Greetings,
since I’ve updated my system to Ultima Thule, wine doesn’t recognize my gamepad (8BitDo SN30pro+) correctly anymore, if I use it via bluetooth.
The joy.cpl from wine recognizes the gamepad as “XBox One S Controller”. Some buttons are not detected or not properly mapped.
Before the update, wine recognizes the pad as “XBox One Controller”. (Without the S)
Everything worked perfectly fine.
I’ve tested multiple wine-version. No changes.
So I think, that the problem isn’t concerning wine only.
(I used the wine-versions from lutris, so they are still the same before and after the update.)
So what’s the error here? How can I change the detection, so wine detects the pad properly?
I don’t want to use another mode on the pad, because I need the analog-triggers. Also I don’t want to use xpadneo, xboxdrv or any other driver.
(With xboxdrv the pad is detected as Xbox360-pad, but it has no rumble then.)
If you need more information, let me know it.
Sincerly,
TheHexer
PS: Things I’ve also noticed, since the update:
- the bluetooth-pairing sometimes failes
