
02e4:02e8: loads DLL C:\windows\system32\user32.dll @00006FFFFDA70000 (6283264<3105
9>)
02e4:02e8: loads DLL C:\windows\system32\win32u.dll @00006FFFFDA00000 (335872<3402>
02e4:02e8: loads DLL C:\windows\system32\imm32.dll @00006FFFFB5F0000 (532480<4349>)
02e4:02e8: loads DLL C:\windows\system32\oleaut32.dll @00006FFFFBB80000 (3424256<19
138>)
02e4:02e8: loads DLL C:\windows\system32\ole32.dll @00006FFFFE520000 (4075520<22980
02e4:02e8: loads DLL C:\windows\system32\combase.dll @00006FFFFE360000 (1736704<128
99>)
02e4:02e8: loads DLL C:\windows\system32\rpcrt4.dll @00006FFFFD740000 (2813952<1834
9>)
02e4:02e8: loads DLL C:\windows\system32\cryptbase.dll @00006FFFFD700000 (151552<99
7>)
02e4:02e8: loads DLL C:\windows\system32\coml2.dll @00006FFFFD690000 (372736<6286>)
02e4:02e8: loads DLL C:\windows\system32\comdlg32.dll @00006FFFFC0E0000 (2482176<14
837>)
02e4:02e8: loads DLL C:\windows\system32\shell32.dll @00006FFFFC8B0000 (14434304<33
104>)
02e4:02e8: loads DLL C:\windows\system32\shlwapi.dll @00006FFFFC780000 (1171456<185
56>)
02e4:02e8: loads DLL C:\windows\system32\shcore.dll @00006FFFFC710000 (339968<3484>
02e4:02e8: loads DLL C:\windows\system32\uxtheme.dll @00006FFFFB190000 (839680<5215
02e4:02e8: loads DLL C:\windows\system32\winmm.dll @00006FFFFBF10000 (1744896<7216>
02e4:02e8: loads DLL C:\windows\system32\msacm32.dll @00006FFFFBAF0000 (520192<3074
02e4:02e8: loads DLL C:\windows\system32\tzres.dll @0000000180000000 (0<0>)
02e4:02e8: unload DLL @0000000180000000
02e4:02e8: loads DLL c:\windows\system32\winex11.drv @00006FFFFB270000 (81920<347>)
warning: remote target does not support file transfer, attempting to access files from local filesystem.
Reading symbols from /home/cz/.wine/drive_c/windows/system32/winecfg.exe...
warning: Could not load shared library symbols for 34 libraries, e.g. .
Use the "info sharedlibrary" command to see the complete listing.
Do you need "set solib-search-path" or "set sysroot"?
This GDB supports auto-downloading debuginfo from the following URLs:
  <https://debuginfod.archlinux.org>
Enable debuginfod for this session? (y or [n]) [answered N; input not from terminal]
Debuginfod has been disabled.
To make this setting permanent, add 'set debuginfod enabled off' to .gdbinit.
0x00006fffffc00bb9 in process_breakpoint ()
   from /home/cz/.wine/drive_c/windows/system32/ntdll.dll
Wine-gdb> bt
#0 0x00006fffffc00bb9 in process_breakpoint ()
#1 0x00006fffffc47cf5 in loader_init (context=context@entry=0x7ffffe2ffb00,
    entry=entry@entry=0x7ffffe2ffb80) at ../wine/dlls/ntdll/loader.c:4517
#2 0x00006fffffc05644 in LdrInitializeThunk (context=0x7ffffe2ffb00,
    unk2=<optimized out>, unk3=<optimized out>, unk4=<optimized out>)
    at ../wine/dlls/ntdll/signal_x86_64.c:1019
#3 0x0000000000000000 in ?? ()
Wine-gdb> continue
Continuing.
02e4:02e8: loads DLL C:\windows\system32\msimg32.dll @00006FFFF5C20000 (98304<741>)
Program received signal SIGSEGV, Segmentation fault.
0x00006ffffe09cbc2 in GPOS_apply_MarkToMark (analysis=<optimized out>,
    glyph_count=<optimized out>, look=<optimized out>, glyphs=<optimized out>,
    glyph_index=<optimized out>, ppem=<optimized out>, pt=<optimized out>)
    at ../wine/dlls/gdi32/uniscribe/opentype.c:2096
warning: 2096 ../wine/dlls/gdi32/uniscribe/opentype.c: No such file or directory
Wine-gdb> bt full
#0 0x00006ffffe09cbc2 in GPOS_apply_MarkToMark (analysis=<optimized out>,
        mark2_index = <optimized out>
        offset = <optimized out>
        mark_index = 4
        mmpf1 = <optimized out>
        j = 0
        rc = <optimized out>
        write_dir = <optimized out>
        __func__ = "GPOS_apply_MarkToMark"
#1 GPOS_apply_lookup (script_cache=script_cache@entry=0x7ffffe950c30,
    lpotm=lpotm@entry=0x7ffffe9515e0, lplogfont=lplogfont@entry=0x7ffffe950c44,
    analysis=<optimized out>, analysis@entry=0x7ffffe9505c4,
    piAdvance=piAdvance@entry=0x7ffffe328760, lookup=0x7ffffe95ee6c,
    lookup_index=lookup_index@entry=30, glyphs=glyphs@entry=0x7ffffe950650,
    glyph_index=glyph_index@entry=0, glyph_count=glyph_count@entry=2,
    pGoffset=pGoffset@entry=0x7ffffe950b90)
    at ../wine/dlls/gdi32/uniscribe/opentype.c:2533
        devX = 6.9533543048693257e-310
        devY = 8.7392385563728838e-315
        desU = {x = 0, y = 0}
        look = 0x0
        ppem = <optimized out>
        type = <optimized out>
        __func__ = "GPOS_apply_lookup"
#2 0x00006ffffe0ae3f1 in OpenType_apply_GPOS_lookup (
    script_cache=script_cache@entry=0x7ffffe950c30, otm=otm@entry=0x7ffffe9515e0,
    logfont=logfont@entry=0x7ffffe950c44, analysis=analysis@entry=0x7ffffe9505c4,
    advance=advance@entry=0x7ffffe328760, lookup_index=30,
    glyphs=glyphs@entry=0x7ffffe950650, glyph_index=glyph_index@entry=0,
    glyph_count=glyph_count@entry=2, goffset=goffset@entry=0x7ffffe950b90)
    at ../wine/dlls/gdi32/uniscribe/opentype.c:2564
        header = <optimized out>
        lookup = <optimized out>
#3 0x00006ffffe0b53dd in GPOS_apply_feature (psc=0x7ffffe950c30,
    otm=0x7ffffe9515e0, logfont=0x7ffffe950c44, analysis=0x7ffffe9505c4,
    advance=<optimized out>, feature=<optimized out>, glyphs=<optimized out>,
    glyph_count=<optimized out>, goffset=<optimized out>)
--Type <RET> for more, q to quit, c to continue without paging--
    at ../wine/dlls/gdi32/uniscribe/shape.c:880
        start_idx = <optimized out>
        i = <optimized out>
        j = 0
        __func__ = "GPOS_apply_feature"
#4 SHAPE_ApplyOpenTypePositions (hdc=hdc@entry=0x1010081, psc=0x7ffffe950c30,
    psa=psa@entry=0x7ffffe9505c4, pwGlyphs=pwGlyphs@entry=0x7ffffe950650,
    cGlyphs=cGlyphs@entry=2, piAdvance=piAdvance@entry=0x7ffffe328760,
    at ../wine/dlls/gdi32/uniscribe/shape.c:3457
        feature = 0x7ffffe97ede0
        rpRangeProperties = <optimized out>
        i = <optimized out>
#5 0x00006ffffe0b8886 in ScriptPlaceOpenType (hdc=hdc@entry=0x1010081,
    psc=psc@entry=0x7ffffe328700, psa=psa@entry=0x7ffffe9505c4,
    tagScript=<optimized out>, tagLangSys=<optimized out>, tagLangSys@entry=0,
    rcRangeChars=rcRangeChars@entry=0x0,
    rpRangeProperties=rpRangeProperties@entry=0x0, cRanges=cRanges@entry=0,
    pwcChars=pwcChars@entry=0x0, pwLogClust=pwLogClust@entry=0x0,
    pCharProps=pCharProps@entry=0x0, cChars=cChars@entry=0,
    pGlyphProps=pGlyphProps@entry=0x7ffffe9506e0, cGlyphs=cGlyphs@entry=2,
    pGoffset=pGoffset@entry=0x7ffffe950b90, pABC=pABC@entry=0x7ffffe328738)
    at ../wine/dlls/gdi32/uniscribe/usp10.c:3396
        hr = <optimized out>
        i = 2
        once = 0
        __func__ = "ScriptPlaceOpenType"
#6 0x00006ffffe0b8521 in ScriptPlace (hdc=hdc@entry=0x1010081,
    psc=psc@entry=0x7ffffe328700, pwGlyphs=pwGlyphs@entry=0x7ffffe950650,
    cGlyphs=2, psva=psva@entry=0x7ffffe9506b0, psa=0x7ffffe9505c4,
    pGoffset=pGoffset@entry=0x7ffffe950b90, pABC=0x7ffffe328738)
    at ../wine/dlls/gdi32/uniscribe/usp10.c:3442
        glyphProps = 0x7ffffe9506e0
        i = <optimized out>
        __func__ = "ScriptPlace"
#7 0x00006ffffe0ba51e in ScriptStringAnalyse (hdc=<optimized out>,
    hdc@entry=0x1010081, pString=<optimized out>, cString=<optimized out>,
    cGlyphs=<optimized out>, iCharset=<optimized out>, iCharset@entry=-1,
    dwFlags=<optimized out>, dwFlags@entry=4256, iReqWidth=<optimized out>,
    iReqWidth@entry=-1, psControl=<optimized out>, psControl@entry=0x0,
    psState=<optimized out>, psState@entry=0x0, piDx=<optimized out>,
    piDx@entry=0x0, pTabdef=<optimized out>, pTabdef@entry=0x0,
    pbInClass=<optimized out>, pbInClass@entry=0x0, pssa=<optimized out>,
    pssa@entry=0x7ffffe950578) at ../wine/dlls/gdi32/uniscribe/usp10.c:2051
        sc = <optimized out>
        cChar = <optimized out>
        piAdvance = 0x7ffffe328760
        psva = <optimized out>
        pGoffset = 0x7ffffe950b90
        originalFont = 0x0
        pStr = <optimized out>
        glyphs = <optimized out>
        numGlyphsReturned = 2
        numGlyphs = <optimized out>
        pwLogClust = <optimized out>
        tab_x = <optimized out>
        analysis = 0x7ffffe3285e0
        sControl = {uDefaultLanguage = 0, fContextDigits = 0,
          fInvertPreBoundDir = 0, fInvertPostBoundDir = 0, fLinkStringBefore = 0,
          fLinkStringAfter = 0, fNeutralOverride = 0, fNumericOverride = 0,
          fLegacyBidiClass = 0, fMergeNeutralItems = 0, fUseStandardBidi = 0,
          fReserved = 0}
        sState = {uBidiLevel = 0, fOverrideDirection = 0, fInhibitSymSwap = 0,
          fCharShape = 0, fDigitSubstitute = 0, fInhibitLigate = 0,
          fDisplayZWG = 0, fArabicNumContext = 0, fGcpClusters = 0,
          fReserved = 0, fEngineReserved = 0}
        i = 0
        num_items = <optimized out>
        BidiLevel = <optimized out>
        iString = <optimized out>
        __func__ = "ScriptStringAnalyse"
#8 0x00006ffffaa53936 in EDIT_UpdateUniscribeData (line=<optimized out>,
    es=<optimized out>, dc=<optimized out>) at ../wine/dlls/comctl32/edit.c:381
        length = <optimized out>
        old_font = 0x18a002d
        udc = 0x1010081
        line_def = <optimized out>
#9 EDIT_UpdateUniscribeData (es=<optimized out>, dc=<optimized out>,
    line=<optimized out>) at ../wine/dlls/comctl32/edit.c:361
        old_font = <optimized out>
        udc = <optimized out>
#10 0x00006ffffaa50c7f in EDIT_CalcLineWidth_SL (es=0x7ffffe950480)
    at ../wine/dlls/comctl32/edit.c:748
No locals.
#11 EDIT_EM_ReplaceSel (es=0x7ffffe950480, can_undo=0,
    lpsz_replace=<optimized out>, strl=<optimized out>, send_update=0,
    honor_limit=0) at ../wine/dlls/comctl32/edit.c:2537
        fw = 28
        tl = <optimized out>
        utl = <optimized out>
        s = 0
        e = 0
        i = <optimized out>
        size = <optimized out>
        p = <optimized out>
        hrgn = 0x0
        buf = <optimized out>
        bufl = <optimized out>
        __func__ = "EDIT_EM_ReplaceSel"
#12 0x00006ffffaa57167 in EDIT_WM_SetText (es=0x7ffffe950480,
    text=0x7ffffe2fdc40 L"96") at ../wine/dlls/comctl32/edit.c:3823
        __func__ = "EDIT_WM_SetText"
#13 EDIT_WindowProc (hwnd=hwnd@entry=0x40052, msg=msg@entry=12,
    wParam=wParam@entry=0, lParam=lParam@entry=140737457937472)
    at ../wine/dlls/comctl32/edit.c:4898
        es = 0x7ffffe950480
        result = 0
        rect = <optimized out>
        pt = {x = 0, y = 0}
        __func__ = "EDIT_WindowProc"
#14 0x00006ffffdacb73e in WINPROC_wrapper (proc=0x6ffffaa55920 <EDIT_WindowProc>,
    hwnd=0x40052, msg=12, wParam=0, lParam=140737457937472)
    at ../wine/dlls/user32/winproc.c:86
No locals.
#15 call_window_proc (hwnd=0x40052, msg=12, wp=0, lp=140737457937472,
    result=0x7ffffe2fe0d8, arg=0x6ffffaa55920 <EDIT_WindowProc>)
    at ../wine/dlls/user32/winproc.c:111
        proc = 0x6ffffaa55920 <EDIT_WindowProc>
        __func__ = "call_window_proc"
#16 0x00006ffffdac523c in WINPROC_CallProcAtoW (
    callback=callback@entry=0x6ffffdacb710 <call_window_proc>, hwnd=0x40052,
    msg=12, wParam=<optimized out>, lParam=140737457938992,
    result=result@entry=0x7ffffe2fe0d8, arg=0x6ffffaa55920 <EDIT_WindowProc>,
    mapping=WMCHAR_MAP_SENDMESSAGE) at ../wine/dlls/user32/winproc.c:325
        buffer = L"96\000\000巬ﺔ翿\000\n\000\000\000쉴ᅢ濿\000\xdc80︯翿\000繯ﶫy\000\002\000\002\000袱ᅢt\000\201\002\000\000\000\000\000\000︯翿\000ﺢ濿\000\xde60︯翿\000ퟠﶰ濿\000\xde20︯翿\000\xde30︯翿\000\000\000\000\000巼ﺔ翿\000\034\000\000\000㭖ﶭ濿\000䔀︲翿\000insx\xde20︯翿\000ﺥ濿\000\002\000\000\000ﺥ濿\000t.wi\xde60︯翿\000p\000\001\000巼ﺔ翿\000\\\000\000\000\002\000\000\000\000\000\000\000\002\000\000\000\000\000\000\000㧯ﺥ濿\000\002", '\000' <repeats 22 times>, " \000\000\000\000\x17eaﶱ濿\000ﺨ濿\000ﺥ濿\000\xdea0︯翿\000︯翿\000\xdec0︯翿\000\xdec0︯翿\000"...
        strA = <optimized out>
        lenW = 6
        lenA = 3
        ptr = <optimized out>
        ret = 0
        __func__ = "WINPROC_CallProcAtoW"
#17 0x00006ffffdad1687 in dispatch_win_proc_params (
    params=params@entry=0x7ffffe2fe1a0) at ../wine/dlls/user32/winproc.c:722
        context = 0x6011
        result = 0
#18 0x00006ffffdad155c in dispatch_send_message (
    params=params@entry=0x7ffffe2fe1a0, wparam=wparam@entry=0,
    lparam=lparam@entry=140737457938992) at ../wine/dlls/user32/message.c:568
        thread_info = 0x7ffc0800
        prev_source = <optimized out>
        retval = 0
#19 0x00006ffffdab7b20 in SendMessageA (hwnd=<optimized out>,
    msg=<optimized out>, msg@entry=12, wparam=<optimized out>, wparam@entry=0,
    lparam=lparam@entry=140737457938992) at ../wine/dlls/user32/message.c:609
        params = {func = 0xffff0030, hwnd = 0x40052, msg = 12, wparam = 0,
          lparam = 140737457938992, ansi = 1, ansi_dst = 0,
          mapping = WMCHAR_MAP_SENDMESSAGE, dpi_context = 24593,
          procA = 0xffff0030, procW = 0x6ffffaa55920 <EDIT_WindowProc>}
        retval = <optimized out>
#20 0x00006ffffdab87ac in SendDlgItemMessageA (hwnd=0x30090, id=1108, msg=12,
    wParam=0, lParam=140737457938992) at ../wine/dlls/user32/dialog.c:1327
        hwndCtrl = <optimized out>
#21 SetDlgItemInt (hwnd=hwnd@entry=0x30090, id=id@entry=1108,
    value=<optimized out>, fSigned=fSigned@entry=0)
    at ../wine/dlls/user32/dialog.c:1394
        str = "96\000\000\000\000\000\000C\331\000@\001\000\000\000\000\000\000@"
#22 0x000000014000520b in init_dpi_editbox (hDlg=0x30090)
    at ../wine/programs/winecfg/x11drvdlg.c:249
        dwLogpixels = <optimized out>
        __func__ = "init_dpi_editbox"
#23 GraphDlgProc (hDlg=hDlg@entry=0x30090, uMsg=uMsg@entry=272,
    wParam=wParam@entry=196756, lParam=lParam@entry=140737464530200)
    at ../wine/programs/winecfg/x11drvdlg.c:344
No locals.
#24 0x00006ffffdacb60a in WINPROC_wrapper (proc=0x1400050c0 <GraphDlgProc>,
    hwnd=0x30090, msg=272, wParam=196756, lParam=140737464530200)
No locals.
#25 call_dialog_proc (hwnd=hwnd@entry=0x30090, msg=msg@entry=272,
    wp=wp@entry=196756, lp=lp@entry=140737464530200,
    result=result@entry=0x7ffffe2fe478, arg=0x1400050c0 <GraphDlgProc>)
    at ../wine/dlls/user32/winproc.c:130
        context = 0x6011
        proc = 0x1400050c0 <GraphDlgProc>
        ret = <optimized out>
        __func__ = "call_dialog_proc"
#26 0x00006ffffdac4edc in WINPROC_CallDlgProcW (hwnd=hwnd@entry=0x30090,
    msg=msg@entry=272, wParam=wParam@entry=196756,
    lParam=lParam@entry=140737464530200) at ../wine/dlls/user32/winproc.c:951
        func = <optimized out>
        proc = 0xffff002f
        result = 123145263030710
#27 0x00006ffffdabdb67 in USER_DefDlgProcW (hwnd=0x30090, msg=272, wParam=196756,
    lParam=140737464530200) at ../wine/dlls/user32/defdlg.c:375
        dlgInfo = 0x7ffffe94eda0
        result = <optimized out>
#28 USER_DefDlgProc (hwnd=0x30090, msg=272, wParam=196756,
    lParam=140737464530200, unicode=1) at ../wine/dlls/user32/defdlg.c:420
No locals.
#29 0x00006ffffda8e955 in DialogWndProcW (hwnd=<optimized out>,
    msg=<optimized out>, wParam=<optimized out>, lParam=<optimized out>)
    at ../wine/dlls/user32/defdlg.c:438
No locals.
#30 0x00006ffffdacb73e in WINPROC_wrapper (
    proc=0x6fffffc08cd0 <NtdllDialogWndProc_W>, hwnd=0x30090, msg=272,
    wParam=196756, lParam=140737464530200) at ../wine/dlls/user32/winproc.c:86
No locals.
#31 call_window_proc (hwnd=0x30090, msg=272, wp=196756, lp=140737464530200,
    result=result@entry=0x7ffffe2fe638, arg=0x6fffffc08cd0 <NtdllDialogWndProc_W>)
        proc = 0x6fffffc08cd0 <NtdllDialogWndProc_W>
#32 0x00006ffffdad16a4 in dispatch_win_proc_params (
    params=params@entry=0x7ffffe2fe700) at ../wine/dlls/user32/winproc.c:725
        context = 0x6011
        result = 0
#33 0x00006ffffdad155c in dispatch_send_message (
    params=params@entry=0x7ffffe2fe700, wparam=wparam@entry=196756,
    lparam=lparam@entry=140737464530200) at ../wine/dlls/user32/message.c:568
        retval = 0
#34 0x00006ffffdab7e6f in SendMessageW (hwnd=hwnd@entry=0x30090,
    msg=msg@entry=272, wparam=196756, lparam=lparam@entry=140737464530200)
    at ../wine/dlls/user32/message.c:587
        params = {func = 0xffff000a, hwnd = 0x30090, msg = 272, wparam = 196756,
          lparam = 140737464530200, ansi = 0, ansi_dst = 0,
          procA = 0x6fffffc08cc0 <NtdllDialogWndProc_A>,
          procW = 0x6fffffc08cd0 <NtdllDialogWndProc_W>}
#35 0x00006ffffda87e28 in DIALOG_CreateIndirect (hInst=0x140000000,
    dlgTemplate=<optimized out>, dlgTemplate@entry=0x7ffffe94fed0,
    owner=<optimized out>, owner@entry=0x400f8,
    dlgProc=0x1400050c0 <GraphDlgProc>, param=param@entry=140737464530200,
    unicode=unicode@entry=1, modal_owner=modal_owner@entry=0x0)
    at ../wine/dlls/user32/dialog.c:679
        focus = <optimized out>
        capture = <optimized out>
        hwnd = 0x30090
        rect = {left = 0, top = 0, right = 390, bottom = 413}
        pos = {x = 0, y = 0}
        template = {style = 1073808448, exStyle = <optimized out>,
          helpId = <optimized out>, nbItems = <optimized out>,
          x = <optimized out>, y = <optimized out>, cx = <optimized out>,
          cy = <optimized out>, menuName = <optimized out>,
          className = <optimized out>, caption = <optimized out>,
          pointSize = <optimized out>, weight = <optimized out>,
          italic = <optimized out>, faceName = <optimized out>,
          dialogEx = <optimized out>}
        dlgInfo = <optimized out>
        units = <optimized out>
        disabled_owner = 0x0
        hMenu = <optimized out>
        hUserFont = <optimized out>
        flags = 0
        xBaseUnit = <optimized out>
        yBaseUnit = <optimized out>
        __func__ = "DIALOG_CreateIndirect"
#36 0x00006ffffda85ac4 in CreateDialogIndirectParamAorW (hInst=<optimized out>,
    dlgTemplate=0x7ffffe94fed0, owner=0x400f8, dlgProc=<optimized out>,
    param=140737464530200, flags=0) at ../wine/dlls/user32/dialog.c:754
No locals.
#37 CreateDialogIndirectParamW (hInst=<optimized out>,
    dlgTemplate=dlgTemplate@entry=0x7ffffe94fed0, owner=owner@entry=0x400f8,
    dlgProc=<optimized out>, param=param@entry=140737464530200)
    at ../wine/dlls/user32/dialog.c:772
No locals.
#38 0x00006ffffaa9423b in HPSP_create_page (hpsp=0x7ffffe947510,
    template=0x7ffffe94fed0, parent=0x400f8)
    at ../wine/dlls/comctl32/propsheet.c:506
        hwnd = <optimized out>
#39 PROPSHEET_CreatePage (hwndParent=hwndParent@entry=0x400f8,
    index=index@entry=2, psInfo=psInfo@entry=0x7ffffe947ff0, hpsp=0x7ffffe947510)
    at ../wine/dlls/comctl32/propsheet.c:1618
        pTemplate = 0x140088f4c
        hwndPage = <optimized out>
        resSize = 658
        pTemplateCopy = 0x7ffffe94fed0
        __func__ = "PROPSHEET_CreatePage"
#40 0x00006ffffaa98251 in PROPSHEET_SetCurSel (hwndDlg=hwndDlg@entry=0x400f8,
    index=2, skipdir=skipdir@entry=1, hpage=hpage@entry=0x0)
    at ../wine/dlls/comctl32/propsheet.c:2169
        psn = {hdr = {hwndFrom = 0x400f8, idFrom = 0, code = 4294967096},
          lParam = 0}
        rc = {left = -30413760, top = 32767, right = 689, bottom = 28671}
        psInfo = 0x7ffffe947ff0
        hwndHelp = 0x400f0
        hwndTabControl = 0x400f2
        __func__ = "PROPSHEET_SetCurSel"
#41 0x00006ffffaa96652 in PROPSHEET_DialogProc (hwnd=hwnd@entry=0x400f8,
    uMsg=<optimized out>, uMsg@entry=78, wParam=wParam@entry=12320,
    lParam=lParam@entry=140737457943696) at ../wine/dlls/comctl32/propsheet.c:3717
        pnmh = 0x7ffffe2ff490
        __func__ = "PROPSHEET_DialogProc"
#42 0x00006ffffdacb60a in WINPROC_wrapper (
    proc=0x6ffffaa943c0 <PROPSHEET_DialogProc>, hwnd=0x400f8, msg=78,
    wParam=12320, lParam=140737457943696) at ../wine/dlls/user32/winproc.c:86
No locals.
#43 call_dialog_proc (hwnd=hwnd@entry=0x400f8, msg=msg@entry=78,
    wp=wp@entry=12320, lp=lp@entry=140737457943696,
    result=result@entry=0x7ffffe2ff118, arg=0x6ffffaa943c0 <PROPSHEET_DialogProc>)
        context = 0x6011
        proc = 0x6ffffaa943c0 <PROPSHEET_DialogProc>
#44 0x00006ffffdac4edc in WINPROC_CallDlgProcW (hwnd=hwnd@entry=0x400f8,
    msg=msg@entry=78, wParam=wParam@entry=12320,
    lParam=lParam@entry=140737457943696) at ../wine/dlls/user32/winproc.c:951
        proc = 0xffff0027
#45 0x00006ffffdabdb67 in USER_DefDlgProcW (hwnd=0x400f8, msg=78, wParam=12320,
    lParam=140737457943696) at ../wine/dlls/user32/defdlg.c:375
        dlgInfo = 0x7ffffe947ea0
#46 USER_DefDlgProc (hwnd=0x400f8, msg=78, wParam=12320, lParam=140737457943696,
No locals.
#47 0x00006ffffda8e955 in DialogWndProcW (hwnd=<optimized out>,
No locals.
#48 0x00006ffffdacb73e in WINPROC_wrapper (
    proc=0x6fffffc08cd0 <NtdllDialogWndProc_W>, hwnd=0x400f8, msg=78,
No locals.
#49 call_window_proc (hwnd=0x400f8, msg=78, wp=12320, lp=140737457943696,
    result=result@entry=0x7ffffe2ff2d8, arg=0x6fffffc08cd0 <NtdllDialogWndProc_W>)
#50 0x00006ffffdad16a4 in dispatch_win_proc_params (
    params=params@entry=0x7ffffe2ff3a0) at ../wine/dlls/user32/winproc.c:725
        context = 0x6011
        result = 0
#51 0x00006ffffdad155c in dispatch_send_message (
    params=params@entry=0x7ffffe2ff3a0, wparam=wparam@entry=12320,
    lparam=lparam@entry=140737457943696) at ../wine/dlls/user32/message.c:568
        retval = 0
#52 0x00006ffffdab7e6f in SendMessageW (hwnd=<optimized out>, msg=msg@entry=78,
    wparam=12320, lparam=lparam@entry=140737457943696)
        params = {func = 0xffff000a, hwnd = 0x400f8, msg = 78, wparam = 12320,
          lparam = 140737457943696, ansi = 0, ansi_dst = 0,
#53 0x00006ffffaab03bb in TAB_SendSimpleNotify (infoPtr=0x7ffffe94a450,
    code=4294966745) at ../wine/dlls/comctl32/tab.c:179
        nmhdr = {hwndFrom = 0x400f2, idFrom = 12320, code = 4294966745}
#54 TAB_LButtonDown (infoPtr=0x7ffffe94a450, wParam=<optimized out>,
    lParam=131201) at ../wine/dlls/comctl32/tab.c:697
        i = <optimized out>
        pressed = <optimized out>
        pt = <optimized out>
        newItem = 2
        dummy = 6
        __func__ = "TAB_LButtonDown"
#55 TAB_WindowProc (hwnd=<optimized out>, uMsg=<optimized out>,
    wParam=<optimized out>, lParam=131201) at ../wine/dlls/comctl32/tab.c:3392
        infoPtr = 0x7ffffe94a450
        __func__ = "TAB_WindowProc"
#56 0x00006ffffdacb73e in WINPROC_wrapper (proc=0x6ffffaaaeed0 <TAB_WindowProc>,
    hwnd=0x400f2, msg=513, wParam=1, lParam=131201)
No locals.
#57 call_window_proc (hwnd=0x400f2, msg=513, wp=1, lp=131201,
    result=result@entry=0x7ffffe2ff608, arg=0x6ffffaaaeed0 <TAB_WindowProc>)
        proc = 0x6ffffaaaeed0 <TAB_WindowProc>
#58 0x00006ffffdad16a4 in dispatch_win_proc_params (
    params=params@entry=0x7ffffe2ff680) at ../wine/dlls/user32/winproc.c:725
        context = 0x80006011
        result = 0
#59 0x00006ffffdad14c1 in dispatch_message (msg=msg@entry=0x7ffffe2ffa20,
    ansi=ansi@entry=0) at ../wine/dlls/user32/message.c:805
        params = {func = 0xffff0020, hwnd = 0x400f2, msg = 513, wparam = 1,
          lparam = 131201, ansi = 0, ansi_dst = 0,
          mapping = WMCHAR_MAP_DISPATCHMESSAGE, dpi_context = 24593,
          procA = 0xffff0020, procW = 0x6ffffaaaeed0 <TAB_WindowProc>}
        retval = 0
#60 0x00006ffffda8eb2c in DispatchMessageW (msg=0x7ffffe2ffa20)
    at ../wine/dlls/user32/message.c:891
#61 0x00006ffffdaa5d30 in IsDialogMessageW (hwndDlg=hwndDlg@entry=0x400f8,
    msg=msg@entry=0x7ffffe2ffa20) at ../wine/dlls/user32/dialog.c:1294
        dlgCode = <optimized out>
#62 0x00006ffffaa975ed in PROPSHEET_IsDialogMessage (hwnd=hwnd@entry=0x400f8,
    lpMsg=lpMsg@entry=0x7ffffe2ffa20) at ../wine/dlls/comctl32/propsheet.c:2956
        psInfo = <optimized out>
        __func__ = "PROPSHEET_IsDialogMessage"
#63 0x00006ffffaa97b24 in do_loop (psInfo=0x7ffffe947ff0)
    at ../wine/dlls/comctl32/propsheet.c:2971
        msg = {hwnd = 0x400f2, message = 513, wParam = 1, lParam = 131201,
          time = 461980, pt = {x = 138, y = 148}}
        ret = 1
        hwnd = 0x400f8
        parent = 0x0
#64 PROPSHEET_PropertySheet (psInfo=0x7ffffe947ff0, unicode=unicode@entry=1)
    at ../wine/dlls/comctl32/propsheet.c:3013
        bRet = 262392
        parent = <optimized out>
        __func__ = "PROPSHEET_PropertySheet"
#65 0x00006ffffaa99fac in PropertySheetW (lppsh=lppsh@entry=0x7ffffe2ffb20)
    at ../wine/dlls/comctl32/propsheet.c:3124
        i = <optimized out>
        n = <optimized out>
        pByte = <optimized out>
        __func__ = "PropertySheetW"
#66 0x0000000140010756 in doPropertySheet (hOwner=0x0, hInstance=0x140000000)
    at ../wine/programs/winecfg/main.c:173
        psp = {{dwSize = 104, dwFlags = 8, hInstance = 0x140000000, {
              pszTemplate = 0x6c <error: Cannot access memory at address 0x6c>,
              pResource = 0x6c}, {hIcon = 0x0, pszIcon = 0x0},
            pszTitle = 0x7ffffe947a50 L"应用程序",
            pfnDlgProc = 0x140002440 <AppDlgProc>, lParam = 0, pfnCallback = 0x0,
            pcRefParent = 0x0, pszHeaderTitle = 0x0, pszHeaderSubTitle = 0x0,
            hActCtx = 0x0, {hbmHeader = 0x0, pszbmHeader = 0x0}}, {dwSize = 104,
              pszTemplate = 0x6f <error: Cannot access memory at address 0x6f>,
              pResource = 0x6f}, {hIcon = 0x0, pszIcon = 0x0},
            pszTitle = 0x7ffffe947a80 L"函数库",
            pfnDlgProc = 0x140005a80 <LibrariesDlgProc>, lParam = 0,
            pfnCallback = 0x0, pcRefParent = 0x0, pszHeaderTitle = 0x0,
            pszHeaderSubTitle = 0x0, hActCtx = 0x0, {hbmHeader = 0x0,
              pszbmHeader = 0x0}}, {dwSize = 104, dwFlags = 8,
              pszTemplate = 0x6e <error: Cannot access memory at address 0x6e>,
              pResource = 0x6e}, {hIcon = 0x0, pszIcon = 0x0},
            pszTitle = 0x7ffffe947ab0 L"显示",
            pfnDlgProc = 0x1400050c0 <GraphDlgProc>, lParam = 0,
              pszTemplate = 0x73 <error: Cannot access memory at address 0x73>,
              pResource = 0x73}, {hIcon = 0x0, pszIcon = 0x0},
            pszTitle = 0x7ffffe947ae0 L"桌面整合",
            pfnDlgProc = 0x1400060c0 <ThemeDlgProc>, lParam = 0,
            pfnCallback = 0x0,
            pcRefParent = 0x6fffffc42481 <heap_allocate_block+353>,
            pszHeaderSubTitle = 0x6fffffc42481 <heap_allocate_block+353> L"ང家䄇褁웺ك셵ת䕸\xdb84萏ʱ", hActCtx = 0x0, {hbmHeader = 0x0,
              pszTemplate = 0x70 <error: Cannot access memory at address 0x70>,
              pResource = 0x70}, {hIcon = 0x0, pszIcon = 0x0},
            pszTitle = 0x7ffffe947b10 L"驱动器",
            pfnDlgProc = 0x140003f00 <DriveDlgProc>, lParam = 0,
            pfnCallback = 0x0, pcRefParent = 0x2648,
            pszHeaderTitle = 0x6fffffc435f2 <heap_free_block+594> L"襉䣰\xda89襈䣹쒃孨彞幁럩\032ༀ耟",
            pszHeaderSubTitle = 0x2978 <error: Cannot access memory at address 0x2978>, hActCtx = 0x0, {hbmHeader = 0x7ffffe320000,
              pszbmHeader = 0x7ffffe320000 L""}}, {dwSize = 104, dwFlags = 8,
              pszTemplate = 0x6d <error: Cannot access memory at address 0x6d>,
              pResource = 0x6d}, {hIcon = 0x0, pszIcon = 0x0},
            pszTitle = 0x7ffffe947b40 L"音效",
            pfnDlgProc = 0x140002e00 <AudioDlgProc>, lParam = 0,
            pfnCallback = 0x7ffffe2ffe30, pcRefParent = 0x0,
            pszHeaderTitle = 0x7ffffe2ffe40 L"쀐ﺔ翿",
            pszHeaderSubTitle = 0x7ffffe9499c0 L"Ä\003",
            hActCtx = 0x7ffffe320000, {hbmHeader = 0x0, pszbmHeader = 0x0}}, {
              pszTemplate = 0x6b <error: Cannot access memory at address 0x6b>,
              pResource = 0x6b}, {hIcon = 0x0, pszIcon = 0x0},
            pszTitle = 0x7ffffe947b70 L"关于",
            pfnDlgProc = 0x140001c90 <AboutDlgProc>, lParam = 0,
            pfnCallback = 0x200000000, pcRefParent = 0x7ffffe9499c0,
            pszHeaderTitle = 0x200000000 <error: Cannot access memory at address 0x200000000>, pszHeaderSubTitle = 0x7ffffe94c010 L"썀ﺔ翿", hActCtx = 0x1, {
              hbmHeader = 0x7ffffe2ffeb0, pszbmHeader = 0x7ffffe2ffeb0 L"h"}}}
        psh = {dwSize = 96, dwFlags = 268, hwndParent = 0x0,
          hInstance = 0x140000000, {hIcon = 0x64,
            pszIcon = 0x64 <error: Cannot access memory at address 0x64>},
          pszCaption = 0x7ffffe947ba0 L"Wine 设置", nPages = 7, {
            nStartPage = 0, pStartPage = 0x0}, {ppsp = 0x7ffffe2ffb80,
            phpage = 0x7ffffe2ffb80},
          pfnCallback = 0x140006050 <PropSheetCallback>, {hbmWatermark = 0x0,
            pszbmWatermark = 0x0}, hplWatermark = 0x0, {hbmHeader = 0x0,
            pszbmHeader = 0x0}}
        pg = 7
#67 wWinMain (hInstance=0x140000000, hPrev=hPrev@entry=0x0,
    cmdline=cmdline@entry=0x7ffffe323aba L"", nShow=nShow@entry=1)
    at ../wine/programs/winecfg/main.c:268
        is_wow64 = 0
        cmd_ret = -1
        __func__ = "wWinMain"
#68 0x0000000140012718 in wmain (argc=argc@entry=1,
    argv=argv@entry=0x7ffffe328580) at ../wine/dlls/msvcrt/crt_wwinmain.c:55
        info = {cb = 104, lpReserved = 0x0, lpDesktop = 0x7ffffe323afc L"",
          lpTitle = 0x7ffffe323abc L"C:\\windows\\system32\\winecfg.exe",
          dwX = 0, dwY = 0, dwXSize = 0, dwYSize = 0, dwXCountChars = 0,
          dwYCountChars = 0, dwFillAttribute = 0, dwFlags = 1, wShowWindow = 1,
          cbReserved2 = 0, lpReserved2 = 0x0, hStdInput = 0x0,
          hStdOutput = 0x6ffffea1a1e9 <_get_initial_wide_environment+25>,
          hStdError = 0x0}
        cmdline = <optimized out>
        bcount = <optimized out>
        in_quotes = <optimized out>
#69 0x00000001400127e6 in wmainCRTStartup () at ../wine/dlls/msvcrt/crt_wmain.c:58
        argc = 1
        argv = 0x7ffffe328580
        env = 0x7ffffe94c010
Wine-gdb>
Wine-gdb> bt
    lpotm=lpotm@entry=0x7ffffe9515e0, lplogfont=0x7ffffe950c44,
    lplogfont@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd320>, analysis=<optimized out>,
    analysis@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd3a0>, piAdvance=0x7ffffe328760,
    piAdvance@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd2f0>, lookup=0x7ffffe95ee6c, lookup_index=30,
    lookup_index@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd2f8>, glyphs=0x7ffffe950650,
    glyphs@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd300>, glyph_index=0,
    glyph_index@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd308>, glyph_count=2,
    glyph_count@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd310>, pGoffset=0x7ffffe950b90,
    pGoffset@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd318>) at ../wine/dlls/gdi32/uniscribe/opentype.c:2533
    logfont=<error reading variable: Cannot access memory at address 0x7ffffe2fd320>,
    analysis=<error reading variable: Cannot access memory at address 0x7ffffe2fd3a0>, advance=0x7ffffe328760,
    advance@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd3b8>, lookup_index=30, glyphs=0x7ffffe950650,
    glyphs@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd3a8>, glyph_index=glyph_index@entry=0, glyph_count=glyph_count@entry=2,
    goffset=0x7ffffe950b90,
    goffset@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd3c0>) at ../wine/dlls/gdi32/uniscribe/opentype.c:2564
#4 SHAPE_ApplyOpenTypePositions (hdc=0x1010081,
    hdc@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd4--Type <RET> for more, q to quit, c to continue without paging--
d0>, psc=0x7ffffe950c30, psa=0x7ffffe9505c4,
    psa@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd4e0>, pwGlyphs=0x7ffffe950650,
    pwGlyphs@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd530>, cGlyphs=2,
    cGlyphs@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd540>, piAdvance=piAdvance@entry=0x7ffffe328760,
    psc=psc@entry=0x7ffffe328700, psa=0x7ffffe9505c4,
    psa@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd5d8>, tagScript=<optimized out>, tagLangSys=<optimized out>, tagLangSys@entry=0,
    piAdvance@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd5e0>, pGoffset=pGoffset@entry=0x7ffffe950b90, pABC=0x7ffffe328738,
    pABC@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd5f0>) at ../wine/dlls/gdi32/uniscribe/usp10.c:3396
#6 0x00006ffffe0b8521 in ScriptPlace (hdc=0x1010081,
    hdc@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd7b0>, psc=psc@entry=0x7ffffe328700, pwGlyphs=0x7ffffe950650,
    pwGlyphs@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd658>, cGlyphs=2, psva=0x7ffffe9506b0,
    psva@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd648>, psa=0x7ffffe9505c4, piAdvance=piAdvance@entry=0x7ffffe328760,
    pssa@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fd--Type <RET> for more, q to quit, c to continue without paging--
828>) at ../wine/dlls/gdi32/uniscribe/usp10.c:2051
    text=0x7ffffe2fdc40 <error: Cannot access memory at address 0x7ffffe2fdc40>)
#13 EDIT_WindowProc (hwnd=0x40052,
    hwnd@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fdb78>, msg=12,
    msg@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fdb78>,
    wParam=<error reading variable: Cannot access memory at address 0x7ffffe2fdb78>, lParam=140737457937472,
    lParam@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fdb78>) at ../wine/dlls/comctl32/edit.c:4898
#23 GraphDlgProc (hDlg=0x30090,
    hDlg@entry=<error reading variable: Cannot access memory at address 0x7ffffe2fe458>,
    uMsg=<error reading variable: Cannot access memory at address 0x7ffffe2fe458>, wParam=<error reading variable: Cannot access memory at address 0x7ffffe2fe458>,
    lParam=<error reading variable: Cannot access memory at address 0x7ffffe2fe458>) at ../wine/programs/winecfg/x11drvdlg.c:344
    hwnd=<error reading variable: Cannot access memory at address 0x7ffffe2fe618>, msg=<error reading variable: Cannot access memory at address 0x7ffffe2fe618>,
    wParam=<error reading variable: Cannot access memory at address 0x7ffffe2fe618>, lParam=<error reading variable: Cannot access memory at address 0x7ffffe2fe618>)
    hwnd=<error reading variable: Cannot access memory at address 0x7ffffe2fe7e0>, msg=msg@entry=272, wparam=196756, lparam=140737464530200,
    lparam@entry=<error reading variable: Cannot access memory at address 0x7ffffe2feaf0>) at ../wine/dlls/user32/message.c:587
    dlgProc=0x1400050c0 <GraphDlgProc>, param=140737464530200,
    param@entry=<error reading variable: Cannot access memory at address 0x7ffffe2feb40>, unicode=unicode@entry=1, modal_owner=modal_owner@entry=0x0)
#41 0x00006ffffaa96652 in PROPSHEET_DialogProc (hwnd=0x400f8,
    hwnd@entry=<error reading variable: Cannot access memory at address 0x7ffffe2ff0f8>, uMsg=<optimized out>,
    uMsg@entry=<error reading variable: Cannot access memory at address 0x7ffffe2ff0f8>, wParam=12320,
    wParam@entry=<error reading variable: Cannot access memory at address 0x7ffffe2ff0f8>, lParam=140737457943696,
    lParam@entry=<error reading variable: Cannot access memory at address 0x7ffffe2ff0f8>) at ../wine/dlls/comctl32/propsheet.c:3717
    hwnd=<error reading variable: Cannot access memory at address 0x7ffffe2ff2b8>, msg=<error reading variable: Cannot access memory at address 0x7ffffe2ff2b8>,
    wParam=<error reading variable: Cannot access memory at address 0x7ffffe2ff2b8>, lParam=<error reading variable: Cannot access memory at address 0x7ffffe2ff2b8>)
    wParam=<error reading variable: Cannot access memory at address 0x7ffffe2ff5e8>, lParam=131201) at ../wine/dlls/comctl32/tab.c:697
    hwnd=<error reading variable: Cannot access memory at address 0x7ffffe2ff5e8>, uMsg=<error reading variable: Cannot access memory at address 0x7ffffe2ff5e8>,
    wParam=<error reading variable: Cannot access memory at address 0x7ffffe2ff5e8>, lParam=131201,
    lParam@entry=<error reading variable: Cannot access memory at address 0x7ffffe2--Type <RET> for more, q to quit, c to continue without paging--
ff5e8>) at ../wine/dlls/comctl32/tab.c:3392
#59 0x00006ffffdad14c1 in dispatch_message (msg=0x7ffffe2ffa20,
    msg@entry=<error reading variable: Cannot access memory at address 0x7ffffe2ff870>, ansi=ansi@entry=0) at ../wine/dlls/user32/message.c:805
    cmdline=cmdline@entry=0x7ffffe323aba <error: Cannot access memory at address 0x7ffffe323aba>, nShow=nShow@entry=1) at ../wine/programs/winecfg/main.c:268
I’m just a beginner, and I want to play some games on Linux using Wine. Hope everyone has a solution
Mod edit:- General tidy. No charge.
Welcome to the forum,
What is the error when you start winecfg from the commandline
Does winetricks work?
Are you using normal wine or wine-staging
Output of inxi -zv7 is a lot more helpful then screenfetch
inxi -zv8 is even more helpful.
@martch7th
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
First, I would check on Protondb if most others are playing your game on wine or if they are using a different Platform protondb.
For wine, I’m using the following script. You can add it to your .zshrc file and run it in the terminal with: wine-config
wine-config
wine-config() {
    # wine steam
    # https://wiki.archlinux.org/title/Wine
    # https://www.winehq.org/
    path_="$HOME"/.wine
    # winetricks option
    winetricks_=(
        # DLL
    d3dx9 d3dcompiler_43 d3dcompiler_47 corefonts vcrun2017 cjkfonts  vcrun2005 dotnet48 xinput xact dxvk d3dx11_43 d3dx11_42 vcrun2008 vcrun2010
    dxvk_nvapi
    vkd3d
    # fonds
    allfonts
    #! wined3d
    pkg_=(
    # wine version
    wine
    # wine-staging
    # steam
    steam
    linux-steam-integration
    gamescope
    wine-gecko
    wine-nine
    winetricks
    protontricks wine-mono vulkan-tools giflib lib32-giflib libpng lib32-libpng libldap lib32-libldap gnutls lib32-gnutls mpg123 lib32-mpg123 openal lib32-openal v4l-utils lib32-v4l-utils libpulse lib32-libpulse libgpg-error lib32-libgpg-error alsa-plugins alsa-lib libjpeg-turbo lib32-libjpeg-turbo sqlite lib32-sqlite libxcomposite lib32-libxcomposite libxinerama lib32-libgcrypt libgcrypt lib32-libxinerama ncurses lib32-ncurses libxslt lib32-libxslt libva lib32-libva gtk3 lib32-gtk3 gst-plugins-base-libs lib32-gst-plugins-base-libs vulkan-icd-loader lib32-vulkan-icd-loader glew lib32-dbus-glib lib32-freeglut lib32-glew lib32-gtk2 lib32-imlib2 lib32-libappindicator-gtk2 lib32-libcaca lib32-libcurl-compat lib32-libcurl-gnutls lib32-libdbusmenu-glib lib32-libdbusmenu-gtk2 lib32-libgcrypt lib32-libid3tag lib32-libidn11 lib32-libindicator-gtk2 lib32-libjpeg6-turbo lib32-libmikmod lib32-libmodplug lib32-libnm lib32-libpng12 lib32-librtmp0 lib32-libtheora lib32-libtiff lib32-libudev0-shim lib32-libvpx lib32-libwebp lib32-openssl lib32-sdl2_image lib32-sdl2_mixer lib32-sdl2_ttf lib32-sdl_image lib32-sdl_mixer lib32-sdl_ttf lib32-smpeg libcurl-compat libcurl-gnutls libdbusmenu-gtk2 libgcrypt15 libidn11 libindicator-gtk2 libjpeg6-turbo libpng librtmp0 libtiff4 libudev0-shim libvpx openssl opusfile sdl2_image sdl2_mixer sdl2_ttf sdl_image sdl_mixer sdl_ttf smpeg vulkan-extra-layers vulkan-extra-tools lib32-alsa-lib lib32-alsa-plugins lib32-gnutls lib32-gst-plugins-base-libs lib32-libldap lib32-libpulse lib32-libva lib32-libxml2 lib32-mpg123 lib32-openal lib32-v4l-utils vulkan-intel vulkan-mesa-layers vkd3d lib32-alsa-oss
    set -e
    if [[ $(pacman -Su --print-format "%v" | wc -l) -gt 0 ]];then
        sudo pacman -Syu
    fi
    for pkg in "${pkg_[@]}";do
        if !  pacman -Qq "$pkg" >/dev/null 2>&1;then
            sudo pacman -S "$pkg"|| echo "failed to get $pkg..."
        fi
    done
    if pgrep -x "wineserver" > /dev/null; then
        wineserver -k 15
    fi
    if ! [[ -d "$path_" ]];then
        mkdir "$path_"
    fi
    env WINEPREFIX="$path_" wineboot
    # echo "prefix set.. " # deprecate
    # echo ""
    # export WINEARCH=win64
    # export WINEARCH=win32
    echo ""
    wine winecfg -v win10
    # winetricks -q win10
    sudo winetricks --self-update
    echo ""
    echo "starting winetricks -q.."
    for option in "${winetricks_[@]}";do
    winetricks -q "$option"
    done
    # sh -c 'sudo chown -Rv "${USER}":"${USER}" "$pkg"'
    # echo "wineboot init"
    # wineboot --init
    # To enable ESync
    export WINEESYNC=1
    # FSync
    # export WINEFSYNC=1
    wine --version
    sh -c 'winetricks &'
    echo ""
    echo done..
    # missing pkg
            echo "$pkg does not exist!.."
        fi
    done
    # wine cmd
    # winedbg --gdb winecfg
if you want to clean up after, you can add this as well:
wine_clean
wine_clean() {
    # yy -Rc wine dxvk-bin wine-mono vulkan-tools lutris wine-gecko lib32-vkd3d winetricks vkd3d d3dx9 vulkan-extra-layers vulkan-extra-tools
    path_="$HOME"/.wine
        wineserver -k 15
    fi
    .local/share/applications
    sudo find ~/.local/share/applications/wine -delete -print
    sudo find ~/.local/share/wineprefixes/* -delete -print
    sudo find ~/.config/menus/applications-merged/wine* -delete -print
    sudo find ~/.config/mimeapps.list/wine -delete -print
    sudo find ~/.config/mimeapps.list/mimeinfo.cache -delete -print
    sudo find ~/.local/share/desktop-directories/wine* -delete -print
    sudo find ~/.local/share/icons/????_*.{xpm,png} -delete -print
    sudo find ~/.local/share/icons/*-x-wine-*.{xpm,png} -delete -print
    sudo find ~/.local/share/mime/packages/x-wine* -delete -print
    sudo find ~/.config/mimeapps.list/wine-extension* -delete -print
    sudo find ~/.local/share/applications/mimeinfo.cache -delete -print
    sudo find ~/.local/share/mime/application/x-wine-extension* -delete -print
    sudo find ~/.config/mimeapps.list/wine-extension*.desktop -delete -print
    sudo find ~/.local/share/icons/hicolor/*/*/application-x-wine-extension* -delete -print
    sudo find /root/.wine -delete -print
    sudo find ~/win32 -delete -print
    sudo find ~/win64 -delete -print
    update-desktop-database ~/.config/mimeapps.list
    update-desktop-database ~/.local/share/applications
    update-mime-database ~/.local/share/mime/
    sudo find "$path_"/drive_c/users/"${USER}"/Temp "$path_"/drive_c/windows/temp -delete -print
    ln -s /tmp/ "$path_"/drive_c/users/"${USER}"/Temp
    ln -s /tmp/ "$path_"/drive_c/windows/temp
    sudo find "$path_" -delete -print
Thank you for being willing to answer my questions.
The winetricks can be used.The wine I am using is the latest software package from pacman stable.
However, this issue has been resolved with the help of chatgpt. Before sending this request, I have tried many times with the help of chatgpt, but all failed. But in the end, I still resolved the problem with the help of chatgpt. I believe it is a font renderer issue because I am using Chinese.
So, I used the sudo pacman -Syu freetype2 lib32-freetype2 harfbuzz lib32-harfbuzz fontconfig lib32-fontconfig fc-cache -fvcommand to install the font renderer freetype harfbuzz fontconfig, then copied the simsun.ttc font from the win directory to the wine directory, and the problem was resolved.
Thanks for sharing your solution, however we do not know what the original issue was besides:
If you could share the specific error mentioned other users can benefit from this thread in the future.
In fact, I’m not clear about the cause of the error.
I think this is related to the font renderer. The process of winecfg failing is when I enter the winecfg command in the terminal and then click on the winecfg display options; winecfg crashes and shows an error. The terminal displays:
wine: Unhandled page fault on read access to FFFFFFFFFFFFFFFF at address 00006FFFFE09CBC2 (thread 0128), starting debugger...
0130:fixme:dbghelp:elf_search_auxv can't find symbol in module
0130:fixme:dbghelp_dwarf:compute_location Only supporting one reg (rsp/335 -> -2)
0130:fixme:dbghelp_dwarf:compute_location Only supporting one breg (r12/340 -> r14/342)
This is the content of the inxi -zv8 command output:
  Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=ea6c8f28-d077-400a-a2d6-71a15385bf67 rw quiet splash
    resume=UUID=2b319df9-8e3e-4f0a-b0f2-521564013e9e udev.log_priority=3
  Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: LENOVO product: 21LF v: ThinkBook 14 G6+ AHP
    serial: <superuser required> Chassis: type: 10 v: ThinkBook 14 G6+ AHP
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76479 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21LF_BU_idea_FM_ThinkBook
    14 G6+ AHP uuid: <superuser required> UEFI: LENOVO v: NLCN34WW
    date: 11/07/2024
  ID-1: BAT1 charge: 81.2 Wh (100%) condition: 81.2/85 Wh (95.6%) volts: 17.63
    min: 15.6 model: ATL L23N4PG1 type: Unknown serial: <filter> charging:
    status: not charging cycles: 105
  System RAM: total: 32 GiB available: 27.21 GiB used: 7.78 GiB (28.6%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 7500 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Hynix
    part-no: H58G66BK7BX067 serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8845H w/ Radeon 780M Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705208
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3442 min/max: 400/5137 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3442 2: 3442 3: 3442
    4: 3442 5: 3442 6: 3442 7: 3442 8: 3442 9: 3442 10: 3442 11: 3442 12: 3442
    13: 3442 14: 3442 15: 3442 16: 3442 bogomips: 121428
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
    avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] HawkPoint1 vendor: Lenovo
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1
    bus-ID: 64:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 40.0 C
  Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
    chip-ID: 30c9:00c2 class-ID: fe01 serial: <filter>
    compositors: 1: gnome-shell 2: SurfaceFlinger driver: X: loaded: amdgpu
    unloaded: modesetting,radeon,vesa alternate: fbdev dri: radeonsi
    gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Lenovo 0x8aaf built: 2022 res: 3072x1920 dpi: 250
    gamma: 1.2 chroma: red: x: 0.678 y: 0.318 green: x: 0.263 y: 0.690 blue:
    x: 0.149 y: 0.059 white: x: 0.314 y: 0.325 size: 312x195mm (12.28x7.68")
    diag: 368mm (14.5") ratio: 16:10 modes: 3072x1920, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
    800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.4
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
    phoenix LLVM 20.1.8 DRM 3.61 6.12.44-3-MANJARO) device-ID: 1002:1900
    memory: 3.91 GiB unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xdriinfo, xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 64:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 64:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 64:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.44-3-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 7000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
    driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 6000 bus-ID: 04:00.0 chip-ID: 10ec:b852 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  IF-ID-1: vethRVIK0m state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-2: waydroid0 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 0bda:4853
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 953.87 GiB used: 50.2 GiB (5.3%)
    model: MZAL81T0HDLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 5L1QKXD7 temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 497.58 GiB size: 488.7 GiB (98.22%)
    used: 50.14 GiB (10.3%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: N/A uuid: ea6c8f28-d077-400a-a2d6-71a15385bf67
    used: 63.5 MiB (21.2%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
    label: boot uuid: 78BB-891F
  ID-1: swap-1 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 2b319df9-8e3e-4f0a-b0f2-521564013e9e
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 448.99 GiB fs: ntfs label: N/A
    uuid: 000AC3500AC34180
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 922 MiB fs: ntfs label: N/A
    uuid: 2A542CD9542CA991
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-2:2 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 275d:0ba6 class-ID: 0301
  Device-2: 1-3:3 info: Hangsheng RK2.4G Dongle type: keyboard,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 342d:e487 class-ID: 0300
  Device-3: 1-5:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: Luxvisions Innotech Integrated RGB Camera
    type: video driver: uvcvideo interfaces: 5 rev: 2.0
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1134 libs: 314 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0
  Active pacman repo servers in: /etc/pacman.conf
    1: https://mirrors.aliyun.com/archlinuxcn/$arch
    1: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    2: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 486
  1: cpu: 8.0% command: localsearch-extractor-3 pid: 18621
    mem: 38.4 MiB (0.1%)
  2: cpu: 4.2% command: chrome pid: 17125 mem: 298.7 MiB (1.0%)
  3: cpu: 1.8% command: chrome pid: 7521 mem: 375.5 MiB (1.3%)
  4: cpu: 1.1% command: gnome-shell pid: 1479 mem: 649.0 MiB (2.3%)
  5: cpu: 1.1% command: system_server pid: 12952 mem: 459.4 MiB (1.6%)
  Memory top: 5 of 486
  1: mem: 649.0 MiB (2.3%) command: gnome-shell pid: 1479 cpu: 1.1%
  2: mem: 583.7 MiB (2.0%) command: WebKitWebProcess pid: 16861 cpu: 0.5%
  3: mem: 459.4 MiB (1.6%) command: system_server pid: 12952 cpu: 1.1%
  4: mem: 425.1 MiB (1.5%) command: chrome pid: 2210 cpu: 0.3%
  5: mem: 420.7 MiB (1.5%) command: chrome pid: 2897 cpu: 0.2%
  Processes: 486 Power: uptime: 10h 29m states: freeze,mem,disk
    suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 10.84 GiB services: gsd-power,
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
    inxi: 3.3.39
Thanks for providing the inxi output, although it was potentially more useful earlier, before the solution was found. :slight_smile:
The point of providing that (and other information) is to encourage others to participate, and potentially identify other factors that might contribute to any given issue.
So-called A.I. can get it right, sometimes – it’s a “numbers game” – sooner or later it must get something right, right?. :wink:
It’s customary to indicate which post helped you the most by marking that post using he solution button found under that post. This can help others with a similar issue quickly find the marked solution and determine whether it also applies to them.
Good to know you found a resolution.
