Hello, so I recently switched to Linux 5.8 and everything seems the same if not better in native games. However, I opened Pokemon Insurgence through Lutris (an RPG maker game) and found that it was extremely laggy. These issues aren’t present on 5.7 and really shouldn’t be the case since it’s not a very demanding game. Switching back to 5.7 fixes this, but what can I do to troubleshoot this?
System Info:
$ inxi -Fxza --no-hostname
Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.7-x86_64
root=UUID=aeff4b12-d7ff-495f-8cba-d226b1c1088d rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: Cinnamon 4.6.7 tk: GTK 3.24.22 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0 serial: <filter>
Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.10 date: 08/22/2018
Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510
status: Discharging
Topology: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10)
microcode: D6 L2 cache: 12.0 MiB
bogomips: 88824
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f07
Display: x11 server: X.Org 1.20.8 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: HDMI-0 res: 2560x1440 dpi: 109 size: 596x335mm (23.5x13.2")
diag: 684mm (26.9")
Monitor-2: DP-5 res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
Device-3: JMTek LLC. JOUNIVO JV605PRO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2:3 chip ID: 0c76:605d
serial: <filter>
Sound Server: ALSA v: k5.7.14-1-MANJARO
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: 3.2.6-k port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
Device-2: Ralink RT5572 Wireless Adapter type: USB driver: rt2800usb
bus ID: 1-9:8 chip ID: 148f:5572 serial: <filter>
IF: wlp0s20f0u9 state: up mac: <filter>
Local Storage: total: 1.42 TiB used: 358.32 GiB (24.6%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH31000G size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 70RL scheme: GPT
ID-2: /dev/sdb vendor: SanDisk model: SDSSDH3500G size: 465.76 GiB
ID-3: /dev/sdc type: USB vendor: Generic model: Flash Disk size: 58.59 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 8.07
ID-1: / raw size: 34.18 GiB size: 34.18 GiB (100.00%)
used: 11.92 GiB (34.9%) fs: btrfs dev: /dev/sda2
ID-2: /home raw size: 889.40 GiB size: 874.43 GiB (98.32%)
used: 346.40 GiB (39.6%) fs: ext4 dev: /dev/sda3
ID-1: swap-1 type: partition size: 7.82 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 347 Uptime: 1h 37m Memory: 15.58 GiB used: 3.43 GiB (22.0%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1074 pacman: 1064
lib: 321 flatpak: 10 Shell: Zsh v: 5.8 running in: tilix inxi: 3.1.05
