I can’t get any wine programs to run!
For example winemine, winefile or winecfg run from console don’t return or show any errors and ‘System Activity’ shows ‘wine’ as ‘stopped’.
Output from
Kernel: 5.4.114-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=69b9e6e6-7f87-4731-a7c7-a3c31aaa2f48 rw quiet udev.log_priority=3
audit=0
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: P8P67 v: Rev 1.xx serial: <filter>
BIOS: American Megatrends v: 3602 date: 11/01/2012
RAM: total: 15.61 GiB used: 2.87 GiB (18.4%)
Info: Quad Core model: Intel Core i5-2500K bits: 64 type: MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 6 MiB bogomips: 26498
Speed: 1605 MHz min/max: 1600/3700 MHz Core speeds (MHz): 1: 1605 2: 1605
3: 1605 4: 1605
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga.com.
driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c02 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1200 s-dpi: 93 s-size: 524x321mm (20.6x12.6")
s-diag: 615mm (24.2")
Monitor-1: DVI-D-0 res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
OpenGL: renderer: GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
class-ID: 0403
Sound Server-1: ALSA v: k5.4.114-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Local Storage: total: 7.06 TiB used: 2.45 TiB (34.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: BB6Q scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EARX-00PASB0
serial: <filter> rev: AB51 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD10EADS-00M2B0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 0A01 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD6400AAKS-22A7B0 size: 596.17 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 3B01 scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS model: DRW-1814BLT rev: 1.14
dev-links: cdrom
ID-1: / raw-size: 111.79 GiB size: 109.91 GiB (98.32%)
used: 25.51 GiB (23.2%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: 840EVO uuid: 69b9e6e6-7f87-4731-a7c7-a3c31aaa2f48
ID-2: /home raw-size: 196.17 GiB size: 192.96 GiB (98.37%)
used: 152.44 GiB (79.0%) fs: ext3 block-size: 4096 B dev: /dev/sde4
maj-min: 8:68 label: store uuid: 4cbaf0a3-bd58-4ca0-ac07-d7196546089e
ID-3: /mnt/Photos raw-size: 100 GiB size: 100 GiB (100.00%)
used: 80.78 GiB (80.8%) fs: ntfs block-size: 4096 B dev: /dev/sde1
maj-min: 8:65 label: Photos uuid: C0808F72808F6E2A
ID-4: /mnt/Photos2 raw-size: 200.01 GiB size: 200.01 GiB (100.00%)
used: 195.25 GiB (97.6%) fs: ntfs block-size: 4096 B dev: /dev/sde3
maj-min: 8:67 label: Photos2 uuid: 684D72556138612D
ID-5: /mnt/VirtualDrives raw-size: 100 GiB size: 98.3 GiB (98.31%)
used: 29.09 GiB (29.6%) fs: ext3 block-size: 4096 B dev: /dev/sde2
maj-min: 8:66 label: VirtualDrives
uuid: c87690e9-9452-40d1-81b4-f76eced5cbc9
ID-6: /mnt/donaldbackup raw-size: 87.89 GiB size: 86.01 GiB (97.86%)
used: 17.04 GiB (19.8%) fs: ext4 block-size: 4096 B dev: /dev/sdc3
maj-min: 8:35 label: dbackup uuid: 96380e90-e9ef-48ef-bf2d-9d3a3a5dcb33
ID-7: /mnt/extra raw-size: 1.82 TiB size: 1.79 TiB (98.42%)
used: 810.32 GiB (44.2%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: extra uuid: bb56e27b-8c95-4225-b16a-e2c834bf1209
ID-8: /run/media/donald/storage raw-size: 3.55 TiB size: 3.55 TiB (100.00%)
used: 735.05 GiB (20.2%) fs: ntfs block-size: 4096 B dev: /dev/sdc2
maj-min: 8:34 label: storage uuid: 20342B74342B4C5A
ID-9: /run/media/donald/win7_storage raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 463.1 GiB (49.7%) fs: ntfs
block-size: 4096 B dev: /dev/sdd1 maj-min: 8:49 label: win7_storage
uuid: 01CDDD4C390D0520
ID-1: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: UC-Logic Tablet WP8060U type: Mouse
driver: uclogic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 100mA
chip-ID: 5543:0005 class-ID: 0301
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-6: 3-1.1:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2514 class-ID: 0900
Device-1: 3-1.2:4 info: Canon PIXMA MP610 type: Printer,Mass Storage
driver: usb-storage,usblp interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 04a9:1725 class-ID: 0806 serial: <filter>
Device-2: 3-1.3:5 info: Logitech G5 Laser Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c049 class-ID: 0300
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-8: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-9: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 28 C
Processes: 244 Uptime: 31m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1868 lib: 438
flatpak: 0 Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.04
Note:
wine is at version 6.7-1
and
mesa at 21.0.3-2
also
export MESA_GL_VERSION_OVERRIDE=4.5
hasn’t helped.
Can anyone help with a fix? I don’t really want to start again with wine as I have some applications like office which would be a pain to reinstall.
thanks for any help.
